Date/Time: Fri, 27 Jan 2023 15:41:05 +0000
How to copy a chart from one chartbook to another on a different PC?
View Count: 90
[2022-09-28 03:23:55] |
TraderTen - Posts: 80 |
I used to do these maneuvers yeas ago with no trouble. Now they don't seem to work. Suggestions?
[2022-09-28 14:25:45] |
John - SC Support - Posts: 21711 |
The information to copy files between systems is at the following link. For just the Chartbooks, you would only need to copy the .cht files: Transferring Sierra_Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra_Chart Settings and Data From Existing Installation to New Installation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
