Date/Time: Thu, 25 Apr 2024 15:11:02 +0000
Sierra charts will not update
View Count: 402
[2022-12-06 17:23:13] |
L2Ltrades - Posts: 45 |
The platform will show connected but the price won't move or change. Every time I close it and open again, the price will show a change.
[2022-12-06 19:28:19] |
John - SC Support - Posts: 31104 |
Is this for all symbols or just for some? What is one symbol for which you are having this issue? Keep in mind, you are only setup to get real-time data from the CME exchange (not the full CME Group, just the CME Exchange). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-12-07 13:19:01] |
This is for ES, MES symbols. Please see the attached image. The platform shows that it is connected, but the price will not update. You can see the price vs the time on the real time clock. The price will update if I close the charts and reopen it. It will show the most recent price and just stay there. Same on the DPM as well. I uninstalled and reinstalled the software as well. It worked for about 10 mins and same thing occurred again.
Screenshot 2022-12-07 081546.png / V - Attached On 2022-12-07 13:17:45 UTC - Size: 86.64 KB - 59 views |
[2022-12-07 14:24:51] |
Sierra_Chart Engineering - Posts: 14088 |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Open a chart for the symbol you have an issue with. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-12-07 14:24:59
[2022-12-07 14:40:54] |
Here you go. It keeps saying feed has been disconnected and will attempt to reconnect in 30 seconds. I have not changed anything. This started yesterday. Software version: 2457 64-bit | 2022-12-07 14:36:52.656 Primary Thread ID: 16800 | 2022-12-07 14:36:52.656 Usage end date: 2023-04-30 | 2022-12-07 14:36:52.656 Enabled for: Advanced Features 2. | 2022-12-07 14:36:52.656 Enabled for: Sierra Chart Historical Data Service. | 2022-12-07 14:36:52.656 Enabled for: Denali Real-Time Exchange Data Feed. | 2022-12-07 14:36:52.656 Enabled for: Delayed Denali Exchange Data Feed. | 2022-12-07 14:36:52.656 Enabled for exchange2: CME | 2022-12-07 14:36:52.656 Enabled for exchange2: fairx_exchange.data | 2022-12-07 14:36:52.656 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-12-07 14:36:52.656 Current selected Data/Trading service: Rithmic Direct - DTC | 2022-12-07 14:36:52.656 Custom symbol settings values: enabled | 2022-12-07 14:36:52.656 Chart Update Interval: 500 | 2022-12-07 14:36:52.656 Intraday Data Storage Time Unit: 1 | 2022-12-07 14:36:52.656 Time Zone: +00:00:00 (UTC+00) | 2022-12-07 14:36:52.656 2022-12-07 14:36:52 Local computer time in UTC | 2022-12-07 14:36:52.656 2022-12-07 14:36:52 Local computer time in SC Time Zone | 2022-12-07 14:36:52.656 2022-12-07 14:15:28 Server time in UTC | 2022-12-07 14:36:52.656 Local computer UTC time and Server UTC time difference: 1 seconds. | 2022-12-07 14:36:52.656 Program path: C:\SierraChart\ | 2022-12-07 14:36:52.656 Data Files path: C:\SierraChart\Data\ | 2022-12-07 14:36:52.656 OS Version Number: 10.0 | 2022-12-07 14:36:52.656 Locale Setting: C | 2022-12-07 14:36:52.656 DLLs: UserContributedStudies_64.dll | 2022-12-07 14:36:52.656 Allowed protected custom studies: | 2022-12-07 14:36:52.656 Crash reporter started: true | 2022-12-07 14:36:52.656 Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated | 2022-12-07 14:36:56.164 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2022-12-07 14:36:56.167 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-12-07 14:37:04.342 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-12-07 14:37:04.342 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-12-07 14:37:04.342 Rithmic Direct - DTC | Network connection to server complete. | 2022-12-07 14:37:04.396 Rithmic Direct - DTC | Starting socket receive thread. | 2022-12-07 14:37:04.396 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-12-07 14:37:04.396 Rithmic Direct - DTC | Sending logon request message. | 2022-12-07 14:37:04.396 Rithmic Direct - DTC | Received logon response. | 2022-12-07 14:37:04.479 Rithmic