Date/Time: Thu, 25 Apr 2024 17:37:48 +0000
Message Log Error Messages
View Count: 485
[2022-08-03 01:53:48] |
Nomad786 - Posts: 16 |
I am continuously seeing following logs, Can you check it out and let me know what is causing it. Triggering next historical data download in queue. | 2022-08-03 00:13:43.487 No download requests in the queue to start downloads for. | 2022-08-03 00:13:43.487 Socket (5) | Socket gracefully closed by remote side. | 2022-08-03 00:13:43.543 Socket (5) | Closed. | 2022-08-03 00:13:43.543 SC Data - All Services | Real-time data for symbol AAPL-NQTV is currently unavailable. | 2022-08-03 01:27:32.010 SC Data - All Services | Real-time data for symbol AAPL-NQTV is currently unavailable. | 2022-08-03 01:27:33.414 SC Data - All Services | Real-time data for symbol AAPL-NQTV is currently unavailable. | 2022-08-03 01:31:34.140 SC Data - All Services | Real-time data for symbol AAPL-NQTV is currently unavailable. | 2022-08-03 01:31:35.536 The message log has been sent to support. | 2022-08-03 01:50:51.307 * HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (5) | Creating socket. Using TLS 1.2. | 2022-08-03 01:50:51.307 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (5) | New receive buffer size: 32768 | 2022-08-03 01:50:51.307 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (5) | Connecting to IP: 95.216.233.104. | 2022-08-03 01:50:51.307 Sending of the Message Log is completed. The response was saved to C:\SierraChart\Data\MessageLogAnalysis.htm | 2022-08-03 01:50:52.773 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (5) | CloseSocket call. | 2022-08-03 01:50:53.034 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (5) | Shutdown started. Waiting for graceful close. | 2022-08-03 01:50:53.034 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (5) | Socket gracefully closed by remote side. | 2022-08-03 01:50:53.200 HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (5) | Closed. | 2022-08-03 01:50:53.200 |
[2022-08-03 01:54:28] |
Triggering next historical data download in queue. | 2022-08-03 00:13:42.670 Initiating new historical data download for XAUUSD to get the latest data since the download was started while not connected to primary service. | 2022-08-03 00:13:42.670 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-03 00:13:42.670 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-03 00:13:42.670 HD Request # 31 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-03 00:13:42.670 HD Request # 31 | Download start date-time: 2022-08-03 00:13:43.000000. File last date-time: 2022-08-03 00:13:43.197000 | 2022-08-03 00:13:42.670 HD Request # 31 | Using server: ds12.sierracharts.com port 10149 | 2022-08-03 00:13:42.670 Socket (5) | Creating socket. | 2022-08-03 00:13:42.670 Socket (5) | New receive buffer size: 5242880 | 2022-08-03 00:13:42.670 Socket (5) | Connecting to IP: 204.15.197.14. | 2022-08-03 00:13:42.670 Socket (6) | Socket gracefully closed by remote side. | 2022-08-03 00:13:42.722 Socket (6) | Closed. | 2022-08-03 00:13:42.722 HD Request # 31 | Setting DTC encoding to Binary VLS | 2022-08-03 00:13:42.818 HD Request # 31 | Sending historical data logon request message. | 2022-08-03 00:13:42.818 HD Request # 31 | Requesting Intraday data. Start date-time: 2022-08-03 00:13:43. Record interval: 1. Symbol: XAUUSD | 2022-08-03 00:13:43.408 HD Request # 31 | Decompressing data. | 2022-08-03 00:13:43.478 HD Request # 31 | Receiving Intraday data for XAUUSD starting at 2022-08-03 00:13:43.197000 | 2022-08-03 00:13:43.478 Socket (5) | CloseSocket call. | 2022-08-03 00:13:43.479 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-03 00:13:43.479 Historical data download thread signaled to stop. | 2022-08-03 00:13:43.479 HD Request # 31 | Timestamp of first Intraday data file record written: 2022-08-03 00:13:43.197000. | 2022-08-03 00:13:43.479 HD Request # 31 | Received 1 Intraday data record from 2022-08-03 00:13:43.197000 to 2022-08-03 00:13:43.197000 (0.0 seconds) and wrote 1 record for XAUUSD | 2022-08-03 00:13:43.479 HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2022-08-03 00:13:43.197000 | 2022-08-03 00:13:43.483 Added 1 Time and Sales records to Intraday data file for XAUUSD after download. | 2022-08-03 00:13:43.483 HD Request # 31 | Completion time: 1s. | 2022-08-03 00:13:43.483 HD Request # 31 | Intraday data download complete for XAUUSD. Unique request ID: 31 | 2022-08-03 00:13:43.483 Removing historical data download ID 31. | 2022-08-03 00:13:43.483 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-03 00:13:43.483 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 5248 | 2022-08-03 00:13:43.487 Intraday chart data file opened for XAUUSD | 2022-08-03 00:13:43.487 HD Request # 31 | Enabling Intraday chart updating for symbol. | 2022-08-03 00:13:43.487 |
[2022-08-03 02:19:51] |
Sierra_Chart Engineering - Posts: 14088 |
There is insufficient information here for us to answer the question because these are partial message logs and we do not know what error message you are referring to.
[2022-08-03 03:04:31] |
What do you need, How do I send you entire log?
[2022-08-03 15:12:48] |
John - SC Support - Posts: 31113 |
The first thing you need to do is to select Edit >> Translate Symbols to Current Service. There are a few symbols that are not correct the current service you are using. The next thing is that you need to update the symbol for TSLA, as you need to add the "-NQTV" suffix. So it should be "TSLA-NQTV", like you have for AAPL. With regards to the message about real-time data not available for AAPL-NQTV, we believe this is related to the following messages in your log: DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
Refer to the information here: https://www.sierrachart.com/index.php?page=doc/helpdetails1.php#NetworkCommunicationOrServerProblem For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-08-05 22:38:03] |
I am still getting following messages Reading Internal Order ID file. | 2022-08-05 14:10:39.409 Reading Trade Orders file. | 2022-08-05 14:10:39.484 Reading Trade Positions file. | 2022-08-05 14:10:39.488 Reading Trade Account Data files. | 2022-08-05 14:10:39.491 Software version: 2416 64-bit | 2022-08-05 14:10:39.510 Primary Thread ID: 15072 | 2022-08-05 14:10:39.510 Usage end date: 2022-09-14 | 2022-08-05 14:10:39.510 Enabled for: Advanced Features 2. | 2022-08-05 14:10:39.510 Enabled for: Sierra Chart Historical Data Service. | 2022-08-05 14:10:39.510 Enabled for: Denali Real-Time Exchange Data Feed. | 2022-08-05 14:10:39.510 Enabled for: Delayed Denali Exchange Data Feed. | 2022-08-05 14:10:39.510 Enabled for exchange2: CME (Trading Account Required) | 2022-08-05 14:10:39.510 Enabled for exchange2: CBOT (Trading Account Required) | 2022-08-05 14:10:39.510 Enabled for exchange2: COMEX (Trading Account Required) | 2022-08-05 14:10:39.510 Enabled for exchange2: NYMEX (Trading Account Required) | 2022-08-05 14:10:39.510 Enabled for exchange2: fairx_exchange.data | 2022-08-05 14:10:39.510 Enabled for exchange2: NASDAQ US stock data | 2022-08-05 14:10:39.510 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-08-05 14:10:39.510 Current selected Data/Trading service: Teton CME Order Routing | 2022-08-05 14:10:39.510 Custom symbol settings values: enabled | 2022-08-05 14:10:39.510 Chart Update Interval: 500 | 2022-08-05 14:10:39.510 Intraday Data Storage Time Unit: 1 | 2022-08-05 14:10:39.510 Time Zone: +00:00:00 (UTC+00) | 2022-08-05 14:10:39.510 2022-08-05 14:10:39 Local computer time in UTC | 2022-08-05 14:10:39.510 2022-08-05 14:10:39 Local computer time in SC Time Zone | 2022-08-05 14:10:39.510 2022-08-05 14:10:38 Server time in UTC | 2022-08-05 14:10:39.510 Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-08-05 14:10:39.510 Program path: C:\SierraChart\ | 2022-08-05 14:10:39.510 Data Files path: C:\SierraChart\Data\ | 2022-08-05 14:10:39.510 OS Version Number: 10.0 | 2022-08-05 14:10:39.510 Locale Setting: C | 2022-08-05 14:10:39.510 DLLs: UserContributedStudies_64.dll | 2022-08-05 14:10:39.510 Allowed protected custom studies: | 2022-08-05 14:10:39.510 Crash reporter started: true | 2022-08-05 14:10:39.510 Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. | 2022-08-05 14:10:39.526 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:39.553 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-08-05 14:10:39.707 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-08-05 14:10:39.707 Received 5 login tokens. | 2022-08-05 14:10:40.028 Symbol settings MD5 received. Request ID: 1. | 2022-08-05 14:10:41.439 Symbol settings are up-to-date for sc_futures_direct.dtc.trading. | 2022-08-05 14:10:41.439 Files to Open on Startup | Opening file: ExampleChartbook.cht | 2022-08-05 14:10:44.251 XAUUSD 1 Min #1 | Reloading chart. | 2022-08-05 14:10:44.270 XAUUSD Daily #2 | Reloading chart. | 2022-08-05 14:10:44.285 US30 1 Min #3 | Reloading chart. | 2022-08-05 14:10:44.296 USOil 1 Min #4 | Reloading chart. | 2022-08-05 14:10:44.308 ESU22-CME 1 Min #5 | Reloading chart. | 2022-08-05 14:10:44.320 SPX500 Daily #6 | Reloading chart. | 2022-08-05 14:10:44.335 EURUSD Daily #7 | Reloading chart. | 2022-08-05 14:10:44.368 EURUSD 5 Min #8 | Reloading chart. | 2022-08-05 14:10:44.380 ESU22-CME #9 | Reloading chart. | 2022-08-05 14:10:44.389 ESU22-CME 1 Min #10 | Reloading chart. | 2022-08-05 14:10:44.740 AAPL-NQTV 10 Min #11 | Reloading chart. | 2022-08-05 14:10:44.780 TSLA 10 Min #12 | Reloading chart. | 2022-08-05 14:10:44.796 SPY 30 Min #13 | Reloading chart. | 2022-08-05 14:10:44.808 ESU22-CME 1 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-08-05 14:10:44.900 Using Bid/Ask average for last trade price for XAUUSD | 2022-08-05 14:10:44.930 Using symbol data fast lookup vector | 2022-08-05 14:10:44.930 Starting DelayedDownloadMonitoringTimer | 2022-08-05 14:10:44.930 Starting HDTimeoutTimer | 2022-08-05 14:10:44.930 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 14:10:44.930 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 14:10:44.930 Triggering next historical data download in queue. | 2022-08-05 14:10:44.930 HD Request # 1 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 14:10:44.933 HD Request # 1 | Download start date-time: 2022-08-04 23:50:45.000000. File last date-time: 2022-08-04 23:50:45.000000 | 2022-08-05 14:10:44.934 HD Request # 1 | Using server: ds12.sierracharts.com port 10150 | 2022-08-05 14:10:44.934 Socket (1) | Creating socket. | 2022-08-05 14:10:44.934 Socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:10:44.934 Socket (1) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:10:44.934 Added historical Daily data request for XAUUSD to the queue. | 2022-08-05 14:10:44.938 Triggering next historical data download in queue. | 2022-08-05 14:10:44.938 Using Bid/Ask average for last trade price for US30 | 2022-08-05 14:10:44.941 Added historical Intraday data request for US30 to the queue. | 2022-08-05 14:10:44.941 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 14:10:44.941 Triggering next historical data download in queue. | 2022-08-05 14:10:44.941 Using Bid/Ask average for last trade price for USOil | 2022-08-05 14:10:44.947 Added historical Intraday data request for USOil to the queue. | 2022-08-05 14:10:44.947 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2022-08-05 14:10:44.947 Triggering next historical data download in queue. | 2022-08-05 14:10:44.947 Added historical Daily data request for SPX500 to the queue. | 2022-08-05 14:10:44.950 Triggering next historical data download in queue. | 2022-08-05 14:10:44.950 Using Bid/Ask average for last trade price for SPX500 | 2022-08-05 14:10:44.950 Added historical Daily data request for EURUSD to the queue. | 2022-08-05 14:10:44.954 Triggering next historical data download in queue. | 2022-08-05 14:10:44.954 Using Bid/Ask average for last trade price for EURUSD | 2022-08-05 14:10:44.954 Added historical Intraday data request for EURUSD to the queue. | 2022-08-05 14:10:44.957 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2022-08-05 14:10:44.957 Triggering next historical data download in queue. | 2022-08-05 14:10:44.957 HD Request # 1 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:45.074 HD Request # 1 | Sending historical data logon request message. | 2022-08-05 14:10:45.074 Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data | 2022-08-05 14:10:45.283 Added historical Intraday data request for AAPL-NQTV to the queue. | 2022-08-05 14:10:45.283 Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'. | 2022-08-05 14:10:45.283 Triggering next historical data download in queue. | 2022-08-05 14:10:45.283 Added historical Intraday data request for TSLA to the queue. | 2022-08-05 14:10:45.296 Intraday data recording state for symbol TSLA is set to download 'Pending'. | 2022-08-05 14:10:45.296 Triggering next historical data download in queue. | 2022-08-05 14:10:45.296 Added historical Intraday data request for SPY to the queue. | 2022-08-05 14:10:45.314 Intraday data recording state for symbol SPY is set to download 'Pending'. | 2022-08-05 14:10:45.314 Triggering next historical data download in queue. | 2022-08-05 14:10:45.314 HD Request # 1 | Requesting Intraday data. Start date-time: 2022-08-04 23:50:45. Record interval: 1. Symbol: XAUUSD | 2022-08-05 14:10:45.660 HD Request # 1 | Decompressing data. | 2022-08-05 14:10:45.727 HD Request # 1 | Receiving Intraday data for XAUUSD starting at 2022-08-04 23:50:45.018000 | 2022-08-05 14:10:46.078 HD Request # 1 | Timestamp of first Intraday data file record written: 2022-08-04 23:50:45.018000. | 2022-08-05 14:10:46.413 Socket (1) | CloseSocket call. | 2022-08-05 14:10:46.415 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:46.415 Historical data download thread signaled to stop. | 2022-08-05 14:10:46.415 HD Request # 1 | Received 35768 Intraday data records from 2022-08-04 23:50:45.018000 to 2022-08-05 14:10:45.037000 (14.3 hours) and wrote 35768 records for XAUUSD | 2022-08-05 14:10:46.415 HD Request # 1 | Completion time: 2s. | 2022-08-05 14:10:46.415 HD Request # 1 | Intraday data download complete for XAUUSD. Unique request ID: 1 | 2022-08-05 14:10:46.415 Removing historical data download ID 1. | 2022-08-05 14:10:46.415 HD Request # 1 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:10:46.415 Triggering next historical data download in queue. | 2022-08-05 14:10:46.415 Historical data for XAUUSD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-08-05 14:10:46.415 HD Request # 2 | Downloading Historical Daily chart data for XAUUSD. Starting date: 2022-08-02. Service: fxcm | 2022-08-05 14:10:46.417 HD Request # 2 | Using server: ds13-3.sierracharts.com port 10149 | 2022-08-05 14:10:46.417 Socket (2) | Creating socket. | 2022-08-05 14:10:46.417 Socket (2) | New receive buffer size: 5242880 | 2022-08-05 14:10:46.417 Socket (2) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:10:46.417 Socket (1) | Socket gracefully closed by remote side. | 2022-08-05 14:10:46.475 Socket (1) | Closed. | 2022-08-05 14:10:46.476 HD Request # 2 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:46.558 HD Request # 2 | Sending historical data logon request message. | 2022-08-05 14:10:46.558 Teton CME Order Routing | Firm: Dorman | 2022-08-05 14:10:46.817 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-08-05 14:10:46.817 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-08-05 14:10:46.881 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:10:46.881 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-08-05 14:10:46.881 Teton CME Order Routing | Network connection to server complete. | 2022-08-05 14:10:46.933 Teton CME Order Routing | Starting socket receive thread. | 2022-08-05 14:10:46.933 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-08-05 14:10:46.933 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:47.127 Teton CME Order Routing | Sending logon request message. | 2022-08-05 14:10:47.127 HD Request # 2 | Requesting historical Daily data starting at 2022-08-02. | 2022-08-05 14:10:47.260 HD Request # 2 | Decompressing data. | 2022-08-05 14:10:47.332 HD Request # 2 | Receiving historical Daily data for XAUUSD starting at 2022-08-02. | 2022-08-05 14:10:47.366 HD Request # 2 | Writing historical Daily data to the file XAUUSD.dly. | 2022-08-05 14:10:47.366 Socket (2) | CloseSocket call. | 2022-08-05 14:10:47.458 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:47.458 Historical data download thread signaled to stop. | 2022-08-05 14:10:47.458 HD Request # 2 | Received 4 Daily data records from 2022-08-02 00:00:00 to 2022-08-05 00:00:00 (4.0 days) and wrote 4 records for XAUUSD | 2022-08-05 14:10:47.458 HD Request # 2 | Completion time: 1s. | 2022-08-05 14:10:47.458 HD Request # 2 | Daily data download complete for XAUUSD. Unique request ID: 2 | 2022-08-05 14:10:47.458 Removing historical data download ID 2. | 2022-08-05 14:10:47.458 Triggering next historical data download in queue. | 2022-08-05 14:10:47.458 HD Request # 3 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 14:10:47.458 HD Request # 3 | Download start date-time: 2022-08-04 23:20:18.000000. File last date-time: 2022-08-04 23:20:18.000000 | 2022-08-05 14:10:47.458 HD Request # 3 | Using server: ds4.sierracharts.com port 10150 | 2022-08-05 14:10:47.458 Socket (3) | Creating socket. | 2022-08-05 14:10:47.459 Socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:10:47.459 Socket (3) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:10:47.459 Socket (2) | Socket gracefully closed by remote side. | 2022-08-05 14:10:47.531 Socket (2) | Closed. | 2022-08-05 14:10:47.531 HD Request # 3 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:47.605 HD Request # 3 | Sending historical data logon request message. | 2022-08-05 14:10:47.605 Teton CME Order Routing | Received logon response. | 2022-08-05 14:10:47.700 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-08-05 14:10:47.700 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:10:47.700 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-08-05 14:10:47.700 Teton CME Order Routing | Trading is supported. | 2022-08-05 14:10:47.700 Teton CME Order Routing | Order cancel and replace is supported. | 2022-08-05 14:10:47.700 Teton CME Order Routing | OCO Orders supported. | 2022-08-05 14:10:47.700 Teton CME Order Routing | Bracket Orders supported. | 2022-08-05 14:10:47.700 Teton CME Order Routing | Connected to server complete. | 2022-08-05 14:10:47.700 Triggering next historical data download in queue. | 2022-08-05 14:10:47.700 Triggering next historical data download in queue. | 2022-08-05 14:10:47.700 Triggering next historical data download in queue. | 2022-08-05 14:10:47.700 Triggering next historical data download in queue. | 2022-08-05 14:10:47.700 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-08-05 14:10:47.701 No download requests in the queue to start downloads for. | 2022-08-05 14:10:47.701 No download requests in the queue to start downloads for. | 2022-08-05 14:10:47.702 No download requests in the queue to start downloads for. | 2022-08-05 14:10:47.702 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 00:00:00.000000 | 2022-08-05 14:10:47.710 Using symbol data fast lookup vector | 2022-08-05 14:10:47.731 Teton CME Order Routing | Starting real-time market data updates for: ESU22-CME. ID: 1 | 2022-08-05 14:10:47.731 Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: ESU22-CME | 2022-08-05 14:10:47.731 Teton CME Order Routing | Requesting security definition data for: ESU22-CME. ID: 1 | 2022-08-05 14:10:47.731 No historical data client is currently set to download historical Intraday data for ESU22-CME. | 2022-08-05 14:10:47.731 Real-time Intraday chart data file updates started for ESU22-CME | 2022-08-05 14:10:47.731 Opened cached Intraday file: C:\SierraChart\Data\ESU22-CME.scid. Thread ID: 15072 | 2022-08-05 14:10:47.731 Intraday chart data file opened for ESU22-CME | 2022-08-05 14:10:47.731 Updated verified funded futures trading account ending date to: 2022-09-04 14:10:47 | 2022-08-05 14:10:47.766 Using Bid/Ask average for last trade price for XAUUSD | 2022-08-05 14:10:47.766 SC DTC Data with Market Depth | Starting real-time market data updates for: XAUUSD. ID: 2 Service code: fxcm | 2022-08-05 14:10:47.767 SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2022-08-05 14:10:47.767 DTC Client socket (2) | Creating socket. | 2022-08-05 14:10:47.767 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-08-05 14:10:47.767 DTC Client socket (2) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:10:47.767 SC DTC Data with Market Depth | Requesting security definition data for: XAUUSD. ID: 2 | 2022-08-05 14:10:47.768 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 14:10:47.768 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 14:10:47.768 Triggering next historical data download in queue. | 2022-08-05 14:10:47.768 Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data | 2022-08-05 14:10:47.784 SC Data - All Services | Starting real-time market data updates for: AAPL-NQTV (AAPL-NQTV). ID: 3 Service code: nasdaq_exchange.data | 2022-08-05 14:10:47.784 SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 10048 | 2022-08-05 14:10:47.784 DTC Client socket (4) | Creating socket. | 2022-08-05 14:10:47.785 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:10:47.785 DTC Client socket (4) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:10:47.785 SC Data - All Services | Requesting security definition data for: AAPL-NQTV (AAPL-NQTV). ID: 3 | 2022-08-05 14:10:47.786 XAUUSD[M] Daily #2 | Reloading chart. | 2022-08-05 14:10:47.796 Teton CME Order Routing | Received security definition for symbol ESU22-CME | 2022-08-05 14:10:47.798 Teton CME Order Routing | Starting real-time market data updates for: TSLA. ID: 4 Service code: equities.us | 2022-08-05 14:10:47.799 Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: TSLA | 2022-08-05 14:10:47.799 Teton CME Order Routing | Requesting security definition data for: TSLA. ID: 4 | 2022-08-05 14:10:47.799 Using Bid/Ask average for last trade price for US30 | 2022-08-05 14:10:47.803 SC DTC Data with Market Depth | Starting real-time market data updates for: US30. ID: 5 Service code: fxcm | 2022-08-05 14:10:47.803 SC DTC Data with Market Depth | Requesting security definition data for: US30. ID: 5 | 2022-08-05 14:10:47.803 Teton CME Order Routing | Starting real-time market data updates for: SPY. ID: 6 Service code: equities.us | 2022-08-05 14:10:47.809 Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: SPY | 2022-08-05 14:10:47.809 Teton CME Order Routing | Requesting security definition data for: SPY. ID: 6 | 2022-08-05 14:10:47.809 Using Bid/Ask average for last trade price for USOil | 2022-08-05 14:10:47.814 SC DTC Data with Market Depth | Starting real-time market data updates for: USOil. ID: 7 Service code: fxcm | 2022-08-05 14:10:47.814 SC DTC Data with Market Depth | Requesting security definition data for: USOil. ID: 7 | 2022-08-05 14:10:47.814 Using Bid/Ask average for last trade price for SPX500 | 2022-08-05 14:10:47.823 SC DTC Data with Market Depth | Starting real-time market data updates for: SPX500. ID: 8 Service code: fxcm | 2022-08-05 14:10:47.823 SC DTC Data with Market Depth | Requesting security definition data for: SPX500. ID: 8 | 2022-08-05 14:10:47.823 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43878 | 2022-08-05 14:10:47.827 SC DTC Data with Market Depth | Network connection to server complete. | 2022-08-05 14:10:47.828 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-08-05 14:10:47.828 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:10:47.828 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:10:47.850 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:10:47.850 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-08-05 14:10:47.850 Using Bid/Ask average for last trade price for EURUSD | 2022-08-05 14:10:47.855 SC DTC Data with Market Depth | Starting real-time market data updates for: EURUSD. ID: 9 Service code: fxcm | 2022-08-05 14:10:47.855 SC DTC Data with Market Depth | Requesting security definition data for: EURUSD. ID: 9 | 2022-08-05 14:10:47.855 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: AAPL-NQTV | 2022-08-05 14:10:47.901 Teton CME Order Routing | Received security definition for symbol AAPL-NQTV | 2022-08-05 14:10:47.901 Teton CME Order Routing | Received security definition for symbol TSLA | 2022-08-05 14:10:47.901 Teton CME Order Routing | Received security definition for symbol SPY | 2022-08-05 14:10:47.901 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:47.909 SC DTC Data with Market Depth | Sending logon request message. | 2022-08-05 14:10:47.909 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:47.924 SC Data - All Services | Sending logon request message. | 2022-08-05 14:10:47.924 HD Request # 3 | Requesting Intraday data. Start date-time: 2022-08-04 23:20:18. Record interval: 1. Symbol: US30 | 2022-08-05 14:10:48.184 HD Request # 3 | Decompressing data. | 2022-08-05 14:10:48.243 HD Request # 3 | Receiving Intraday data for US30 starting at 2022-08-04 23:20:18.445000 | 2022-08-05 14:10:48.521 SC DTC Data with Market Depth | Received logon response. | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Successfully connected. | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Trading is not supported. | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-08-05 14:10:48.599 SC Data - All Services | Received logon response. | 2022-08-05 14:10:48.612 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:10:48.612 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:10:48.612 SC Data - All Services | Successfully connected. | 2022-08-05 14:10:48.612 SC Data - All Services | Trading is not supported. | 2022-08-05 14:10:48.612 SC Data - All Services | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2022-08-05 14:10:48.612 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2022-08-05 14:10:48.752 SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-08-05 14:10:48.752 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2022-08-05 14:10:48.752 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2022-08-05 14:10:48.752 SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-08-05 14:10:48.752 SC Data - All Services | Received security definition for symbol AAPL-NQTV | 2022-08-05 14:10:48.773 HD Request # 3 | Timestamp of first Intraday data file record written: 2022-08-04 23:20:18.445000. | 2022-08-05 14:10:48.792 Socket (3) | CloseSocket call. | 2022-08-05 14:10:48.793 Historical data download thread signaled to stop. | 2022-08-05 14:10:48.793 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:48.793 HD Request # 3 | Received 34356 Intraday data records from 2022-08-04 23:20:18.445000 to 2022-08-05 14:10:46.042000 (14.8 hours) and wrote 34356 records for US30 | 2022-08-05 14:10:48.793 HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:10:46.042000 | 2022-08-05 14:10:48.798 Added 1 Time and Sales records to Intraday data file for US30 after download. | 2022-08-05 14:10:48.798 HD Request # 3 | Completion time: 1s. | 2022-08-05 14:10:48.798 HD Request # 3 | Intraday data download complete for US30. Unique request ID: 3 | 2022-08-05 14:10:48.798 Removing historical data download ID 3. | 2022-08-05 14:10:48.798 Real-time Intraday chart data file updates started for US30 | 2022-08-05 14:10:48.798 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 14:10:48.801 Intraday chart data file opened for US30 | 2022-08-05 14:10:48.801 HD Request # 3 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:10:48.801 Triggering next historical data download in queue. | 2022-08-05 14:10:48.801 Initiating new historical data download for US30 to get the latest data since the download was started while not connected to primary service. | 2022-08-05 14:10:48.801 Added historical Intraday data request for US30 to the queue. | 2022-08-05 14:10:48.801 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 14:10:48.801 Delaying start of download for US30. | 2022-08-05 14:10:48.801 Socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:10:48.849 Socket (3) | Closed. | 2022-08-05 14:10:48.849 HD Request # 4 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 14:10:53.917 HD Request # 4 | Download start date-time: 2022-08-05 14:10:48.000000. File last date-time: 2022-08-05 14:10:48.933000 | 2022-08-05 14:10:53.917 HD Request # 4 | Using server: ds12.sierracharts.com port 10149 | 2022-08-05 14:10:53.917 Socket (3) | Creating socket. | 2022-08-05 14:10:53.917 Socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:10:53.917 Socket (3) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:10:53.917 HD Request # 4 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:54.065 HD Request # 4 | Sending historical data logon request message. | 2022-08-05 14:10:54.065 MESU22_FUT_CME [CBV] #2 | Reloading chart. | 2022-08-05 14:10:54.192 MESU22_FUT_CME [CBV] #2 | Performing continuous chart historical