Date/Time: Thu, 25 Apr 2024 13:39:12 +0000
Export 10 years of data from a 5 min ES chart with studies
View Count: 273
[2023-01-29 20:05:53] |
Beezkneez - Posts: 3 |
Hi there, I have been looking all over and I can't seem to find the answer to this. I am looking to export 10 years of data from a 5 min ES chart including my studies. I pay for denali data package 11. Is there any way I can do this? Thanks very much! |
[2023-01-29 23:27:51] |
Sierra_Chart Engineering - Posts: 14079 |
Yes this can be done. You first need to configure the chart to load and display 10 years. Refer to: Continuous Futures Contract Charts And then export the data: Exporting and Importing Intraday Data Files Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
