Date/Time: Sat, 20 Apr 2024 02:42:55 +0000
USDOLLAR via FXCM
View Count: 344
[2022-11-21 13:09:50] |
Barry L - Posts: 33 |
Is there a problem with this quote for the Dollar Index ? , I haven't been able to get anything since 5 pm EST on Friday, Worked fine all last week for Sunday Globex open
[2022-11-21 13:51:19] |
User133389 - Posts: 5 |
I also am not receiving data for this symbol "USDOLLAR" at any time that I check from last Friday to now.
[2022-11-21 14:19:13] |
It just started working again
[2022-11-21 14:27:13] |
Sierra_Chart Engineering - Posts: 14016 |
This was a problem all along with FXCM.
[2022-11-21 15:52:09] |
For at least the last six months I have watching the "USDOLLAR" using a chart set to update on the scale of seconds. Over this time, on average, these "USDOLLAR" data have been updating on a frequency of about 12 times a minute. Since the data feed for the "USDOLLAR" has been restored this morning the updates are coming in at exactly one time per minute. Is this a revised frequency for these data or is it an error in the data distribution?
[2022-11-21 15:55:34] |
[2022-11-21 16:20:52] |
We do not know what the problem is. All we can say is FXCM is not sending data for this symbol. You should be using the symbol USDX instead anyway. Refer to: Sierra Chart Market Statistics Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-22 04:13:24] |
Thanks for informing us about that USDX symbol, I didn't know about that one . Switched and its working fine, I use it in a correlation study. I did see the same as 133389 did when the USDOLLAR came back on, it was a far slower update , But doesn't matter now anyway |
