Date/Time: Thu, 25 Apr 2024 05:34:21 +0000
EUREX DATA
View Count: 696
[2022-10-03 15:06:07] |
User613910 - Posts: 45 |
Hi, I ordered EUREX data through CQG today....now I hear this is not possible anymore..... I am a customer of AMP....and payed for this data today. Now I hear Sierra has disconnected this way last Friday. I could I know?? When I take the Denali DaTA can I route the orders through AMP brokers? and How?? Best regards, Anita |
[2022-10-03 16:58:49] |
Sierra_Chart Engineering - Posts: 14076 |
The EUREX data needs to come from our Denali Data Feed. You need to complete the agreements, and activate the EUREX exchange here: https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation#DenaliEUREX Yes: When I take the Denali DaTA can I route the orders through AMP brokers?
Refer to: Real-Time Exchange Data Feeds Available From Sierra Chart: Integration with Trading Services Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-03 16:59:10
[2022-10-03 22:17:12] |
Hi, Thanks for your answer. On the website I see there is a lot about the fact CQG is not a good choice for orderrouting, better choice is teton but can you give me a broker that deliver Teton orderrouting for CME and EUREX?? I din't find one yet. Already thanks for your answer, Anita |
[2022-10-04 07:33:39] |
Teton order routing does not support EUREX. So in this case you would need to use CQG for EUREX and use Teton for CME. All of the brokers listed at step 2 here, will support both Teton order routing and CQG: Sierra Chart Teton Futures Order Routing: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
