Date/Time: Fri, 27 Jan 2023 14:58:47 +0000
2nd laptop for Sim trading
View Count: 94
[2022-09-26 15:59:32] |
aroymukherjee - Posts: 10 |
Can I confirm that my Sierra license allows a 2nd laptop for Sim trading (I am using the first one live for IB). I chose SC Data - All Services for the Sim trading - even I expect 10 mins delayed data for this I am noticing a static data point (price does not change over several bars). How can I fix this problem?
[2022-09-26 16:31:39] |
John - SC Support - Posts: 21711 |
Your account allows for the Sierra Chart software to be running on up to 3 computers at the same time. So there is not an issue with this. As you note, the data feed is different, and unless you pay for the additional connection, you can only get real-time data to one system at a time. If you want to have real-time data on one system and the delayed streaming data on another, then you need to set the option for Global Settings >> Data/Trade Service Settings >> Common Settings >> Allow Support For Sierra Chart Data Feeds to No on the system for which you want the delayed streaming data. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
