Date/Time: Thu, 11 Jun 2026 19:03:15 +0000
daylight saving time issue
View Count: 1595
| [2014-06-02 07:01:24] |
| User17064 - Posts: 70 |
Hi SC support, I am in Timezone GMT+8 and I want to generate some chart only base on the US session open to close. So I set the session time in chart setting from US session open to close. But consider the daylight saving time, currently I set the start session to 21:30(local time), it may change to 22::30 in winter.So I could not generate like 2 or 3 year length chart cause this daylight saving time always change the open and close session time. Is there any solution? |
| [2014-06-02 08:47:40] |
In newer Sierra Chart versions you can set an independent time zone within Chart >> Chart Settings for the chart itself. So that can be set to a US time zone.
| [2014-06-02 10:25:28] |
Thank a lot! Problem solved!
