Date/Time: Thu, 25 Apr 2024 04:58:00 +0000
Chart support
View Count: 336
[2023-01-25 23:26:33] |
Daniel Kamiński - Posts: 25 |
hello, I am asking for help in setting up the chart. On your website Cryptocurrency / Bitcoin Data and Trading Services there is a nice BTC chart. I can't set it up. My graph contains a ton of data and is completely unreadable. How to make it as it is on your website, what should I change? View of your chart and mine attached. Thank you in advance for your help Regards, Daniel |
Attachment Deleted. BTC by Sierra.png / V - Attached On 2023-01-25 23:24:54 UTC - Size: 98.47 KB - 60 views My Chart.png / V - Attached On 2023-01-25 23:25:00 UTC - Size: 111.49 KB - 57 views |
[2023-01-25 23:31:48] |
John - SC Support - Posts: 31098 |
Start by adjusting the Volume at Price Multiplier for Intraday Charts in Chart >> Chart Settings >> Chart Data. Refer to the following: Chart Settings: Volume at Price Multiplier for Historical/Intraday Chart (Chart >> Chart Settings >> Chart Data >> Volume at Price menu) You may also need to set the Volume and Open Interest Multiplier to a value less than 1 (such as 0.01 or 0.001). Refer to the following: Chart Settings: Volume and Open Interest Multiplier (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-26 11:58:22] |
Hello, thanks for the hints, but the modifications according to the articles don't bring me any closer to changing the values, which are still huge. Do you just have step-by-step instructions to make a chart like yours? |
[2023-01-26 12:28:04] |
or like this - I found a chart in sierra chart that will contain Symbol K instead of zeros. How to insert such a symbol into a value
Symbol K.png / V - Attached On 2023-01-26 12:27:42 UTC - Size: 1007.53 KB - 56 views |
[2023-01-26 16:02:03] |
To view the Numbers Bars data with the size suffix set the Input for Use Large Volume Number Formatting to Yes. But you will still need to work with the other 2 options we showed above (particularly the first one) in order to put together enough price levels so the data can be seen in a reasonable manner. Also refer to the following for more information: Cryptocurrency / Bitcoin Data and Trading Services: Important: Volume at Price Studies with Cryptocurrency Symbols For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-26 17:08:05] |
thank you for the hint. I changed it but the K symbol does not appear. I saved the changes, closed and reopened the chart and nothing :( |
Attachment Deleted. Prefix.png / V - Attached On 2023-01-26 17:07:07 UTC - Size: 76.47 KB - 53 views |
[2023-01-26 17:26:23] |
Sierra_Chart Engineering - Posts: 14076 |
That is not the right setting. There is a setting in the Numbers Bars Inputs to control this.: Numbers Bars: Use Large Volume Number Formatting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
