Date/Time: Thu, 28 Mar 2024 22:21:05 +0000
Consolidated volume for NASDAQ NQTV?
View Count: 301
[2022-09-29 07:01:29] |
User655271 - Posts: 1 |
Hi, do you have any updates on the Nasdaq NQTV volumes? I'm using CQG with AMP for futures and would like to add the real time NASDAQ. I started using the NQTV delayed and noticed the low volumes issue. I have read the related documentation on it and if I understood this issue isn't resolved yet. Can you comment on this please? Thank you and Regards, Akos |
[2022-09-30 08:51:29] |
Sierra_Chart Engineering - Posts: 13610 |
The NASDAQ TotalView volume data you see is correct. We are still working on offering a full consolidated tape data feed. But that will not be ready until later in the year. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
