Date/Time: Fri, 19 Apr 2024 10:02:11 +0000
Edit >> Translate Symbol to Current Service match not found
View Count: 294
[2022-11-21 17:46:04] |
bradh - Posts: 853 |
I received a chartbook with the symbol GBL-202212-EUREX and it does not get translated to FGBLZ22-EUREX. I am not sure which broker the chartbook symbol is from.
[2022-11-22 01:24:52] |
Sierra_Chart Engineering - Posts: 14006 |
We will check on this.
[2022-11-22 02:38:10] |
This is resolved. The patterns for translation still used -DTB. This has been updated to EUREX now. Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-11-22 02:38:44
