Date/Time: Sat, 20 Apr 2024 09:19:06 +0000
DTC Protocol - JSON heartbeat (ping client->server) - bug?
View Count: 621
[2022-12-21 22:34:24] |
User5044343 - Posts: 67 |
I'm sending a heartbeat(ping) back to the server - Sierra logs confirm that - but it doesn't register as a heartbeat and times out after 60 sec. Data flows to the client fine. I have the null terminator at the end of the json as well. (PHP) $msg = '{"Type":3}'."\0"; $conn2->send($msg); DTC Protocol server | Incoming connection from 10.70.70.72. | 2022-12-16 05:23:09.976 DTC client #37. 10.70.70.72 (4) | Creating socket. | 2022-12-16 05:23:09.979 DTC client #37. 10.70.70.72 (4) | New receive buffer size: 262144 | 2022-12-16 05:23:09.979 DTC client #37. 10.70.70.72 (4) | Allocated send buffers: 32 of 131072 bytes. | 2022-12-16 05:23:09.980 WSServer | DTC client #37. 10.70.70.72 (4) | Start Server | 2022-12-16 05:23:09.981 WSServer | DTC client #37. 10.70.70.72 (4) | Switch to HANDSHAKE | 2022-12-16 05:23:09.981 WSServer | DTC client #37. 10.70.70.72 (4) | Switch to READY_DATA | 2022-12-16 05:23:09.981 WSServer | DTC client #37. 10.70.70.72 (4) | Response HANDSHAKE with status code 101 | 2022-12-16 05:23:09.981 JSON data: {"Type":1,"HeartbeatIntervalInSeconds":5,"TradeMode":1,"Username": xxx"Password": "xxx","ClientName":"trades"} | 2022-12-16 05:23:09.985 DTC client #37. 10.70.70.72 | Requested heartbeat interval: 5 | 2022-12-16 05:23:09.987 DTC client #37. trades. 10.70.70.72 | Received logon request. | 2022-12-16 05:23:09.987 DTC client #37. trades. 10.70.70.72 | Sent successful Logon response message to client. Username: xxx. Result text: Connected to SC DTC Protocol server. Service=sc_futures_direct.dtc.trading|SymbolSettings=sc_futures_direct.dtc.trading | 2022-12-16 05:23:09.987 JSON data: {"Type":3} | 2022-12-16 05:23:10.981 JSON data: {"Type":3} | 2022-12-16 05:23:15.983 JSON data: {"Type":3} | 2022-12-16 05:23:20.988 JSON data: {"Type":3} | 2022-12-16 05:23:25.992 JSON data: {"Type":3} | 2022-12-16 05:23:30.996 JSON data: {"Type":3} | 2022-12-16 05:23:36.000 JSON data: {"Type":3} | 2022-12-16 05:23:41.003 JSON data: {"Type":3} | 2022-12-16 05:23:46.012 WSServer | DTC client #37. 10.70.70.72 (4) | Timeout waiting for ping message from client. | 2022-12-16 05:23:49.986 WSServer | DTC client #37. 10.70.70.72 (4) | Delay close connection now | 2022-12-16 05:23:50.005 DTC client #37. 10.70.70.72 (4) | CloseSocket call. | 2022-12-16 05:23:50.005 DTC client #37. 10.70.70.72 (4) | Max send buffers used during socket life: 3 | 2022-12-16 05:23:50.005 DTC client #37. 10.70.70.72 (4) | Max send buffer size during socket life: 14174 | 2022-12-16 05:23:50.005 DTC client #37. 10.70.70.72 (4) | Shutdown started. Waiting for graceful close. | 2022-12-16 05:23:50.005 DTC client #37. 10.70.70.72 (4) | Socket gracefully closed by remote side. | 2022-12-16 05:23:50.005 DTC client #37. 10.70.70.72 (4) | Closed. | 2022-12-16 05:23:50.005 Deleting individual DTC server: DTC client #37. trades. 10.70.70.72 | 2022-12-16 05:23:50.999 DTC server: DTC client #37. trades. 10.70.70.72 successfully deleted. | 2022-12-16 05:23:51.002 |
[2022-12-22 01:31:18] |
Sierra_Chart Engineering - Posts: 14017 |
This is completely unrelated to a DTC protocol heartbeat: WSServer | DTC client #37. 10.70.70.72 (4) | Timeout waiting for ping message from client. | 2022-12-16 05:23:49.986 WSServer | DTC client #37. 10.70.70.72 (4) | Delay close connection now | 2022-12-16 05:23:50.005 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-22 01:31:32
