Date/Time: Wed, 17 Apr 2024 21:22:01 +0000
[User Discussion] - Change Font size for all columns
View Count: 232
[2023-01-30 15:25:31] |
Thaddeus Fulmer - Posts: 70 |
Hello, I've been scouring support board to figure out how to change the Font size of all the columns with no luck. I was able to change the Font size on the price column but nothing else. could you direct me in how to do this. Also, How to I get the volume by price study shifted to the far right of the DOM rather that it's current position on the far left? Thank you, Thaddeus |
Attachment Deleted. |
[2023-01-30 19:00:22] |
John - SC Support - Posts: 30926 |
The Price Ladder font is controlled by the Chart Text font. The other DOM numbers are controlled by the DOM Quantities/Sizes font. Refer to the following: Graphics Settings: Chart Text - (current font name) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-30 19:42:42] |
That worked thank you. Now how do I shift the Volume by price study all the way to the right?
[2023-01-30 20:58:24] |
And how do I change the background color of price column?
change background.png / V - Attached On 2023-01-30 20:58:18 UTC - Size: 95.56 KB - 49 views |
[2023-01-30 23:01:57] |
You can not move the Volume by Price to the right side of the DOM. The DOMs are fixed to the right side of the screen and can not be moved and therefore the VbP can only be put on the left side of the DOM. You can not change the background color of the Price Ladder by itself. It uses the general chart Background color. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
