Date/Time: Thu, 28 Mar 2024 15:43:28 +0000
Space near right margin ONLY if chart at the end (latest quotes) position, in other time - no
View Count: 977
[2014-05-20 06:33:55] |
User79347 - Posts: 23 |
Hello! Is it possible? If yes, how can i do that? It's Metarader, Metastock tradition with right margin space... Thank you very much! |
[2014-05-20 06:51:30] |
This is not exactly supported. You can add space to the right side of the chart. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_WorkingWithCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-05-20 07:01:44] |
Thank you very much for FASTEST reply! I hope, may be a some indicators can do that... Just... with space, i am always know (yes, i know about red|green indicator) - where i am - at tne end, or not the end.. Date Time Of Last Edit: 2014-05-20 07:02:11