[2022-12-22 02:36:00] |
$ping = new Frame('', true, Frame::OP_PING); $conn2->send($ping); That fixed it. Thank you. No more disconnects. Follow up question. I'm sending 300, 601, 400 and 305 messages yet I'm not getting a response on most of the requests. Position and Balance request come in only if there is an open position and the price changes to affect the open P&L. Date Time Of Last Edit: 2022-12-22 02:36:24
[2022-12-22 02:48:33] |
We do not know from memory, what those messages are. Best to give the names of them. Did you also enable Global Settings >> Sierra Chart Server Settings >> DTC Protocol Server >> Allow Trading. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-22 03:01:22] |
Here are the names: OPEN_ORDERS_REQUEST - 300 ACCOUNT_BALANCE_REQUEST - 601 TRADE_ACCOUNTS_REQUEST - 400 CURRENT_POSITIONS_REQUEST - 305 Allow Trading - is set to a green "YES" I'm running 2458 Date Time Of Last Edit: 2022-12-22 03:01:57
[2022-12-22 14:14:59] |
You absolutely should get a response for all of those requests. Even if it is a rejection message. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-22 14:15:10
[2022-12-22 23:17:30] |
My mistake again - was sending \n instead of \0 for termination. All issues resolved. No bugs with sierra :)
[2023-01-23 17:39:46] |
User230940 - Posts: 121 |
Hello, I am trying to implement my necessary DTC Communication in Perl. And I am failed on the missing heartbeat within 20 seconds. $ping = new Frame('', true, Frame::OP_PING); I expect the $PING is a JSON Format Value, what content is it? If I would write it be text, what do I have to send as Heartbeat? Thanks best regards Carsten |
[2023-01-23 18:23:33] |
I add something during initiation of the connection: connection init
$client->send_text_frame( encode_json { Type=>1, ProtocolVersion=>8, HeartbeatIntervalInSeconds=>120, ClientName=>'Client' } ); } DTC Protocol server | Incoming connection from 192.168.17.201. | 2023-01-23 19:01:31.248
DTC client #20. 192.168.17.201 (2) | Creating socket. | 2023-01-23 19:01:31.251 DTC client #20. 192.168.17.201 (2) | New receive buffer size: 262144 | 2023-01-23 19:01:31.251 DTC client #20. 192.168.17.201 (2) | Allocated send buffers: 32 of 131072 bytes. | 2023-01-23 19:01:31.252 WSServer | DTC client #20. 192.168.17.201 (2) | Start Server | 2023-01-23 19:01:31.252 WSServer | DTC client #20. 192.168.17.201 (2) | Switch to HANDSHAKE | 2023-01-23 19:01:31.252 WSServer | DTC client #20. 192.168.17.201 (2) | Switch to READY_DATA | 2023-01-23 19:01:31.252 WSServer | DTC client #20. 192.168.17.201 (2) | Response HANDSHAKE with status code 101 | 2023-01-23 19:01:31.252 JSON data: {"HeartbeatIntervalInSeconds":120,"ProtocolVersion":8,"Type":1,"ClientName":"Client"} | 2023-01-23 19:01:31.260 DTC client #20. 192.168.17.201 | No heartbeat received after 20s. Closing network socket. Bytes in receive buffer: 0 | 2023-01-23 19:01:51.748 DTC client #20. 192.168.17.201 (2) | CloseSocket call. | 2023-01-23 19:01:51.748 I think request for inititiation the Connection does not take place. The heartbeat interval is not changed. Do I have to change / add something to my init JSON String? tbanks |
[2023-01-23 18:38:23] |
We definitely do not recommend a heartbeat interval of 120 seconds. It should be about 20 seconds. First resolve that. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-23 18:40:27] |
This is only for testing if my send JSON does change anything. Yes, of I will use 5 sec instead.