Daily data download for symbol MESU22_FUT_CME starting at last date in file. | 2022-08-05 14:10:54.211 Starting DelayedDownloadMonitoringTimer | 2022-08-05 14:10:54.211 Starting HDTimeoutTimer | 2022-08-05 14:10:54.211 Added historical Daily data request for MESU22_FUT_CME to the queue. | 2022-08-05 14:10:54.211 Triggering next historical data download in queue. | 2022-08-05 14:10:54.211 MESU22_FUT_CME [CBV] #2 | Waiting for historical downloads to complete with the IDs: 13, | 2022-08-05 14:10:54.233 Mapping MESU22_FUT_CME to MESU22. Service code: cme | 2022-08-05 14:10:54.250 HD Request # 5 | Downloading Historical Daily chart data for MESU22_FUT_CME. Starting date: 2022-08-02. Service: sc_futures_direct.dtc.trading | 2022-08-05 14:10:54.252 HD Request # 4 | Requesting Intraday data. Start date-time: 2022-08-05 14:10:48. Record interval: 1. Symbol: US30 | 2022-08-05 14:10:54.658 HD Request # 4 | Decompressing data. | 2022-08-05 14:10:54.728 HD Request # 4 | Receiving Intraday data for US30 starting at 2022-08-05 14:10:48.032000 | 2022-08-05 14:10:54.729 Socket (3) | CloseSocket call. | 2022-08-05 14:10:54.729 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:54.729 Historical data download thread signaled to stop. | 2022-08-05 14:10:54.729 HD Request # 4 | Timestamp of first Intraday data file record written: 2022-08-05 14:10:49.003000. | 2022-08-05 14:10:54.729 HD Request # 4 | Received 6 Intraday data records from 2022-08-05 14:10:48.032000 to 2022-08-05 14:10:53.382000 (5.3 seconds) and wrote 5 records for US30 | 2022-08-05 14:10:54.729 HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:10:53.382000 | 2022-08-05 14:10:54.733 Added 1 Time and Sales records to Intraday data file for US30 after download. | 2022-08-05 14:10:54.733 HD Request # 4 | Completion time: 1s. | 2022-08-05 14:10:54.733 HD Request # 4 | Intraday data download complete for US30. Unique request ID: 12 | 2022-08-05 14:10:54.734 Removing historical data download ID 12. | 2022-08-05 14:10:54.734 Real-time Intraday chart data file updates started for US30 | 2022-08-05 14:10:54.734 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 14:10:54.737 Intraday chart data file opened for US30 | 2022-08-05 14:10:54.737 HD Request # 4 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:10:54.737 Triggering next historical data download in queue. | 2022-08-05 14:10:54.737 HD Request # 6 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2022-08-05 14:10:54.738 HD Request # 6 | Download start date-time: 2022-08-04 23:50:41.000000. File last date-time: 2022-08-04 23:50:41.000000 | 2022-08-05 14:10:54.738 HD Request # 6 | Using server: ds13-3.sierracharts.com port 10150 | 2022-08-05 14:10:54.738 Socket (6) | Creating socket. | 2022-08-05 14:10:54.738 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:10:54.738 Socket (6) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:10:54.738 Socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:10:54.799 Socket (3) | Closed. | 2022-08-05 14:10:54.799 HD Request # 6 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:54.868 HD Request # 6 | Sending historical data logon request message. | 2022-08-05 14:10:54.868 HD Request # 5 | Requesting historical Daily data for ETU22 starting at 2022-08-01. SC External HD service. | 2022-08-05 14:10:54.965 HD Request # 5 | Receiving historical Daily data for MESU22_FUT_CME starting at 2022-08-02. | 2022-08-05 14:10:55.245 HD Request # 5 | Writing historical Daily data to the file MESU22_FUT_CME.dly. | 2022-08-05 14:10:55.245 HD Request # 5 | Bytes received: 241 | 2022-08-05 14:10:55.247 HD Request # 5 | Received 4 Daily data records from 2022-08-02 00:00:00 to 2022-08-04 00:00:00 (3.0 days) and wrote 3 records for MESU22_FUT_CME | 2022-08-05 14:10:55.247 HD Request # 5 | Completion time: 1s. | 2022-08-05 14:10:55.248 HD Request # 5 | Daily data download complete for MESU22_FUT_CME. Unique request ID: 13 | 2022-08-05 14:10:55.248 Removing historical data download ID 13. | 2022-08-05 14:10:55.248 Triggering next historical data download in queue. | 2022-08-05 14:10:55.248 No download requests in the queue to start downloads for. | 2022-08-05 14:10:55.248 HD Request # 6 | Requesting Intraday data. Start date-time: 2022-08-04 23:50:41. Record interval: 1. Symbol: USOil | 2022-08-05 14:10:55.575 HD Request # 6 | Decompressing data. | 2022-08-05 14:10:55.638 MESU22_FUT_CME [CBV] #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-08-05 14:10:55.700 MESU22_FUT_CME [CBV] #2 | Reloading chart. | 2022-08-05 14:10:55.701 HD Request # 6 | Receiving Intraday data for USOil starting at 2022-08-04 23:50:41.473000 | 2022-08-05 14:10:55.844 Socket (6) | CloseSocket call. | 2022-08-05 14:10:56.046 Historical data download thread signaled to stop. | 2022-08-05 14:10:56.046 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:56.046 HD Request # 6 | Timestamp of first Intraday data file record written: 2022-08-04 23:50:41.473000. | 2022-08-05 14:10:56.047 HD Request # 6 | Received 23639 Intraday data records from 2022-08-04 23:50:41.473000 to 2022-08-05 14:10:54.114000 (14.3 hours) and wrote 23639 records for USOil | 2022-08-05 14:10:56.047 HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:10:54.114000 | 2022-08-05 14:10:56.051 Added 2 Time and Sales records to Intraday data file for USOil after download. | 2022-08-05 14:10:56.051 HD Request # 6 | Completion time: 2s. | 2022-08-05 14:10:56.051 HD Request # 6 | Intraday data download complete for USOil. Unique request ID: 4 | 2022-08-05 14:10:56.051 Removing historical data download ID 4. | 2022-08-05 14:10:56.051 Real-time Intraday chart data file updates started for USOil | 2022-08-05 14:10:56.051 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 15072 | 2022-08-05 14:10:56.054 Intraday chart data file opened for USOil | 2022-08-05 14:10:56.054 HD Request # 6 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:10:56.054 Triggering next historical data download in queue. | 2022-08-05 14:10:56.054 HD Request # 7 | Downloading Historical Daily chart data for SPX500. Starting date: 2022-08-02. Service: fxcm | 2022-08-05 14:10:56.056 HD Request # 7 | Using server: ds4.sierracharts.com port 10149 | 2022-08-05 14:10:56.056 Socket (3) | Creating socket. | 2022-08-05 14:10:56.056 Socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:10:56.056 Socket (3) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:10:56.056 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:10:56.102 Socket (6) | Closed. | 2022-08-05 14:10:56.102 HD Request # 7 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:56.189 HD Request # 7 | Sending historical data logon request message. | 2022-08-05 14:10:56.189 MESU22_FUT_CME [CBV] #2 | Reloading chart. | 2022-08-05 14:10:56.201 SC Data - All Services | Starting real-time market data updates for: MESU22_FUT_CME (MESU22). ID: 10 Service code: cme | 2022-08-05 14:10:56.700 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2022-08-05 14:10:56.700 SC Data - All Services | Requesting security definition data for: MESU22_FUT_CME (MESU22). ID: 10 | 2022-08-05 14:10:56.701 Added historical Intraday data request for MESU22_FUT_CME to the queue. | 2022-08-05 14:10:56.701 Intraday data recording state for symbol MESU22_FUT_CME is set to download 'Pending'. | 2022-08-05 14:10:56.701 Triggering next historical data download in queue. | 2022-08-05 14:10:56.701 DTC Client socket (5) | Creating socket. | 2022-08-05 14:10:56.704 DTC Client socket (5) | New receive buffer size: 5242880 | 2022-08-05 14:10:56.704 DTC Client socket (5) | Connecting to IP: 208.185.224.129. | 2022-08-05 14:10:56.704 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESU22_FUT_CME | 2022-08-05 14:10:56.763 Teton CME Order Routing | Received security definition for symbol MESU22_FUT_CME | 2022-08-05 14:10:56.763 HD Request # 7 | Requesting historical Daily data starting at 2022-08-02. | 2022-08-05 14:10:56.769 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:10:56.770 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:10:56.770 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:10:56.770 HD Request # 7 | Decompressing data. | 2022-08-05 14:10:56.831 HD Request # 7 | Receiving historical Daily data for SPX500 starting at 2022-08-02. | 2022-08-05 14:10:56.850 HD Request # 7 | Writing historical Daily data to the file SPX500.dly. | 2022-08-05 14:10:56.850 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:56.853 SC Data - All Services | Sending logon request message. | 2022-08-05 14:10:56.853 Socket (3) | CloseSocket call. | 2022-08-05 14:10:56.905 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:56.905 Historical data download thread signaled to stop. | 2022-08-05 14:10:56.905 HD Request # 7 | Received 4 Daily data records from 2022-08-02 00:00:00 to 2022-08-05 00:00:00 (4.0 days) and wrote 4 records for SPX500 | 2022-08-05 14:10:56.905 HD Request # 7 | Completion time: 0s. | 2022-08-05 14:10:56.905 HD Request # 7 | Daily data download complete for SPX500. Unique request ID: 5 | 2022-08-05 14:10:56.905 Removing historical data download ID 5. | 2022-08-05 14:10:56.905 Triggering next historical data download in queue. | 2022-08-05 14:10:56.905 HD Request # 8 | Downloading Historical Daily chart data for EURUSD. Starting date: 2022-08-02. Service: fxcm | 2022-08-05 14:10:56.906 HD Request # 8 | Using server: ds12.sierracharts.com port 10150 | 2022-08-05 14:10:56.906 Socket (6) | Creating socket. | 2022-08-05 14:10:56.906 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:10:56.906 Socket (6) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:10:56.906 Socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:10:56.964 Socket (3) | Closed. | 2022-08-05 14:10:56.964 HD Request # 8 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:57.054 HD Request # 8 | Sending historical data logon request message. | 2022-08-05 14:10:57.054 HD Request # 8 | Requesting historical Daily data starting at 2022-08-02. | 2022-08-05 14:10:57.114 HD Request # 8 | Decompressing data. | 2022-08-05 14:10:57.199 HD Request # 8 | Receiving historical Daily data for EURUSD starting at 2022-08-02. | 2022-08-05 14:10:57.208 HD Request # 8 | Writing historical Daily data to the file EURUSD.dly. | 2022-08-05 14:10:57.209 Socket (6) | CloseSocket call. | 2022-08-05 14:10:57.262 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:57.262 Historical data download thread signaled to stop. | 2022-08-05 14:10:57.262 HD Request # 8 | Received 4 Daily data records from 2022-08-02 00:00:00 to 2022-08-05 00:00:00 (4.0 days) and wrote 4 records for EURUSD | 2022-08-05 14:10:57.262 HD Request # 8 | Completion time: 1s. | 2022-08-05 14:10:57.262 HD Request # 8 | Daily data download complete for EURUSD. Unique request ID: 6 | 2022-08-05 14:10:57.262 Removing historical data download ID 6. | 2022-08-05 14:10:57.262 Triggering next historical data download in queue. | 2022-08-05 14:10:57.263 HD Request # 9 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2022-08-05 14:10:57.263 HD Request # 9 | Download start date-time: 2022-08-04 23:50:45.000000. File last date-time: 2022-08-04 23:50:45.000000 | 2022-08-05 14:10:57.263 HD Request # 9 | Using server: ds13-3.sierracharts.com port 10149 | 2022-08-05 14:10:57.263 Socket (3) | Creating socket. | 2022-08-05 14:10:57.263 Socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:10:57.263 Socket (3) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:10:57.263 SPX500[M] Daily #6 | Reloading chart. | 2022-08-05 14:10:57.325 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:10:57.329 Socket (6) | Closed. | 2022-08-05 14:10:57.329 EURUSD[M] Daily #7 | Reloading chart. | 2022-08-05 14:10:57.355 HD Request # 9 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:57.408 HD Request # 9 | Sending historical data logon request message. | 2022-08-05 14:10:57.408 HD Request # 9 | Requesting Intraday data. Start date-time: 2022-08-04 23:50:45. Record interval: 1. Symbol: EURUSD | 2022-08-05 14:10:57.470 HD Request # 9 | Decompressing data. | 2022-08-05 14:10:57.531 SC Data - All Services | Received logon response. | 2022-08-05 14:10:57.605 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:10:57.605 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:10:57.605 SC Data - All Services | Successfully connected. | 2022-08-05 14:10:57.605 SC Data - All Services | Trading is not supported. | 2022-08-05 14:10:57.605 SC Data - All Services | Restarting real-time data updates for symbol: MESU22_FUT_CME -> MESU22 | 2022-08-05 14:10:57.605 SC Data - All Services | Received security definition for symbol MESU22_FUT_CME | 2022-08-05 14:10:57.761 HD Request # 9 | Receiving Intraday data for EURUSD starting at 2022-08-04 23:50:45.172000 | 2022-08-05 14:10:57.816 HD Request # 9 | Timestamp of first Intraday data file record written: 2022-08-04 23:50:45.172000. | 2022-08-05 14:10:58.028 Socket (3) | CloseSocket call. | 2022-08-05 14:10:58.029 Historical data download thread signaled to stop. | 2022-08-05 14:10:58.029 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:58.029 HD Request # 9 | Received 33764 Intraday data records from 2022-08-04 23:50:45.172000 to 2022-08-05 14:10:56.026000 (14.3 hours) and wrote 33764 records for EURUSD | 2022-08-05 14:10:58.030 HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:10:56.026000 | 2022-08-05 14:10:58.033 Added 1 Time and Sales records to Intraday data file for EURUSD after download. | 2022-08-05 14:10:58.033 HD Request # 9 | Completion time: 1s. | 2022-08-05 14:10:58.034 HD Request # 9 | Intraday data download complete for EURUSD. Unique request ID: 7 | 2022-08-05 14:10:58.034 Removing historical data download ID 7. | 2022-08-05 14:10:58.034 Real-time Intraday chart data file updates started for EURUSD | 2022-08-05 14:10:58.034 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 15072 | 2022-08-05 14:10:58.037 Intraday chart data file opened for EURUSD | 2022-08-05 14:10:58.037 HD Request # 9 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:10:58.037 Triggering next historical data download in queue. | 2022-08-05 14:10:58.037 HD Request # 10 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data | 2022-08-05 14:10:58.037 HD Request # 10 | Download start date-time: 2022-08-04 23:50:37.000000. File last date-time: 2022-08-04 23:50:37.000000 | 2022-08-05 14:10:58.037 HD Request # 10 | Using server: ds25.sierracharts.com port 10150 | 2022-08-05 14:10:58.037 Socket (6) | Creating socket. | 2022-08-05 14:10:58.037 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:10:58.038 Socket (6) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:10:58.038 Socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:10:58.091 Socket (3) | Closed. | 2022-08-05 14:10:58.091 HD Request # 10 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:58.168 HD Request # 10 | Sending historical data logon request message. | 2022-08-05 14:10:58.168 HD Request # 10 | Requesting Intraday data. Start date-time: 2022-08-04 23:50:37. Record interval: 1. Symbol: AAPL-NQTV | 2022-08-05 14:10:58.662 HD Request # 10 | Decompressing data. | 2022-08-05 14:10:58.723 HD Request # 10 | Receiving Intraday data for AAPL-NQTV starting at 2022-08-04 23:50:37.042000 | 2022-08-05 14:10:58.934 Socket (6) | CloseSocket call. | 2022-08-05 14:10:58.936 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:58.936 Historical data download thread signaled to stop. | 2022-08-05 14:10:58.936 HD Request # 10 | Timestamp of first Intraday data file record written: 2022-08-04 23:50:37.042000. | 2022-08-05 14:10:58.936 HD Request # 10 | Received 3554 Intraday data records from 2022-08-04 23:50:37.042000 to 2022-08-05 14:10:57.516000 (14.3 hours) and wrote 3554 records for AAPL-NQTV | 2022-08-05 14:10:58.937 HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:10:57.516000 | 2022-08-05 14:10:58.941 HD Request # 10 | Completion time: 0s. | 2022-08-05 14:10:58.941 HD Request # 10 | Intraday data download complete for AAPL-NQTV. Unique request ID: 8 | 2022-08-05 14:10:58.941 Removing historical data download ID 8. | 2022-08-05 14:10:58.941 Real-time Intraday chart data file updates started for AAPL-NQTV | 2022-08-05 14:10:58.941 Opened cached Intraday file: C:\SierraChart\Data\AAPL-NQTV.scid. Thread ID: 15072 | 2022-08-05 14:10:58.941 Intraday chart data file opened for AAPL-NQTV | 2022-08-05 14:10:58.941 HD Request # 10 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:10:58.941 Triggering next historical data download in queue. | 2022-08-05 14:10:58.941 HD Request # 11 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2022-08-05 14:10:58.941 HD Request # 11 | Download start date-time: 2022-08-04 13:42:51.000000. File last date-time: 2022-08-04 13:42:51.253000 | 2022-08-05 14:10:58.941 HD Request # 11 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2022-08-05 14:10:58.941 Socket (3) | Creating socket. | 2022-08-05 14:10:58.998 Socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:10:58.998 Socket (3) | Connecting to IP: 8.18.161.133. | 2022-08-05 14:10:58.998 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:10:59.005 Socket (6) | Closed. | 2022-08-05 14:10:59.005 HD Request # 11 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:59.108 HD Request # 11 | Sending historical data logon request message. | 2022-08-05 14:10:59.108 HD Request # 11 | Requesting Intraday data. Start date-time: 2022-08-04 13:42:51. Record interval: 1. Symbol: TSLA | 2022-08-05 14:10:59.622 HD Request # 11 | Decompressing data. | 2022-08-05 14:10:59.683 HD Request # 11 | Receiving Intraday data for TSLA starting at 2022-08-04 13:42:51.253000 | 2022-08-05 14:10:59.979 Socket (3) | CloseSocket call. | 2022-08-05 14:11:00.103 Historical data download thread signaled to stop. | 2022-08-05 14:11:00.103 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:11:00.103 HD Request # 11 | Timestamp of first Intraday data file record written: 2022-08-04 13:42:51.253000. | 2022-08-05 14:11:00.103 HD Request # 11 | Received 18631 Intraday data records from 2022-08-04 13:42:51.253000 to 2022-08-05 13:55:59.122000 (24.2 hours) and wrote 18631 records for TSLA | 2022-08-05 14:11:00.103 HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2022-08-05 13:55:59.122000 | 2022-08-05 14:11:00.109 HD Request # 11 | Completion time: 2s. | 2022-08-05 14:11:00.109 HD Request # 11 | Intraday data download complete for TSLA. Unique request ID: 9 | 2022-08-05 14:11:00.109 Removing historical data download ID 9. | 2022-08-05 14:11:00.109 Real-time Intraday chart data file updates started for TSLA | 2022-08-05 14:11:00.109 Opened cached Intraday file: C:\SierraChart\Data\TSLA.scid. Thread ID: 15072 | 2022-08-05 14:11:00.109 Intraday chart data file opened for TSLA | 2022-08-05 14:11:00.109 HD Request # 11 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:11:00.109 Triggering next historical data download in queue. | 2022-08-05 14:11:00.109 HD Request # 12 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: equities.us | 2022-08-05 14:11:00.110 HD Request # 12 | Download start date-time: 2022-08-04 13:42:50.000000. File last date-time: 2022-08-04 13:42:50.191000 | 2022-08-05 14:11:00.110 HD Request # 12 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2022-08-05 14:11:00.110 Socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:11:00.154 Socket (3) | Closed. | 2022-08-05 14:11:00.154 Socket (6) | Creating socket. | 2022-08-05 14:11:00.178 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:11:00.178 Socket (6) | Connecting to IP: 8.18.161.135. | 2022-08-05 14:11:00.178 HD Request # 12 | Setting DTC encoding to Binary VLS | 2022-08-05 14:11:00.313 HD Request # 12 | Sending historical data logon request message. | 2022-08-05 14:11:00.313 HD Request # 12 | Requesting Intraday data. Start date-time: 2022-08-04 13:42:50. Record interval: 1. Symbol: SPY | 2022-08-05 14:11:00.824 HD Request # 12 | Decompressing data. | 2022-08-05 14:11:00.878 HD Request # 12 | Receiving Intraday data for SPY starting at 2022-08-04 13:42:50.191000 | 2022-08-05 14:11:01.200 Socket (6) | CloseSocket call. | 2022-08-05 14:11:01.377 Historical data download thread signaled to stop. | 2022-08-05 14:11:01.377 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:11:01.377 HD Request # 12 | Timestamp of first Intraday data file record written: 2022-08-04 13:42:50.191000. | 2022-08-05 14:11:01.378 HD Request # 12 | Received 23920 Intraday data records from 2022-08-04 13:42:50.191000 to 2022-08-05 13:56:00.014000 (24.2 hours) and wrote 23920 records for SPY | 2022-08-05 14:11:01.378 HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2022-08-05 13:56:00.014000 | 2022-08-05 14:11:01.382 HD Request # 12 | Completion time: 1s. | 2022-08-05 14:11:01.382 HD Request # 12 | Intraday data download complete for SPY. Unique request ID: 10 | 2022-08-05 14:11:01.382 Removing historical data download ID 10. | 2022-08-05 14:11:01.382 Real-time Intraday chart data file updates started for SPY | 2022-08-05 14:11:01.382 Opened cached Intraday file: C:\SierraChart\Data\SPY.scid. Thread ID: 15072 | 2022-08-05 14:11:01.382 Intraday chart data file opened for SPY | 2022-08-05 14:11:01.382 HD Request # 12 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:11:01.382 Triggering next historical data download in queue. | 2022-08-05 14:11:01.382 HD Request # 13 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 14:11:01.382 HD Request # 13 | Download start date-time: 2022-08-05 14:10:45.000000. File last date-time: 2022-08-05 14:10:45.037000 | 2022-08-05 14:11:01.383 HD Request # 13 | Using server: ds4.sierracharts.com port 10149 | 2022-08-05 14:11:01.383 Socket (3) | Creating socket. | 2022-08-05 14:11:01.383 Socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:11:01.383 Socket (3) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:11:01.383 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:11:01.429 Socket (6) | Closed. | 2022-08-05 14:11:01.429 HD Request # 13 | Setting DTC encoding to Binary VLS | 2022-08-05 14:11:01.512 HD Request # 13 | Sending historical data logon request message. | 2022-08-05 14:11:01.512 HD Request # 13 | Requesting Intraday data. Start date-time: 2022-08-05 14:10:45. Record interval: 1. Symbol: XAUUSD | 2022-08-05 14:11:01.576 HD Request # 13 | Decompressing data. | 2022-08-05 14:11:01.637 HD Request # 13 | Receiving Intraday data for XAUUSD starting at 2022-08-05 14:10:45.037000 | 2022-08-05 14:11:01.637 Socket (3) | CloseSocket call. | 2022-08-05 14:11:01.637 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:11:01.637 Historical data download thread signaled to stop. | 2022-08-05 14:11:01.637 HD Request # 13 | Timestamp of first Intraday data file record written: 2022-08-05 14:10:45.037000. | 2022-08-05 14:11:01.637 HD Request # 13 | Received 16 Intraday data records from 2022-08-05 14:10:45.037000 to 2022-08-05 14:11:00.017000 (15.0 seconds) and wrote 16 records for XAUUSD | 2022-08-05 14:11:01.638 HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:11:00.017000 | 2022-08-05 14:11:01.642 Added 1 Time and Sales records to Intraday data file for XAUUSD after download. | 2022-08-05 14:11:01.642 HD Request # 13 | Completion time: 0s. | 2022-08-05 14:11:01.642 HD Request # 13 | Intraday data download complete for XAUUSD. Unique request ID: 11 | 2022-08-05 14:11:01.642 Removing historical data download ID 11. | 2022-08-05 14:11:01.642 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-05 14:11:01.642 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 15072 | 2022-08-05 14:11:01.645 Intraday chart data file opened for XAUUSD | 2022-08-05 14:11:01.645 HD Request # 13 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:11:01.645 Triggering next historical data download in queue. | 2022-08-05 14:11:01.645 Delaying start of download for MESU22_FUT_CME. | 2022-08-05 14:11:01.645 Socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:11:01.703 Socket (3) | Closed. | 2022-08-05 14:11:01.703 HD Request # 14 | Downloading Intraday chart data for MESU22_FUT_CME to the file MESU22_FUT_CME.scid. Service: cme | 2022-08-05 14:11:02.928 HD Request # 14 | Download start date-time: 2022-08-05 03:32:53.000000. File last date-time: 2022-08-05 03:32:53.000000 | 2022-08-05 14:11:02.928 HD Request # 14 | Using server: ds23.sierracharts.com port 10150 | 2022-08-05 14:11:02.928 Socket (3) | Creating socket. | 2022-08-05 14:11:02.975 Socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:11:02.976 Socket (3) | Connecting to IP: 216.1.90.130. | 2022-08-05 14:11:02.976 HD Request # 14 | Setting DTC encoding to Binary VLS | 2022-08-05 14:11:03.103 HD Request # 14 | Sending historical data logon request message. | 2022-08-05 14:11:03.103 HD Request # 14 | Requesting Intraday data. Start date-time: 2022-08-05 03:32:53. Record interval: 1. Symbol: MESU22 | 2022-08-05 14:11:03.696 HD Request # 14 | Decompressing data. | 2022-08-05 14:11:03.764 HD Request # 14 | Receiving Intraday data for MESU22_FUT_CME starting at 2022-08-05 03:32:53.882000 | 2022-08-05 14:11:03.988 Socket (3) | CloseSocket call. | 2022-08-05 14:11:04.141 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:11:04.141 Historical data download thread signaled to stop. | 2022-08-05 14:11:04.141 HD Request # 14 | Timestamp of first Intraday data file record written: 2022-08-05 03:32:53.882000. | 2022-08-05 14:11:04.142 HD Request # 14 | Received 15079 Intraday data records from 2022-08-05 03:32:53.882000 to 2022-08-05 14:11:00.038000 (10.6 hours) and wrote 15079 records for MESU22_FUT_CME | 2022-08-05 14:11:04.142 HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:11:00.038000 | 2022-08-05 14:11:04.146 Added 4 Time and Sales records to Intraday data file for MESU22_FUT_CME after download. | 2022-08-05 14:11:04.146 HD Request # 14 | Completion time: 2s. | 2022-08-05 14:11:04.146 HD Request # 14 | Intraday data download complete for MESU22_FUT_CME. Unique request ID: 14 | 2022-08-05 14:11:04.146 Removing historical data download ID 14. | 2022-08-05 14:11:04.146 Real-time Intraday chart data file updates started for MESU22_FUT_CME | 2022-08-05 14:11:04.146 Opened cached Intraday file: C:\SierraChart\Data\MESU22_FUT_CME.scid. Thread ID: 15072 | 2022-08-05 14:11:04.149 Intraday chart data file opened for MESU22_FUT_CME | 2022-08-05 14:11:04.149 HD Request # 14 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:11:04.149 Triggering next historical data download in queue. | 2022-08-05 14:11:04.149 No download requests in the queue to start downloads for. | 2022-08-05 14:11:04.149 Socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:11:04.200 Socket (3) | Closed. | 2022-08-05 14:11:04.200 DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:16:39.026 * DTC Client socket (5) | Socket gracefully closed by remote side. | 2022-08-05 14:16:39.026 DTC Client socket (5) | CloseSocket call. | 2022-08-05 14:16:39.026 DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:16:39.026 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:16:39.026 DTC Client socket (5) | Closed. | 2022-08-05 14:16:39.026 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:16:39.027 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:16:39.027 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:16:39.027 SC Data - All Services | Connecting to the server ds26.sierracharts.com. Port 10048 | 2022-08-05 14:16:41.033 DTC Client socket (3) | Creating socket. | 2022-08-05 14:16:41.071 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:16:41.071 DTC Client socket (3) | Connecting to IP: 38.89.235.129. | 2022-08-05 14:16:41.071 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:16:41.120 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:16:41.120 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:16:41.120 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:41.206 SC Data - All Services | Sending logon request message. | 2022-08-05 14:16:41.206 SC Data - All Services | Received logon response. | 2022-08-05 14:16:41.957 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:16:41.957 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:16:41.957 SC Data - All Services | Successfully connected. | 2022-08-05 14:16:41.957 SC Data - All Services | Trading is not supported. | 2022-08-05 14:16:41.957 Added historical Intraday data request for MESU22_FUT_CME to the queue. | 2022-08-05 14:16:41.957 Intraday data recording state for symbol MESU22_FUT_CME is set to download 'Pending'. | 2022-08-05 14:16:41.957 Triggering next historical data download in queue. | 2022-08-05 14:16:41.957 SC Data - All Services | Restarting real-time data updates for symbol: MESU22_FUT_CME -> MESU22 | 2022-08-05 14:16:41.957 HD Request # 15 | Downloading Intraday chart data for MESU22_FUT_CME to the file MESU22_FUT_CME.scid. Service: cme | 2022-08-05 14:16:41.957 HD Request # 15 | Download start date-time: 2022-08-05 14:16:23.000000. File last date-time: 2022-08-05 14:16:23.000000 | 2022-08-05 14:16:41.958 HD Request # 15 | Using server: ds21.sierracharts.com port 10149 | 2022-08-05 14:16:41.958 Socket (5) | Creating