Direct - DTC | Server Name: . | 2022-12-07 14:37:04.479 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-12-07 14:37:04.479 Rithmic Direct - DTC | Successfully connected. | 2022-12-07 14:37:04.479 Rithmic Direct - DTC | Trading is supported. | 2022-12-07 14:37:04.479 Rithmic Direct - DTC | Order cancel and replace is supported. | 2022-12-07 14:37:04.479 Rithmic Direct - DTC | OCO Orders supported. | 2022-12-07 14:37:04.479 Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2022-12-07 14:37:04.479 Rithmic Direct - DTC | Connected to server complete. | 2022-12-07 14:37:04.479 Triggering next historical data download in queue. | 2022-12-07 14:37:04.487 Triggering next historical data download in queue. | 2022-12-07 14:37:04.487 Triggering next historical data download in queue. | 2022-12-07 14:37:04.487 Triggering next historical data download in queue. | 2022-12-07 14:37:04.487 Updated verified funded futures trading account ending date to: 2023-01-06 14:37:04 | 2022-12-07 14:37:04.487 No download requests in the queue to start downloads for. | 2022-12-07 14:37:04.499 No download requests in the queue to start downloads for. | 2022-12-07 14:37:04.499 No download requests in the queue to start downloads for. | 2022-12-07 14:37:04.499 No download requests in the queue to start downloads for. | 2022-12-07 14:37:04.499 Updated verified funded futures trading account ending date to: 2023-01-06 14:37:04 | 2022-12-07 14:37:04.554 Mapping ESZ2.CME to ESZ22. Service code: cme | 2022-12-07 14:37:04.717 Using symbol data fast lookup vector | 2022-12-07 14:37:04.717 SC Data - All Services | Starting real-time market data updates for: ESZ2.CME (ESZ22). ID: 1 Service code: cme | 2022-12-07 14:37:04.717 SC Data - All Services | Connecting to the server ds26.sierracharts.com. Port 10048 | 2022-12-07 14:37:04.717 SC Data - All Services | Requesting security definition data for: ESZ2.CME (ESZ22). ID: 1 | 2022-12-07 14:37:04.718 Added historical Intraday data request for ESZ2.CME to the queue. | 2022-12-07 14:37:04.718 Intraday data recording state for symbol ESZ2.CME is set to download 'Pending'. | 2022-12-07 14:37:04.718 Triggering next historical data download in queue. | 2022-12-07 14:37:04.718 DTC Client socket (2) | Creating socket. | 2022-12-07 14:37:04.726 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-12-07 14:37:04.726 DTC Client socket (2) | Connecting to IP: 142.215.18.107. | 2022-12-07 14:37:04.726 Delaying start of download for ESZ2.CME. | 2022-12-07 14:37:04.757 SC Data - All Services | Network connection to server complete. | 2022-12-07 14:37:04.757 SC Data - All Services | Starting socket receive thread. | 2022-12-07 14:37:04.757 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-12-07 14:37:04.757 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-12-07 14:37:04.849 SC Data - All Services | Sending logon request message. | 2022-12-07 14:37:04.849 SC Data - All Services | Received logon response. | 2022-12-07 14:37:05.536 SC Data - All Services | Server Name: RealTime Server. | 2022-12-07 14:37:05.536 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-12-07 14:37:05.536 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-12-07 14:37:05.536 SC Data - All Services | Waiting for socket receive thread to end | 2022-12-07 14:37:05.536 DTC Client socket (2) | CloseSocket call. | 2022-12-07 14:37:05.536 SC Data - All Services | Disconnected from the server. | 2022-12-07 14:37:05.536 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-12-07 14:37:05.536 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-12-07 14:37:05.536 DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-12-07 14:37:05.568 DTC Client socket (2) | Closed. | 2022-12-07 14:37:05.568 Requesting market depth updates for: ESZ2.CME if supported. | 2022-12-07 14:37:09.473 Separate subscription for market depth updates not supported. ESZ2.CME | 2022-12-07 14:37:09.473 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (2) | Creating socket. Using TLS 1.2. | 2022-12-07 14:37:16.332 