Date/Time: Tue, 23 Apr 2024 20:07:21 +0000
Verified Trading Accounts
View Count: 234
[2023-01-26 03:26:58] |
User513720 - Posts: 4 |
I was wondering if you could please point me information on how to verified trading account with Edge Clear. For example should I use the Ironbeam login portal? I just don't know how to with sierra chart. Thank you in advance.
[2023-01-26 15:41:50] |
John - SC Support - Posts: 31054 |
You just need to connect your Sierra Chart to the trading service that you are setup to use with EdgeClear. If you are using the Teton Order Routing Service with Edge Clear, then you will need to go through the Setup Instructions at the following link starting at Step #6: Sierra Chart Teton Futures Order Routing: Setup Instructions If you are using a different order routing service, then let us know what it is and we will point you to the proper instructions. If you are not going to stay connected to your trading account at all times (i.e. you are only using Sierra Chart for charting and not for placing trades), then refer to the information here: Real-Time Exchange Data Feeds Available From Sierra Chart: Connecting Only Once a Month to Trading Account to Support CME Group Exchange Fees For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