socket. | 2022-08-05 14:16:41.993 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 14:16:41.994 Socket (5) | Connecting to IP: 216.1.90.129. | 2022-08-05 14:16:41.994 SC Data - All Services | Received security definition for symbol MESU22_FUT_CME | 2022-08-05 14:16:42.115 HD Request # 15 | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:42.118 HD Request # 15 | Sending historical data logon request message. | 2022-08-05 14:16:42.118 HD Request # 15 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:23. Record interval: 1. Symbol: MESU22 | 2022-08-05 14:16:42.686 HD Request # 15 | Decompressing data. | 2022-08-05 14:16:42.743 HD Request # 15 | Receiving Intraday data for MESU22_FUT_CME starting at 2022-08-05 14:16:23.050000 | 2022-08-05 14:16:42.743 Socket (5) | CloseSocket call. | 2022-08-05 14:16:42.743 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:16:42.743 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 14:16:42.798 Socket (5) | Closed. | 2022-08-05 14:16:42.798 Historical data download thread signaled to stop. | 2022-08-05 14:16:42.803 HD Request # 15 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:23.050000. | 2022-08-05 14:16:42.803 HD Request # 15 | Received 19 Intraday data records from 2022-08-05 14:16:23.050000 to 2022-08-05 14:16:41.344000 (18.3 seconds) and wrote 19 records for MESU22_FUT_CME | 2022-08-05 14:16:42.803 HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:16:41.344000 | 2022-08-05 14:16:42.807 Added 1 Time and Sales records to Intraday data file for MESU22_FUT_CME after download. | 2022-08-05 14:16:42.807 HD Request # 15 | Completion time: 1s. | 2022-08-05 14:16:42.807 HD Request # 15 | Intraday data download complete for MESU22_FUT_CME. Unique request ID: 15 | 2022-08-05 14:16:42.807 Removing historical data download ID 15. | 2022-08-05 14:16:42.807 Real-time Intraday chart data file updates started for MESU22_FUT_CME | 2022-08-05 14:16:42.807 Opened cached Intraday file: C:\SierraChart\Data\MESU22_FUT_CME.scid. Thread ID: 15072 | 2022-08-05 14:16:42.810 Intraday chart data file opened for MESU22_FUT_CME | 2022-08-05 14:16:42.810 HD Request # 15 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:16:42.810 Triggering next historical data download in queue. | 2022-08-05 14:16:42.810 No download requests in the queue to start downloads for. | 2022-08-05 14:16:42.810 DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:16:51.608 * DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-08-05 14:16:51.608 DTC Client socket (4) | CloseSocket call. | 2022-08-05 14:16:51.608 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:16:51.608 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:16:51.608 DTC Client socket (4) | Closed. | 2022-08-05 14:16:51.609 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:16:51.609 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:16:51.609 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:16:51.609 DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:16:52.607 * DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-08-05 14:16:52.607 DTC Client socket (2) | CloseSocket call. | 2022-08-05 14:16:52.607 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:16:52.607 DTC Client socket (2) | Closed. | 2022-08-05 14:16:52.607 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-08-05 14:16:52.607 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:16:52.607 SC DTC Data with Market Depth | Disconnected from the server. | 2022-08-05 14:16:52.607 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:16:52.607 SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 10048 | 2022-08-05 14:16:53.609 DTC Client socket (2) | Creating socket. | 2022-08-05 14:16:53.609 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-08-05 14:16:53.609 DTC Client socket (2) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:16:53.609 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:16:53.677 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:16:53.677 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-08-05 14:16:53.677 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:16:53.756 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-08-05 14:16:53.756 DTC Client socket (1) | CloseSocket call. | 2022-08-05 14:16:53.805 DTC Client socket (1) | Max send buffers used during socket life: 3 | 2022-08-05 14:16:53.805 DTC Client socket (1) | Max send buffer size during socket life: 329 | 2022-08-05 14:16:53.805 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:16:53.805 Connection to the external service has been lost. | 2022-08-05 14:16:53.805 DTC Client socket (1) | Closed. | 2022-08-05 14:16:53.805 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:53.818 SC Data - All Services | Sending logon request message. | 2022-08-05 14:16:53.818 Teton CME Order Routing | Waiting for socket receive thread to end | 2022-08-05 14:16:53.818 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:16:53.818 Teton CME Order Routing | Disconnected. | 2022-08-05 14:16:53.818 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-08-05 14:16:53.818 SC Data - All Services | Received logon response. | 2022-08-05 14:16:54.509 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:16:54.509 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:16:54.509 SC Data - All Services | Successfully connected. | 2022-08-05 14:16:54.509 SC Data - All Services | Trading is not supported. | 2022-08-05 14:16:54.509 Added historical Intraday data request for AAPL-NQTV to the queue. | 2022-08-05 14:16:54.509 Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'. | 2022-08-05 14:16:54.509 Triggering next historical data download in queue. | 2022-08-05 14:16:54.509 SC Data - All Services | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2022-08-05 14:16:54.509 HD Request # 16 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data | 2022-08-05 14:16:54.509 HD Request # 16 | Download start date-time: 2022-08-05 14:16:23.000000. File last date-time: 2022-08-05 14:16:23.000000 | 2022-08-05 14:16:54.509 HD Request # 16 | Using server: ds25.sierracharts.com port 10150 | 2022-08-05 14:16:54.509 Socket (1) | Creating socket. | 2022-08-05 14:16:54.510 Socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:16:54.510 Socket (1) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:16:54.510 SC DTC Data with Market Depth | Connecting to the server ds13-3.sierracharts.com. Port 443 | 2022-08-05 14:16:54.610 DTC Client socket (4) | Creating socket. | 2022-08-05 14:16:54.611 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:16:54.611 DTC Client socket (4) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:16:54.611 HD Request # 16 | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:54.652 HD Request # 16 | Sending historical data logon request message. | 2022-08-05 14:16:54.652 SC Data - All Services | Received security definition for symbol AAPL-NQTV | 2022-08-05 14:16:54.667 SC DTC Data with Market Depth | Network connection to server complete. | 2022-08-05 14:16:54.680 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-08-05 14:16:54.680 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:16:54.680 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:54.802 SC DTC Data with Market Depth | Sending logon request message. | 2022-08-05 14:16:54.802 HD Request # 16 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:23. Record interval: 1. Symbol: AAPL-NQTV | 2022-08-05 14:16:55.186 HD Request # 16 | Decompressing data. | 2022-08-05 14:16:55.258 HD Request # 16 | Receiving Intraday data for AAPL-NQTV starting at 2022-08-05 14:16:23.058000 | 2022-08-05 14:16:55.258 Socket (1) | CloseSocket call. | 2022-08-05 14:16:55.258 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:16:55.258 Historical data download thread signaled to stop. | 2022-08-05 14:16:55.299 HD Request # 16 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:23.058000. | 2022-08-05 14:16:55.299 HD Request # 16 | Received 27 Intraday data records from 2022-08-05 14:16:23.058000 to 2022-08-05 14:16:55.089000 (32.0 seconds) and wrote 27 records for AAPL-NQTV | 2022-08-05 14:16:55.300 HD Request # 16 | Completion time: 1s. | 2022-08-05 14:16:55.300 HD Request # 16 | Intraday data download complete for AAPL-NQTV. Unique request ID: 16 | 2022-08-05 14:16:55.300 Removing historical data download ID 16. | 2022-08-05 14:16:55.300 HD Request # 16 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:16:55.300 Triggering next historical data download in queue. | 2022-08-05 14:16:55.300 Historical data for AAPL-NQTV is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-08-05 14:16:55.300 No download requests in the queue to start downloads for. | 2022-08-05 14:16:55.300 Socket (1) | Socket gracefully closed by remote side. | 2022-08-05 14:16:55.324 Socket (1) | Closed. | 2022-08-05 14:16:55.324 SC DTC Data with Market Depth | Received logon response. | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Successfully connected. | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Trading is not supported. | 2022-08-05 14:16:55.593 Added historical Intraday data request for EURUSD to the queue. | 2022-08-05 14:16:55.593 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2022-08-05 14:16:55.593 Triggering next historical data download in queue. | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-08-05 14:16:55.593 Added historical Intraday data request for US30 to the queue. | 2022-08-05 14:16:55.593 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2022-08-05 14:16:55.593 Added historical Intraday data request for USOil to the queue. | 2022-08-05 14:16:55.593 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2022-08-05 14:16:55.593 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 14:16:55.593 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-08-05 14:16:55.593 HD Request # 17 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2022-08-05 14:16:55.593 HD Request # 17 | Download start date-time: 2022-08-05 14:16:22.000000. File last date-time: 2022-08-05 14:16:22.000000 | 2022-08-05 14:16:55.593 HD Request # 17 | Using server: ds12.sierracharts.com port 10149 | 2022-08-05 14:16:55.593 Socket (1) | Creating socket. | 2022-08-05 14:16:55.594 Socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:16:55.594 Socket (1) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:16:55.594 HD Request # 17 | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:55.733 HD Request # 17 | Sending historical data logon request message. | 2022-08-05 14:16:55.733 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2022-08-05 14:16:55.805 SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-08-05 14:16:55.805 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2022-08-05 14:16:55.805 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2022-08-05 14:16:55.805 SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-08-05 14:16:55.805 Teton CME Order Routing | Firm: Dorman | 2022-08-05 14:16:55.807 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-08-05 14:16:55.807 DTC Client socket (5) | Creating socket. Using TLS 1.2. | 2022-08-05 14:16:55.808 DTC Client socket (5) | New receive buffer size: 5242880 | 2022-08-05 14:16:55.808 DTC Client socket (5) | Connecting to IP: 208.185.224.129. | 2022-08-05 14:16:55.808 Teton CME Order Routing | Network connection to server complete. | 2022-08-05 14:16:55.867 Teton CME Order Routing | Starting socket receive thread. | 2022-08-05 14:16:55.867 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-08-05 14:16:55.867 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:56.075 Teton CME Order Routing | Sending logon request message. | 2022-08-05 14:16:56.075 HD Request # 17 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:22. Record interval: 1. Symbol: EURUSD | 2022-08-05 14:16:56.314 HD Request # 17 | Decompressing data. | 2022-08-05 14:16:56.382 HD Request # 17 | Receiving Intraday data for EURUSD starting at 2022-08-05 14:16:22.008000 | 2022-08-05 14:16:56.382 Socket (1) | CloseSocket call. | 2022-08-05 14:16:56.382 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:16:56.382 Historical data download thread signaled to stop. | 2022-08-05 14:16:56.382 HD Request # 17 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:22.008000. | 2022-08-05 14:16:56.382 HD Request # 17 | Received 31 Intraday data records from 2022-08-05 14:16:22.008000 to 2022-08-05 14:16:54.028000 (32.0 seconds) and wrote 31 records for EURUSD | 2022-08-05 14:16:56.383 HD Request # 17 | Completion time: 1s. | 2022-08-05 14:16:56.383 HD Request # 17 | Intraday data download complete for EURUSD. Unique request ID: 17 | 2022-08-05 14:16:56.383 Removing historical data download ID 17. | 2022-08-05 14:16:56.383 HD Request # 17 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:16:56.383 Triggering next historical data download in queue. | 2022-08-05 14:16:56.383 Historical data for EURUSD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-08-05 14:16:56.383 HD Request # 18 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 14:16:56.383 HD Request # 18 | Download start date-time: 2022-08-05 14:16:23.000000. File last date-time: 2022-08-05 14:16:23.000000 | 2022-08-05 14:16:56.383 HD Request # 18 | Using server: ds13-3.sierracharts.com port 10150 | 2022-08-05 14:16:56.383 Socket (6) | Creating socket. | 2022-08-05 14:16:56.383 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:16:56.383 Socket (6) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:16:56.383 Socket (1) | Socket gracefully closed by remote side. | 2022-08-05 14:16:56.455 Socket (1) | Closed. | 2022-08-05 14:16:56.455 HD Request # 18 | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:56.521 HD Request # 18 | Sending historical data logon request message. | 2022-08-05 14:16:56.521 Teton CME Order Routing | Received logon response. | 2022-08-05 14:16:56.608 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-08-05 14:16:56.608 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:16:56.608 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-08-05 14:16:56.608 Teton CME Order Routing | Trading is supported. | 2022-08-05 14:16:56.608 Teton CME Order Routing | Order cancel and replace is supported. | 2022-08-05 14:16:56.608 Teton CME Order Routing | OCO Orders supported. | 2022-08-05 14:16:56.608 Teton CME Order Routing | Bracket Orders supported. | 2022-08-05 14:16:56.608 Teton CME Order Routing | Connected to server complete. | 2022-08-05 14:16:56.608 Triggering next historical data download in queue. | 2022-08-05 14:16:56.609 Triggering next historical data download in queue. | 2022-08-05 14:16:56.609 Triggering next historical data download in queue. | 2022-08-05 14:16:56.609 Triggering next historical data download in queue. | 2022-08-05 14:16:56.609 Updated verified funded futures trading account ending date to: 2022-09-04 14:16:56 | 2022-08-05 14:16:56.609 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-08-05 14:16:56.621 No download requests in the queue to start downloads for. | 2022-08-05 14:16:56.621 No download requests in the queue to start downloads for. | 2022-08-05 14:16:56.621 No download requests in the queue to start downloads for. | 2022-08-05 14:16:56.621 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 00:00:00.000000 | 2022-08-05 14:16:56.633 Updated verified funded futures trading account ending date to: 2022-09-04 14:16:56 | 2022-08-05 14:16:56.683 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43878 | 2022-08-05 14:16:56.692 HD Request # 18 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:23. Record interval: 1. Symbol: US30 | 2022-08-05 14:16:57.227 HD Request # 18 | Decompressing data. | 2022-08-05 14:16:57.303 HD Request # 18 | Receiving Intraday data for US30 starting at 2022-06-07 14:04:01.627000 | 2022-08-05 14:16:57.442 Socket (6) | CloseSocket call. | 2022-08-05 14:16:57.443 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:16:57.443 Historical data download thread signaled to stop. | 2022-08-05 14:16:57.443 HD Request # 18 | Received 1510 Intraday data records from 2022-06-07 14:04:01.627000 to 2022-06-07 15:03:42.116000 (59.7 minutes) and wrote 0 records for US30 | 2022-08-05 14:16:57.443 HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:16:23.000000 | 2022-08-05 14:16:57.444 HD Request # 18 | Completion time: 1s. | 2022-08-05 14:16:57.444 HD Request # 18 | Intraday data download complete for US30. Unique request ID: 18 | 2022-08-05 14:16:57.444 Removing historical data download ID 18. | 2022-08-05 14:16:57.444 Real-time Intraday chart data file updates started for US30 | 2022-08-05 14:16:57.444 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 14:16:57.444 Intraday chart data file opened for US30 | 2022-08-05 14:16:57.444 HD Request # 18 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:16:57.444 Triggering next historical data download in queue. | 2022-08-05 14:16:57.444 Initiating new historical data download for US30 to get the latest data since the download was started while not connected to primary service. | 2022-08-05 14:16:57.444 Added historical Intraday data request for US30 to the queue. | 2022-08-05 14:16:57.444 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 14:16:57.444 HD Request # 19 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 14:16:57.444 HD Request # 19 | Download start date-time: 2022-08-05 14:16:23.000000. File last date-time: 2022-08-05 14:16:23.000000 | 2022-08-05 14:16:57.444 HD Request # 19 | Using server: ds4.sierracharts.com port 10149 | 2022-08-05 14:16:57.444 Socket (1) | Creating socket. | 2022-08-05 14:16:57.444 Socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:16:57.444 Socket (1) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:16:57.444 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:16:57.507 Socket (6) | Closed. | 2022-08-05 14:16:57.507 HD Request # 19 | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:57.575 HD Request # 19 | Sending historical data logon request message. | 2022-08-05 14:16:57.575 HD Request # 19 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:23. Record interval: 1. Symbol: US30 | 2022-08-05 14:16:58.154 HD Request # 19 | Decompressing data. | 2022-08-05 14:16:58.211 HD Request # 19 | Receiving Intraday data for US30 starting at 2022-08-05 14:16:23.012000 | 2022-08-05 14:16:58.211 Socket (1) | CloseSocket call. | 2022-08-05 14:16:58.212 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:16:58.212 Historical data download thread signaled to stop. | 2022-08-05 14:16:58.212 HD Request # 19 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:23.012000. | 2022-08-05 14:16:58.212 HD Request # 19 | Received 35 Intraday data records from 2022-08-05 14:16:23.012000 to 2022-08-05 14:16:57.014000 (34.0 seconds) and wrote 35 records for US30 | 2022-08-05 14:16:58.212 HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:16:57.014000 | 2022-08-05 14:16:58.216 HD Request # 19 | Completion time: 1s. | 2022-08-05 14:16:58.216 HD Request # 19 | Intraday data download complete for US30. Unique request ID: 21 | 2022-08-05 14:16:58.216 Removing historical data download ID 21. | 2022-08-05 14:16:58.216 Real-time Intraday chart data file updates started for US30 | 2022-08-05 14:16:58.216 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 14:16:58.216 Intraday chart data file opened for US30 | 2022-08-05 14:16:58.216 HD Request # 19 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:16:58.216 Triggering next historical data download in queue. | 2022-08-05 14:16:58.216 HD Request # 20 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2022-08-05 14:16:58.216 HD Request # 20 | Download start date-time: 2022-08-05 14:16:22.000000. File last date-time: 2022-08-05 14:16:22.000000 | 2022-08-05 14:16:58.216 HD Request # 20 | Using server: ds12.sierracharts.com port 10150 | 2022-08-05 14:16:58.216 Socket (6) | Creating socket. | 2022-08-05 14:16:58.216 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:16:58.216 Socket (6) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:16:58.216 Socket (1) | Socket gracefully closed by remote side. | 2022-08-05 14:16:58.271 Socket (1) | Closed. | 2022-08-05 14:16:58.271 HD Request # 20 | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:58.357 HD Request # 20 | Sending historical data logon request message. | 2022-08-05 14:16:58.357 HD Request # 20 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:22. Record interval: 1. Symbol: USOil | 2022-08-05 14:16:58.940 HD Request # 20 | Decompressing data. | 2022-08-05 14:16:59.004 HD Request # 20 | Receiving Intraday data for USOil starting at 2022-08-05 14:16:22.600000 | 2022-08-05 14:16:59.005 Socket (6) | CloseSocket call. | 2022-08-05 14:16:59.005 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:16:59.005 Historical data download thread signaled to stop. | 2022-08-05 14:16:59.005 HD Request # 20 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:22.600000. | 2022-08-05 14:16:59.005 HD Request # 20 | Received 33 Intraday data records from 2022-08-05 14:16:22.600000 to 2022-08-05 14:16:57.014000 (34.4 seconds) and wrote 33 records for USOil | 2022-08-05 14:16:59.005 HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:16:57.014000 | 2022-08-05 14:16:59.009 HD Request # 20 | Completion time: 1s. | 2022-08-05 14:16:59.009 HD Request # 20 | Intraday data download complete for USOil. Unique request ID: 19 | 2022-08-05 14:16:59.009 Removing historical data download ID 19. | 2022-08-05 14:16:59.009 Real-time Intraday chart data file updates started for USOil | 2022-08-05 14:16:59.009 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 15072 | 2022-08-05 14:16:59.009 Intraday chart data file opened for USOil | 2022-08-05 14:16:59.009 HD Request # 20 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:16:59.009 Triggering next historical data download in queue. | 2022-08-05 14:16:59.009 HD Request # 21 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 14:16:59.009 HD Request # 21 | Download start date-time: 2022-08-05 14:16:22.000000. File last date-time: 2022-08-05 14:16:22.000000 | 2022-08-05 14:16:59.010 HD Request # 21 | Using server: ds13-3.sierracharts.com port 10149 | 2022-08-05 14:16:59.010 Socket (1) | Creating socket. | 2022-08-05 14:16:59.010 Socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:16:59.010 Socket (1) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:16:59.010 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:16:59.066 Socket (6) | Closed. | 2022-08-05 14:16:59.066 HD Request # 21 | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:59.138 HD Request # 21 | Sending historical data logon request message. | 2022-08-05 14:16:59.138 HD Request # 21 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:22. Record interval: 1. Symbol: XAUUSD | 2022-08-05 14:16:59.827 HD Request # 21 | Decompressing data. | 2022-08-05 14:16:59.890 HD Request # 21 | Receiving Intraday data for XAUUSD starting at 2022-08-05 14:16:22.719000 | 2022-08-05 14:16:59.890 Socket (1) | CloseSocket call. | 2022-08-05 14:16:59.890 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:16:59.890 Historical data download thread signaled to stop. | 2022-08-05 14:16:59.891 HD Request # 21 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:22.719000. | 2022-08-05 14:16:59.891 HD Request # 21 | Received 37 Intraday data records from 2022-08-05 14:16:22.719000 to 2022-08-05 14:16:58.100000 (35.4 seconds) and wrote 37 records for XAUUSD | 2022-08-05 14:16:59.891 HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:16:58.100000 | 2022-08-05 14:16:59.894 Added 1 Time and Sales records to Intraday data file for XAUUSD after download. | 2022-08-05 14:16:59.894 HD Request # 21 | Completion time: 0s. | 2022-08-05 14:16:59.895 HD Request # 21 | Intraday data download complete for XAUUSD. Unique request ID: 20 | 2022-08-05 14:16:59.895 Removing historical data download ID 20. | 2022-08-05 14:16:59.895 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-05 14:16:59.895 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 15072 | 2022-08-05 14:16:59.897 Intraday chart data file opened for XAUUSD | 2022-08-05 14:16:59.898 HD Request # 21 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:16:59.898 Triggering next historical data download in queue. | 2022-08-05 14:16:59.898 No download requests in the queue to start downloads for. | 2022-08-05 14:16:59.898 Socket (1) | Socket gracefully closed by remote side. | 2022-08-05 14:16:59.962 Socket (1) | Closed. | 2022-08-05 14:16:59.962 DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:17:56.027 * DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-08-05 14:17:56.027 DTC Client socket (4) | CloseSocket call. | 2022-08-05 14:17:56.027 DTC Client socket (4) | Max send buffers used during socket life: 4 | 2022-08-05 14:17:56.027 DTC Client socket (4) | Max send buffer size during socket life: 354 | 2022-08-05 14:17:56.027 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:17:56.027 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-08-05 14:17:56.028 DTC Client socket (4) | Closed. | 2022-08-05 14:17:56.028 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:17:56.028 SC DTC Data with Market Depth | Disconnected from the server. | 2022-08-05 14:17:56.028 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:17:56.028 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2022-08-05 14:17:58.031 DTC Client socket (1) | Creating socket. | 2022-08-05 14:17:58.031 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:17:58.031 DTC Client socket (1) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:17:58.031 SC DTC Data with Market Depth | Network connection to server complete. | 2022-08-05 14:17:58.094 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-08-05 14:17:58.094 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:17:58.094 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-08-05 14:17:58.163 SC DTC Data with Market Depth | Sending logon request message. | 2022-08-05 14:17:58.163 SC DTC Data with Market Depth | Received logon response. | 2022-08-05 14:17:58.848 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-08-05 14:17:58.848 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:17:58.848 SC DTC Data with Market Depth | Successfully connected. | 2022-08-05 14:17:58.848 SC DTC Data with Market Depth | Trading is not supported. | 2022-08-05 14:17:58.848 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-08-05 14:17:58.848 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-08-05 14:17:58.848 Added historical Intraday data request for US30 to the queue. | 2022-08-05 14:17:58.849 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 14:17:58.849 Triggering next historical data download in queue. | 2022-08-05 14:17:58.849 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2022-08-05 14:17:58.849 Added historical Intraday data request for USOil to the queue. | 2022-08-05 14:17:58.849 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2022-08-05 14:17:58.849 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2022-08-05 14:17:58.849 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 14:17:58.849 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 14:17:58.849 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-08-05 14:17:58.849 HD Request # 22 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 14:17:58.849 HD Request # 22 | Download start date-time: 2022-08-05 14:16:57.000000. File last date-time: 2022-08-05 14:16:57.014000 | 2022-08-05 14:17:58.849 HD Request # 22 | Using server: ds4.sierracharts.com port 10150 | 2022-08-05 14:17:58.849 Socket (4) | Creating socket. | 2022-08-05 14:17:58.849 Socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:17:58.849 Socket (4) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:17:58.849 HD Request # 22 | Setting DTC encoding to Binary VLS | 2022-08-05 14:17:58.992 HD Request # 22 | Sending historical data logon request message. | 2022-08-05 14:17:58.992 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2022-08-05 14:17:59.004 SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-08-05 14:17:59.004 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2022-08-05 14:17:59.004 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2022-08-05 14:17:59.004 SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-08-05 14:17:59.004 HD Request # 22 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:57. Record interval: 1. Symbol: US30 | 2022-08-05 14:17:59.565 HD Request # 22 | Decompressing data. | 2022-08-05 14:17:59.631 HD Request # 22 | Receiving Intraday data for US30 starting at 2022-08-05 14:16:57.014000 | 2022-08-05 14:17:59.633 Socket (4) | CloseSocket call. | 2022-08-05 14:17:59.633 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:17:59.634 Historical data download thread signaled to stop. | 2022-08-05 14:17:59.634 HD Request # 22 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:57.014000. | 2022-08-05 14:17:59.634 HD Request # 22 | Received 