[2023-01-23 18:45:11] |
5 or 0 sec. It is not important to me. JSON data: {"HeartbeatIntervalInSeconds":18,"ProtocolVersion":8,"Type":1,"ClientName":"Client"} | 2023-01-23 19:41:31.260 DTC client #20. 192.168.17.201 | No heartbeat received after 20s. Closing network socket. Bytes in receive buffer: 0 | 2023-01-23 19:41:51.748 DTC client #20. 192.168.17.201 (2) | CloseSocket call. | 2023-01-23 19401:51.748 I changed it to 18 sec, but still the same of course. |
[2023-01-24 08:06:19] |
Hello, got success: (I use Perl ) Now I send for Logon $client->send_text_frame("{\"Type\":1,\"HeartbeatIntervalInSeconds\":18,\"ClientName\":\"DTC4FMA\"}\0");
with result on Server: DTC client #11. 192.168.17.201 (3) | New receive buffer size: 262144 | 2023-01-24 08:50:05.437
DTC client #11. 192.168.17.201 (3) | Allocated send buffers: 32 of 131072 bytes. | 2023-01-24 08:50:05.438 WSServer | DTC client #11. 192.168.17.201 (3) | Start Server | 2023-01-24 08:50:05.439 WSServer | DTC client #11. 192.168.17.201 (3) | Switch to HANDSHAKE | 2023-01-24 08:50:05.439 WSServer | DTC client #11. 192.168.17.201 (3) | Switch to READY_DATA | 2023-01-24 08:50:05.439 WSServer | DTC client #11. 192.168.17.201 (3) | Response HANDSHAKE with status code 101 | 2023-01-24 08:50:05.439 JSON data: {"Type":1,"HeartbeatIntervalInSeconds":18,"ClientName":"DTC4FMA"} | 2023-01-24 08:50:05.448 DTC client #11. 192.168.17.201 | Requested heartbeat interval: 18 | 2023-01-24 08:50:05.451 DTC client #11. DTC4FMA. 192.168.17.201 | Received logon request. | 2023-01-24 08:50:05.451 DTC client #11. 192.168.17.201 (3) | Send: {"Type":2,"ProtocolVersion":8,"Result":1,"Integer_1":0,"MarketDepthUpdatesBestBidAndAsk":0,"TradingIsSupported":1,"OCOOrdersSupported":1,"OrderCancelReplaceSupported":1,"SecurityDefinitionsSupported":1,"HistoricalPriceDataSupported":0,"ResubscribeWhenMarketDataFeedAvailable":0,"MarketDepthIsSupported":1,"OneHistoricalPriceDataRequestPerConnection":0,"BracketOrdersSupported":1,"UsesMultiplePositionsPerSymbolAndTradeAccount":0,"MarketDataSupported":1,"ResultText":"Connected to SC DTC Protocol server. Service=cqg|SymbolSettings=cqg","ReconnectAddress":"","ServerName":"SC DTC Server. Build=44247","SymbolExchangeDelimiter":""} | 2023-01-24 08:50:05.451 DTC client #11. DTC4FMA. 192.168.17.201 | Sent successful Logon response message to client. Username: . Result text: Connected to SC DTC Protocol server. Service=cqg|SymbolSettings=cqg | 2023-01-24 08:50:05.451 On my Client I see the return as successful Logon (perfect): {
'MarketDepthIsSupported' => 1, 'BracketOrdersSupported' => 1, 'ReconnectAddress' => '', 'MarketDepthUpdatesBestBidAndAsk' => 0, 'OCOOrdersSupported' => 1, 'Integer_1' => 0, 'UsesMultiplePositionsPerSymbolAndTradeAccount' => 0, 'HistoricalPriceDataSupported' => 0, 'ServerName' => 'SC DTC Server. Build=44247', 'SymbolExchangeDelimiter' => '', 'ResubscribeWhenMarketDataFeedAvailable' => 0, 'SecurityDefinitionsSupported' => 1, 'ResultText' => 'Connected to SC DTC Protocol server. Service=cqg|SymbolSettings=cqg', 'OneHistoricalPriceDataRequestPerConnection' => 0, 'OrderCancelReplaceSupported' => 1, 'Type' => 2, 'TradingIsSupported' => 1, 'Result' => 1, 'MarketDataSupported' => 1, 'ProtocolVersion' => 8 }; Additionally I see the heartbeat request Type 3 which comes JSON Compact encoded. {
'Type' => 3, 'F' => [ 0, 1674546515, 0, 0, 0, 0, '1674546514862035', 0, 762, 0, 0, 3232239923 ] }; What do I have to answer on the heartbeat request? Do I have to answer in JSON Compact Encoding too? Thanks for help |
[2023-01-24 20:12:59] |
Hello, could it be enough to send the following JSON Frame? {type:3}\0
I have not tested until now, but I read in the Documentation: There are no required member fields to set in this message. The purpose of the HEARTBEAT message is so that the Client or the Server can determine whether the other side is still connected.