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (2) | New receive buffer size: 32768 | 2022-12-07 14:37:16.332 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (2) | Connecting to IP: 38.79.0.89. | 2022-12-07 14:37:16.332 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (2) | Socket gracefully closed by remote side. | 2022-12-07 14:37:16.430 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (2) | CloseSocket call. | 2022-12-07 14:37:16.431 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-12-07 14:37:16.431 HTTPS connection ID:3 to www.rithmic.com:443 for request ID:3 (2) | Closed. | 2022-12-07 14:37:16.431 File >> Disconnect selected. | 2022-12-07 14:37:31.101 Rithmic Direct - DTC | Waiting for socket receive thread to end | 2022-12-07 14:37:31.110 DTC Client socket (1) | CloseSocket call. | 2022-12-07 14:37:31.110 DTC Client socket (1) | Max send buffers used during socket life: 3 | 2022-12-07 14:37:31.110 DTC Client socket (1) | Max send buffer size during socket life: 1325 | 2022-12-07 14:37:31.110 DTC Client socket (0) | CloseSocket call. | 2022-12-07 14:37:31.110 SC Data - All Services | Disconnected from the server. | 2022-12-07 14:37:31.110 Rithmic Direct - DTC | Disconnected. | 2022-12-07 14:37:31.110 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-12-07 14:37:31.110 DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-12-07 14:37:31.137 DTC Client socket (1) | Closed. | 2022-12-07 14:37:31.137 HD Request # 29 | Downloading Intraday chart data for ESZ2.CME to the file ESZ2.CME.scid. Service: cme | 2022-12-07 14:37:32.096 HD Request # 29 | Download start date-time: 2022-12-07 14:21:48.000000. File last date-time: 2022-12-07 14:21:48.095000 | 2022-12-07 14:37:32.097 HD Request # 29 | Using server: ds26.sierracharts.com port 10150 | 2022-12-07 14:37:32.097 Socket (1) | Creating socket. | 2022-12-07 14:37:32.098 Socket (1) | New receive buffer size: 5242880 | 2022-12-07 14:37:32.098 Socket (1) | Connecting to IP: 142.215.18.107. | 2022-12-07 14:37:32.098 HD Request # 29 | Setting DTC encoding to Binary VLS | 2022-12-07 14:37:32.158 HD Request # 29 | Sending historical data logon request message. | 2022-12-07 14:37:32.158 HD Request # 29 | Requesting Intraday data. Start date-time: 2022-12-07 14:21:48. Record interval: 1. Symbol: ESZ22 | 2022-12-07 14:37:32.706 HD Request # 29 | Decompressing data. | 2022-12-07 14:37:32.733 HD Request # 29 | Receiving Intraday data for ESZ2.CME starting at 2022-12-07 14:21:48.095000 | 2022-12-07 14:37:32.795 Socket (1) | CloseSocket call. | 2022-12-07 14:37:32.799 Historical data download thread signaled to stop. | 2022-12-07 14:37:32.799 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-12-07 14:37:32.799 HD Request # 29 | Timestamp of first Intraday data file record written: 2022-12-07 14:21:48.095000. | 2022-12-07 14:37:32.800 HD Request # 29 | Received 903 Intraday data records from 2022-12-07 14:21:48.095000 to 2022-12-07 14:37:30.000000 (15.7 minutes) and wrote 903 records for ESZ2.CME | 2022-12-07 14:37:32.800 HD Request # 29 | Completion time: 0s. | 2022-12-07 14:37:32.801 HD Request # 29 | Intraday data download complete for ESZ2.CME. Unique request ID: 29 | 2022-12-07 14:37:32.801 Removing historical data download ID 29. | 2022-12-07 14:37:32.801 HD Request # 29 | Enabling Intraday chart updating for symbol. | 2022-12-07 14:37:32.801 Triggering next historical data download in queue. | 2022-12-07 14:37:32.801 Historical data for ESZ2.CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-12-07 14:37:32.801 No download requests in the queue to start downloads for. | 2022-12-07 14:37:32.801 Socket (1) | Socket gracefully closed by remote side. | 2022-12-07 14:37:32.823 Socket (1) | Closed. | 2022-12-07 14:37:32.823 Chart #8 has tagged chart #11 for full recalculation. Chartbook: ES.Cht | 2022-12-07 14:37:33.240 Chart #8 has tagged chart #13 for full recalculation. Chartbook: ES.Cht | 2022-12-07 14:37:33.240 Chart #8 has tagged chart #15 for full recalculation. Chartbook: ES.Cht | 2022-12-07 