62 Intraday data records from 2022-08-05 14:16:57.014000 to 2022-08-05 14:17:58.021000 (61.0 seconds) and wrote 62 records for US30 | 2022-08-05 14:17:59.634 HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:17:58.021000 | 2022-08-05 14:17:59.638 Added 1 Time and Sales records to Intraday data file for US30 after download. | 2022-08-05 14:17:59.638 HD Request # 22 | Completion time: 1s. | 2022-08-05 14:17:59.638 HD Request # 22 | Intraday data download complete for US30. Unique request ID: 22 | 2022-08-05 14:17:59.638 Removing historical data download ID 22. | 2022-08-05 14:17:59.638 Real-time Intraday chart data file updates started for US30 | 2022-08-05 14:17:59.638 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 14:17:59.641 Intraday chart data file opened for US30 | 2022-08-05 14:17:59.641 HD Request # 22 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:17:59.641 Triggering next historical data download in queue. | 2022-08-05 14:17:59.641 HD Request # 23 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2022-08-05 14:17:59.641 HD Request # 23 | Download start date-time: 2022-08-05 14:17:51.000000. File last date-time: 2022-08-05 14:17:51.000000 | 2022-08-05 14:17:59.641 HD Request # 23 | Using server: ds12.sierracharts.com port 10149 | 2022-08-05 14:17:59.641 Socket (6) | Creating socket. | 2022-08-05 14:17:59.641 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:17:59.641 Socket (6) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:17:59.641 Socket (4) | Socket gracefully closed by remote side. | 2022-08-05 14:17:59.711 Socket (4) | Closed. | 2022-08-05 14:17:59.711 HD Request # 23 | Setting DTC encoding to Binary VLS | 2022-08-05 14:17:59.825 HD Request # 23 | Sending historical data logon request message. | 2022-08-05 14:17:59.825 HD Request # 23 | Requesting Intraday data. Start date-time: 2022-08-05 14:17:51. Record interval: 1. Symbol: USOil | 2022-08-05 14:18:00.410 HD Request # 23 | Decompressing data. | 2022-08-05 14:18:00.478 HD Request # 23 | Receiving Intraday data for USOil starting at 2022-08-05 14:17:51.542000 | 2022-08-05 14:18:00.478 Socket (6) | CloseSocket call. | 2022-08-05 14:18:00.478 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:18:00.478 Historical data download thread signaled to stop. | 2022-08-05 14:18:00.479 HD Request # 23 | Timestamp of first Intraday data file record written: 2022-08-05 14:17:51.542000. | 2022-08-05 14:18:00.479 HD Request # 23 | Received 8 Intraday data records from 2022-08-05 14:17:51.542000 to 2022-08-05 14:17:58.477000 (6.9 seconds) and wrote 8 records for USOil | 2022-08-05 14:18:00.479 HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:17:58.477000 | 2022-08-05 14:18:00.483 Added 2 Time and Sales records to Intraday data file for USOil after download. | 2022-08-05 14:18:00.483 HD Request # 23 | Completion time: 1s. | 2022-08-05 14:18:00.483 HD Request # 23 | Intraday data download complete for USOil. Unique request ID: 23 | 2022-08-05 14:18:00.483 Removing historical data download ID 23. | 2022-08-05 14:18:00.483 Real-time Intraday chart data file updates started for USOil | 2022-08-05 14:18:00.483 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 15072 | 2022-08-05 14:18:00.485 Intraday chart data file opened for USOil | 2022-08-05 14:18:00.485 HD Request # 23 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:18:00.485 Triggering next historical data download in queue. | 2022-08-05 14:18:00.485 HD Request # 24 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 14:18:00.485 HD Request # 24 | Download start date-time: 2022-08-05 14:17:51.000000. File last date-time: 2022-08-05 14:17:51.000000 | 2022-08-05 14:18:00.486 HD Request # 24 | Using server: ds13-3.sierracharts.com port 10150 | 2022-08-05 14:18:00.486 Socket (4) | Creating socket. | 2022-08-05 14:18:00.486 Socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:18:00.486 Socket (4) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:18:00.486 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:18:00.540 Socket (6) | Closed. | 2022-08-05 14:18:00.540 HD Request # 24 | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:00.614 HD Request # 24 | Sending historical data logon request message. | 2022-08-05 14:18:00.614 HD Request # 24 | Requesting Intraday data. Start date-time: 2022-08-05 14:17:51. Record interval: 1. Symbol: XAUUSD | 2022-08-05 14:18:01.344 HD Request # 24 | Decompressing data. | 2022-08-05 14:18:01.414 HD Request # 24 | Receiving Intraday data for XAUUSD starting at 2022-08-05 14:17:51.788000 | 2022-08-05 14:18:01.415 Socket (4) | CloseSocket call. | 2022-08-05 14:18:01.415 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:18:01.415 Historical data download thread signaled to stop. | 2022-08-05 14:18:01.415 HD Request # 24 | Timestamp of first Intraday data file record written: 2022-08-05 14:17:51.788000. | 2022-08-05 14:18:01.415 HD Request # 24 | Received 9 Intraday data records from 2022-08-05 14:17:51.788000 to 2022-08-05 14:18:00.103000 (8.3 seconds) and wrote 9 records for XAUUSD | 2022-08-05 14:18:01.415 HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:18:00.103000 | 2022-08-05 14:18:01.419 Added 1 Time and Sales records to Intraday data file for XAUUSD after download. | 2022-08-05 14:18:01.419 HD Request # 24 | Completion time: 1s. | 2022-08-05 14:18:01.419 HD Request # 24 | Intraday data download complete for XAUUSD. Unique request ID: 24 | 2022-08-05 14:18:01.419 Removing historical data download ID 24. | 2022-08-05 14:18:01.419 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-05 14:18:01.419 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 15072 | 2022-08-05 14:18:01.422 Intraday chart data file opened for XAUUSD | 2022-08-05 14:18:01.422 HD Request # 24 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:18:01.422 Triggering next historical data download in queue. | 2022-08-05 14:18:01.422 No download requests in the queue to start downloads for. | 2022-08-05 14:18:01.422 Socket (4) | Socket gracefully closed by remote side. | 2022-08-05 14:18:01.479 Socket (4) | Closed. | 2022-08-05 14:18:01.479 DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:18:14.384 * DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-08-05 14:18:14.384 DTC Client socket (2) | CloseSocket call. | 2022-08-05 14:18:14.384 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:18:14.384 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:18:14.384 DTC Client socket (2) | Closed. | 2022-08-05 14:18:14.384 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:18:14.385 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:18:14.385 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:18:14.385 SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 10048 | 2022-08-05 14:18:16.393 DTC Client socket (2) | Creating socket. | 2022-08-05 14:18:16.393 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-08-05 14:18:16.393 DTC Client socket (2) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:18:16.393 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:18:16.453 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:18:16.453 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-08-05 14:18:16.453 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:16.550 SC Data - All Services | Sending logon request message. | 2022-08-05 14:18:16.550 DTC Client socket (5) | Socket gracefully closed by remote side. | 2022-08-05 14:18:16.563 DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:18:16.563 * DTC Client socket (5) | CloseSocket call. | 2022-08-05 14:18:16.563 DTC Client socket (5) | Max send buffers used during socket life: 3 | 2022-08-05 14:18:16.563 DTC Client socket (5) | Max send buffer size during socket life: 236 | 2022-08-05 14:18:16.563 Connection to the external service has been lost. | 2022-08-05 14:18:16.563 DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:18:16.563 DTC Client socket (5) | Closed. | 2022-08-05 14:18:16.563 Teton CME Order Routing | Waiting for socket receive thread to end | 2022-08-05 14:18:16.575 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:18:16.576 Teton CME Order Routing | Disconnected. | 2022-08-05 14:18:16.576 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-08-05 14:18:16.576 SC Data - All Services | Received logon response. | 2022-08-05 14:18:17.238 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:18:17.238 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:18:17.238 SC Data - All Services | Successfully connected. | 2022-08-05 14:18:17.238 SC Data - All Services | Trading is not supported. | 2022-08-05 14:18:17.238 SC Data - All Services | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2022-08-05 14:18:17.238 SC Data - All Services | Received security definition for symbol AAPL-NQTV | 2022-08-05 14:18:17.395 Teton CME Order Routing | Firm: Dorman | 2022-08-05 14:18:18.575 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-08-05 14:18:18.575 DTC Client socket (4) | Creating socket. Using TLS 1.2. | 2022-08-05 14:18:18.575 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:18:18.575 DTC Client socket (4) | Connecting to IP: 208.185.224.129. | 2022-08-05 14:18:18.575 Teton CME Order Routing | Network connection to server complete. | 2022-08-05 14:18:18.640 Teton CME Order Routing | Starting socket receive thread. | 2022-08-05 14:18:18.640 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-08-05 14:18:18.641 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:18.824 Teton CME Order Routing | Sending logon request message. | 2022-08-05 14:18:18.824 Teton CME Order Routing | Received logon response. | 2022-08-05 14:18:19.359 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-08-05 14:18:19.359 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:18:19.359 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-08-05 14:18:19.359 Teton CME Order Routing | Trading is supported. | 2022-08-05 14:18:19.359 Teton CME Order Routing | Order cancel and replace is supported. | 2022-08-05 14:18:19.359 Teton CME Order Routing | OCO Orders supported. | 2022-08-05 14:18:19.359 Teton CME Order Routing | Bracket Orders supported. | 2022-08-05 14:18:19.359 Teton CME Order Routing | Connected to server complete. | 2022-08-05 14:18:19.359 Triggering next historical data download in queue. | 2022-08-05 14:18:19.359 Triggering next historical data download in queue. | 2022-08-05 14:18:19.359 Triggering next historical data download in queue. | 2022-08-05 14:18:19.359 Triggering next historical data download in queue. | 2022-08-05 14:18:19.359 Updated verified funded futures trading account ending date to: 2022-09-04 14:18:19 | 2022-08-05 14:18:19.359 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-08-05 14:18:19.371 No download requests in the queue to start downloads for. | 2022-08-05 14:18:19.371 No download requests in the queue to start downloads for. | 2022-08-05 14:18:19.371 No download requests in the queue to start downloads for. | 2022-08-05 14:18:19.371 No download requests in the queue to start downloads for. | 2022-08-05 14:18:19.371 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 00:00:00.000000 | 2022-08-05 14:18:19.383 Updated verified funded futures trading account ending date to: 2022-09-04 14:18:19 | 2022-08-05 14:18:19.434 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43878 | 2022-08-05 14:18:19.453 DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:18:24.860 DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:18:24.860 * DTC Client socket (3) | CloseSocket call. | 2022-08-05 14:18:24.861 DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:18:24.861 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:18:24.861 DTC Client socket (3) | Closed. | 2022-08-05 14:18:24.861 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:18:24.861 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:18:24.861 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:18:24.861 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2022-08-05 14:18:26.867 DTC Client socket (3) | Creating socket. | 2022-08-05 14:18:26.867 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:18:26.867 DTC Client socket (3) | Connecting to IP: 216.1.90.130. | 2022-08-05 14:18:26.867 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:18:26.924 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:18:26.924 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:18:26.924 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:27.020 SC Data - All Services | Sending logon request message. | 2022-08-05 14:18:27.020 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:18:39.496 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-08-05 14:18:39.496 DTC Client socket (1) | CloseSocket call. | 2022-08-05 14:18:39.496 DTC Client socket (1) | Max send buffers used during socket life: 3 | 2022-08-05 14:18:39.496 DTC Client socket (1) | Max send buffer size during socket life: 354 | 2022-08-05 14:18:39.496 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:18:39.496 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-08-05 14:18:39.496 DTC Client socket (1) | Closed. | 2022-08-05 14:18:39.496 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:18:39.497 SC DTC Data with Market Depth | Disconnected from the server. | 2022-08-05 14:18:39.497 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:18:39.497 SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2022-08-05 14:18:41.502 DTC Client socket (1) | Creating socket. | 2022-08-05 14:18:41.502 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:18:41.502 DTC Client socket (1) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:18:41.502 SC DTC Data with Market Depth | Network connection to server complete. | 2022-08-05 14:18:41.567 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-08-05 14:18:41.567 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:18:41.567 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:41.664 SC DTC Data with Market Depth | Sending logon request message. | 2022-08-05 14:18:41.664 SC DTC Data with Market Depth | Received logon response. | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Successfully connected. | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Trading is not supported. | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-08-05 14:18:42.351 Added historical Intraday data request for US30 to the queue. | 2022-08-05 14:18:42.351 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 14:18:42.351 Triggering next historical data download in queue. | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2022-08-05 14:18:42.351 Added historical Intraday data request for USOil to the queue. | 2022-08-05 14:18:42.351 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2022-08-05 14:18:42.351 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 14:18:42.351 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-08-05 14:18:42.351 HD Request # 25 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 14:18:42.351 HD Request # 25 | Download start date-time: 2022-08-05 14:18:27.000000. File last date-time: 2022-08-05 14:18:27.000000 | 2022-08-05 14:18:42.352 HD Request # 25 | Using server: ds4.sierracharts.com port 10149 | 2022-08-05 14:18:42.352 Socket (5) | Creating socket. | 2022-08-05 14:18:42.352 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 14:18:42.352 Socket (5) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:18:42.352 HD Request # 25 | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:42.480 HD Request # 25 | Sending historical data logon request message. | 2022-08-05 14:18:42.480 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2022-08-05 14:18:42.508 SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-08-05 14:18:42.508 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2022-08-05 14:18:42.508 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2022-08-05 14:18:42.508 SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-08-05 14:18:42.508 HD Request # 25 | Requesting Intraday data. Start date-time: 2022-08-05 14:18:27. Record interval: 1. Symbol: US30 | 2022-08-05 14:18:43.064 HD Request # 25 | Decompressing data. | 2022-08-05 14:18:43.125 HD Request # 25 | Receiving Intraday data for US30 starting at 2022-08-05 14:18:27.089000 | 2022-08-05 14:18:43.125 Socket (5) | CloseSocket call. | 2022-08-05 14:18:43.125 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:18:43.126 Historical data download thread signaled to stop. | 2022-08-05 14:18:43.126 HD Request # 25 | Timestamp of first Intraday data file record written: 2022-08-05 14:18:27.089000. | 2022-08-05 14:18:43.126 HD Request # 25 | Received 16 Intraday data records from 2022-08-05 14:18:27.089000 to 2022-08-05 14:18:42.009000 (14.9 seconds) and wrote 16 records for US30 | 2022-08-05 14:18:43.126 HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:18:42.009000 | 2022-08-05 14:18:43.130 Added 1 Time and Sales records to Intraday data file for US30 after download. | 2022-08-05 14:18:43.130 HD Request # 25 | Completion time: 1s. | 2022-08-05 14:18:43.130 HD Request # 25 | Intraday data download complete for US30. Unique request ID: 25 | 2022-08-05 14:18:43.130 Removing historical data download ID 25. | 2022-08-05 14:18:43.130 Real-time Intraday chart data file updates started for US30 | 2022-08-05 14:18:43.130 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 14:18:43.134 Intraday chart data file opened for US30 | 2022-08-05 14:18:43.134 HD Request # 25 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:18:43.134 Triggering next historical data download in queue. | 2022-08-05 14:18:43.134 HD Request # 26 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2022-08-05 14:18:43.134 HD Request # 26 | Download start date-time: 2022-08-05 14:18:26.000000. File last date-time: 2022-08-05 14:18:26.000000 | 2022-08-05 14:18:43.134 HD Request # 26 | Using server: ds12.sierracharts.com port 10150 | 2022-08-05 14:18:43.134 Socket (6) | Creating socket. | 2022-08-05 14:18:43.134 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:18:43.134 Socket (6) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:18:43.134 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 14:18:43.192 Socket (5) | Closed. | 2022-08-05 14:18:43.192 HD Request # 26 | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:43.286 HD Request # 26 | Sending historical data logon request message. | 2022-08-05 14:18:43.286 HD Request # 26 | Requesting Intraday data. Start date-time: 2022-08-05 14:18:26. Record interval: 1. Symbol: USOil | 2022-08-05 14:18:43.867 HD Request # 26 | Decompressing data. | 2022-08-05 14:18:43.933 HD Request # 26 | Receiving Intraday data for USOil starting at 2022-08-05 14:18:26.556000 | 2022-08-05 14:18:43.933 Socket (6) | CloseSocket call. | 2022-08-05 14:18:43.933 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:18:43.933 Historical data download thread signaled to stop. | 2022-08-05 14:18:43.933 HD Request # 26 | Timestamp of first Intraday data file record written: 2022-08-05 14:18:26.556000. | 2022-08-05 14:18:43.934 HD Request # 26 | Received 17 Intraday data records from 2022-08-05 14:18:26.556000 to 2022-08-05 14:18:43.042000 (16.5 seconds) and wrote 17 records for USOil | 2022-08-05 14:18:43.934 HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:18:43.042000 | 2022-08-05 14:18:43.938 HD Request # 26 | Completion time: 0s. | 2022-08-05 14:18:43.938 HD Request # 26 | Intraday data download complete for USOil. Unique request ID: 26 | 2022-08-05 14:18:43.938 Removing historical data download ID 26. | 2022-08-05 14:18:43.938 Real-time Intraday chart data file updates started for USOil | 2022-08-05 14:18:43.938 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 15072 | 2022-08-05 14:18:43.938 Intraday chart data file opened for USOil | 2022-08-05 14:18:43.938 HD Request # 26 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:18:43.938 Triggering next historical data download in queue. | 2022-08-05 14:18:43.938 HD Request # 27 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 14:18:43.938 HD Request # 27 | Download start date-time: 2022-08-05 14:18:27.000000. File last date-time: 2022-08-05 14:18:27.000000 | 2022-08-05 14:18:43.938 HD Request # 27 | Using server: ds13-3.sierracharts.com port 10149 | 2022-08-05 14:18:43.938 Socket (5) | Creating socket. | 2022-08-05 14:18:43.938 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 14:18:43.938 Socket (5) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:18:43.938 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:18:43.999 Socket (6) | Closed. | 2022-08-05 14:18:43.999 HD Request # 27 | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:44.077 HD Request # 27 | Sending historical data logon request message. | 2022-08-05 14:18:44.077 HD Request # 27 | Requesting Intraday data. Start date-time: 2022-08-05 14:18:27. Record interval: 1. Symbol: XAUUSD | 2022-08-05 14:18:44.821 HD Request # 27 | Decompressing data. | 2022-08-05 14:18:44.884 HD Request # 27 | Receiving Intraday data for XAUUSD starting at 2022-08-05 14:18:27.682000 | 2022-08-05 14:18:44.884 Socket (5) | CloseSocket call. | 2022-08-05 14:18:44.885 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:18:44.885 Historical data download thread signaled to stop. | 2022-08-05 14:18:44.885 HD Request # 27 | Timestamp of first Intraday data file record written: 2022-08-05 14:18:27.682000. | 2022-08-05 14:18:44.885 HD Request # 27 | Received 17 Intraday data records from 2022-08-05 14:18:27.682000 to 2022-08-05 14:18:44.289000 (16.6 seconds) and wrote 17 records for XAUUSD | 2022-08-05 14:18:44.885 HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:18:44.289000 | 2022-08-05 14:18:44.889 HD Request # 27 | Completion time: 1s. | 2022-08-05 14:18:44.889 HD Request # 27 | Intraday data download complete for XAUUSD. Unique request ID: 27 | 2022-08-05 14:18:44.889 Removing historical data download ID 27. | 2022-08-05 14:18:44.889 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-05 14:18:44.889 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 15072 | 2022-08-05 14:18:44.889 Intraday chart data file opened for XAUUSD | 2022-08-05 14:18:44.889 HD Request # 27 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:18:44.889 Triggering next historical data download in queue. | 2022-08-05 14:18:44.889 No download requests in the queue to start downloads for. | 2022-08-05 14:18:44.889 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 14:18:44.954 Socket (5) | Closed. | 2022-08-05 14:18:44.954 DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:18:56.838 * DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-08-05 14:18:56.838 DTC Client socket (2) | CloseSocket call. | 2022-08-05 14:18:56.838 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:18:56.838 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:18:56.838 DTC Client socket (2) | Closed. | 2022-08-05 14:18:56.838 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:18:56.839 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:18:56.839 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:18:56.839 SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 443 | 2022-08-05 14:18:58.846 DTC Client socket (2) | Creating socket. | 2022-08-05 14:18:58.847 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-08-05 14:18:58.847 DTC Client socket (2) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:18:58.847 DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:18:58.896 * DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-08-05 14:18:58.896 DTC Client socket (4) | CloseSocket call. | 2022-08-05 14:18:58.896 DTC Client socket (4) | Max send buffers used during socket life: 3 | 2022-08-05 14:18:58.896 DTC Client socket (4) | Max send buffer size during socket life: 329 | 2022-08-05 14:18:58.896 Connection to the external service has been lost. | 2022-08-05 14:18:58.896 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:18:58.896 DTC Client socket (4) | Closed. | 2022-08-05 14:18:58.896 Teton CME Order Routing | Waiting for socket receive thread to end | 2022-08-05 14:18:58.910 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:18:58.910 Teton CME Order Routing | Disconnected. | 2022-08-05 14:18:58.911 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-08-05 14:18:58.911 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:18:58.911 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:18:58.911 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-08-05 14:18:58.911 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:58.992 SC Data - All Services | Sending logon request message. | 2022-08-05 14:18:58.992 SC Data - All Services | Received logon response. | 2022-08-05 14:18:59.711 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:18:59.711 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:18:59.711 SC Data - All Services | Successfully connected. | 2022-08-05 14:18:59.711 SC Data - All Services | Trading is not supported. | 2022-08-05 14:18:59.711 SC Data - All Services | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2022-08-05 14:18:59.711 SC Data - All Services | Received security definition for symbol AAPL-NQTV | 2022-08-05 14:18:59.868 Teton CME Order Routing | Firm: Dorman | 2022-08-05 14:19:00.905 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-08-05 14:19:00.905 DTC Client socket (4) | Creating socket. Using TLS 1.2. | 2022-08-05 14:19:00.905 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:19:00.905 DTC Client socket (4) | Connecting to IP: 208.185.224.129. | 2022-08-05 14:19:00.905 Teton CME Order Routing | Network connection to server complete. | 2022-08-05 14:19:00.968 Teton CME Order Routing | Starting socket receive thread. | 2022-08-05 14:19:00.968 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-08-05 14:19:00.969 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:01.156 Teton CME Order Routing | Sending logon request message. | 2022-08-05 14:19:01.156 Teton CME Order Routing | Received logon response. | 2022-08-05 14:19:01.218 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-08-05 14:19:01.218 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:19:01.218 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-08-05 14:19:01.218 Teton CME Order Routing | Trading is supported. | 2022-08-05 14:19:01.218 Teton CME Order Routing | Order cancel and replace is supported. | 2022-08-05 14:19:01.218 Teton CME Order Routing | OCO Orders supported. | 2022-08-05 14:19:01.218 Teton CME Order Routing | Bracket Orders supported. | 2022-08-05 14:19:01.218 Teton CME Order Routing | Connected to server complete. | 2022-08-05 14:19:01.218 Triggering next historical data download in queue. | 2022-08-05 14:19:01.219 Triggering next historical data download in queue. | 2022-08-05 14:19:01.219 Triggering next historical data download in queue. | 2022-08-05 14:19:01.219 Triggering next historical data download in queue. | 2022-08-05 14:19:01.219 Updated verified funded futures trading account ending date to: 2022-09-04 14:19:01 | 2022-08-05 14:19:01.219 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-08-05 14:19:01.231 No download requests in the queue to start downloads for. | 2022-08-05 14:19:01.231 No download requests in the queue to start downloads for. | 2022-08-05 14:19:01.231 No download requests in the queue to start downloads for. | 2022-08-05 14:19:01.231 No download requests in the queue to start downloads for. | 2022-08-05 14:19:01.231 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 00:00:00.000000 | 2022-08-05 14:19:01.242 Updated verified funded futures trading account ending date to: 2022-09-04 14:19:01 | 2022-08-05 14:19:01.291 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43878 | 2022-08-05 14:19:01.310 File >> Disconnect selected. | 2022-08-05 14:19:41.820 Teton CME Order Routing | Waiting for socket receive thread to end | 2022-08-05 14:19:41.833 DTC Client socket (4) | CloseSocket call. | 2022-08-05 14:19:41.833 DTC Client socket (4) | Max send buffers used during socket life: 3 | 2022-08-05 14:19:41.833 DTC Client socket (4) | Max send buffer size during socket life: 329 | 2022-08-05 14:19:41.833 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:41.833 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:19:41.833 DTC Client socket (3) | CloseSocket call. | 2022-08-05 14:19:41.834 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:19:41.834 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:19:41.834 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:41.834 DTC Client socket (2) | CloseSocket call. | 2022-08-05 14:19:41.834 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:19:41.834 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-08-05 14:19:41.834 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:41.834 DTC Client socket (1) | CloseSocket call. | 2022-08-05 14:19:41.834 DTC Client socket (1) | Max send buffers used during socket life: 3 | 2022-08-05 14:19:41.834 DTC Client socket (1) | Max send buffer size during