Date/Time: Wed, 24 Apr 2024 07:45:50 +0000
study alerts
View Count: 277
[2022-11-18 17:08:49] |
rondawes - Posts: 39 |
OK, I know the info is somewhere in the support wiki but I cannot find how to set up an alert on a study. I've tried but I'm not using proper syntax according to the alert log. Please point me to the proper section. Thanks.
[2022-11-18 17:54:14] |
John - SC Support - Posts: 31059 |
The general information on Alerts is the following page: Study/Chart Alerts And Scanning For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-11-18 20:35:12] |
Thanks John. It does not look like its possible to trigger two different alert sounds from one study, i.e. =if SG1 >250 then alert sound 1, =if SG2 <-250 then alert sound 2. I can do it by duplicating the study but was wondering if there was a more efficient way.
[2022-11-18 21:46:42] |
You need to do what you have stated - you would have to enter the second Alert condition somewhere else - either a duplicate study, or on the Chart Settings (there is an Alert section on the Chart Settings that you can use) in order to get two different alert sounds.
