Date/Time: Sat, 20 Apr 2024 07:54:59 +0000
VBP Formula
View Count: 259
[2022-11-22 14:28:14] |
Ben A - Posts: 123 |
Hi, Is there any way that I can use formula against VBP in say the spreadsheet formula study? I want to work out the average price of all VBP above a certain threshold, for example all instances where VBP>1000. Thanks you, |
[2022-11-22 17:50:53] |
John - SC Support - Posts: 30976 |
There is a way to do this, but you will have to work with relatively raw volume data. On the Spreadsheet Study there is an option for Output Volume at Price Data. Set this to Yes to get the Volume at Price data for each bar in the chart. You can then sift through this data to get what you are wanting. Refer to the information here: Spreadsheet Study Inputs: Output Volume at Price Data For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