socket life: 354 | 2022-08-05 14:19:41.834 SC DTC Data with Market Depth | Disconnected from the server. | 2022-08-05 14:19:41.834 Teton CME Order Routing | Disconnected. | 2022-08-05 14:19:41.834 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:41.834 DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-08-05 14:19:41.890 DTC Client socket (4) | Closed. | 2022-08-05 14:19:41.890 Teton CME Order Routing | Firm: Dorman | 2022-08-05 14:19:44.987 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-08-05 14:19:44.987 DTC Client socket (4) | Creating socket. Using TLS 1.2. | 2022-08-05 14:19:44.987 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:19:44.987 DTC Client socket (4) | Connecting to IP: 208.185.224.129. | 2022-08-05 14:19:44.987 Teton CME Order Routing | Network connection to server complete. | 2022-08-05 14:19:45.050 Teton CME Order Routing | Starting socket receive thread. | 2022-08-05 14:19:45.050 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-08-05 14:19:45.050 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:45.254 Teton CME Order Routing | Sending logon request message. | 2022-08-05 14:19:45.254 Teton CME Order Routing | Received logon response. | 2022-08-05 14:19:45.794 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-08-05 14:19:45.794 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:19:45.794 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-08-05 14:19:45.794 Teton CME Order Routing | Trading is supported. | 2022-08-05 14:19:45.794 Teton CME Order Routing | Order cancel and replace is supported. | 2022-08-05 14:19:45.794 Teton CME Order Routing | OCO Orders supported. | 2022-08-05 14:19:45.794 Teton CME Order Routing | Bracket Orders supported. | 2022-08-05 14:19:45.794 Teton CME Order Routing | Connected to server complete. | 2022-08-05 14:19:45.794 Triggering next historical data download in queue. | 2022-08-05 14:19:45.794 Triggering next historical data download in queue. | 2022-08-05 14:19:45.794 Triggering next historical data download in queue. | 2022-08-05 14:19:45.794 Triggering next historical data download in queue. | 2022-08-05 14:19:45.794 Updated verified funded futures trading account ending date to: 2022-09-04 14:19:45 | 2022-08-05 14:19:45.794 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-08-05 14:19:45.806 No download requests in the queue to start downloads for. | 2022-08-05 14:19:45.807 No download requests in the queue to start downloads for. | 2022-08-05 14:19:45.807 No download requests in the queue to start downloads for. | 2022-08-05 14:19:45.807 No download requests in the queue to start downloads for. | 2022-08-05 14:19:45.807 Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data | 2022-08-05 14:19:45.808 Using symbol data fast lookup vector | 2022-08-05 14:19:45.808 SC Data - All Services | Starting real-time market data updates for: AAPL-NQTV (AAPL-NQTV). ID: 1 Service code: nasdaq_exchange.data | 2022-08-05 14:19:45.808 SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 10048 | 2022-08-05 14:19:45.808 SC Data - All Services | Requesting security definition data for: AAPL-NQTV (AAPL-NQTV). ID: 1 | 2022-08-05 14:19:45.808 Added historical Intraday data request for AAPL-NQTV to the queue. | 2022-08-05 14:19:45.808 Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'. | 2022-08-05 14:19:45.808 Triggering next historical data download in queue. | 2022-08-05 14:19:45.808 Delaying start of download for AAPL-NQTV. | 2022-08-05 14:19:45.808 Using Bid/Ask average for last trade price for XAUUSD | 2022-08-05 14:19:45.808 SC DTC Data with Market Depth | Starting real-time market data updates for: XAUUSD. ID: 2 Service code: fxcm | 2022-08-05 14:19:45.808 SC DTC Data with Market Depth | Connecting to the server ds13-3.sierracharts.com. Port 10048 | 2022-08-05 14:19:45.808 DTC Client socket (5) | Creating socket. | 2022-08-05 14:19:45.808 SC DTC Data with Market Depth | Requesting security definition data for: XAUUSD. ID: 2 | 2022-08-05 14:19:45.808 DTC Client socket (5) | New receive buffer size: 5242880 | 2022-08-05 14:19:45.808 DTC Client socket (5) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:19:45.808 Teton CME Order Routing | Starting real-time market data updates for: TSLA. ID: 3 Service code: equities.us | 2022-08-05 14:19:45.808 Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: TSLA | 2022-08-05 14:19:45.808 Teton CME Order Routing | Requesting security definition data for: TSLA. ID: 3 | 2022-08-05 14:19:45.808 Added historical Intraday data request for TSLA to the queue. | 2022-08-05 14:19:45.808 Intraday data recording state for symbol TSLA is set to download 'Pending'. | 2022-08-05 14:19:45.808 Triggering next historical data download in queue. | 2022-08-05 14:19:45.808 DTC Client socket (6) | Creating socket. | 2022-08-05 14:19:45.808 DTC Client socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:19:45.808 DTC Client socket (6) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:19:45.808 Using Bid/Ask average for last trade price for US30 | 2022-08-05 14:19:45.809 SC DTC Data with Market Depth | Starting real-time market data updates for: US30. ID: 4 Service code: fxcm | 2022-08-05 14:19:45.809 SC DTC Data with Market Depth | Requesting security definition data for: US30. ID: 4 | 2022-08-05 14:19:45.809 Added historical Intraday data request for US30 to the queue. | 2022-08-05 14:19:45.809 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 14:19:45.809 Triggering next historical data download in queue. | 2022-08-05 14:19:45.809 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 00:00:00.000000 | 2022-08-05 14:19:45.818 Using Bid/Ask average for last trade price for SPX500 | 2022-08-05 14:19:45.839 SC DTC Data with Market Depth | Starting real-time market data updates for: SPX500. ID: 5 Service code: fxcm | 2022-08-05 14:19:45.839 SC DTC Data with Market Depth | Requesting security definition data for: SPX500. ID: 5 | 2022-08-05 14:19:45.839 Teton CME Order Routing | Starting real-time market data updates for: SPY. ID: 6 Service code: equities.us | 2022-08-05 14:19:45.839 Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: SPY | 2022-08-05 14:19:45.839 Teton CME Order Routing | Requesting security definition data for: SPY. ID: 6 | 2022-08-05 14:19:45.839 Added historical Intraday data request for SPY to the queue. | 2022-08-05 14:19:45.839 Intraday data recording state for symbol SPY is set to download 'Pending'. | 2022-08-05 14:19:45.839 Triggering next historical data download in queue. | 2022-08-05 14:19:45.839 Teton CME Order Routing | Starting real-time market data updates for: ESU22-CME. ID: 7 | 2022-08-05 14:19:45.839 Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: ESU22-CME | 2022-08-05 14:19:45.839 Teton CME Order Routing | Requesting security definition data for: ESU22-CME. ID: 7 | 2022-08-05 14:19:45.839 No historical data client is currently set to download historical Intraday data for ESU22-CME. | 2022-08-05 14:19:45.839 Real-time Intraday chart data file updates started for ESU22-CME | 2022-08-05 14:19:45.839 Opened cached Intraday file: C:\SierraChart\Data\ESU22-CME.scid. Thread ID: 15072 | 2022-08-05 14:19:45.840 Intraday chart data file opened for ESU22-CME | 2022-08-05 14:19:45.840 Using Bid/Ask average for last trade price for USOil | 2022-08-05 14:19:45.840 SC DTC Data with Market Depth | Starting real-time market data updates for: USOil. ID: 8 Service code: fxcm | 2022-08-05 14:19:45.840 SC DTC Data with Market Depth | Requesting security definition data for: USOil. ID: 8 | 2022-08-05 14:19:45.840 Added historical Intraday data request for USOil to the queue. | 2022-08-05 14:19:45.840 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2022-08-05 14:19:45.840 Triggering next historical data download in queue. | 2022-08-05 14:19:45.840 Updated verified funded futures trading account ending date to: 2022-09-04 14:19:45 | 2022-08-05 14:19:45.868 Using Bid/Ask average for last trade price for EURUSD | 2022-08-05 14:19:45.871 SC DTC Data with Market Depth | Starting real-time market data updates for: EURUSD. ID: 9 Service code: fxcm | 2022-08-05 14:19:45.871 SC DTC Data with Market Depth | Requesting security definition data for: EURUSD. ID: 9 | 2022-08-05 14:19:45.871 SC DTC Data with Market Depth | Network connection to server complete. | 2022-08-05 14:19:45.872 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-08-05 14:19:45.872 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:19:45.872 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:19:45.873 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:19:45.873 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-08-05 14:19:45.873 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: AAPL-NQTV | 2022-08-05 14:19:45.876 Teton CME Order Routing | Received security definition for symbol AAPL-NQTV | 2022-08-05 14:19:45.876 Teton CME Order Routing | Received security definition for symbol TSLA | 2022-08-05 14:19:45.877 Added historical Intraday data request for EURUSD to the queue. | 2022-08-05 14:19:45.903 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2022-08-05 14:19:45.903 Triggering next historical data download in queue. | 2022-08-05 14:19:45.903 Teton CME Order Routing | Received security definition for symbol SPY | 2022-08-05 14:19:45.938 Teton CME Order Routing | Received security definition for symbol ESU22-CME | 2022-08-05 14:19:45.938 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43878 | 2022-08-05 14:19:45.942 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:45.950 SC Data - All Services | Sending logon request message. | 2022-08-05 14:19:45.950 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:45.971 SC DTC Data with Market Depth | Sending logon request message. | 2022-08-05 14:19:45.971 Mapping MESU22_FUT_CME to MESU22. Service code: cme | 2022-08-05 14:19:46.217 SC Data - All Services | Starting real-time market data updates for: MESU22_FUT_CME (MESU22). ID: 10 Service code: cme | 2022-08-05 14:19:46.217 SC Data - All Services | Connecting to the server ds27.sierracharts.com. Port 443 | 2022-08-05 14:19:46.217 SC Data - All Services | Requesting security definition data for: MESU22_FUT_CME (MESU22). ID: 10 | 2022-08-05 14:19:46.217 Added historical Intraday data request for MESU22_FUT_CME to the queue. | 2022-08-05 14:19:46.217 Intraday data recording state for symbol MESU22_FUT_CME is set to download 'Pending'. | 2022-08-05 14:19:46.217 Triggering next historical data download in queue. | 2022-08-05 14:19:46.217 DTC Client socket (7) | Creating socket. | 2022-08-05 14:19:46.266 DTC Client socket (7) | New receive buffer size: 5242880 | 2022-08-05 14:19:46.266 DTC Client socket (7) | Connecting to IP: 208.185.224.128. | 2022-08-05 14:19:46.266 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESU22_FUT_CME | 2022-08-05 14:19:46.303 Teton CME Order Routing | Received security definition for symbol MESU22_FUT_CME | 2022-08-05 14:19:46.303 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 14:19:46.305 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 14:19:46.305 Triggering next historical data download in queue. | 2022-08-05 14:19:46.305 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:19:46.322 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:19:46.322 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:19:46.322 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:46.403 SC Data - All Services | Sending logon request message. | 2022-08-05 14:19:46.403 SC Data - All Services | Received logon response. | 2022-08-05 14:19:46.637 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:19:46.637 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:19:46.637 SC Data - All Services | Successfully connected. | 2022-08-05 14:19:46.637 SC Data - All Services | Trading is not supported. | 2022-08-05 14:19:46.637 SC Data - All Services | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2022-08-05 14:19:46.637 SC DTC Data with Market Depth | Received logon response. | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Successfully connected. | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Trading is not supported. | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-08-05 14:19:46.751 SC Data - All Services | Received security definition for symbol AAPL-NQTV | 2022-08-05 14:19:46.793 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2022-08-05 14:19:46.908 SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-08-05 14:19:46.908 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2022-08-05 14:19:46.908 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2022-08-05 14:19:46.908 SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-08-05 14:19:46.908 SC Data - All Services | Received logon response. | 2022-08-05 14:19:47.122 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:19:47.122 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:19:47.122 SC Data - All Services | Successfully connected. | 2022-08-05 14:19:47.122 SC Data - All Services | Trading is not supported. | 2022-08-05 14:19:47.122 SC Data - All Services | Restarting real-time data updates for symbol: MESU22_FUT_CME -> MESU22 | 2022-08-05 14:19:47.122 SC Data - All Services | Received security definition for symbol MESU22_FUT_CME | 2022-08-05 14:19:47.282 HD Request # 28 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data | 2022-08-05 14:19:51.934 HD Request # 28 | Download start date-time: 2022-08-05 14:16:55.000000. File last date-time: 2022-08-05 14:16:55.089000 | 2022-08-05 14:19:51.935 HD Request # 28 | Using server: ds25.sierracharts.com port 10150 | 2022-08-05 14:19:51.935 Socket (8) | Creating socket. | 2022-08-05 14:19:51.935 Socket (8) | New receive buffer size: 5242880 | 2022-08-05 14:19:51.935 Socket (8) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:19:51.935 HD Request # 28 | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:52.068 HD Request # 28 | Sending historical data logon request message. | 2022-08-05 14:19:52.068 HD Request # 28 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:55. Record interval: 1. Symbol: AAPL-NQTV | 2022-08-05 14:19:52.599 HD Request # 28 | Decompressing data. | 2022-08-05 14:19:52.665 HD Request # 28 | Receiving Intraday data for AAPL-NQTV starting at 2022-08-05 14:16:55.089000 | 2022-08-05 14:19:52.666 Socket (8) | CloseSocket call. | 2022-08-05 14:19:52.666 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:52.666 Historical data download thread signaled to stop. | 2022-08-05 14:19:52.666 HD Request # 28 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:55.089000. | 2022-08-05 14:19:52.666 HD Request # 28 | Received 145 Intraday data records from 2022-08-05 14:16:55.089000 to 2022-08-05 14:19:48.139000 (2.9 minutes) and wrote 145 records for AAPL-NQTV | 2022-08-05 14:19:52.666 HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:19:48.139000 | 2022-08-05 14:19:52.670 Added 3 Time and Sales records to Intraday data file for AAPL-NQTV after download. | 2022-08-05 14:19:52.670 HD Request # 28 | Completion time: 1s. | 2022-08-05 14:19:52.670 HD Request # 28 | Intraday data download complete for AAPL-NQTV. Unique request ID: 28 | 2022-08-05 14:19:52.670 Removing historical data download ID 28. | 2022-08-05 14:19:52.670 Real-time Intraday chart data file updates started for AAPL-NQTV | 2022-08-05 14:19:52.670 Opened cached Intraday file: C:\SierraChart\Data\AAPL-NQTV.scid. Thread ID: 15072 | 2022-08-05 14:19:52.674 Intraday chart data file opened for AAPL-NQTV | 2022-08-05 14:19:52.674 HD Request # 28 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:19:52.674 Triggering next historical data download in queue. | 2022-08-05 14:19:52.674 HD Request # 29 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2022-08-05 14:19:52.674 HD Request # 29 | Download start date-time: 2022-08-05 13:55:59.000000. File last date-time: 2022-08-05 13:55:59.122000 | 2022-08-05 14:19:52.674 HD Request # 29 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2022-08-05 14:19:52.674 Socket (9) | Creating socket. | 2022-08-05 14:19:52.674 Socket (9) | New receive buffer size: 5242880 | 2022-08-05 14:19:52.674 Socket (9) | Connecting to IP: 8.18.161.133. | 2022-08-05 14:19:52.674 Socket (8) | Socket gracefully closed by remote side. | 2022-08-05 14:19:52.734 Socket (8) | Closed. | 2022-08-05 14:19:52.734 HD Request # 29 | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:52.798 HD Request # 29 | Sending historical data logon request message. | 2022-08-05 14:19:52.798 HD Request # 29 | Requesting Intraday data. Start date-time: 2022-08-05 13:55:59. Record interval: 1. Symbol: TSLA | 2022-08-05 14:19:53.306 HD Request # 29 | Decompressing data. | 2022-08-05 14:19:53.377 HD Request # 29 | Receiving Intraday data for TSLA starting at 2022-08-05 13:55:59.122000 | 2022-08-05 14:19:53.440 Socket (9) | CloseSocket call. | 2022-08-05 14:19:53.441 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:53.441 Historical data download thread signaled to stop. | 2022-08-05 14:19:53.441 HD Request # 29 | Timestamp of first Intraday data file record written: 2022-08-05 13:55:59.122000. | 2022-08-05 14:19:53.441 HD Request # 29 | Received 503 Intraday data records from 2022-08-05 13:55:59.122000 to 2022-08-05 14:04:51.222000 (8.9 minutes) and wrote 503 records for TSLA | 2022-08-05 14:19:53.441 HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:04:51.222000 | 2022-08-05 14:19:53.446 HD Request # 29 | Completion time: 1s. | 2022-08-05 14:19:53.446 HD Request # 29 | Intraday data download complete for TSLA. Unique request ID: 29 | 2022-08-05 14:19:53.446 Removing historical data download ID 29. | 2022-08-05 14:19:53.446 Real-time Intraday chart data file updates started for TSLA | 2022-08-05 14:19:53.446 Opened cached Intraday file: C:\SierraChart\Data\TSLA.scid. Thread ID: 15072 | 2022-08-05 14:19:53.446 Intraday chart data file opened for TSLA | 2022-08-05 14:19:53.446 HD Request # 29 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:19:53.446 Triggering next historical data download in queue. | 2022-08-05 14:19:53.446 HD Request # 30 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 14:19:53.446 HD Request # 30 | Download start date-time: 2022-08-05 14:19:41.000000. File last date-time: 2022-08-05 14:19:41.000000 | 2022-08-05 14:19:53.446 HD Request # 30 | Using server: ds4.sierracharts.com port 10150 | 2022-08-05 14:19:53.446 Socket (8) | Creating socket. | 2022-08-05 14:19:53.447 Socket (8) | New receive buffer size: 5242880 | 2022-08-05 14:19:53.447 Socket (8) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:19:53.447 Socket (9) | Socket gracefully closed by remote side. | 2022-08-05 14:19:53.501 Socket (9) | Closed. | 2022-08-05 14:19:53.501 HD Request # 30 | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:53.581 HD Request # 30 | Sending historical data logon request message. | 2022-08-05 14:19:53.581 HD Request # 30 | Requesting Intraday data. Start date-time: 2022-08-05 14:19:41. Record interval: 1. Symbol: US30 | 2022-08-05 14:19:54.157 HD Request # 30 | Decompressing data. | 2022-08-05 14:19:54.218 HD Request # 30 | Receiving Intraday data for US30 starting at 2022-08-05 14:19:41.067000 | 2022-08-05 14:19:54.218 Socket (8) | CloseSocket call. | 2022-08-05 14:19:54.218 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:54.218 Socket (8) | Socket gracefully closed by remote side. | 2022-08-05 14:19:54.283 Socket (8) | Closed. | 2022-08-05 14:19:54.283 Historical data download thread signaled to stop. | 2022-08-05 14:19:54.302 HD Request # 30 | Timestamp of first Intraday data file record written: 2022-08-05 14:19:41.067000. | 2022-08-05 14:19:54.302 HD Request # 30 | Received 12 Intraday data records from 2022-08-05 14:19:41.067000 to 2022-08-05 14:19:52.162000 (11.1 seconds) and wrote 12 records for US30 | 2022-08-05 14:19:54.302 HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:19:52.162000 | 2022-08-05 14:19:54.306 HD Request # 30 | Completion time: 1s. | 2022-08-05 14:19:54.306 HD Request # 30 | Intraday data download complete for US30. Unique request ID: 30 | 2022-08-05 14:19:54.306 Removing historical data download ID 30. | 2022-08-05 14:19:54.306 Real-time Intraday chart data file updates started for US30 | 2022-08-05 14:19:54.306 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 14:19:54.307 Intraday chart data file opened for US30 | 2022-08-05 14:19:54.307 HD Request # 30 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:19:54.307 Triggering next historical data download in queue. | 2022-08-05 14:19:54.307 HD Request # 31 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: equities.us | 2022-08-05 14:19:54.307 HD Request # 31 | Download start date-time: 2022-08-05 13:56:00.000000. File last date-time: 2022-08-05 13:56:00.014000 | 2022-08-05 14:19:54.307 HD Request # 31 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2022-08-05 14:19:54.307 Socket (8) | Creating socket. | 2022-08-05 14:19:54.307 Socket (8) | New receive buffer size: 5242880 | 2022-08-05 14:19:54.307 Socket (8) | Connecting to IP: 8.18.161.135. | 2022-08-05 14:19:54.307 HD Request # 31 | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:54.420 HD Request # 31 | Sending historical data logon request message. | 2022-08-05 14:19:54.420 HD Request # 31 | Requesting Intraday data. Start date-time: 2022-08-05 13:56:00. Record interval: 1. Symbol: SPY | 2022-08-05 14:19:54.926 HD Request # 31 | Decompressing data. | 2022-08-05 14:19:54.995 HD Request # 31 | Receiving Intraday data for SPY starting at 2022-08-05 13:56:00.014000 | 2022-08-05 14:19:55.054 Socket (8) | CloseSocket call. | 2022-08-05 14:19:55.055 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:55.055 Historical data download thread signaled to stop. | 2022-08-05 14:19:55.055 HD Request # 31 | Timestamp of first Intraday data file record written: 2022-08-05 13:56:00.014000. | 2022-08-05 14:19:55.055 HD Request # 31 | Received 526 Intraday data records from 2022-08-05 13:56:00.014000 to 2022-08-05 14:04:54.210000 (8.9 minutes) and wrote 526 records for SPY | 2022-08-05 14:19:55.055 HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:04:54.210000 | 2022-08-05 14:19:55.060 HD Request # 31 | Completion time: 1s. | 2022-08-05 14:19:55.060 HD Request # 31 | Intraday data download complete for SPY. Unique request ID: 31 | 2022-08-05 14:19:55.060 Removing historical data download ID 31. | 2022-08-05 14:19:55.060 Real-time Intraday chart data file updates started for SPY | 2022-08-05 14:19:55.060 Opened cached Intraday file: C:\SierraChart\Data\SPY.scid. Thread ID: 15072 | 2022-08-05 14:19:55.060 Intraday chart data file opened for SPY | 2022-08-05 14:19:55.060 HD Request # 31 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:19:55.060 Triggering next historical data download in queue. | 2022-08-05 14:19:55.060 HD Request # 32 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2022-08-05 14:19:55.060 HD Request # 32 | Download start date-time: 2022-08-05 14:19:41.000000. File last date-time: 2022-08-05 14:19:41.000000 | 2022-08-05 14:19:55.060 HD Request # 32 | Using server: ds12.sierracharts.com port 10150 | 2022-08-05 14:19:55.060 Socket (9) | Creating socket. | 2022-08-05 14:19:55.060 Socket (9) | New receive buffer size: 5242880 | 2022-08-05 14:19:55.060 Socket (9) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:19:55.060 Socket (8) | Socket gracefully closed by remote side. | 2022-08-05 14:19:55.115 Socket (8) | Closed. | 2022-08-05 14:19:55.115 HD Request # 32 | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:55.211 HD Request # 32 | Sending historical data logon request message. | 2022-08-05 14:19:55.211 HD Request # 32 | Requesting Intraday data. Start date-time: 2022-08-05 14:19:41. Record interval: 1. Symbol: USOil | 2022-08-05 14:19:55.806 HD Request # 32 | Decompressing data. | 2022-08-05 14:19:55.874 HD Request # 32 | Receiving Intraday data for USOil starting at 2022-08-05 14:19:41.911000 | 2022-08-05 14:19:55.876 Socket (9) | CloseSocket call. | 2022-08-05 14:19:55.877 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:55.877 Historical data download thread signaled to stop. | 2022-08-05 14:19:55.877 HD Request # 32 | Timestamp of first Intraday data file record written: 2022-08-05 14:19:41.911000. | 2022-08-05 14:19:55.877 HD Request # 32 | Received 13 Intraday data records from 2022-08-05 14:19:41.911000 to 2022-08-05 14:19:55.228000 (13.3 seconds) and wrote 13 records for USOil | 2022-08-05 14:19:55.877 HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:19:55.228000 | 2022-08-05 14:19:55.881 HD Request # 32 | Completion time: 0s. | 2022-08-05 14:19:55.881 HD Request # 32 | Intraday data download complete for USOil. Unique request ID: 32 | 2022-08-05 14:19:55.881 Removing historical data download ID 32. | 2022-08-05 14:19:55.881 Real-time Intraday chart data file updates started for USOil | 2022-08-05 14:19:55.881 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 15072 | 2022-08-05 14:19:55.881 Intraday chart data file opened for USOil | 2022-08-05 14:19:55.881 HD Request # 32 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:19:55.881 Triggering next historical data download in queue. | 2022-08-05 14:19:55.881 HD Request # 33 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2022-08-05 14:19:55.881 HD Request # 33 | Download start date-time: 2022-08-05 14:16:54.000000. File last date-time: 2022-08-05 14:16:54.028000 | 2022-08-05 14:19:55.881 HD Request # 33 | Using server: ds13-3.sierracharts.com port 10149 | 2022-08-05 14:19:55.881 Socket (8) | Creating socket. | 2022-08-05 14:19:55.881 Socket (8) | New receive buffer size: 5242880 | 2022-08-05 14:19:55.881 Socket (8) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:19:55.881 Socket (9) | Socket gracefully closed by remote side. | 2022-08-05 14:19:55.951 Socket (9) | Closed. | 2022-08-05 14:19:55.951 HD Request # 33 | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:56.035 HD Request # 33 | Sending historical data logon request message. | 2022-08-05 14:19:56.035 HD Request # 33 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:54. Record interval: 1. Symbol: EURUSD | 2022-08-05 14:19:56.735 HD Request # 33 | Decompressing data. | 2022-08-05 14:19:56.802 HD Request # 33 | Receiving Intraday data for EURUSD starting at 2022-08-05 14:16:54.000000 | 2022-08-05 14:19:56.804 Socket (8) | CloseSocket call. | 2022-08-05 14:19:56.804 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:56.804 Historical data download thread signaled to stop. | 2022-08-05 14:19:56.804 HD Request # 33 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:55.026000. | 2022-08-05 14:19:56.804 HD Request # 33 | Received 176 Intraday data records from 2022-08-05 14:16:54.000000 to 2022-08-05 14:19:55.022000 (3.0 minutes) and wrote 175 records for EURUSD | 2022-08-05 14:19:56.804 HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:19:55.022000 | 2022-08-05 14:19:56.809 Added 1 Time and Sales records to Intraday data file for EURUSD after download. | 2022-08-05 14:19:56.809 HD Request # 33 | Completion time: 1s. | 2022-08-05 14:19:56.809 HD Request # 33 | Intraday data download complete for EURUSD. Unique request ID: 33 | 2022-08-05 14:19:56.809 Removing historical data download ID 33. | 2022-08-05 14:19:56.809 Real-time Intraday chart data file updates started for EURUSD | 2022-08-05 14:19:56.809 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 15072 | 2022-08-05 14:19:56.812 Intraday chart data file opened for EURUSD | 2022-08-05 14:19:56.812 HD Request # 33 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:19:56.812 Triggering next historical data download in queue. | 2022-08-05 14:19:56.812 HD Request # 34 | Downloading Intraday chart data for MESU22_FUT_CME to the file MESU22_FUT_CME.scid. Service: cme | 2022-08-05 14:19:56.813 HD Request # 34 | Download start date-time: 2022-08-05 14:17:52.000000. File last date-time: 2022-08-05 14:17:52.000000 | 2022-08-05 14:19:56.813 HD Request # 34 | Using server: ds23.sierracharts.com port 10150 | 2022-08-05 14:19:56.813 Socket (9) | Creating socket. | 2022-08-05 14:19:56.813 Socket (9) | New receive buffer size: 5242880 | 2022-08-05 14:19:56.813 Socket (9) | Connecting to IP: 216.1.90.130. | 2022-08-05 14:19:56.813 Socket (8) | Socket gracefully closed by remote side. | 2022-08-05 14:19:56.868 Socket (8) | Closed. | 2022-08-05 14:19:56.868 HD Request # 34 | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:56.940 HD Request # 34 | Sending historical data logon request message. | 2022-08-05 14:19:56.940 HD Request # 34 | Requesting Intraday data. Start date-time: 2022-08-05 14:17:52. Record interval: 1. Symbol: MESU22 | 2022-08-05 14:19:57.495 HD Request # 34 | Decompressing data. | 2022-08-05 14:19:57.551 HD Request # 34 | Receiving Intraday data for MESU22_FUT_CME starting at 2022-08-05 14:17:52.226000 | 2022-08-05 14:19:57.556 Socket (9) | CloseSocket call. | 2022-08-05 14:19:57.556 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:57.556 Historical