Date/Time: Sat, 20 Apr 2024 12:22:19 +0000
Order association lines question..
View Count: 181
[2023-01-30 16:19:31] |
User414533 - Posts: 89 |
When you have multiple orders open, each subsequent bracket order's association lines are supposed to be outside the previous. On occasion, I have had a subsequent order's association lines be placed inside the previous. Do you have any idea why that would happen? Super confusing when it does. Thanks. |
[2023-01-30 22:01:06] |
John - SC Support - Posts: 30976 |
It is not the case that each subsequent bracket's association lines will be outside of the previous. That would only hold true if each bracket is further outside of the others. But bracket orders can be anywhere in relation to each other, so you should have lines that cross over each other if that is the way the brackets are setup.
