Date/Time: Tue, 23 Apr 2024 15:15:09 +0000
Is there a Draw Style for SCSubgraphs that replicates the Rectangular tool?
View Count: 215
[2023-01-20 17:51:32] |
User907967 - Posts: 53 |
Is there a Draw Style for SCSubgraphs that allows me to draw a rectangular shape across multiple bars? I sense the use of Subgraphs is more efficient from the resource perspective than the tool methods. Thanks, Bogdan |
[2023-01-20 18:21:23] |
John - SC Support - Posts: 31031 |
The closest option for this are the Top and Bottom Draw Styles that will fill in the area between two subgraphs. Refer to the following: Chart Studies: Notes about Top and Bottom Draw Style Pairs For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-20 18:26:16] |
That makes sense, thank you for your swift response!
