Date/Time: Fri, 19 Apr 2024 22:26:23 +0000
Volume by Price using Custom Intraday Sessions
View Count: 285
[2023-01-21 00:32:30] |
Kevin941 - Posts: 22 |
Hi, I am trying to build 4 intraday session VbP's, I have input the 4 custom sessions with no overlapping time. Also I have set the Time Period Type for 'Fixed Time' to Days and the Time Period Length for 'Fixed Time' to 1. I have not been able to get 4 profiles to create for the intraday session. I looked in the documentation and did not find an example that showed all the settings needed to make the function work correctly. Can you please help? Thanks, Kevin |
[2023-01-23 15:51:30] |
John - SC Support - Posts: 30976 |
You also need to be using a Volume Graph Period Type of Multiple Profiles Based on Fixed Time. Refer to the following for how to set this: Volume By Price Study: Volume Graph Period Type For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
