Date/Time: Thu, 25 Apr 2024 02:17:41 +0000
Renko brick counter & alarm
View Count: 226
[2022-09-30 16:53:39] |
User305655 - Posts: 2 |
Is there a way set up a brick count (green & red)on the recko chart and possibly send an alarm if certain counts are triggered? Thanks in advance |
[2022-09-30 18:15:40] |
John - SC Support - Posts: 31098 |
You would just need to setup an Alert using the appropriate values. Refer to the following for how to access the Renko Open and Close for an alert: Renko Bar Charts: Renko Open, High, Low, Close Values And refer to the information on the Alerts page for how to setup an alert. In particular, it sounds like you will want to take the Renko High minus the Renko Low and then divide that by the tick size to get your brick count. Study/Chart Alerts And Scanning For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
