Date/Time: Thu, 28 Mar 2024 20:35:15 +0000
[Locked] - Required Update for CQG Users who are Using Sierra Chart Versions 2290 and Earlier
View Count: 1317
[2022-08-06 17:22:40] |
Sierra_Chart Engineering - Posts: 13610 |
If you are using CQG with Sierra Chart and you are running version 2290 or earlier you need to update, to any version after that, before August 20, 2022 at the latest. Version 2290 was released on July 23, 2021. You do not have to run version 2394 or later which do not support CQG data for CME or EUREX. You can run any version from 2291 through 2393. Or if you want to run version 2394 to the present that is fine as well. So you have a very wide range of versions to pick from. This update is required for technical compatibility reasons. Update instructions: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-08-06 17:24:40
