Date/Time: Fri, 19 Apr 2024 07:43:38 +0000
Cannot add same study twice.
View Count: 986
[2014-05-20 06:36:18] |
User26994 - Posts: 32 |
I am trying to add a CCI study to a chart twice as I require two different length values. I've been to Help - Chart Studies Windows and read the following : Add Adds the selected study in the Studies Available list box to the Studies To Graph list box. If you wish to add the same study more than once, then press the Add button twice. Unfortunately when I press Add twice, then apply and ok it only appears once. Is there anything else I can do ? |
[2014-05-20 07:56:26] |
Do you see the study you added twice listed twice in the Studies to Graph list in the Chart >> Chart Studies window? Have you set it to display in a different Chart Region from the other study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-20 08:08:18] |
Do you see the study you added twice listed twice in the Studies to Graph list in the Chart >> Chart Studies window? ... Yes. Have you set it to display in a different Chart Region from the other study. I have now and it has solved my problem. Many thanks. |
