Date/Time: Fri, 27 Jan 2023 14:44:54 +0000
Study Angle
View Count: 227
[2022-09-27 02:18:02] |
User841161 - Posts: 152 |
How is Downtrend Angle(Study Angle) Positive degrees. Down sloping Lines are supposed to be negative degrees.
![]() Attachment Deleted. |
[2022-09-27 10:07:20] |
Sierra_Chart Engineering - Posts: 6328 |
Provide an image of the chart showing this, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-28 13:49:33] |
Here you go. https://www.sierrachart.com/image.php?Image=1664372916817.png |