data download thread signaled to stop. | 2022-08-05 14:19:57.556 HD Request # 34 | Timestamp of first Intraday data file record written: 2022-08-05 14:17:52.226000. | 2022-08-05 14:19:57.556 HD Request # 34 | Received 126 Intraday data records from 2022-08-05 14:17:52.226000 to 2022-08-05 14:19:57.023000 (2.1 minutes) and wrote 126 records for MESU22_FUT_CME | 2022-08-05 14:19:57.556 HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:19:57.023000 | 2022-08-05 14:19:57.561 HD Request # 34 | Completion time: 1s. | 2022-08-05 14:19:57.561 HD Request # 34 | Intraday data download complete for MESU22_FUT_CME. Unique request ID: 34 | 2022-08-05 14:19:57.561 Removing historical data download ID 34. | 2022-08-05 14:19:57.561 Real-time Intraday chart data file updates started for MESU22_FUT_CME | 2022-08-05 14:19:57.561 Opened cached Intraday file: C:\SierraChart\Data\MESU22_FUT_CME.scid. Thread ID: 15072 | 2022-08-05 14:19:57.561 Intraday chart data file opened for MESU22_FUT_CME | 2022-08-05 14:19:57.561 HD Request # 34 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:19:57.561 Triggering next historical data download in queue. | 2022-08-05 14:19:57.561 HD Request # 35 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 14:19:57.561 HD Request # 35 | Download start date-time: 2022-08-05 14:19:41.000000. File last date-time: 2022-08-05 14:19:41.000000 | 2022-08-05 14:19:57.561 HD Request # 35 | Using server: ds4.sierracharts.com port 10149 | 2022-08-05 14:19:57.561 Socket (8) | Creating socket. | 2022-08-05 14:19:57.561 Socket (8) | New receive buffer size: 5242880 | 2022-08-05 14:19:57.561 Socket (8) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:19:57.561 Socket (9) | Socket gracefully closed by remote side. | 2022-08-05 14:19:57.612 Socket (9) | Closed. | 2022-08-05 14:19:57.612 HD Request # 35 | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:57.696 HD Request # 35 | Sending historical data logon request message. | 2022-08-05 14:19:57.696 HD Request # 35 | Requesting Intraday data. Start date-time: 2022-08-05 14:19:41. Record interval: 1. Symbol: XAUUSD | 2022-08-05 14:19:58.272 HD Request # 35 | Decompressing data. | 2022-08-05 14:19:58.340 HD Request # 35 | Receiving Intraday data for XAUUSD starting at 2022-08-05 14:19:41.385000 | 2022-08-05 14:19:58.340 Socket (8) | CloseSocket call. | 2022-08-05 14:19:58.341 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:58.341 Historical data download thread signaled to stop. | 2022-08-05 14:19:58.341 HD Request # 35 | Timestamp of first Intraday data file record written: 2022-08-05 14:19:41.385000. | 2022-08-05 14:19:58.341 HD Request # 35 | Received 16 Intraday data records from 2022-08-05 14:19:41.385000 to 2022-08-05 14:19:56.426000 (15.0 seconds) and wrote 16 records for XAUUSD | 2022-08-05 14:19:58.341 HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:19:56.426000 | 2022-08-05 14:19:58.345 Added 2 Time and Sales records to Intraday data file for XAUUSD after download. | 2022-08-05 14:19:58.345 HD Request # 35 | Completion time: 1s. | 2022-08-05 14:19:58.345 HD Request # 35 | Intraday data download complete for XAUUSD. Unique request ID: 35 | 2022-08-05 14:19:58.345 Removing historical data download ID 35. | 2022-08-05 14:19:58.345 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-05 14:19:58.345 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 15072 | 2022-08-05 14:19:58.349 Intraday chart data file opened for XAUUSD | 2022-08-05 14:19:58.349 HD Request # 35 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:19:58.349 Triggering next historical data download in queue. | 2022-08-05 14:19:58.349 No download requests in the queue to start downloads for. | 2022-08-05 14:19:58.349 Socket (8) | Socket gracefully closed by remote side. | 2022-08-05 14:19:58.403 Socket (8) | Closed. | 2022-08-05 14:19:58.403 DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:20:00.776 * DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:20:00.776 DTC Client socket (3) | Closed. | 2022-08-05 14:20:00.776 DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-08-05 14:22:06.352 DTC Client socket (1) | Closed. | 2022-08-05 14:22:06.352 DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-08-05 14:22:06.352 DTC Client socket (2) | Closed. | 2022-08-05 14:22:06.352 DTC Client socket (1) | Deleting network socket now after delay. | 2022-08-05 14:22:36.352 DTC Client socket (2) | Deleting network socket now after delay. | 2022-08-05 14:22:36.352 DTC Client socket (7) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:23:41.769 * DTC Client socket (7) | Socket gracefully closed by remote side. | 2022-08-05 14:23:41.769 DTC Client socket (7) | CloseSocket call. | 2022-08-05 14:23:41.769 DTC Client socket (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:23:41.769 DTC Client socket (7) | Closed. | 2022-08-05 14:23:41.769 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:23:41.769 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:23:41.770 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:23:41.770 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:23:41.770 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2022-08-05 14:23:43.768 DTC Client socket (1) | Creating socket. | 2022-08-05 14:23:43.769 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:23:43.769 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2022-08-05 14:23:43.769 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:23:43.823 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:23:43.823 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:23:43.823 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:23:43.889 SC Data - All Services | Sending logon request message. | 2022-08-05 14:23:43.889 SC Data - All Services | Received logon response. | 2022-08-05 14:23:44.612 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:23:44.612 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:23:44.612 SC Data - All Services | Successfully connected. | 2022-08-05 14:23:44.612 SC Data - All Services | Trading is not supported. | 2022-08-05 14:23:44.612 Added historical Intraday data request for MESU22_FUT_CME to the queue. | 2022-08-05 14:23:44.612 Intraday data recording state for symbol MESU22_FUT_CME is set to download 'Pending'. | 2022-08-05 14:23:44.612 Triggering next historical data download in queue. | 2022-08-05 14:23:44.612 SC Data - All Services | Restarting real-time data updates for symbol: MESU22_FUT_CME -> MESU22 | 2022-08-05 14:23:44.612 HD Request # 36 | Downloading Intraday chart data for MESU22_FUT_CME to the file MESU22_FUT_CME.scid. Service: cme | 2022-08-05 14:23:44.612 HD Request # 36 | Download start date-time: 2022-08-05 14:23:41.000000. File last date-time: 2022-08-05 14:23:41.000000 | 2022-08-05 14:23:44.616 HD Request # 36 | Using server: ds21.sierracharts.com port 10150 | 2022-08-05 14:23:44.617 Socket (2) | Creating socket. | 2022-08-05 14:23:44.617 Socket (2) | New receive buffer size: 5242880 | 2022-08-05 14:23:44.617 Socket (2) | Connecting to IP: 216.1.90.129. | 2022-08-05 14:23:44.617 HD Request # 36 | Setting DTC encoding to Binary VLS | 2022-08-05 14:23:44.732 HD Request # 36 | Sending historical data logon request message. | 2022-08-05 14:23:44.732 SC Data - All Services | Received security definition for symbol MESU22_FUT_CME | 2022-08-05 14:23:44.770 HD Request # 36 | Requesting Intraday data. Start date-time: 2022-08-05 14:23:41. Record interval: 1. Symbol: MESU22 | 2022-08-05 14:23:45.302 HD Request # 36 | Decompressing data. | 2022-08-05 14:23:45.356 HD Request # 36 | Receiving Intraday data for MESU22_FUT_CME starting at 2022-08-05 14:23:41.297000 | 2022-08-05 14:23:45.356 Socket (2) | CloseSocket call. | 2022-08-05 14:23:45.356 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:23:45.357 Historical data download thread signaled to stop. | 2022-08-05 14:23:45.357 HD Request # 36 | Timestamp of first Intraday data file record written: 2022-08-05 14:23:41.297000. | 2022-08-05 14:23:45.357 HD Request # 36 | Received 3 Intraday data records from 2022-08-05 14:23:41.297000 to 2022-08-05 14:23:43.049000 (1.8 seconds) and wrote 3 records for MESU22_FUT_CME | 2022-08-05 14:23:45.357 HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:23:43.049000 | 2022-08-05 14:23:45.361 Added 1 Time and Sales records to Intraday data file for MESU22_FUT_CME after download. | 2022-08-05 14:23:45.361 HD Request # 36 | Completion time: 1s. | 2022-08-05 14:23:45.361 HD Request # 36 | Intraday data download complete for MESU22_FUT_CME. Unique request ID: 36 | 2022-08-05 14:23:45.361 Removing historical data download ID 36. | 2022-08-05 14:23:45.361 Real-time Intraday chart data file updates started for MESU22_FUT_CME | 2022-08-05 14:23:45.361 Opened cached Intraday file: C:\SierraChart\Data\MESU22_FUT_CME.scid. Thread ID: 15072 | 2022-08-05 14:23:45.364 Intraday chart data file opened for MESU22_FUT_CME | 2022-08-05 14:23:45.364 HD Request # 36 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:23:45.364 Triggering next historical data download in queue. | 2022-08-05 14:23:45.364 No download requests in the queue to start downloads for. | 2022-08-05 14:23:45.364 Socket (2) | Socket gracefully closed by remote side. | 2022-08-05 14:23:45.416 Socket (2) | Closed. | 2022-08-05 14:23:45.416 DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-08-05 14:24:05.780 DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:24:05.780 * DTC Client socket (4) | CloseSocket call. | 2022-08-05 14:24:05.780 DTC Client socket (4) | Max send buffers used during socket life: 3 | 2022-08-05 14:24:05.780 DTC Client socket (4) | Max send buffer size during socket life: 281 | 2022-08-05 14:24:05.780 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:24:05.780 Connection to the external service has been lost. | 2022-08-05 14:24:05.780 DTC Client socket (4) | Closed. | 2022-08-05 14:24:05.780 Teton CME Order Routing | Waiting for socket receive thread to end | 2022-08-05 14:24:05.795 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:24:05.795 Teton CME Order Routing | Disconnected. | 2022-08-05 14:24:05.795 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-08-05 14:24:05.795 Teton CME Order Routing | Firm: Dorman | 2022-08-05 14:24:07.803 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-08-05 14:24:07.803 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-08-05 14:24:07.853 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-08-05 14:24:07.854 DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2022-08-05 14:24:07.854 Teton CME Order Routing | Network connection to server complete. | 2022-08-05 14:24:07.915 Teton CME Order Routing | Starting socket receive thread. | 2022-08-05 14:24:07.915 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-08-05 14:24:07.915 DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:24:08.081 * DTC Client socket (5) | Socket gracefully closed by remote side. | 2022-08-05 14:24:08.081 DTC Client socket (5) | CloseSocket call. | 2022-08-05 14:24:08.081 DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:24:08.081 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:24:08.081 DTC Client socket (5) | Closed. | 2022-08-05 14:24:08.081 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:24:08.082 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:24:08.082 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:24:08.082 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-08-05 14:24:08.113 Teton CME Order Routing | Sending logon request message. | 2022-08-05 14:24:08.113 Teton CME Order Routing | Received logon response. | 2022-08-05 14:24:08.665 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-08-05 14:24:08.665 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:24:08.665 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-08-05 14:24:08.665 Teton CME Order Routing | Trading is supported. | 2022-08-05 14:24:08.665 Teton CME Order Routing | Order cancel and replace is supported. | 2022-08-05 14:24:08.665 Teton CME Order Routing | OCO Orders supported. | 2022-08-05 14:24:08.665 Teton CME Order Routing | Bracket Orders supported. | 2022-08-05 14:24:08.665 Teton CME Order Routing | Connected to server complete. | 2022-08-05 14:24:08.665 Triggering next historical data download in queue. | 2022-08-05 14:24:08.666 Triggering next historical data download in queue. | 2022-08-05 14:24:08.666 Triggering next historical data download in queue. | 2022-08-05 14:24:08.666 Triggering next historical data download in queue. | 2022-08-05 14:24:08.666 Updated verified funded futures trading account ending date to: 2022-09-04 14:24:08 | 2022-08-05 14:24:08.666 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-08-05 14:24:08.672 No download requests in the queue to start downloads for. | 2022-08-05 14:24:08.672 No download requests in the queue to start downloads for. | 2022-08-05 14:24:08.672 No download requests in the queue to start downloads for. | 2022-08-05 14:24:08.672 No download requests in the queue to start downloads for. | 2022-08-05 14:24:08.672 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 00:00:00.000000 | 2022-08-05 14:24:08.686 Updated verified funded futures trading account ending date to: 2022-09-04 14:24:08 | 2022-08-05 14:24:08.769 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43878 | 2022-08-05 14:24:08.769 SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 10048 | 2022-08-05 14:24:10.072 DTC Client socket (3) | Creating socket. | 2022-08-05 14:24:10.073 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:24:10.073 DTC Client socket (3) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:24:10.073 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:24:10.151 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:24:10.151 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-08-05 14:24:10.151 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:24:10.271 SC Data - All Services | Sending logon request message. | 2022-08-05 14:24:10.271 DTC Client socket (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:24:10.444 * DTC Client socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:24:10.444 DTC Client socket (6) | CloseSocket call. | 2022-08-05 14:24:10.444 DTC Client socket (6) | Max send buffers used during socket life: 4 | 2022-08-05 14:24:10.444 DTC Client socket (6) | Max send buffer size during socket life: 354 | 2022-08-05 14:24:10.444 DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:24:10.444 DTC Client socket (6) | Closed. | 2022-08-05 14:24:10.444 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-08-05 14:24:10.444 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:24:10.445 SC DTC Data with Market Depth | Disconnected from the server. | 2022-08-05 14:24:10.445 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:24:10.445 SC Data - All Services | Received logon response. | 2022-08-05 14:24:10.946 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:24:10.946 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:24:10.946 SC Data - All Services | Successfully connected. | 2022-08-05 14:24:10.946 SC Data - All Services | Trading is not supported. | 2022-08-05 14:24:10.946 Added historical Intraday data request for AAPL-NQTV to the queue. | 2022-08-05 14:24:10.946 Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'. | 2022-08-05 14:24:10.946 Triggering next historical data download in queue. | 2022-08-05 14:24:10.946 SC Data - All Services | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2022-08-05 14:24:10.946 HD Request # 37 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data | 2022-08-05 14:24:10.946 HD Request # 37 | Download start date-time: 2022-08-05 14:23:41.000000. File last date-time: 2022-08-05 14:23:41.000000 | 2022-08-05 14:24:10.950 HD Request # 37 | Using server: ds25.sierracharts.com port 10149 | 2022-08-05 14:24:10.950 Socket (4) | Creating socket. | 2022-08-05 14:24:10.950 Socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:24:10.950 Socket (4) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:24:10.950 HD Request # 37 | Setting DTC encoding to Binary VLS | 2022-08-05 14:24:11.082 HD Request # 37 | Sending historical data logon request message. | 2022-08-05 14:24:11.082 SC Data - All Services | Received security definition for symbol AAPL-NQTV | 2022-08-05 14:24:11.101 HD Request # 37 | Requesting Intraday data. Start date-time: 2022-08-05 14:23:41. Record interval: 1. Symbol: AAPL-NQTV | 2022-08-05 14:24:11.582 HD Request # 37 | Decompressing data. | 2022-08-05 14:24:11.646 HD Request # 37 | Receiving Intraday data for AAPL-NQTV starting at 2022-08-05 14:23:41.110000 | 2022-08-05 14:24:11.646 Socket (4) | CloseSocket call. | 2022-08-05 14:24:11.646 Historical data download thread signaled to stop. | 2022-08-05 14:24:11.646 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:24:11.646 HD Request # 37 | Timestamp of first Intraday data file record written: 2022-08-05 14:23:41.110000. | 2022-08-05 14:24:11.646 HD Request # 37 | Received 23 Intraday data records from 2022-08-05 14:23:41.110000 to 2022-08-05 14:24:08.026000 (26.9 seconds) and wrote 23 records for AAPL-NQTV | 2022-08-05 14:24:11.647 HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:24:08.026000 | 2022-08-05 14:24:11.650 HD Request # 37 | Completion time: 1s. | 2022-08-05 14:24:11.650 HD Request # 37 | Intraday data download complete for AAPL-NQTV. Unique request ID: 37 | 2022-08-05 14:24:11.650 Removing historical data download ID 37. | 2022-08-05 14:24:11.650 Real-time Intraday chart data file updates started for AAPL-NQTV | 2022-08-05 14:24:11.650 Opened cached Intraday file: C:\SierraChart\Data\AAPL-NQTV.scid. Thread ID: 15072 | 2022-08-05 14:24:11.651 Intraday chart data file opened for AAPL-NQTV | 2022-08-05 14:24:11.651 HD Request # 37 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:24:11.651 Triggering next historical data download in queue. | 2022-08-05 14:24:11.651 No download requests in the queue to start downloads for. | 2022-08-05 14:24:11.651 Socket (4) | Socket gracefully closed by remote side. | 2022-08-05 14:24:11.709 Socket (4) | Closed. | 2022-08-05 14:24:11.709 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2022-08-05 14:24:12.432 DTC Client socket (4) | Creating socket. | 2022-08-05 14:24:12.432 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:24:12.432 DTC Client socket (4) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:24:12.432 SC DTC Data with Market Depth | Network connection to server complete. | 2022-08-05 14:24:12.494 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-08-05 14:24:12.494 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:24:12.494 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-08-05 14:24:12.561 SC DTC Data with Market Depth | Sending logon request message. | 2022-08-05 14:24:12.561 SC DTC Data with Market Depth | Received logon response. | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Successfully connected. | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Trading is not supported. | 2022-08-05 14:24:13.264 Added historical Intraday data request for EURUSD to the queue. | 2022-08-05 14:24:13.264 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2022-08-05 14:24:13.264 Triggering next historical data download in queue. | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-08-05 14:24:13.264 Added historical Intraday data request for US30 to the queue. | 2022-08-05 14:24:13.264 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2022-08-05 14:24:13.264 Added historical Intraday data request for USOil to the queue. | 2022-08-05 14:24:13.264 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2022-08-05 14:24:13.264 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 14:24:13.264 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-08-05 14:24:13.264 HD Request # 38 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2022-08-05 14:24:13.264 HD Request # 38 | Download start date-time: 2022-08-05 14:23:41.000000. File last date-time: 2022-08-05 14:23:41.000000 | 2022-08-05 14:24:13.269 HD Request # 38 | Using server: ds12.sierracharts.com port 10150 | 2022-08-05 14:24:13.269 Socket (5) | Creating socket. | 2022-08-05 14:24:13.269 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 14:24:13.269 Socket (5) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:24:13.269 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2022-08-05 14:24:13.405 SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-08-05 14:24:13.405 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2022-08-05 14:24:13.405 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2022-08-05 14:24:13.405 HD Request # 38 | Setting DTC encoding to Binary VLS | 2022-08-05 14:24:13.411 HD Request # 38 | Sending historical data logon request message. | 2022-08-05 14:24:13.411 SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-08-05 14:24:13.501 HD Request # 38 | Requesting Intraday data. Start date-time: 2022-08-05 14:23:41. Record interval: 1. Symbol: EURUSD | 2022-08-05 14:24:14.002 HD Request # 38 | Decompressing data. | 2022-08-05 14:24:14.065 HD Request # 38 | Receiving Intraday data for EURUSD starting at 2022-08-05 14:23:41.430000 | 2022-08-05 14:24:14.067 Socket (5) | CloseSocket call. | 2022-08-05 14:24:14.067 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:24:14.067 Historical data download thread signaled to stop. | 2022-08-05 14:24:14.067 HD Request # 38 | Timestamp of first Intraday data file record written: 2022-08-05 14:23:41.430000. | 2022-08-05 14:24:14.067 HD Request # 38 | Received 32 Intraday data records from 2022-08-05 14:23:41.430000 to 2022-08-05 14:24:13.030000 (31.6 seconds) and wrote 32 records for EURUSD | 2022-08-05 14:24:14.067 HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:24:13.030000 | 2022-08-05 14:24:14.071 Added 1 Time and Sales records to Intraday data file for EURUSD after download. | 2022-08-05 14:24:14.071 HD Request # 38 | Completion time: 1s. | 2022-08-05 14:24:14.071 HD Request # 38 | Intraday data download complete for EURUSD. Unique request ID: 38 | 2022-08-05 14:24:14.071 Removing historical data download ID 38. | 2022-08-05 14:24:14.071 Real-time Intraday chart data file updates started for EURUSD | 2022-08-05 14:24:14.071 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 15072 | 2022-08-05 14:24:14.075 Intraday chart data file opened for EURUSD | 2022-08-05 14:24:14.075 HD Request # 38 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:24:14.075 Triggering next historical data download in queue. | 2022-08-05 14:24:14.075 HD Request # 39 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 14:24:14.075 HD Request # 39 | Download start date-time: 2022-08-05 14:19:52.000000. File last date-time: 2022-08-05 14:19:52.162000 | 2022-08-05 14:24:14.075 HD Request # 39 | Using server: ds13-3.sierracharts.com port 10149 | 2022-08-05 14:24:14.075 Socket (6) | Creating socket. | 2022-08-05 14:24:14.076 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:24:14.076 Socket (6) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:24:14.076 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 14:24:14.148 Socket (5) | Closed. | 2022-08-05 14:24:14.148 HD Request # 39 | Setting DTC encoding to Binary VLS | 2022-08-05 14:24:14.215 HD Request # 39 | Sending historical data logon request message. | 2022-08-05 14:24:14.215 HD Request # 39 | Requesting Intraday data. Start date-time: 2022-08-05 14:19:52. Record interval: 1. Symbol: US30 | 2022-08-05 14:24:14.908 HD Request # 39 | Decompressing data. | 2022-08-05 14:24:14.970 HD Request # 39 | Receiving Intraday data for US30 starting at 2022-06-07 14:04:01.627000 | 2022-08-05 14:24:15.113 Socket (6) | CloseSocket call. | 2022-08-05 14:24:15.113 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:24:15.113 Historical data download thread signaled to stop. | 2022-08-05 14:24:15.113 HD Request # 39 | Received 1510 Intraday data records from 2022-06-07 14:04:01.627000 to 2022-06-07 15:03:42.116000 (59.7 minutes) and wrote 0 records for US30 | 2022-08-05 14:24:15.114 HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:19:52.162000 | 2022-08-05 14:24:15.114 Added 3 Time and Sales records to Intraday data file for US30 after download. | 2022-08-05 14:24:15.114 HD Request # 39 | Timestamp of first Intraday data file record written: 2022-08-05 14:24:13.609000. | 2022-08-05 14:24:15.114 HD Request # 39 | Completion time: 1s. | 2022-08-05 14:24:15.114 HD Request # 39 | Intraday data download complete for US30. Unique request ID: 39 | 2022-08-05 14:24:15.114 Removing historical data download ID 39. | 2022-08-05 14:24:15.114 Real-time Intraday chart data file updates started for US30 | 2022-08-05 14:24:15.114 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 14:24:15.118 Intraday chart data file opened for US30 | 2022-08-05 14:24:15.118 HD Request # 39 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:24:15.118 Triggering next historical data download in queue. | 2022-08-05 14:24:15.118 HD Request # 40 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2022-08-05 14:24:15.118 HD Request # 40 | Download start date-time: 2022-08-05 14:23:41.000000. File last date-time: 2022-08-05 14:23:41.000000 | 2022-08-05 14:24:15.119 HD Request # 40 | Using server: ds4.sierracharts.com port 10150 | 2022-08-05 14:24:15.119 Socket (5) | Creating socket. | 2022-08-05 14:24:15.119 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 14:24:15.119 Socket (5) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:24:15.119 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:24:15.182 Socket (6) | Closed. | 2022-08-05 14:24:15.182 HD Request # 40 | Setting DTC encoding to Binary VLS | 2022-08-05 14:24:15.242 HD Request # 40 | Sending historical data logon request message. | 2022-08-05 14:24:15.242 HD Request # 40 | Requesting Intraday data. Start date-time: 2022-08-05 14:23:41. Record interval: 1. Symbol: USOil | 2022-08-05 14:24:15.830 HD Request # 40 | Decompressing data. | 2022-08-05 14:24:15.898 HD Request # 40 | Receiving Intraday data for USOil starting at 2022-08-05 14:23:41.109000 | 2022-08-05 14:24:15.898 Socket (5) | CloseSocket call. | 2022-08-05 14:24:15.899 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:24:15.899 Historical data download thread signaled to stop. | 2022-08-05 14:24:15.899 HD Request # 40 | Timestamp of first Intraday data file record written: 2022-08-05 14:23:41.109000. | 2022-08-05 14:24:15.899 HD Request # 40 | Received 31 Intraday data records from 2022-08-05 14:23:41.109000 to 2022-08-05 14:24:14.449000 (33.3 seconds) and wrote 31 records for USOil | 2022-08-05 14:24:15.899 HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:24:14.449000 | 2022-08-05 14:24:15.903 Added 1 Time and Sales records to Intraday data file for USOil after download. | 2022-08-05 14:24:15.903 HD Request # 40 | Completion time: 0s. | 2022-08-05 14:24:15.903 HD Request # 40 | Intraday data download complete for USOil. Unique request ID: 40 | 2022-08-05 14:24:15.903 Removing historical data download ID 40. | 2022-08-05 14:24:15.903 Real-time Intraday chart data file updates started for USOil | 2022-08-05 14:24:15.903 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 15072 | 2022-08-05 14:24:15.907 Intraday chart data file opened for USOil | 2022-08-05 14:24:15.907 HD Request # 40 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:24:15.907 Triggering next historical data download in queue. | 2022-08-05 14:24:15.907 HD Request # 41 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 14:24:15.907 HD Request # 41 | Download start date-time: 2022-08-05 14:23:41.000000. File last date-time: 2022-08-05 14:23:41.000000 | 2022-08-05 14:24:15.907 HD Request # 41 | Using server: ds12.sierracharts.com port 10149 | 2022-08-05 14:24:15.907 Socket (6) | Creating socket. | 2022-08-05 14:24:15.907 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:24:15.907 Socket (6) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:24:15.907 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 14:24:15.967 Socket (5) | Closed. | 2022-08-05 14:24:15.967 HD Request # 41 | Setting DTC encoding to Binary VLS | 2022-08-05 14:24:16.059 HD Request # 41 | Sending historical data logon request message. | 2022-08-05 14:24:16.059 HD Request # 41 | Requesting Intraday data. Start date-time: 2022-08-05 14:23:41. Record interval: 1. Symbol: XAUUSD | 2022-08-05 14:24:16.640 HD Request # 41 | Decompressing data. | 2022-08-05 14:24:16.700 HD Request # 41 | Receiving Intraday data for XAUUSD starting at 2022-08-05 14:23:41.003000 | 2022-08-05 14:24:16.700 Socket (6) | CloseSocket call. | 2022-08-05 14:24:16.701 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:24:16.701 Historical data download thread signaled to stop. | 2022-08-05 14:24:16.701 HD Request # 41 | Timestamp of first Intraday data file record written: 2022-08-05 14:23:41.003000. | 2022-08-05 14:24:16.701 HD Request # 41 | Received 34 Intraday data records from 2022-08-05 14:23:41.003000 