Date/Time: Thu, 25 Apr 2024 12:02:42 +0000
Sierra Chart different charts then IBKR an Tradingview
View Count: 872
[2023-02-02 19:39:25] |
Ferhat Ucar - Posts: 8 |
Hello, I see differences in chart with IBKR TWS and Tradingview. I have included an image. Is there anything I am doing wrong in my settings or is it just different data? Thank you in advance |
TV vs SC.jpg / V - Attached On 2023-02-02 19:34:31 UTC - Size: 203.77 KB - 160 views Attachment Deleted. |
[2023-02-02 23:03:36] |
John - SC Support - Posts: 31098 |
It is different data, as the NASDAQ TotalView data from us does not include the Consolidated Tape. For more information, refer to the following: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-03 12:08:04] |
I see that Sierra Chart Exchange Data Feed does have full consolidated tape. Can I have a trial to test that data? Also I tried turning off Sierra Chart data to receive data from IBKR, but I did’nt get intraday historical data. |
[2023-02-03 17:01:06] |
There is not a trial available for the Sierra Chart Exchange Data Feed, but it does have the consolidated tape, but it does not have Market Depth data. You can deactivate the NASDAQ TotalView and activate the U.S. Equites on the Sierra Chart Exchange Data Feed if you like. Or you can keep both, as the Sierra Chart Exchange Data Feed uses the standard symbol (IBM), which is why you have to add the -NQTV for the NASDAQ TotalView data (IBM-NQTV). To setup the Sierra Chart Exchange Data Feed, follow the instructions at the following link: Sierra Chart Exchange Data Feed: Setup Instructions You can also get delayed data for the U.S. Equities from the Sierra Chart Data Feed by opening a chart for a symbol (again without the -NQTV). This would allow you to at least make comparisons. There have been various issues with IB at this point due to changes they are making. If you are able to trade with them, then we recommend staying on the software you have now and the lack of historical data is just something that comes with this version. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-03 20:11:52] |
Thank you for the suggestion. I compared the delayed data of Sierra Chart Data Feed and it is great! It has no gaps or any data lacking. The Denali Data is inaccurate. See the picture is sended. Also SC has some issues with the Denali Data Feed symbols, like not showing the p&l of a position on the DOM. Also, can I choose package 3 to place orders on IBKR via SC? |
Attachment Deleted. Schermafbeelding 2023-02-03 202539.jpg / V - Attached On 2023-02-03 19:34:10 UTC - Size: 293.38 KB - 69 views |
[2023-02-03 22:00:51] |
Whichever one works best for your purposes you should use. We are working on getting the Consolidated Tape for the NASDAQ TotalView, but we just do not have it done yet. In order to connect to any trading service, or get real-time data, you need to be on one of the Integrated Packages. You can not be on Package 3 and connect to IB. Refer to the information here: Description of Service Packages and Pricing: Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
