Date/Time: Tue, 23 Apr 2024 17:26:54 +0000
TPO Chart
View Count: 604
[2023-01-25 14:23:19] |
User409644 - Posts: 39 |
I drew a TPO chart but the volume bars are on the left side of the screen, and I would like them on the right side. How do I change that ?
[2023-01-25 15:25:51] |
Sierra_Chart Engineering - Posts: 14057 |
So we can understand this better, provide an image of the chart, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-26 00:38:42] |
User628616 - Posts: 132 |
Do you need Pkg. 5 to run the TPO charts, or will Pkg. 3 run it fine?
[2023-01-26 15:19:25] |
John - SC Support - Posts: 31044 |
User628616: You need one of the Advanced packages in order to be able to use the TPO study. Package 3 will not display the TPO. Refer to the differences in the packages at the following link: Description of Service Packages and Pricing: Packages For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-03-09 16:45:06
[2023-01-27 21:11:27] |
So if I do 5 Base Advanced $36/mo, and I select to use Denali Top of Book All Exchanges for $3.50, my monthly total will be $40/mo? Also will I use Teton for Order Routing to my broker(AmpFutures)
[2023-01-27 22:04:43] |
You can not be on one of the Base Packages and be able to get real-time data or connect to a trading service. For these, you need to be on of the "Integrated Packages". Therefore, you would need to be on Package 11 ($46.00 per month) and you can use the Full CME Group for Non-Professional Accounts for $3.50 per month bringing your monthly total to $49.50. Note that AMP does not support the Teton Order Routing Service. So you will use CQG for your Order Routing and your data will be coming from our Denali feed. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-16 10:33:13] |
How do I get my chart to display like the attached chart: Market Profiles and Volume Profiles(RTH session is Pink one, ETH is Turquoise one)
Screenshot_20230216-052231-041.png / V - Attached On 2023-02-16 10:29:44 UTC - Size: 473.34 KB - 77 views |
[2023-02-16 17:01:52] |
Add the TPO study, then add the Volume by Price study. When you do this, the Volume by Price study will automatically be setup to match the TPOs. In order to get the Volume profiles right-aligned as they are in the image, set the Input on the Volume by Price study for Right Align Volume Bars to Yes. Refer to the following: Volume By Price Study: Right Align Volume Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-09 13:43:33] |
Hi. Please see the attached picture. I am trying to get a tpo on the right side of chart, as in the picture. Id also like to try and add a button on the menu bar, so i can 1 click to remove it easily. IS that doable? |
Screenshot 2023-03-09 083718.png / V - Attached On 2023-03-09 13:43:02 UTC - Size: 187.6 KB - 68 views |
[2023-03-09 16:48:46] |
That is not a TPO in the image, that is a Volume by Price profile. Refer to the following: Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart There is not an option to have a control bar that will show/hide a specific study. You can create multiple Study Collections such that you can load one or another and change what you are viewing that way, which is supported with Control Bars. Refer to the following: Control Bar: Control Bar Study Collection Buttons and Keyboard Shortcuts For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-03-16 22:17:06] |
I have one last question on this topic. If I add a custom drawing tool to the toolbar, how do I set up the button to the default settings I am looking to save ? Like for volume profile, having the bars on the right side of chart. not the default left side. thanks |
[2023-03-17 14:00:18] |
Refer to the information here: Chart Drawing Tools: Creating Control Bar Buttons which Select Drawing Tool and Drawing Tool Configuration in One Step For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-05-15 12:02:51] |
I have been able to set the button correctly....The issue I am having now is I cant change the settings within the button, like where I want the tpo to be ( right or left side), or other settings. How do I change that, with the button already on the control bar ? Is that possible ?
[2023-05-15 15:22:20] |
There is not an option for a Drawing Tool for the TPO study. You have to add the TPO study using the Analysis >> Studies option.