But this is the starting point of this thread? Thanks for your feedback regards |
[2023-01-25 12:17:06] |
Hello, my heartbeat fails always. I send: Actual DateTime in Miliseconds: 1674647806
My Connection request is as follows: Which works {"Type":1,"HeartbeatIntervalInSeconds":18,"ClientName":"DTC4FMA"}\0
[b]Heartbeat as JSON Compact[/b]
{"Type":3,"F":"[0,1674647806]"}\0 WSServer | DTC client #9. 192.168.17.201 (1) | Response HANDSHAKE with status code 101 | 2023-01-25 12:52:54.122
JSON data: {"Type":1,"HeartbeatIntervalInSeconds":18,"ClientName":"DTC4FMA"} | 2023-01-25 12:52:54.154 DTC client #9. 192.168.17.201 | Requested heartbeat interval: 18 | 2023-01-25 12:52:54.158 DTC client #9. DTC4FMA. 192.168.17.201 | Received logon request. | 2023-01-25 12:52:54.158 DTC client #9. 192.168.17.201 (1) | Send: {"Type":2,"ProtocolVersion":8,"Result":1,"Integer_1":0,"MarketDepthUpdatesBestBidAndAsk":0,"TradingIsSupported":1,"OCOOrdersSupported":1,"OrderCancelReplaceSupported":1,"SecurityDefinitionsSupported":1,"HistoricalPriceDataSupported":0,"ResubscribeWhenMarketDataFeedAvailable":0,"MarketDepthIsSupported":1,"OneHistoricalPriceDataRequestPerConnection":0,"BracketOrdersSupported":1,"UsesMultiplePositionsPerSymbolAndTradeAccount":0,"MarketDataSupported":1,"ResultText":"Connected to SC DTC Protocol server. Service=cqg|SymbolSettings=cqg","ReconnectAddress":"","ServerName":"SC DTC Server. Build=44247","SymbolExchangeDelimiter":""} | 2023-01-25 12:52:54.158 DTC client #9. DTC4FMA. 192.168.17.201 | Sent successful Logon response message to client. Username: . Result text: Connected to SC DTC Protocol server. Service=cqg|SymbolSettings=cqg | 2023-01-25 12:52:54.158 JSON data: {"Type":3","F":[0,1674647578]} | 2023-01-25 12:52:59.190 JSON data: {"Type":3","F":[0,1674647583]} | 2023-01-25 12:53:04.266 JSON data: {"Type":3","F":[0,1674647588]} | 2023-01-25 12:53:09.262 DTC client #9. 192.168.17.201 (1) | Send: {"Type":3,"F":[0,1674647592,3,0,0,0,1674647592363376,0,762,0,0,3232239923]} | 2023-01-25 12:53:12.363 JSON data: {"Type":3","F":[0,1674647593]} | 2023-01-25 12:53:14.135 JSON data: {"Type":3","F":[0,1674647598]} | 2023-01-25 12:53:19.168 JSON data: {"Type":3","F":[0,1674647603]} | 2023-01-25 12:53:24.161 JSON data: {"Type":3","F":[0,1674647608]} | 2023-01-25 12:53:29.156 DTC client #9. 192.168.17.201 (1) | Send: {"Type":3,"F":[0,1674647610,1,0,0,0,1674647610473615,0,845,0,0,3232239923]} | 2023-01-25 12:53:30.473 JSON data: {"Type":3","F":[0,1674647613]} | 2023-01-25 12:53:34.154 WSServer | DTC client #9. 192.168.17.201 (1) | Timeout waiting for ping message from client. | 2023-01-25 12:53:34.459 or [b]Heartbeat as JSON[/b]
{"Type":3,"NumDroppedMessages":0,"CurrentDateTime":1674647806}\0 WSServer | DTC client #10. 192.168.17.201 (1) | Response HANDSHAKE with status code 101 | 2023-01-25 12:56:26.599
JSON data: {"Type":1,"HeartbeatIntervalInSeconds":18,"ClientName":"DTC4FMA"} | 2023-01-25 12:56:26.610 DTC client #10. 192.168.17.201 | Requested heartbeat interval: 18 | 2023-01-25 12:56:26.613 DTC client #10. DTC4FMA. 192.168.17.201 | Received logon request. | 2023-01-25 12:56:26.613 DTC client #10. 192.168.17.201 (1) | Send: {"Type":2,"ProtocolVersion":8,"Result":1,"Integer_1":0,"MarketDepthUpdatesBestBidAndAsk":0,"TradingIsSupported":1,"OCOOrdersSupported":1,"OrderCancelReplaceSupported":1,"SecurityDefinitionsSupported":1,"HistoricalPriceDataSupported":0,"ResubscribeWhenMarketDataFeedAvailable":0,"MarketDepthIsSupported":1,"OneHistoricalPriceDataRequestPerConnection":0,"BracketOrdersSupported":1,"UsesMultiplePositionsPerSymbolAndTradeAccount":0,"MarketDataSupported":1,"ResultText":"Connected to SC DTC Protocol server. Service=cqg|SymbolSettings=cqg","ReconnectAddress":"","ServerName":"SC DTC Server. Build=44247","SymbolExchangeDelimiter":""} | 2023-01-25 12:56:26.613 DTC client #10. DTC4FMA. 192.168.17.201 | Sent successful Logon response message to client. Username: . Result text: Connected to SC DTC Protocol server. Service=cqg|SymbolSettings=cqg | 2023-01-25 12:56:26.613 JSON data: {"Type":3,"NumDroppedMessages":0,"CurrentDateTime":1674647791} | 2023-01-25 12:56:31.614 JSON data: {"Type":3,"NumDroppedMessages":0,"CurrentDateTime":1674647796} | 2023-01-25 12:56:36.623 JSON data: {"Type":3,"NumDroppedMessages":0,"CurrentDateTime":1674647801} | 2023-01-25 12:56:41.613 DTC client #10. 