Date/Time: Fri, 27 Jan 2023 15:25:30 +0000
Denali + EUREX
View Count: 191
[2022-08-30 19:38:52] |
ycomp - Posts: 274 |
to get a sierra data feed for EUREX (I'm interested in FGBL) does it require you to login with a broker account each month, like is required for CME futures on the sierra data feeds? and also do you pay all fees 30 days after you first set it up? or at the start of the month? |
[2022-08-30 20:22:14] |
John - SC Support - Posts: 21711 |
EUREX does not have the requirement to have to have a broker account. That is just a CME Group requirement. The exchange fees are due on the first day of each month. Therefore, you would not want to activate the exchange today (August 30) as you would pay the full amount for the exchange for the remainder of today and tomorrow. You would then pay the full price again for the data through September. Follow through the instructions at the following link to setup the EUREX data: Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges* For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-09-02 11:10:53] |
does "setting the # of systems" to 1 or 2 make a difference price-wise?
[2022-09-02 11:36:00] |
Sierra_Chart Engineering - Posts: 6328 |
Yes you then pay the exchange fees twice if you set the number of systems to 2.
[2022-09-25 17:33:47] |
if i click deactivate a week before the displayed ending date, will it still work until the ending date?
[2022-09-26 10:14:24] |
Yes this is the case.
