Date/Time: Fri, 19 Apr 2024 19:47:51 +0000
[User Discussion] - Auto Spreadsheet Trading - Signal Only Once per Bar determined if it is an entry or exit
View Count: 235
[2023-01-22 20:58:32] |
User960420 - Posts: 4 |
In this scenario I have I've built out a position through multiple entries over multiple bars, with the Signal only once per bar set to yes. With this setting still remaining as yes (for the entry) I'd the ability like to flatten the entire position when the exit trigger hits. It would be to allow a single entry per bar while allowing multiple exits per bar. Is this possible? |
