Date/Time: Thu, 25 Apr 2024 07:31:00 +0000
Can I buy Your Datafeeds and use them in Agenatrader.
View Count: 340
[2022-11-23 07:40:34] |
User408639 - Posts: 59 |
Moin Moin. I still have agenatrader, but want to switch over to Sierra for volumentrading (As I have been booking the g7fx-course). Of course I can use a data-feed-subscription only from one station at a time. My question is, whether I can buy a feed's license here, and, see what SC and AT are doing upon switching over, and, then, somehow learn to build my own Trading-strategy-"buttons" (If You have a tutorial for this, hinting me at it, would be great.). _Tschüß, __Michael. |
[2022-11-23 15:47:07] |
John - SC Support - Posts: 31098 |
The Sierra Chart data feeds are not available for use with any other system. They only work with Sierra Chart. In terms of trading-strategy "buttons", there are a few options depending on what you want to do. First, refer to the general Control Bar button options for Trading: Control Bar: Customize Control Bars >> Control Bar 1-8 (Global Settings) And then if you are wanting to create a custom trading program that can use various control bar buttons, then start with the information on our interface named "ACSIL" at the following: Advanced Custom Study Interface and Language (ACSIL): Introduction For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