14:37:33.240 Chart #8 has tagged chart #3 for full recalculation. Chartbook: ES.Cht | 2022-12-07 14:37:33.240 Chart #8 has tagged chart #7 for full recalculation. Chartbook: ES.Cht | 2022-12-07 14:37:33.240 Chart #8 has tagged chart #9 for full recalculation. Chartbook: ES.Cht | 2022-12-07 14:37:33.240 ESZ2.CME [CV][M] 15 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: ES.Cht | 2022-12-07 14:37:33.404 ESZ2.CME [CV][M] 1 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: ES.Cht | 2022-12-07 14:37:33.425 ESZ2.CME [CV][M] 3000 Volume #11 | Performing a full recalculation because it has been tagged. Chartbook: ES.Cht | 2022-12-07 14:37:33.468 ESZ2.CME [CV][M] 1 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: ES.Cht | 2022-12-07 14:37:33.481 ESZ2.CME [CV][M] 5 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: ES.Cht | 2022-12-07 14:37:33.518 ESZ2.CME [CV][M] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: ES.Cht | 2022-12-07 14:37:33.545 Rithmic Direct - DTC | Using server connection: Apex-Chicago Area-Non-Aggregated | 2022-12-07 14:37:35.901 Rithmic Direct - DTC | Connecting to the server rsc.rithmic.com. Port 50528 | 2022-12-07 14:37:35.905 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-12-07 14:37:35.905 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-12-07 14:37:35.905 DTC Client socket (1) | Connecting to IP: 216.57.156.163. | 2022-12-07 14:37:35.905 Rithmic Direct - DTC | Network connection to server complete. | 2022-12-07 14:37:35.944 Rithmic Direct - DTC | Starting socket receive thread. | 2022-12-07 14:37:35.944 Rithmic Direct - DTC | Setting DTC encoding to Binary | 2022-12-07 14:37:35.944 Rithmic Direct - DTC | Sending logon request message. | 2022-12-07 14:37:35.944 Rithmic Direct - DTC | Received logon response. | 2022-12-07 14:37:36.043 Rithmic Direct - DTC | Server Name: . | 2022-12-07 14:37:36.043 Rithmic Direct - DTC | Server protocol version: 8. Client protocol version: 8 | 2022-12-07 14:37:36.043 Rithmic Direct - DTC | Successfully connected. | 2022-12-07 14:37:36.043 Rithmic Direct - DTC | Trading is supported. | 2022-12-07 14:37:36.043 Rithmic Direct - DTC | Order cancel and replace is supported. | 2022-12-07 14:37:36.043 Rithmic Direct - DTC | OCO Orders supported. | 2022-12-07 14:37:36.043 Rithmic Direct - DTC | Symbol and Exchange Delimiter: . | 2022-12-07 14:37:36.043 Rithmic Direct - DTC | Connected to server complete. | 2022-12-07 14:37:36.043 Triggering next historical data download in queue. | 2022-12-07 14:37:36.048 Triggering next historical data download in queue. | 2022-12-07 14:37:36.048 Triggering next historical data download in queue. | 2022-12-07 14:37:36.048 Triggering next historical data download in queue. | 2022-12-07 14:37:36.048 Updated verified funded futures trading account ending date to: 2023-01-06 14:37:36 | 2022-12-07 14:37:36.048 No download requests in the queue to start downloads for. | 2022-12-07 14:37:36.056 No download requests in the queue to start downloads for. | 2022-12-07 14:37:36.056 No download requests in the queue to start downloads for. | 2022-12-07 14:37:36.056 No download requests in the queue to start downloads for. | 2022-12-07 14:37:36.056 Updated verified funded futures trading account ending date to: 2023-01-06 14:37:36 | 2022-12-07 14:37:36.116 Mapping ESZ2.CME to ESZ22. Service code: cme | 2022-12-07 14:37:36.344 Using symbol data fast lookup vector | 2022-12-07 14:37:36.344 SC Data - All Services | Starting real-time market data updates for: ESZ2.CME (ESZ22). ID: 1 Service code: cme | 2022-12-07 14:37:36.344 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 10048 | 2022-12-07 14:37:36.344 SC Data - All Services | Requesting security definition data for: ESZ2.CME (ESZ22). ID: 1 | 2022-12-07 14:37:36.345 Added historical Intraday data request for ESZ2.CME to the queue. | 2022-12-07 14:37:36.345 Intraday data recording state for symbol ESZ2.CME is set to download 'Pending'. | 2022-12-07 14:37:36.345 Triggering next historical data download in queue. | 