to 2022-08-05 14:24:14.327000 (33.3 seconds) and wrote 34 records for XAUUSD | 2022-08-05 14:24:16.701 HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:24:14.327000 | 2022-08-05 14:24:16.705 Added 1 Time and Sales records to Intraday data file for XAUUSD after download. | 2022-08-05 14:24:16.705 HD Request # 41 | Completion time: 1s. | 2022-08-05 14:24:16.705 HD Request # 41 | Intraday data download complete for XAUUSD. Unique request ID: 41 | 2022-08-05 14:24:16.705 Removing historical data download ID 41. | 2022-08-05 14:24:16.705 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-05 14:24:16.705 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 15072 | 2022-08-05 14:24:16.709 Intraday chart data file opened for XAUUSD | 2022-08-05 14:24:16.709 HD Request # 41 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:24:16.709 Triggering next historical data download in queue. | 2022-08-05 14:24:16.709 No download requests in the queue to start downloads for. | 2022-08-05 14:24:16.709 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:24:16.766 Socket (6) | Closed. | 2022-08-05 14:24:16.766 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.087 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.087 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.421 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.421 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.429 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.429 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.437 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.437 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.445 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.445 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.453 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.453 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.461 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.461 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.469 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.469 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.477 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.477 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.485 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.485 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.493 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.493 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.501 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.501 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.509 Array message repeat count limit reached. | 2022-08-05 19:20:24.509 Teton CME Order Routing | Market data feed reported to be lost. | 2022-08-05 22:10:07.238 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 22:16:54.502 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-08-05 22:16:54.502 DTC Client socket (1) | CloseSocket call. | 2022-08-05 22:16:54.502 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 22:16:54.502 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 22:16:54.502 DTC Client socket (1) | Closed. | 2022-08-05 22:16:54.502 DTC Client socket (0) | CloseSocket call. | 2022-08-05 22:16:54.503 SC Data - All Services | Disconnected from the server. | 2022-08-05 22:16:54.503 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 22:16:54.503 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2022-08-05 22:16:56.494 DTC Client socket (1) | Creating socket. | 2022-08-05 22:16:56.545 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-08-05 22:16:56.545 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-08-05 22:16:56.545 SC Data - All Services | Network connection to server complete. | 2022-08-05 22:16:56.609 SC Data - All Services | Starting socket receive thread. | 2022-08-05 22:16:56.609 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 22:16:56.609 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 22:16:56.685 SC Data - All Services | Sending logon request message. | 2022-08-05 22:16:56.685 SC Data - All Services | Received logon response. | 2022-08-05 22:16:57.466 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 22:16:57.466 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 22:16:57.466 SC Data - All Services | Successfully connected. | 2022-08-05 22:16:57.466 SC Data - All Services | Trading is not supported. | 2022-08-05 22:16:57.466 Added historical Intraday data request for MESU22_FUT_CME to the queue. | 2022-08-05 22:16:57.466 Intraday data recording state for symbol MESU22_FUT_CME is set to download 'Pending'. | 2022-08-05 22:16:57.466 Triggering next historical data download in queue. | 2022-08-05 22:16:57.466 SC Data - All Services | Restarting real-time data updates for symbol: MESU22_FUT_CME -> MESU22 | 2022-08-05 22:16:57.466 HD Request # 42 | Downloading Intraday chart data for MESU22_FUT_CME to the file MESU22_FUT_CME.scid. Service: cme | 2022-08-05 22:16:57.466 HD Request # 42 | Download start date-time: 2022-08-05 20:59:59.000000. File last date-time: 2022-08-05 20:59:59.000000 | 2022-08-05 22:16:57.467 HD Request # 42 | Using server: ds23.sierracharts.com port 10150 | 2022-08-05 22:16:57.467 Socket (5) | Creating socket. | 2022-08-05 22:16:57.468 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 22:16:57.468 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-08-05 22:16:57.468 HD Request # 42 | Setting DTC encoding to Binary VLS | 2022-08-05 22:16:57.587 HD Request # 42 | Sending historical data logon request message. | 2022-08-05 22:16:57.587 SC Data - All Services | Received security definition for symbol MESU22_FUT_CME | 2022-08-05 22:16:57.622 HD Request # 42 | Requesting Intraday data. Start date-time: 2022-08-05 20:59:59. Record interval: 1. Symbol: MESU22 | 2022-08-05 22:16:58.164 HD Request # 42 | Decompressing data. | 2022-08-05 22:16:58.222 HD Request # 42 | Receiving Intraday data for MESU22_FUT_CME starting at 2022-08-05 20:59:59.073000 | 2022-08-05 22:16:58.223 Socket (5) | CloseSocket call. | 2022-08-05 22:16:58.223 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:16:58.223 Historical data download thread signaled to stop. | 2022-08-05 22:16:58.223 HD Request # 42 | Timestamp of first Intraday data file record written: 2022-08-05 20:59:59.073000. | 2022-08-05 22:16:58.223 HD Request # 42 | Received 1 Intraday data record from 2022-08-05 20:59:59.073000 to 2022-08-05 20:59:59.073000 (0.0 seconds) and wrote 1 record for MESU22_FUT_CME | 2022-08-05 22:16:58.223 HD Request # 42 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:59:59.073000 | 2022-08-05 22:16:58.228 HD Request # 42 | Completion time: 1s. | 2022-08-05 22:16:58.228 HD Request # 42 | Intraday data download complete for MESU22_FUT_CME. Unique request ID: 42 | 2022-08-05 22:16:58.228 Removing historical data download ID 42. | 2022-08-05 22:16:58.228 Real-time Intraday chart data file updates started for MESU22_FUT_CME | 2022-08-05 22:16:58.228 Opened cached Intraday file: C:\SierraChart\Data\MESU22_FUT_CME.scid. Thread ID: 15072 | 2022-08-05 22:16:58.228 Intraday chart data file opened for MESU22_FUT_CME | 2022-08-05 22:16:58.228 HD Request # 42 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:16:58.228 Triggering next historical data download in queue. | 2022-08-05 22:16:58.228 No download requests in the queue to start downloads for. | 2022-08-05 22:16:58.228 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 22:16:58.287 Socket (5) | Closed. | 2022-08-05 22:16:58.287 DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 22:17:17.479 * DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-08-05 22:17:17.479 DTC Client socket (3) | CloseSocket call. | 2022-08-05 22:17:17.479 DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 22:17:17.479 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 22:17:17.479 DTC Client socket (3) | Closed. | 2022-08-05 22:17:17.479 DTC Client socket (0) | CloseSocket call. | 2022-08-05 22:17:17.479 SC Data - All Services | Disconnected from the server. | 2022-08-05 22:17:17.479 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 22:17:17.480 SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 10048 | 2022-08-05 22:17:19.487 DTC Client socket (3) | Creating socket. | 2022-08-05 22:17:19.487 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-08-05 22:17:19.487 DTC Client socket (3) | Connecting to IP: 38.65.8.115. | 2022-08-05 22:17:19.487 SC Data - All Services | Network connection to server complete. | 2022-08-05 22:17:19.551 SC Data - All Services | Starting socket receive thread. | 2022-08-05 22:17:19.551 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-08-05 22:17:19.551 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 22:17:19.619 SC Data - All Services | Sending logon request message. | 2022-08-05 22:17:19.619 DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 22:17:19.811 * DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-08-05 22:17:19.811 DTC Client socket (2) | CloseSocket call. | 2022-08-05 22:17:19.812 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 22:17:19.812 DTC Client socket (2) | Closed. | 2022-08-05 22:17:19.812 Connection to the external service has been lost. | 2022-08-05 22:17:19.812 Teton CME Order Routing | Waiting for socket receive thread to end | 2022-08-05 22:17:19.827 DTC Client socket (0) | CloseSocket call. | 2022-08-05 22:17:19.827 Teton CME Order Routing | Disconnected. | 2022-08-05 22:17:19.827 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-08-05 22:17:19.827 SC Data - All Services | Received logon response. | 2022-08-05 22:17:20.307 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 22:17:20.307 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 22:17:20.307 SC Data - All Services | Successfully connected. | 2022-08-05 22:17:20.307 SC Data - All Services | Trading is not supported. | 2022-08-05 22:17:20.307 Added historical Intraday data request for AAPL-NQTV to the queue. | 2022-08-05 22:17:20.307 Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'. | 2022-08-05 22:17:20.307 Triggering next historical data download in queue. | 2022-08-05 22:17:20.307 SC Data - All Services | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2022-08-05 22:17:20.307 HD Request # 43 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data | 2022-08-05 22:17:20.307 HD Request # 43 | Download start date-time: 2022-08-05 22:16:35.000000. File last date-time: 2022-08-05 22:16:35.000000 | 2022-08-05 22:17:20.311 HD Request # 43 | Using server: ds25.sierracharts.com port 10149 | 2022-08-05 22:17:20.311 Socket (2) | Creating socket. | 2022-08-05 22:17:20.311 Socket (2) | New receive buffer size: 5242880 | 2022-08-05 22:17:20.311 Socket (2) | Connecting to IP: 38.65.8.115. | 2022-08-05 22:17:20.311 HD Request # 43 | Setting DTC encoding to Binary VLS | 2022-08-05 22:17:20.436 HD Request # 43 | Sending historical data logon request message. | 2022-08-05 22:17:20.436 SC Data - All Services | Received security definition for symbol AAPL-NQTV | 2022-08-05 22:17:20.462 HD Request # 43 | Requesting Intraday data. Start date-time: 2022-08-05 22:16:35. Record interval: 1. Symbol: AAPL-NQTV | 2022-08-05 22:17:20.927 HD Request # 43 | Decompressing data. | 2022-08-05 22:17:20.987 HD Request # 43 | Receiving Intraday data for AAPL-NQTV starting at 2022-08-05 22:16:35.456000 | 2022-08-05 22:17:20.987 Socket (2) | CloseSocket call. | 2022-08-05 22:17:20.987 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:17:20.987 Historical data download thread signaled to stop. | 2022-08-05 22:17:20.987 HD Request # 43 | Timestamp of first Intraday data file record written: 2022-08-05 22:16:35.456000. | 2022-08-05 22:17:20.988 HD Request # 43 | Received 1 Intraday data record from 2022-08-05 22:16:35.456000 to 2022-08-05 22:16:35.456000 (0.0 seconds) and wrote 1 record for AAPL-NQTV | 2022-08-05 22:17:20.988 HD Request # 43 | Completion time: 0s. | 2022-08-05 22:17:20.988 HD Request # 43 | Intraday data download complete for AAPL-NQTV. Unique request ID: 43 | 2022-08-05 22:17:20.988 Removing historical data download ID 43. | 2022-08-05 22:17:20.988 HD Request # 43 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:17:20.988 Triggering next historical data download in queue. | 2022-08-05 22:17:20.988 Historical data for AAPL-NQTV is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-08-05 22:17:20.988 No download requests in the queue to start downloads for. | 2022-08-05 22:17:20.988 Socket (2) | Socket gracefully closed by remote side. | 2022-08-05 22:17:21.043 Socket (2) | Closed. | 2022-08-05 22:17:21.043 Teton CME Order Routing | Firm: Dorman | 2022-08-05 22:17:21.826 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-08-05 22:17:21.826 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-08-05 22:17:21.889 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-08-05 22:17:21.889 DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2022-08-05 22:17:21.889 Teton CME Order Routing | Network connection to server complete. | 2022-08-05 22:17:21.944 Teton CME Order Routing | Starting socket receive thread. | 2022-08-05 22:17:21.944 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-08-05 22:17:21.945 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-08-05 22:17:22.123 Teton CME Order Routing | Sending logon request message. | 2022-08-05 22:17:22.123 Teton CME Order Routing | Received logon response. | 2022-08-05 22:17:22.648 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-08-05 22:17:22.648 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 22:17:22.648 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-08-05 22:17:22.648 Teton CME Order Routing | Trading is supported. | 2022-08-05 22:17:22.648 Teton CME Order Routing | Order cancel and replace is supported. | 2022-08-05 22:17:22.648 Teton CME Order Routing | OCO Orders supported. | 2022-08-05 22:17:22.648 Teton CME Order Routing | Bracket Orders supported. | 2022-08-05 22:17:22.648 Teton CME Order Routing | Connected to server complete. | 2022-08-05 22:17:22.648 Triggering next historical data download in queue. | 2022-08-05 22:17:22.648 Triggering next historical data download in queue. | 2022-08-05 22:17:22.648 Triggering next historical data download in queue. | 2022-08-05 22:17:22.648 Triggering next historical data download in queue. | 2022-08-05 22:17:22.648 Updated verified funded futures trading account ending date to: 2022-09-04 22:17:22 | 2022-08-05 22:17:22.648 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-08-05 22:17:22.654 No download requests in the queue to start downloads for. | 2022-08-05 22:17:22.654 No download requests in the queue to start downloads for. | 2022-08-05 22:17:22.654 No download requests in the queue to start downloads for. | 2022-08-05 22:17:22.654 No download requests in the queue to start downloads for. | 2022-08-05 22:17:22.654 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 00:00:00.000000 | 2022-08-05 22:17:22.666 Updated verified funded futures trading account ending date to: 2022-09-04 22:17:22 | 2022-08-05 22:17:22.716 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43878 | 2022-08-05 22:17:22.732 DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 22:17:26.745 * DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-08-05 22:17:26.745 DTC Client socket (4) | CloseSocket call. | 2022-08-05 22:17:26.746 DTC Client socket (4) | Max send buffers used during socket life: 3 | 2022-08-05 22:17:26.746 DTC Client socket (4) | Max send buffer size during socket life: 354 | 2022-08-05 22:17:26.746 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 22:17:26.746 DTC Client socket (4) | Closed. | 2022-08-05 22:17:26.746 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-08-05 22:17:26.746 DTC Client socket (0) | CloseSocket call. | 2022-08-05 22:17:26.746 SC DTC Data with Market Depth | Disconnected from the server. | 2022-08-05 22:17:26.746 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 22:17:26.746 SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2022-08-05 22:17:28.769 DTC Client socket (4) | Creating socket. | 2022-08-05 22:17:28.805 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-08-05 22:17:28.805 DTC Client socket (4) | Connecting to IP: 204.15.197.14. | 2022-08-05 22:17:28.805 SC DTC Data with Market Depth | Network connection to server complete. | 2022-08-05 22:17:28.872 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-08-05 22:17:28.872 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 22:17:28.872 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-08-05 22:17:28.939 SC DTC Data with Market Depth | Sending logon request message. | 2022-08-05 22:17:28.939 SC DTC Data with Market Depth | Received logon response. | 2022-08-05 22:17:29.628 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-08-05 22:17:29.628 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 22:17:29.628 SC DTC Data with Market Depth | Successfully connected. | 2022-08-05 22:17:29.628 SC DTC Data with Market Depth | Trading is not supported. | 2022-08-05 22:17:29.628 Added historical Intraday data request for EURUSD to the queue. | 2022-08-05 22:17:29.628 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2022-08-05 22:17:29.628 Triggering next historical data download in queue. | 2022-08-05 22:17:29.628 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-08-05 22:17:29.628 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-08-05 22:17:29.628 Added historical Intraday data request for US30 to the queue. | 2022-08-05 22:17:29.628 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 22:17:29.628 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2022-08-05 22:17:29.628 Added historical Intraday data request for USOil to the queue. | 2022-08-05 22:17:29.629 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2022-08-05 22:17:29.629 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2022-08-05 22:17:29.629 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 22:17:29.629 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 22:17:29.629 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-08-05 22:17:29.629 HD Request # 44 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2022-08-05 22:17:29.629 HD Request # 44 | Download start date-time: 2022-08-05 20:58:55.000000. File last date-time: 2022-08-05 20:58:55.000000 | 2022-08-05 22:17:29.634 HD Request # 44 | Using server: ds13-3.sierracharts.com port 10150 | 2022-08-05 22:17:29.634 Socket (5) | Creating socket. | 2022-08-05 22:17:29.672 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 22:17:29.672 Socket (5) | Connecting to IP: 162.251.232.235. | 2022-08-05 22:17:29.672 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2022-08-05 22:17:29.788 SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-08-05 22:17:29.788 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2022-08-05 22:17:29.788 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2022-08-05 22:17:29.788 SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-08-05 22:17:29.788 HD Request # 44 | Setting DTC encoding to Binary VLS | 2022-08-05 22:17:29.802 HD Request # 44 | Sending historical data logon request message. | 2022-08-05 22:17:29.802 HD Request # 44 | Requesting Intraday data. Start date-time: 2022-08-05 20:58:55. Record interval: 1. Symbol: EURUSD | 2022-08-05 22:17:30.502 HD Request # 44 | Decompressing data. | 2022-08-05 22:17:30.566 HD Request # 44 | Receiving Intraday data for EURUSD starting at 2022-08-05 20:58:55.856000 | 2022-08-05 22:17:30.566 Socket (5) | CloseSocket call. | 2022-08-05 22:17:30.567 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:17:30.567 Historical data download thread signaled to stop. | 2022-08-05 22:17:30.567 HD Request # 44 | Timestamp of first Intraday data file record written: 2022-08-05 20:58:55.856000. | 2022-08-05 22:17:30.567 HD Request # 44 | Received 19 Intraday data records from 2022-08-05 20:58:55.856000 to 2022-08-05 20:59:57.353000 (61.5 seconds) and wrote 19 records for EURUSD | 2022-08-05 22:17:30.567 HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:59:57.353000 | 2022-08-05 22:17:30.571 HD Request # 44 | Completion time: 1s. | 2022-08-05 22:17:30.571 HD Request # 44 | Intraday data download complete for EURUSD. Unique request ID: 44 | 2022-08-05 22:17:30.571 Removing historical data download ID 44. | 2022-08-05 22:17:30.571 Real-time Intraday chart data file updates started for EURUSD | 2022-08-05 22:17:30.571 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 15072 | 2022-08-05 22:17:30.571 Intraday chart data file opened for EURUSD | 2022-08-05 22:17:30.571 HD Request # 44 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:17:30.571 Triggering next historical data download in queue. | 2022-08-05 22:17:30.571 HD Request # 45 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 22:17:30.571 HD Request # 45 | Download start date-time: 2022-08-05 20:44:59.000000. File last date-time: 2022-08-05 20:44:59.000000 | 2022-08-05 22:17:30.572 HD Request # 45 | Using server: ds4.sierracharts.com port 10149 | 2022-08-05 22:17:30.572 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 22:17:30.629 Socket (5) | Closed. | 2022-08-05 22:17:30.629 Socket (6) | Creating socket. | 2022-08-05 22:17:30.647 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 22:17:30.647 Socket (6) | Connecting to IP: 192.81.56.146. | 2022-08-05 22:17:30.647 HD Request # 45 | Setting DTC encoding to Binary VLS | 2022-08-05 22:17:30.772 HD Request # 45 | Sending historical data logon request message. | 2022-08-05 22:17:30.772 HD Request # 45 | Requesting Intraday data. Start date-time: 2022-08-05 20:44:59. Record interval: 1. Symbol: US30 | 2022-08-05 22:17:31.355 HD Request # 45 | Decompressing data. | 2022-08-05 22:17:31.439 HD Request # 45 | Receiving Intraday data for US30 starting at 2022-08-05 20:44:59.419000 | 2022-08-05 22:17:31.439 Socket (6) | CloseSocket call. | 2022-08-05 22:17:31.440 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:17:31.440 Historical data download thread signaled to stop. | 2022-08-05 22:17:31.440 HD Request # 45 | Timestamp of first Intraday data file record written: 2022-08-05 20:44:59.419000. | 2022-08-05 22:17:31.440 HD Request # 45 | Received 1 Intraday data record from 2022-08-05 20:44:59.419000 to 2022-08-05 20:44:59.419000 (0.0 seconds) and wrote 1 record for US30 | 2022-08-05 22:17:31.440 HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:44:59.419000 | 2022-08-05 22:17:31.444 HD Request # 45 | Completion time: 1s. | 2022-08-05 22:17:31.444 HD Request # 45 | Intraday data download complete for US30. Unique request ID: 45 | 2022-08-05 22:17:31.444 Removing historical data download ID 45. | 2022-08-05 22:17:31.444 Real-time Intraday chart data file updates started for US30 | 2022-08-05 22:17:31.444 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 22:17:31.444 Intraday chart data file opened for US30 | 2022-08-05 22:17:31.444 HD Request # 45 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:17:31.444 Triggering next historical data download in queue. | 2022-08-05 22:17:31.444 HD Request # 46 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2022-08-05 22:17:31.444 HD Request # 46 | Download start date-time: 2022-08-05 20:44:59.000000. File last date-time: 2022-08-05 20:44:59.000000 | 2022-08-05 22:17:31.444 HD Request # 46 | Using server: ds12.sierracharts.com port 10150 | 2022-08-05 22:17:31.444 Socket (5) | Creating socket. | 2022-08-05 22:17:31.444 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 22:17:31.444 Socket (5) | Connecting to IP: 204.15.197.14. | 2022-08-05 22:17:31.444 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 22:17:31.504 Socket (6) | Closed. | 2022-08-05 22:17:31.504 HD Request # 46 | Setting DTC encoding to Binary VLS | 2022-08-05 22:17:31.598 HD Request # 46 | Sending historical data logon request message. | 2022-08-05 22:17:31.598 HD Request # 46 | Requesting Intraday data. Start date-time: 2022-08-05 20:44:59. Record interval: 1. Symbol: USOil | 2022-08-05 22:17:32.186 HD Request # 46 | Decompressing data. | 2022-08-05 22:17:32.248 HD Request # 46 | Receiving Intraday data for USOil starting at 2022-08-05 20:44:59.089000 | 2022-08-05 22:17:32.248 Socket (5) | CloseSocket call. | 2022-08-05 22:17:32.248 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:17:32.248 Historical data download thread signaled to stop. | 2022-08-05 22:17:32.248 HD Request # 46 | Timestamp of first Intraday data file record written: 2022-08-05 20:44:59.089000. | 2022-08-05 22:17:32.248 HD Request # 46 | Received 1 Intraday data record from 2022-08-05 20:44:59.089000 to 2022-08-05 20:44:59.089000 (0.0 seconds) and wrote 1 record for USOil | 2022-08-05 22:17:32.248 HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:44:59.089000 | 2022-08-05 22:17:32.253 HD Request # 46 | Completion time: 1s. | 2022-08-05 22:17:32.253 HD Request # 46 | Intraday data download complete for USOil. Unique request ID: 46 | 2022-08-05 22:17:32.253 Removing historical data download ID 46. | 2022-08-05 22:17:32.253 Real-time Intraday chart data file updates started for USOil | 2022-08-05 22:17:32.253 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 15072 | 2022-08-05 22:17:32.253 Intraday chart data file opened for USOil | 2022-08-05 22:17:32.253 HD Request # 46 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:17:32.253 Triggering next historical data download in queue. | 2022-08-05 22:17:32.253 HD Request # 47 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 22:17:32.253 HD Request # 47 | Download start date-time: 2022-08-05 20:58:49.000000. File last date-time: 2022-08-05 20:58:49.000000 | 2022-08-05 22:17:32.253 HD Request # 47 | Using server: ds13-3.sierracharts.com port 10149 | 2022-08-05 22:17:32.253 Socket (6) | Creating socket. | 2022-08-05 22:17:32.253 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 22:17:32.253 Socket (6) | Connecting to IP: 162.251.232.235. | 2022-08-05 22:17:32.253 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 22:17:32.318 Socket (5) | Closed. | 2022-08-05 22:17:32.318 HD Request # 47 | Setting DTC encoding to Binary VLS | 2022-08-05 22:17:32.392 HD Request # 47 | Sending historical data logon request message. | 2022-08-05 22:17:32.392 HD Request # 47 | Requesting Intraday data. Start date-time: 2022-08-05 20:58:49. Record interval: 1. Symbol: XAUUSD | 2022-08-05 22:17:33.132 HD Request # 47 | Decompressing data. | 2022-08-05 22:17:33.196 HD Request # 47 | Receiving Intraday data for XAUUSD starting at 2022-08-05 20:58:49.436000 | 2022-08-05 22:17:33.197 Socket (6) | CloseSocket call. | 2022-08-05 22:17:33.197 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:17:33.197 Historical data download thread signaled to stop. | 2022-08-05 22:17:33.197 HD Request # 47 | Timestamp of first Intraday data file record written: 2022-08-05 20:58:49.436000. | 2022-08-05 22:17:33.197 HD Request # 47 | Received 21 Intraday data records from 2022-08-05 20:58:49.436000 to 2022-08-05 20:59:58.038000 (68.6 seconds) and wrote 21 records for XAUUSD | 2022-08-05 22:17:33.197 HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:59:58.038000 | 2022-08-05 22:17:33.201 HD Request # 47 | Completion time: 1s. | 2022-08-05 22:17:33.201 HD Request # 47 | Intraday data download complete for XAUUSD. Unique request ID: 47 | 2022-08-05 22:17:33.201 Removing historical data download ID 47. | 2022-08-05 22:17:33.201 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-05 22:17:33.201 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 15072 | 2022-08-05 22:17:33.202 Intraday chart data file opened for XAUUSD | 2022-08-05 22:17:33.202 HD Request # 47 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:17:33.202 Triggering next historical data download in queue. | 2022-08-05 22:17:33.202 No download requests in the queue to start downloads for. | 2022-08-05 22:17:33.202 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 22:17:33.256 Socket (6) | Closed. | 2022-08-05 22:17:33.256 Teton CME Order Routing | Market data feed reported to be restored. | 2022-08-05 22:33:55.452 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 22:33:55.452 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 22:33:55.452 Triggering next historical data download in queue. | 2022-08-05 22:33:55.452 Added historical Intraday data request for TSLA to the queue. | 2022-08-05 22:33:55.452 Intraday data recording state for symbol TSLA is set to download 'Pending'. | 2022-08-05 22:33:55.452 Added historical Intraday data request for US30 to the queue. | 2022-08-05 22:33:55.452 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 22:33:55.452 Added historical Intraday data request for SPY to the queue. | 2022-08-05 22:33:55.452 Intraday data recording state for symbol SPY is set to download 'Pending'. | 2022-08-05 22:33:55.452 No historical data client is currently set to download historical Intraday data for ESU22-CME. | 2022-08-05 22:33:55.452 Real-time Intraday chart data file updates started for ESU22-CME | 2022-08-05 22:33:55.452 Opened