Date/Time: Sat, 11 Jul 2026 05:12:51 +0000
Using Sierra Chart on multiple computers
View Count: 6293
| [2025-12-08 00:09:56] |
| lion323 - Posts: 69 |
So don’t have to pay on my other computer
| [2025-12-08 00:36:13] |
| Sierra_Chart Engineering - Posts: 24233 |
No.
| [2025-12-08 03:34:59] |
When am connected to my broker and using simulation mode am getting real time data ? But still trading on the sim
| [2025-12-08 14:42:19] |
Yes, you should be getting real-time data. Have a look at the Data Delay (DD:) indicator on the chart header: Working With Charts: Region Data Line / Chart Header Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-18 21:50:39] |
How can I see the codes of sierra chart studies the same way its viewed on ninja trader and trading view Is it possible to see the code of studies on sierra chart if possible please guide me And I assume it’s all coded in C++ ? |
| [2025-12-18 22:25:13] |
| John - SC Support - Posts: 47144 |
What code is available (which is most, but not all, of the studies we have) is in the "ACS_Source" folder under your main Sierra Chart installation folder. Refer to the following: How to Build an Advanced Custom Study from Source Code: Searching for Source Code for Sierra Chart Built-In Studies And yes, all the code is in C++. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-19 11:06:28] |
How can I see the math in the codes It feels like built in Is there a way to see the code in its full manual form ? |
| [2025-12-19 21:01:56] |
If you go through the Technical Studies Reference, the mathematics for most of the studies is provided: Technical Studies Reference Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-12-19 21:36:57] |
Thanks One last question what kind of math is used in these studies how can I know what’s is calculating and where can I learn about it ? |
| [2025-12-19 21:53:47] |
We cannot provide any further help other than what we gave in post 32.
