Date/Time: Thu, 20 Aug 2026 00:23:53 +0000
Histogram for Bid/Ask columns?
View Count: 2149
| [2014-05-15 16:19:20] |
| User14266 - Posts: 225 |
Is it possible to have a histogram on the bid/ask columns? I can not figure out how to do this. Is this an option? See example: http://screencast.com/t/EYMWmAha
| [2014-05-15 16:28:27] |
It is not possible to add volume bars to the Bid and Ask market depth rows.
| [2014-05-15 16:30:12] |
Thank you. Could I make the request that this feature be added? Most platforms offer this, and I think it's a helpful feature. With a histogram, it's much easier to visually see the levels at a glance. Thank you for the consideration. |
| [2014-05-15 16:42:07] |
We will look into this.
| [2014-09-25 22:05:02] |
Just a friendly bump! This is the only feature missing from the amazing SC DOM! And if I was dreaming, I would also have the ability to adjust the width of bid/ask columns :) |
| [2014-09-25 22:19:32] |
This was added a while ago. This can be set through Global Settings >> Chart DOM Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-25 22:19:50
| [2014-09-25 23:28:36] |
So it was. And it works great. Much appreciated. There is only one adjustment missing now(or maybe this exists too?); the ability to align volume bars on right or left side of the column. This would be perfect. Sierra Chart DOM > every other DOM. Ever. Bravo. |