2022-12-07 14:37:36.345 DTC Client socket (2) | Creating socket. | 2022-12-07 14:37:36.346 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-12-07 14:37:36.346 DTC Client socket (2) | Connecting to IP: 216.1.90.129. | 2022-12-07 14:37:36.346 Delaying start of download for ESZ2.CME. | 2022-12-07 14:37:36.380 SC Data - All Services | Network connection to server complete. | 2022-12-07 14:37:36.380 SC Data - All Services | Starting socket receive thread. | 2022-12-07 14:37:36.380 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-12-07 14:37:36.380 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-12-07 14:37:36.462 SC Data - All Services | Sending logon request message. | 2022-12-07 14:37:36.462 SC Data - All Services | Received logon response. | 2022-12-07 14:37:37.270 SC Data - All Services | Server Name: RealTime Server. | 2022-12-07 14:37:37.270 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-12-07 14:37:37.270 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-12-07 14:37:37.270 SC Data - All Services | Waiting for socket receive thread to end | 2022-12-07 14:37:37.270 DTC Client socket (2) | CloseSocket call. | 2022-12-07 14:37:37.271 SC Data - All Services | Disconnected from the server. | 2022-12-07 14:37:37.271 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-12-07 14:37:37.271 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-12-07 14:37:37.272 DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-12-07 14:37:37.313 DTC Client socket (2) | Closed. | 2022-12-07 14:37:37.313 Requesting market depth updates for: ESZ2.CME if supported. | 2022-12-07 14:37:41.043 Separate subscription for market depth updates not supported. ESZ2.CME | 2022-12-07 14:37:41.043 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | Creating socket. Using TLS 1.2. | 2022-12-07 14:37:56.046 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | New receive buffer size: 32768 | 2022-12-07 14:37:56.046 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | Connecting to IP: 38.79.0.89. | 2022-12-07 14:37:56.046 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | Socket gracefully closed by remote side. | 2022-12-07 14:37:56.123 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | CloseSocket call. | 2022-12-07 14:37:56.124 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-12-07 14:37:56.124 HTTPS connection ID:4 to www.rithmic.com:443 for request ID:4 (2) | Closed. | 2022-12-07 14:37:56.124 HD Request # 30 | Downloading Intraday chart data for ESZ2.CME to the file ESZ2.CME.scid. Service: cme | 2022-12-07 14:38:07.214 HD Request # 30 | Download start date-time: 2022-12-07 14:37:30.000000. File last date-time: 2022-12-07 14:37:30.000000 | 2022-12-07 14:38:07.215 HD Request # 30 | Using server: ds21.sierracharts.com port 10149 | 2022-12-07 14:38:07.215 Socket (2) | Creating socket. | 2022-12-07 14:38:07.215 Socket (2) | New receive buffer size: 5242880 | 2022-12-07 14:38:07.215 Socket (2) | Connecting to IP: 216.1.90.129. | 2022-12-07 14:38:07.215 HD Request # 30 | Setting DTC encoding to Binary VLS | 2022-12-07 14:38:07.283 HD Request # 30 | Sending historical data logon request message. | 2022-12-07 14:38:07.283 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2022-12-07 14:38:07.438 DTC Client socket (3) | Creating socket. | 2022-12-07 14:38:07.438 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-12-07 14:38:07.438 DTC Client socket (3) | Connecting to IP: 142.215.18.103. | 2022-12-07 14:38:07.438 SC Data - All Services | Network connection to server complete. | 2022-12-07 14:38:07.476 SC Data - All Services | Starting socket receive thread. | 2022-12-07 14:38:07.476 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-12-07 14:38:07.476 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-12-07 14:38:07.566 SC Data - All Services | Sending logon request message. | 2022-12-07 14:38:07.566 HD Request # 30 | Requesting Intraday data. Start date-time: 2022-12-07 14:37:30. Record interval: 1. Symbol: ESZ22 | 2022-12-07 14:38:07.890 HD Request # 