Date/Time: Fri, 27 Jan 2023 14:47:37 +0000
Crypto tick data for backtesting
View Count: 207
[2022-09-15 16:27:05] |
Grischa - Posts: 1 |
Dear CustomerSupport, I am running on a trial version tight now and trying to get 3 questions answered that I could not get answered elsewhere: 1: Can I get "historic tick data" for Crypto assets displayed in RENKO on my trial or do I need to subscribe to a data feed (if so which one?) I was now able to activate it unless I overlooked something. 2: Please note as a Mac user I have come across the app "Crossover/ Codeweavers" since I could not get Parallels to work with Sierra, which leads me to my second question: does this cause limitations to the functionality in Sierra? if so which ones since I am hoping to avoid having to buy a PC just for using Sierra. 3: lastly I plan backtesting with specific Renko chart set ups. Is that possible within Sierra and if so which service package is required for subscription in order to get tick data on Crypto displayed in Renko charts? if thats not possible to backtest within Sierra could you kindly recommend a third party vendor that works with Sierra? As a new user I am not very familiar with Sierra so please forgive me for the questions but I would like to get a clear picture to what's possible and how before I commit to in depth learning and expenditure into the windows eco system and your otherwise great charting program. thank you and looking forward to hearing from you Grischa Ruschendorf |
[2022-09-25 22:44:23] |
Sierra_Chart Engineering - Posts: 6328 |
We apologize for the delay. We will get all of this answered today.
[2022-09-26 07:18:16] |
1. Yes you can do this on the trial. Refer to: Renko Bar Charts And: Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration 2. No limitations but you could have technical problems when not using Windows. 3. You can do back testing. Refer to: Replaying Charts And: Auto Trade System Back Testing The historical data for crypto currencies is in one second units and it is not tick by tick but all trades are included. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-09-26 07:18:34
