Date/Time: Fri, 29 Mar 2024 14:11:32 +0000
Apex Funding Connection Using Sierra Charts
View Count: 2263
[2022-10-03 11:46:19] |
User103847 - Posts: 4 |
Good Afternoon Im looking to take the Apex funding challenge that works with Rithmic Connection Im looking to use my Sierra Charts package 11 with the Denali Data Service, with my Amp Broker, and connecting it to Rithmic. It looks possible to me as Apex gives you the Login to Rithmic. I just want to check where I would get the Username and Passwords for the Denali Data Service and Historical data service as Sierra Charts asks for that too. Kind Regards |
[2022-10-03 12:38:03] |
Sierra_Chart Engineering - Posts: 13625 |
You will want to have two installations of Sierra Chart. One to use with AMP and one with Rithmic. Refer to: Using Multiple Data and Trading Services at the Same Time These do not exist and are not needed: I just want to check where I would get the Username and Passwords for the Denali Data Service and Historical data service as Sierra Charts asks for that too. There is no place these would be entered . You only just log into Sierra Chart with your Sierra Chart username and password. This is all. In the case of when using Rithmic, and you are using the Denali data feed for data, the Rithmic username and password settings for market data and historical data need to be left blank. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-10-03 12:38:39
[2022-10-03 15:34:38] |
Thanks for the reply Just to check, My Personal account is, My Sierra Charts linked to Amp with the Denali data service and is running Off CQG order routing. This allows me to switch between my real account and the sim. Now If I use Rithmic with APEX Funding and I connect to it, won't that just be Sierra Charts with Denali Data running off Rithmic. This means I can just use one installation of Sierra Charts. Have I got that right? Kind Regards |
[2022-10-03 17:48:23] |
John - SC Support - Posts: 30451 |
You want to have two installations in order to not keep switching between your trading services and possibly creating an issue with missing a trade. In one case, you will have Sierra Chart setup to connect to CQG and in the other you will have Sierra Chart connected to Rithmic. In both installations you will have the Denali data (there is no issue with this as long as both installations are on the same system). Refer to the following for how to install a second Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