192.168.17.201 (1) | Send: {"Type":3,"F":[0,1674647805,3,0,0,0,1674647805120806,0,762,0,0,3232239923]} | 2023-01-25 12:56:45.120 JSON data: {"Type":3,"NumDroppedMessages":0,"CurrentDateTime":1674647806} | 2023-01-25 12:56:46.634 JSON data: {"Type":3,"NumDroppedMessages":0,"CurrentDateTime":1674647811} | 2023-01-25 12:56:51.744 JSON data: {"Type":3,"NumDroppedMessages":0,"CurrentDateTime":1674647816} | 2023-01-25 12:56:56.630 JSON data: {"Type":3,"NumDroppedMessages":0,"CurrentDateTime":1674647821} | 2023-01-25 12:57:01.626 DTC client #10. 192.168.17.201 (1) | Send: {"Type":3,"F":[0,1674647823,1,0,0,0,1674647823078658,0,845,0,0,3232239923]} | 2023-01-25 12:57:03.078 JSON data: {"Type":3,"NumDroppedMessages":0,"CurrentDateTime":1674647826} | 2023-01-25 12:57:06.634 WSServer | DTC client #10. 192.168.17.201 (1) | Timeout waiting for ping message from client. | 2023-01-25 12:57:07.277 WSServer | DTC client #10. 192.168.17.201 (1) | Delay close connection now | 2023-01-25 12:57:07.664 All without any change, the connection will be closed because of missing heartbeat. Can you please tell me what I have to send to send a valid heartbeat? Do I have to answer on the Heartbeat send by the server? Or can I send the heartbeart regularly, like I did up to now? thanks in advance regards |
[2023-01-25 15:12:27] |
Yes: Or can I send the heartbeart regularly, like I did up to now?
Now that we look more closely at this log the problem is not the heartbeat but the websocket ping: WSServer | DTC client #10. 192.168.17.201 (1) | Timeout waiting for ping message from client. | 2023-01-25 12:57:07.277 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-25 15:12:41
[2023-01-25 15:15:03] |
Yes it should be: could it be enough to send the following JSON Frame?
{type:3}\0 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-01-25 15:24:56] |
Do I have to send an additional Websocket ping to the DTC Server?
[2023-01-25 15:26:21] |
Yes that is certainly required by the websocket protocol.
[2023-01-25 15:28:50] |
Than the heartbeat Type 3 is not necessary for a Websocket connection, only a Websocket ping?
[2023-01-25 15:35:08] |
Do you have a documentation on what is required by the DTC Server. Now I send a ping every 5 seconds. Now I will be disconnected a bit latest. Now with the Message the PONG Message is missing. regards |
[2023-01-25 17:33:08] |
Hello, Actually I send every five seconds a ping and a pong and the Type 3 Message and this seams to work. Up to now it is not nice, but it works for the moment. Do you have documentation on the WebSocket Communication? PIng and Pong requirement? thanks |
[2023-01-26 18:19:19] |
Regarding post #20 you need both. You need the DTC protocol heartbeat message to be sent about every 20 seconds and you need the websocket Ping message according to the websocket specifications which we do not publish.
[2023-01-26 18:23:42] |
Thanks, I got it working. regards |
[2023-01-28 14:35:51] |
Hello, at least for the Trading Messsages the Documentation of Fields is not complete. Already reported in ThreadID=72591. The following Fields will be send by the DTC Server in the JSON but they are not defined. LatestTransactionDateTime t_DateTime Username char regards Date Time Of Last Edit: 2023-01-28 14:38:19