30 | Decompressing data. | 2022-12-07 14:38:08.013 HD Request # 30 | Receiving Intraday data for ESZ2.CME starting at 2022-12-07 14:37:30.000000 | 2022-12-07 14:38:08.014 Socket (2) | CloseSocket call. | 2022-12-07 14:38:08.014 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-12-07 14:38:08.014 Historical data download thread signaled to stop. | 2022-12-07 14:38:08.017 HD Request # 30 | Timestamp of first Intraday data file record written: 2022-12-07 14:37:30.000000. | 2022-12-07 14:38:08.017 HD Request # 30 | Received 35 Intraday data records from 2022-12-07 14:37:30.000000 to 2022-12-07 14:38:04.004000 (34.0 seconds) and wrote 35 records for ESZ2.CME | 2022-12-07 14:38:08.017 HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2022-12-07 14:38:04.004000 | 2022-12-07 14:38:08.017 HD Request # 30 | Completion time: 1s. | 2022-12-07 14:38:08.017 HD Request # 30 | Intraday data download complete for ESZ2.CME. Unique request ID: 30 | 2022-12-07 14:38:08.017 Removing historical data download ID 30. | 2022-12-07 14:38:08.017 Real-time Intraday chart data file updates started for ESZ2.CME | 2022-12-07 14:38:08.017 Opened cached Intraday file: C:\SierraChart\Data\ESZ2.CME.scid. Thread ID: 16800 | 2022-12-07 14:38:08.018 Intraday chart data file opened for ESZ2.CME | 2022-12-07 14:38:08.018 HD Request # 30 | Enabling Intraday chart updating for symbol. | 2022-12-07 14:38:08.018 Triggering next historical data download in queue. | 2022-12-07 14:38:08.018 No download requests in the queue to start downloads for. | 2022-12-07 14:38:08.018 Socket (2) | Socket gracefully closed by remote side. | 2022-12-07 14:38:08.081 Socket (2) | Closed. | 2022-12-07 14:38:08.081 SC Data - All Services | Received logon response. | 2022-12-07 14:38:08.292 SC Data - All Services | Server Name: RealTime Server. | 2022-12-07 14:38:08.292 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-12-07 14:38:08.292 SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2 | 2022-12-07 14:38:08.292 SC Data - All Services | Waiting for socket receive thread to end | 2022-12-07 14:38:08.292 DTC Client socket (3) | CloseSocket call. | 2022-12-07 14:38:08.292 SC Data - All Services | Disconnected from the server. | 2022-12-07 14:38:08.292 SC Data - All Services | Data feed disconnected. Will reconnect in 30 seconds. | 2022-12-07 14:38:08.292 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-12-07 14:38:08.292 DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-12-07 14:38:08.349 DTC Client socket (3) | Closed. | 2022-12-07 14:38:08.349 Chart #8 has tagged chart #11 for full recalculation. Chartbook: ES.Cht | 2022-12-07 14:38:08.446 Chart #8 has tagged chart #13 for full recalculation. Chartbook: ES.Cht | 2022-12-07 14:38:08.446 Chart #8 has tagged chart #15 for full recalculation. Chartbook: ES.Cht | 2022-12-07 14:38:08.446 Chart #8 has tagged chart #3 for full recalculation. Chartbook: ES.Cht | 2022-12-07 14:38:08.446 Chart #8 has tagged chart #7 for full recalculation. Chartbook: ES.Cht | 2022-12-07 14:38:08.446 Chart #8 has tagged chart #9 for full recalculation. Chartbook: ES.Cht | 2022-12-07 14:38:08.446 ESZ2.CME [CV][M] 15 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: ES.Cht | 2022-12-07 14:38:08.560 ESZ2.CME [CV][M] 1 Min #9 | Performing a full recalculation because it has been tagged. Chartbook: ES.Cht | 2022-12-07 14:38:08.578 ESZ2.CME [CV][M] 3000 Volume #11 | Performing a full recalculation because it has been tagged. Chartbook: ES.Cht | 2022-12-07 14:38:08.619 ESZ2.CME [CV][M] 1 Min #15 | Performing a full recalculation because it has been tagged. Chartbook: ES.Cht | 2022-12-07 14:38:08.887 ESZ2.CME [CV][M] 5 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: ES.Cht | 2022-12-07 14:38:08.924 ESZ2.CME [CV][M] 30 Min #13 | Performing a full recalculation because it has been tagged. Chartbook: ES.Cht | 2022-12-07 14:38:08.949 SC Data - All Services | Connecting to the server ds13.sierracharts.com. Port 10048 | 2022-12-07 14:38:38.304 DTC Client socket (2) | Creating socket. | 