Date/Time: Fri, 29 Mar 2024 10:09:01 +0000
Watchlist from file
View Count: 327
[2022-11-23 13:50:18] |
User361939 - Posts: 158 |
Hello, I have EOD data with tickers. I scan them o daily basis so i get 10-20 stocks to check. I want to create "Watchlist" from my scan so i can check charts in sierrachart. Is is possible to create "text" file witch i will past into sierrachat folder so sierra will interpret it as a watchlist so i can check chart in platform? Best Regards |
[2022-11-23 16:17:29] |
John - SC Support - Posts: 30444 |
Yes, you can do this. Refer to the following information on the Associated Watchlist and note the subsection for "Importing a list of Symbols" within it: Changing the Symbol of a Chart: Using the Associated Watch List For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-24 12:33:43] |
Thank you. I wam looking further into this and still cannot work with this. I will show my steps: I download historical EOD data for stock AIRWAY in TXT file and file is in Sierrachart/DATA folder. I create watchlist test.SymbolList. Inside file is only string AIRWAY I put this file in DATA FOLDER I import list from associated watchlist I mark field "Watch List mode" I click on text "AIRWAY" I got msg "Invalid symbol name" I noticed that in DATA folder has been creted file AIRWAY.dly How can I "direct" symbol name to TXT file? |
[2022-11-24 15:43:04] |
Sierra_Chart Engineering - Posts: 13625 |
You need to save your own historical daily data with a dly extension. Do not use TXT. Refer to: Text/CSV Data Format Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
