Date/Time: Thu, 28 Mar 2024 09:37:39 +0000
Lines connection
View Count: 253
[2022-10-03 07:09:44] |
Gabor Maly - Posts: 11 |
Dear SC, My question is best illustrated by the screenshot attached. IS there any way to remove the connection line (the red line) between different market generated information like VPOC in this example from one session to the next. I could not find any setting to do this and occasionally this is very disturbing, the line also serves no purpose. This does serve a purpose within a session but not outside of it. Thanks, Regards, |
ConnectLines.png / V - Attached On 2022-10-03 07:07:37 UTC - Size: 93.89 KB - 59 views |
[2022-10-03 16:01:02] |
John - SC Support - Posts: 30399 |
On the particular study (like the Volume by Price) go to the Subgraphs and change the Draw Style to Dash for the particular item you want to change. Refer to the following: Chart Studies: Subgraphs Tab >> Draw Style For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
