Date/Time: Fri, 19 Apr 2024 11:40:29 +0000
Subscription with delayed data
View Count: 224
[2022-12-29 20:17:31] |
User314484 - Posts: 7 |
Dear Support, I would like to buy a 12 months subscription with SierraChart. As I am planning to work only on SIM for the next 12 months (trading with delayed data), I would like to know if the basic subcription (26$ a month) would be suitable for me. I would like to have access to all symbols. Thanks a lot. Best regards William |
[2022-12-29 21:10:41] |
John - SC Support - Posts: 30953 |
Definitely you can (and should) be on one of the Base packages since you are just going to use the Delayed Streaming Data. Whether you need the Standard or Advanced depends on whether you need to use the TPO or Numbers Bars studies. Refer to the differences in the packages at the following link: Description of Service Packages and Pricing: Packages Keep in mind that the Delayed Streaming data has data for the CME Group, EUREX, CFE and NASDAQ TotalView. You also have access to free real-time data for FOREX and CFDs from FXCM. Any other data is going to be delayed historical data, not streaming. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