2022-12-07 14:38:38.305 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-12-07 14:38:38.305 DTC Client socket (2) | Connecting to IP: 162.251.232.237. | 2022-12-07 14:38:38.305 SC Data - All Services | Network connection to server complete. | 2022-12-07 14:38:38.379 SC Data - All Services | Starting socket receive thread. | 2022-12-07 14:38:38.379 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-12-07 14:38:38.379 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-12-07 14:38:38.462 SC Data - All Services | Sending logon request message. | 2022-12-07 14:38:38.462 SC Data - All Services | Received logon response. | 2022-12-07 14:38:38.539 SC Data - All Services | Server Name: RealTime Server. | 2022-12-07 14:38:38.539 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-12-07 14:38:38.539 SC Data - All Services | Logon error received from server: Data service (sc_exchange2.datafeed) is disabled or unsupported. A software update may be necessary. | 2022-12-07 14:38:38.539 SC Data - All Services | Waiting for socket receive thread to end | 2022-12-07 14:38:38.539 DTC Client socket (2) | CloseSocket call. | 2022-12-07 14:38:38.540 SC Data - All Services | Disconnected from the server. | 2022-12-07 14:38:38.540 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-12-07 14:38:38.540 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-12-07 14:38:38.540 DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-12-07 14:38:38.610 DTC Client socket (2) | Closed. | 2022-12-07 14:38:38.610 SC Data - All Services | Connecting to the server ds28.sierracharts.com. Port 443 | 2022-12-07 14:38:40.554 DTC Client socket (2) | Creating socket. | 2022-12-07 14:38:40.993 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-12-07 14:38:40.993 DTC Client socket (2) | Connecting to IP: 142.215.18.126. | 2022-12-07 14:38:40.993 DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond. | 2022-12-07 14:39:02.025 * DTC Client socket (2) | CloseSocket call. | 2022-12-07 14:39:02.025 DTC Client socket (0) | CloseSocket call. | 2022-12-07 14:39:02.025 SC Data - All Services | Disconnected from the server. | 2022-12-07 14:39:02.025 DTC Client socket (2) | Closed. | 2022-12-07 14:39:02.025 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-12-07 14:39:02.025 SC Data - All Services | Connecting to the server ds28-2.sierracharts.com. Port 443 | 2022-12-07 14:39:04.041 DTC Client socket (2) | Creating socket. | 2022-12-07 14:39:04.463 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-12-07 14:39:04.463 DTC Client socket (2) | Connecting to IP: 142.215.18.125. | 2022-12-07 14:39:04.463 |
[2022-12-07 15:03:20] |
Also just a follow up information. I rebooted the system, the issue persists at my home, work or any other place. The firewall does not seem like an issue since it has been almost a year and nothing has changed for it to suddenly stop the connection. Hopefully this helps. I have uninstalled and installed the software couple of time since last night. Regards, |
[2022-12-07 17:44:33] |
The main issue is the following from your log: SC Data - All Services | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
You are connected to the Denali feed from more than 1 computer. The exchanges do not allow this unless you pay an additional exchange fee to allow 2 systems to connect at the same time. Refer to the following: Denali Exchange Data Feed: Denali Exchange Data Feed on Two Computers Simultaneously You do also have the following: DTC Client socket (2) | Connect event error. Windows error code 10060: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
But this could have been just a one time incident where there was a routing issue. But, refer to the following regarding this error: Data/Trading Service Connection and Symbol Issues: 1.2. Network Communication or Server Problem -- Finally - note that you do not need to reinstall Sierra Chart for any issue. Just wait until we can get you the answer through this support board. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
