Date/Time: Thu, 28 Mar 2024 20:59:13 +0000
activity log export data contains different time zone than what I have it showing on chart
View Count: 192
[2023-01-20 16:15:17] |
User553413 - Posts: 35 |
On the chart, when I open the activity log the time stamp on the trades is in EST, but when I export the data, it shows that the time is about 5 hours ahead. When I opened the file, it showed that the time was indeed different from what it says on my activity log on the chart. Please help me to change the timezone on the exported data going forward so that it shows the same time I have on my chart.
[2023-01-20 17:22:42] |
John - SC Support - Posts: 30444 |
If you use the option for "Save" for the Trade Activity Log, then the times will match what is displayed. Refer to the following: Trade Activity Log: Saving to a Text File If you use the option for "Export" for the Trade Activity Log, then the times will be in GMT. Refer to the following: Trade Activity Log: Importing and Exporting Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
