Date/Time: Wed, 24 Apr 2024 04:42:52 +0000
Small question
View Count: 252
[2022-11-20 20:29:31] |
OriolCasas - Posts: 155 |
Hello, Small question, what does the button on the square bottom on the right mean? Connected to live data? Is there an explanation on the help board? Attached picture of it. Thank you |
Attachment Deleted. SMALL QUESTION SIERRA.png / V - Attached On 2022-11-20 20:29:11 UTC - Size: 148.05 KB - 55 views |
[2022-11-20 21:47:36] |
User585104 - Posts: 114 |
Working With Charts: Chart Settings Indicators at Lower Right of Chart
[2022-11-21 15:27:34] |
Sierra_Chart Engineering - Posts: 14068 |
This is explained here: https://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#LRChartSettingsIndicators Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
