Date/Time: Thu, 28 Mar 2024 19:21:27 +0000
Marker config default options not working
View Count: 194
[2022-09-28 10:15:51] |
User251043 - Posts: 42 |
Hi, I'm trying to work with the marker tool. I want to have the config of the attached picture. In As you can see, I placed vertical align: Center. I save the config, I apply it. I do that on Tools -> Tools config. I also tried to do that with the marker tool selected and then tools -> current tool config. On the very moment I try to draw a marker, the program draws it with top vertical align, as the one drawn in the attached file. I don't know what else to do to make the default vertical align center and not top. If I go to a specific marker and I change it to center, there's no problem, but I need to draw it and change the configuration item by item, and I don't have the time to do that while trading live. Is there anything I'm missing? Regards |
marker config.png / V - Attached On 2022-09-28 10:10:00 UTC - Size: 32.61 KB - 56 views |
