Date/Time: Thu, 25 Apr 2024 09:53:33 +0000
Spreadsheet programming question
View Count: 319
[2022-11-26 03:57:17] |
User183724 - Posts: 183 |
using Spread Sheet Study How do I plot 0 (zero) on a study in Chart Region 2? Ive got two lines ... one column K and one in column L. Ive tried putting a '0' in column M but it's not generating a line at 0 (zero) on the chart. thanks |
[2022-11-26 13:52:50] |
Sawtooth - Posts: 3976 |
Use a value close to zero, like 0.0000000001
[2022-11-26 15:33:04] |
Sierra_Chart Engineering - Posts: 14076 |
The technically correct way to do this, is to set this Input to Yes: Spreadsheet Study Inputs: Draw Zero Values Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-26 17:07:08] |
thank you both... while I always try to be technically correct, the "Draw Zero Values" appears to affect the entire study and sometimes I don't want to plot zeros in all of the other lines so tomgilb's way works better for me this time. Thanks again
