Date/Time: Fri, 29 Mar 2024 05:43:07 +0000
E-MINI S&P500
View Count: 325
[2022-11-23 15:10:53] |
pegssfx - Posts: 15 |
Hi i have an "error", Is it normal that it takes so long to load the data? it's been like this for half an hour. (look the pictures) |
Private File |
[2022-11-23 16:55:35] |
John - SC Support - Posts: 30444 |
It can take this long, depending on how much data you are trying to download. How much intraday data are you trying to access?
[2022-11-24 11:31:35] |
it's my first time trying to load data on this asset.
[2022-11-24 15:45:27] |
Sierra_Chart Engineering - Posts: 13625 |
To improve performance, refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Improving Historical Intraday Data Downloading Performance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