cached Intraday file: C:\SierraChart\Data\ESU22-CME.scid. Thread ID: 15072 | 2022-08-05 22:33:55.452 Intraday chart data file opened for ESU22-CME | 2022-08-05 22:33:55.452 Added historical Intraday data request for USOil to the queue. | 2022-08-05 22:33:55.453 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2022-08-05 22:33:55.453 Added historical Intraday data request for EURUSD to the queue. | 2022-08-05 22:33:55.453 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2022-08-05 22:33:55.453 Added historical Intraday data request for MESU22_FUT_CME to the queue. | 2022-08-05 22:33:55.453 Intraday data recording state for symbol MESU22_FUT_CME is set to download 'Pending'. | 2022-08-05 22:33:55.453 HD Request # 48 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 22:33:55.453 HD Request # 48 | Download start date-time: 2022-08-05 20:59:58.000000. File last date-time: 2022-08-05 20:59:58.038000 | 2022-08-05 22:33:55.453 HD Request # 48 | Using server: ds4.sierracharts.com port 10150 | 2022-08-05 22:33:55.453 Socket (5) | Creating socket. | 2022-08-05 22:33:55.453 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 22:33:55.453 Socket (5) | Connecting to IP: 192.81.56.146. | 2022-08-05 22:33:55.453 HD Request # 48 | Setting DTC encoding to Binary VLS | 2022-08-05 22:33:55.579 HD Request # 48 | Sending historical data logon request message. | 2022-08-05 22:33:55.579 HD Request # 48 | Requesting Intraday data. Start date-time: 2022-08-05 20:59:58. Record interval: 1. Symbol: XAUUSD | 2022-08-05 22:33:56.157 HD Request # 48 | Decompressing data. | 2022-08-05 22:33:56.222 HD Request # 48 | Receiving Intraday data for XAUUSD starting at 2022-08-05 19:58:49.279000 | 2022-08-05 22:33:56.286 Socket (5) | CloseSocket call. | 2022-08-05 22:33:56.286 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:33:56.286 Historical data download thread signaled to stop. | 2022-08-05 22:33:56.287 HD Request # 48 | Received 958 Intraday data records from 2022-08-05 19:58:49.279000 to 2022-08-05 20:58:49.273000 (60.0 minutes) and wrote 0 records for XAUUSD | 2022-08-05 22:33:56.287 HD Request # 48 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:59:58.038000 | 2022-08-05 22:33:56.287 HD Request # 48 | Completion time: 1s. | 2022-08-05 22:33:56.287 HD Request # 48 | Intraday data download complete for XAUUSD. Unique request ID: 48 | 2022-08-05 22:33:56.287 Removing historical data download ID 48. | 2022-08-05 22:33:56.287 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-05 22:33:56.287 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 15072 | 2022-08-05 22:33:56.287 Intraday chart data file opened for XAUUSD | 2022-08-05 22:33:56.287 HD Request # 48 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:33:56.287 Triggering next historical data download in queue. | 2022-08-05 22:33:56.287 HD Request # 49 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2022-08-05 22:33:56.287 HD Request # 49 | Download start date-time: 2022-08-05 14:04:51.000000. File last date-time: 2022-08-05 14:04:51.222000 | 2022-08-05 22:33:56.287 HD Request # 49 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2022-08-05 22:33:56.287 Socket (6) | Creating socket. | 2022-08-05 22:33:56.288 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 22:33:56.288 Socket (6) | Connecting to IP: 8.18.161.133. | 2022-08-05 22:33:56.288 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 22:33:56.351 Socket (5) | Closed. | 2022-08-05 22:33:56.351 HD Request # 49 | Setting DTC encoding to Binary VLS | 2022-08-05 22:33:56.404 HD Request # 49 | Sending historical data logon request message. | 2022-08-05 22:33:56.404 HD Request # 49 | Requesting Intraday data. Start date-time: 2022-08-05 14:04:51. Record interval: 1. Symbol: TSLA | 2022-08-05 22:33:56.924 HD Request # 49 | Decompressing data. | 2022-08-05 22:33:56.999 HD Request # 49 | Receiving Intraday data for TSLA starting at 2022-08-05 14:04:51.222000 | 2022-08-05 22:33:57.355 Socket (6) | CloseSocket call. | 2022-08-05 22:33:57.478 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:33:57.478 Historical data download thread signaled to stop. | 2022-08-05 22:33:57.478 HD Request # 49 | Timestamp of first Intraday data file record written: 2022-08-05 14:04:51.222000. | 2022-08-05 22:33:57.478 HD Request # 49 | Received 18475 Intraday data records from 2022-08-05 14:04:51.222000 to 2022-08-05 22:17:04.349000 (8.2 hours) and wrote 18475 records for TSLA | 2022-08-05 22:33:57.478 HD Request # 49 | Add time&sales data | Remembered last file record date-time: 2022-08-05 22:17:04.349000 | 2022-08-05 22:33:57.484 HD Request # 49 | Completion time: 1s. | 2022-08-05 22:33:57.484 HD Request # 49 | Intraday data download complete for TSLA. Unique request ID: 49 | 2022-08-05 22:33:57.484 Removing historical data download ID 49. | 2022-08-05 22:33:57.484 Real-time Intraday chart data file updates started for TSLA | 2022-08-05 22:33:57.484 Opened cached Intraday file: C:\SierraChart\Data\TSLA.scid. Thread ID: 15072 | 2022-08-05 22:33:57.484 Intraday chart data file opened for TSLA | 2022-08-05 22:33:57.484 HD Request # 49 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:33:57.484 Triggering next historical data download in queue. | 2022-08-05 22:33:57.484 HD Request # 50 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 22:33:57.484 HD Request # 50 | Download start date-time: 2022-08-05 20:44:59.000000. File last date-time: 2022-08-05 20:44:59.419000 | 2022-08-05 22:33:57.484 HD Request # 50 | Using server: ds12.sierracharts.com port 10150 | 2022-08-05 22:33:57.484 Socket (5) | Creating socket. | 2022-08-05 22:33:57.485 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 22:33:57.485 Socket (5) | Connecting to IP: 204.15.197.14. | 2022-08-05 22:33:57.485 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 22:33:57.530 Socket (6) | Closed. | 2022-08-05 22:33:57.531 HD Request # 50 | Setting DTC encoding to Binary VLS | 2022-08-05 22:33:57.650 HD Request # 50 | Sending historical data logon request message. | 2022-08-05 22:33:57.650 HD Request # 50 | Requesting Intraday data. Start date-time: 2022-08-05 20:44:59. Record interval: 1. Symbol: US30 | 2022-08-05 22:33:58.234 HD Request # 50 | Decompressing data. | 2022-08-05 22:33:58.294 HD Request # 50 | Receiving Intraday data for US30 starting at 2022-08-05 20:44:59.419000 | 2022-08-05 22:33:58.294 Socket (5) | CloseSocket call. | 2022-08-05 22:33:58.294 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:33:58.294 Historical data download thread signaled to stop. | 2022-08-05 22:33:58.294 HD Request # 50 | Timestamp of first Intraday data file record written: 2022-08-05 20:44:59.419000. | 2022-08-05 22:33:58.295 HD Request # 50 | Received 1 Intraday data record from 2022-08-05 20:44:59.419000 to 2022-08-05 20:44:59.419000 (0.0 seconds) and wrote 1 record for US30 | 2022-08-05 22:33:58.295 HD Request # 50 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:44:59.419000 | 2022-08-05 22:33:58.298 HD Request # 50 | Completion time: 1s. | 2022-08-05 22:33:58.298 HD Request # 50 | Intraday data download complete for US30. Unique request ID: 50 | 2022-08-05 22:33:58.298 Removing historical data download ID 50. | 2022-08-05 22:33:58.298 Real-time Intraday chart data file updates started for US30 | 2022-08-05 22:33:58.298 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 22:33:58.299 Intraday chart data file opened for US30 | 2022-08-05 22:33:58.299 HD Request # 50 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:33:58.299 Triggering next historical data download in queue. | 2022-08-05 22:33:58.299 HD Request # 51 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: equities.us | 2022-08-05 22:33:58.299 HD Request # 51 | Download start date-time: 2022-08-05 14:04:54.000000. File last date-time: 2022-08-05 14:04:54.210000 | 2022-08-05 22:33:58.299 HD Request # 51 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2022-08-05 22:33:58.299 Socket (6) | Creating socket. | 2022-08-05 22:33:58.299 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 22:33:58.299 Socket (6) | Connecting to IP: 8.18.161.135. | 2022-08-05 22:33:58.299 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 22:33:58.362 Socket (5) | Closed. | 2022-08-05 22:33:58.362 HD Request # 51 | Setting DTC encoding to Binary VLS | 2022-08-05 22:33:58.418 HD Request # 51 | Sending historical data logon request message. | 2022-08-05 22:33:58.418 HD Request # 51 | Requesting Intraday data. Start date-time: 2022-08-05 14:04:54. Record interval: 1. Symbol: SPY | 2022-08-05 22:33:58.927 HD Request # 51 | Decompressing data. | 2022-08-05 22:33:58.994 HD Request # 51 | Receiving Intraday data for SPY starting at 2022-08-05 14:04:54.210000 | 2022-08-05 22:33:59.382 Socket (6) | CloseSocket call. | 2022-08-05 22:33:59.615 Historical data download thread signaled to stop. | 2022-08-05 22:33:59.615 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:33:59.615 HD Request # 51 | Timestamp of first Intraday data file record written: 2022-08-05 14:04:54.210000. | 2022-08-05 22:33:59.616 HD Request # 51 | Received 19757 Intraday data records from 2022-08-05 14:04:54.210000 to 2022-08-05 22:16:52.063000 (8.2 hours) and wrote 19757 records for SPY | 2022-08-05 22:33:59.616 HD Request # 51 | Add time&sales data | Remembered last file record date-time: 2022-08-05 22:16:52.063000 | 2022-08-05 22:33:59.620 HD Request # 51 | Completion time: 1s. | 2022-08-05 22:33:59.620 HD Request # 51 | Intraday data download complete for SPY. Unique request ID: 51 | 2022-08-05 22:33:59.620 Removing historical data download ID 51. | 2022-08-05 22:33:59.620 Real-time Intraday chart data file updates started for SPY | 2022-08-05 22:33:59.620 Opened cached Intraday file: C:\SierraChart\Data\SPY.scid. Thread ID: 15072 | 2022-08-05 22:33:59.620 Intraday chart data file opened for SPY | 2022-08-05 22:33:59.620 HD Request # 51 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:33:59.620 Triggering next historical data download in queue. | 2022-08-05 22:33:59.620 HD Request # 52 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2022-08-05 22:33:59.620 HD Request # 52 | Download start date-time: 2022-08-05 20:44:59.000000. File last date-time: 2022-08-05 20:44:59.089000 | 2022-08-05 22:33:59.620 HD Request # 52 | Using server: ds13-3.sierracharts.com port 10150 | 2022-08-05 22:33:59.620 Socket (5) | Creating socket. | 2022-08-05 22:33:59.621 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 22:33:59.621 Socket (5) | Connecting to IP: 162.251.232.235. | 2022-08-05 22:33:59.621 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 22:33:59.671 Socket (6) | Closed. | 2022-08-05 22:33:59.671 HD Request # 52 | Setting DTC encoding to Binary VLS | 2022-08-05 22:33:59.768 HD Request # 52 | Sending historical data logon request message. | 2022-08-05 22:33:59.768 HD Request # 52 | Requesting Intraday data. Start date-time: 2022-08-05 20:44:59. Record interval: 1. Symbol: USOil | 2022-08-05 22:34:00.480 HD Request # 52 | Decompressing data. | 2022-08-05 22:34:00.547 HD Request # 52 | Receiving Intraday data for USOil starting at 2022-08-05 20:44:59.132000 | 2022-08-05 22:34:00.547 Socket (5) | CloseSocket call. | 2022-08-05 22:34:00.548 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:34:00.548 Historical data download thread signaled to stop. | 2022-08-05 22:34:00.548 HD Request # 52 | Timestamp of first Intraday data file record written: 2022-08-05 20:44:59.132000. | 2022-08-05 22:34:00.548 HD Request # 52 | Received 182 Intraday data records from 2022-08-05 20:44:59.132000 to 2022-08-05 20:59:59.043000 (15.0 minutes) and wrote 182 records for USOil | 2022-08-05 22:34:00.548 HD Request # 52 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:59:59.043000 | 2022-08-05 22:34:00.552 HD Request # 52 | Completion time: 1s. | 2022-08-05 22:34:00.552 HD Request # 52 | Intraday data download complete for USOil. Unique request ID: 52 | 2022-08-05 22:34:00.552 Removing historical data download ID 52. | 2022-08-05 22:34:00.552 Real-time Intraday chart data file updates started for USOil | 2022-08-05 22:34:00.552 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 15072 | 2022-08-05 22:34:00.553 Intraday chart data file opened for USOil | 2022-08-05 22:34:00.553 HD Request # 52 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:34:00.553 Triggering next historical data download in queue. | 2022-08-05 22:34:00.553 HD Request # 53 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2022-08-05 22:34:00.553 HD Request # 53 | Download start date-time: 2022-08-05 20:59:57.000000. File last date-time: 2022-08-05 20:59:57.353000 | 2022-08-05 22:34:00.553 HD Request # 53 | Using server: ds4.sierracharts.com port 10149 | 2022-08-05 22:34:00.553 Socket (6) | Creating socket. | 2022-08-05 22:34:00.553 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 22:34:00.553 Socket (6) | Connecting to IP: 192.81.56.146. | 2022-08-05 22:34:00.553 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 22:34:00.618 Socket (5) | Closed. | 2022-08-05 22:34:00.618 HD Request # 53 | Setting DTC encoding to Binary VLS | 2022-08-05 22:34:00.684 HD Request # 53 | Sending historical data logon request message. | 2022-08-05 22:34:00.684 HD Request # 53 | Requesting Intraday data. Start date-time: 2022-08-05 20:59:57. Record interval: 1. Symbol: EURUSD | 2022-08-05 22:34:01.262 HD Request # 53 | Decompressing data. | 2022-08-05 22:34:01.323 HD Request # 53 | Receiving Intraday data for EURUSD starting at 2022-08-05 19:58:58.293000 | 2022-08-05 22:34:01.388 Socket (6) | CloseSocket call. | 2022-08-05 22:34:01.389 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:34:01.389 Historical data download thread signaled to stop. | 2022-08-05 22:34:01.389 HD Request # 53 | Received 1295 Intraday data records from 2022-08-05 19:58:58.293000 to 2022-08-05 20:58:55.746000 (60.0 minutes) and wrote 0 records for EURUSD | 2022-08-05 22:34:01.389 HD Request # 53 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:59:57.353000 | 2022-08-05 22:34:01.390 HD Request # 53 | Completion time: 1s. | 2022-08-05 22:34:01.390 HD Request # 53 | Intraday data download complete for EURUSD. Unique request ID: 53 | 2022-08-05 22:34:01.390 Removing historical data download ID 53. | 2022-08-05 22:34:01.390 Real-time Intraday chart data file updates started for EURUSD | 2022-08-05 22:34:01.390 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 15072 | 2022-08-05 22:34:01.390 Intraday chart data file opened for EURUSD | 2022-08-05 22:34:01.390 HD Request # 53 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:34:01.390 Triggering next historical data download in queue. | 2022-08-05 22:34:01.390 HD Request # 54 | Downloading Intraday chart data for MESU22_FUT_CME to the file MESU22_FUT_CME.scid. Service: cme | 2022-08-05 22:34:01.390 HD Request # 54 | Download start date-time: 2022-08-05 20:59:59.000000. File last date-time: 2022-08-05 20:59:59.073000 | 2022-08-05 22:34:01.390 HD Request # 54 | Using server: ds23.sierracharts.com port 10150 | 2022-08-05 22:34:01.390 Socket (5) | Creating socket. | 2022-08-05 22:34:01.390 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 22:34:01.390 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-08-05 22:34:01.390 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 22:34:01.452 Socket (6) | Closed. | 2022-08-05 22:34:01.452 HD Request # 54 | Setting DTC encoding to Binary VLS | 2022-08-05 22:34:01.649 HD Request # 54 | Sending historical data logon request message. | 2022-08-05 22:34:01.649 HD Request # 54 | Requesting Intraday data. Start date-time: 2022-08-05 20:59:59. Record interval: 1. Symbol: MESU22 | 2022-08-05 22:34:10.883 HD Request # 54 | Decompressing data. | 2022-08-05 22:34:10.940 HD Request # 54 | Receiving Intraday data for MESU22_FUT_CME starting at 2022-08-05 20:59:59.073000 | 2022-08-05 22:34:10.940 Socket (5) | CloseSocket call. | 2022-08-05 22:34:10.940 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:34:10.940 Historical data download thread signaled to stop. | 2022-08-05 22:34:10.940 HD Request # 54 | Timestamp of first Intraday data file record written: 2022-08-05 20:59:59.073000. | 2022-08-05 22:34:10.941 HD Request # 54 | Received 1 Intraday data record from 2022-08-05 20:59:59.073000 to 2022-08-05 20:59:59.073000 (0.0 seconds) and wrote 1 record for MESU22_FUT_CME | 2022-08-05 22:34:10.941 HD Request # 54 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:59:59.073000 | 2022-08-05 22:34:10.945 HD Request # 54 | Completion time: 9s. | 2022-08-05 22:34:10.945 HD Request # 54 | Intraday data download complete for MESU22_FUT_CME. Unique request ID: 54 | 2022-08-05 22:34:10.945 Removing historical data download ID 54. | 2022-08-05 22:34:10.945 Real-time Intraday chart data file updates started for MESU22_FUT_CME | 2022-08-05 22:34:10.945 Opened cached Intraday file: C:\SierraChart\Data\MESU22_FUT_CME.scid. Thread ID: 15072 | 2022-08-05 22:34:10.945 Intraday chart data file opened for MESU22_FUT_CME | 2022-08-05 22:34:10.945 HD Request # 54 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:34:10.945 Triggering next historical data download in queue. | 2022-08-05 22:34:10.945 No download requests in the queue to start downloads for. | 2022-08-05 22:34:10.945 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 22:34:10.996 Socket (5) | Closed. | 2022-08-05 22:34:10.996 Reading Internal Order ID file. | 2022-08-05 14:10:39.409 Reading Trade Orders file. | 2022-08-05 14:10:39.484 Reading Trade Positions file. | 2022-08-05 14:10:39.488 Reading Trade Account Data files. | 2022-08-05 14:10:39.491 Software version: 2416 64-bit | 2022-08-05 14:10:39.510 Primary Thread ID: 15072 | 2022-08-05 14:10:39.510 Usage end date: 2022-09-14 | 2022-08-05 14:10:39.510 Enabled for: Advanced Features 2. | 2022-08-05 14:10:39.510 Enabled for: Sierra Chart Historical Data Service. | 2022-08-05 14:10:39.510 Enabled for: Denali Real-Time Exchange Data Feed. | 2022-08-05 14:10:39.510 Enabled for: Delayed Denali Exchange Data Feed. | 2022-08-05 14:10:39.510 Enabled for exchange2: CME (Trading Account Required) | 2022-08-05 14:10:39.510 Enabled for exchange2: CBOT (Trading Account Required) | 2022-08-05 14:10:39.510 Enabled for exchange2: COMEX (Trading Account Required) | 2022-08-05 14:10:39.510 Enabled for exchange2: NYMEX (Trading Account Required) | 2022-08-05 14:10:39.510 Enabled for exchange2: fairx_exchange.data | 2022-08-05 14:10:39.510 Enabled for exchange2: NASDAQ US stock data | 2022-08-05 14:10:39.510 Allow Support for Sierra Chart Data Feeds is enabled. | 2022-08-05 14:10:39.510 Current selected Data/Trading service: Teton CME Order Routing | 2022-08-05 14:10:39.510 Custom symbol settings values: enabled | 2022-08-05 14:10:39.510 Chart Update Interval: 500 | 2022-08-05 14:10:39.510 Intraday Data Storage Time Unit: 1 | 2022-08-05 14:10:39.510 Time Zone: +00:00:00 (UTC+00) | 2022-08-05 14:10:39.510 2022-08-05 14:10:39 Local computer time in UTC | 2022-08-05 14:10:39.510 2022-08-05 14:10:39 Local computer time in SC Time Zone | 2022-08-05 14:10:39.510 2022-08-05 14:10:38 Server time in UTC | 2022-08-05 14:10:39.510 Local computer UTC time and Server UTC time difference: 0 seconds. | 2022-08-05 14:10:39.510 Program path: C:\SierraChart\ | 2022-08-05 14:10:39.510 Data Files path: C:\SierraChart\Data\ | 2022-08-05 14:10:39.510 OS Version Number: 10.0 | 2022-08-05 14:10:39.510 Locale Setting: C | 2022-08-05 14:10:39.510 DLLs: UserContributedStudies_64.dll | 2022-08-05 14:10:39.510 Allowed protected custom studies: | 2022-08-05 14:10:39.510 Crash reporter started: true | 2022-08-05 14:10:39.510 Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. | 2022-08-05 14:10:39.526 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:39.553 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2022-08-05 14:10:39.707 HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2022-08-05 14:10:39.707 Received 5 login tokens. | 2022-08-05 14:10:40.028 Symbol settings MD5 received. Request ID: 1. | 2022-08-05 14:10:41.439 Symbol settings are up-to-date for sc_futures_direct.dtc.trading. | 2022-08-05 14:10:41.439 Files to Open on Startup | Opening file: ExampleChartbook.cht | 2022-08-05 14:10:44.251 XAUUSD 1 Min #1 | Reloading chart. | 2022-08-05 14:10:44.270 XAUUSD Daily #2 | Reloading chart. | 2022-08-05 14:10:44.285 US30 1 Min #3 | Reloading chart. | 2022-08-05 14:10:44.296 USOil 1 Min #4 | Reloading chart. | 2022-08-05 14:10:44.308 ESU22-CME 1 Min #5 | Reloading chart. | 2022-08-05 14:10:44.320 SPX500 Daily #6 | Reloading chart. | 2022-08-05 14:10:44.335 EURUSD Daily #7 | Reloading chart. | 2022-08-05 14:10:44.368 EURUSD 5 Min #8 | Reloading chart. | 2022-08-05 14:10:44.380 ESU22-CME #9 | Reloading chart. | 2022-08-05 14:10:44.389 ESU22-CME 1 Min #10 | Reloading chart. | 2022-08-05 14:10:44.740 AAPL-NQTV 10 Min #11 | Reloading chart. | 2022-08-05 14:10:44.780 TSLA 10 Min #12 | Reloading chart. | 2022-08-05 14:10:44.796 SPY 30 Min #13 | Reloading chart. | 2022-08-05 14:10:44.808 ESU22-CME 1 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00 | 2022-08-05 14:10:44.900 Using Bid/Ask average for last trade price for XAUUSD | 2022-08-05 14:10:44.930 Using symbol data fast lookup vector | 2022-08-05 14:10:44.930 Starting DelayedDownloadMonitoringTimer | 2022-08-05 14:10:44.930 Starting HDTimeoutTimer | 2022-08-05 14:10:44.930 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 14:10:44.930 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 14:10:44.930 Triggering next historical data download in queue. | 2022-08-05 14:10:44.930 HD Request # 1 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 14:10:44.933 HD Request # 1 | Download start date-time: 2022-08-04 23:50:45.000000. File last date-time: 2022-08-04 23:50:45.000000 | 2022-08-05 14:10:44.934 HD Request # 1 | Using server: ds12.sierracharts.com port 10150 | 2022-08-05 14:10:44.934 Socket (1) | Creating socket. | 2022-08-05 14:10:44.934 Socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:10:44.934 Socket (1) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:10:44.934 Added historical Daily data request for XAUUSD to the queue. | 2022-08-05 14:10:44.938 Triggering next historical data download in queue. | 2022-08-05 14:10:44.938 Using Bid/Ask average for last trade price for US30 | 2022-08-05 14:10:44.941 Added historical Intraday data request for US30 to the queue. | 2022-08-05 14:10:44.941 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 14:10:44.941 Triggering next historical data download in queue. | 2022-08-05 14:10:44.941 Using Bid/Ask average for last trade price for USOil | 2022-08-05 14:10:44.947 Added historical Intraday data request for USOil to the queue. | 2022-08-05 14:10:44.947 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2022-08-05 14:10:44.947 Triggering next historical data download in queue. | 2022-08-05 14:10:44.947 Added historical Daily data request for SPX500 to the queue. | 2022-08-05 14:10:44.950 Triggering next historical data download in queue. | 2022-08-05 14:10:44.950 Using Bid/Ask average for last trade price for SPX500 | 2022-08-05 14:10:44.950 Added historical Daily data request for EURUSD to the queue. | 2022-08-05 14:10:44.954 Triggering next historical data download in queue. | 2022-08-05 14:10:44.954 Using Bid/Ask average for last trade price for EURUSD | 2022-08-05 14:10:44.954 Added historical Intraday data request for EURUSD to the queue. | 2022-08-05 14:10:44.957 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2022-08-05 14:10:44.957 Triggering next historical data download in queue. | 2022-08-05 14:10:44.957 HD Request # 1 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:45.074 HD Request # 1 | Sending historical data logon request message. | 2022-08-05 14:10:45.074 Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data | 2022-08-05 14:10:45.283 Added historical Intraday data request for AAPL-NQTV to the queue. | 2022-08-05 14:10:45.283 Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'. | 2022-08-05 14:10:45.283 Triggering next historical data download in queue. | 2022-08-05 14:10:45.283 Added historical Intraday data request for TSLA to the queue. | 2022-08-05 14:10:45.296 Intraday data recording state for symbol TSLA is set to download 'Pending'. | 2022-08-05 14:10:45.296 Triggering next historical data download in queue. | 2022-08-05 14:10:45.296 Added historical Intraday data request for SPY to the queue. | 2022-08-05 14:10:45.314 Intraday data recording state for symbol SPY is set to download 'Pending'. | 2022-08-05 14:10:45.314 Triggering next historical data download in queue. | 2022-08-05 14:10:45.314 HD Request # 1 | Requesting Intraday data. Start date-time: 2022-08-04 23:50:45. Record interval: 1. Symbol: XAUUSD | 2022-08-05 14:10:45.660 HD Request # 1 | Decompressing data. | 2022-08-05 14:10:45.727 HD Request # 1 | Receiving Intraday data for XAUUSD starting at 2022-08-04 23:50:45.018000 | 2022-08-05 14:10:46.078 HD Request # 1 | Timestamp of first Intraday data file record written: 2022-08-04 23:50:45.018000. | 2022-08-05 14:10:46.413 Socket (1) | CloseSocket call. | 2022-08-05 14:10:46.415 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:46.415 Historical data download thread signaled to stop. | 2022-08-05 14:10:46.415 HD Request # 1 | Received 35768 Intraday data records from 2022-08-04 23:50:45.018000 to 2022-08-05 14:10:45.037000 (14.3 hours) and wrote 35768 records for XAUUSD | 2022-08-05 14:10:46.415 HD Request # 1 | Completion time: 2s. | 2022-08-05 14:10:46.415 HD Request # 1 | Intraday data download complete for XAUUSD. Unique request ID: 1 | 2022-08-05 14:10:46.415 Removing historical data download ID 1. | 2022-08-05 14:10:46.415 HD Request # 1 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:10:46.415 Triggering next historical data download in queue. | 2022-08-05 14:10:46.415 Historical data for XAUUSD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-08-05 14:10:46.415 HD Request # 2 | Downloading Historical Daily chart data for XAUUSD. Starting date: 2022-08-02. Service: fxcm | 2022-08-05 14:10:46.417 HD Request # 2 | Using server: ds13-3.sierracharts.com port 10149 | 2022-08-05 14:10:46.417 Socket (2) | Creating socket. | 2022-08-05 14:10:46.417 Socket (2) | New receive buffer size: 5242880 | 2022-08-05 14:10:46.417 Socket (2) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:10:46.417 Socket (1) | Socket gracefully closed by remote side. | 2022-08-05 14:10:46.475 Socket (1) | Closed. | 2022-08-05 14:10:46.476 HD Request # 2 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:46.558 HD Request # 2 | Sending historical data logon request message. | 2022-08-05 14:10:46.558 Teton CME Order Routing | Firm: Dorman | 2022-08-05 14:10:46.817 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-08-05 14:10:46.817 DTC Client socket (1) | Creating socket. Using TLS 1.2. | 2022-08-05 14:10:46.881 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:10:46.881 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-08-05 14:10:46.881 Teton CME Order Routing | Network connection to server complete. | 2022-08-05 14:10:46.933 Teton CME Order Routing | Starting socket receive thread. | 2022-08-05 14:10:46.933 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-08-05 14:10:46.933 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:47.127 Teton CME Order Routing | Sending logon request message. | 2022-08-05 14:10:47.127 HD Request # 2 | Requesting historical Daily data starting at 2022-08-02. | 2022-08-05 14:10:47.260 HD Request # 2 | Decompressing data. | 2022-08-05 14:10:47.332 HD Request # 2 | Receiving historical Daily data for XAUUSD starting at 2022-08-02. | 2022-08-05 14:10:47.366 HD Request # 2 | Writing historical Daily data to the file XAUUSD.dly. | 2022-08-05 14:10:47.366 Socket (2) | CloseSocket call. | 2022-08-05 14:10:47.458 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:47.458 Historical data download thread signaled to stop. | 2022-08-05 14:10:47.458 HD Request # 2 | Received 4 Daily data records from 2022-08-02 00:00:00 to 2022-08-05 00:00:00 (4.0 days) and wrote 4 records for XAUUSD | 2022-08-05 14:10:47.458 HD Request # 2 | Completion time: 1s. | 2022-08-05 14:10:47.458 HD Request # 2 | Daily data download complete for XAUUSD. Unique request ID: 2 | 2022-08-05 14:10:47.458 Removing historical data download ID 2. | 2022-08-05 14:10:47.458 Triggering next historical data download in queue. | 2022-08-05 14:10:47.458 HD Request # 3 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 14:10:47.458 HD Request # 3 | Download start date-time: 2022-08-04 23:20:18.000000. File last date-time: 2022-08-04 23:20:18.000000 | 2022-08-05 14:10:47.458 HD Request # 3 | Using server: ds4.sierracharts.com port 10150 | 2022-08-05 14:10:47.458 Socket (3) | Creating socket. | 2022-08-05 14:10:47.459 Socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:10:47.459 Socket (3) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:10:47.459 Socket (2) | Socket gracefully closed by remote side. | 2022-08-05 14:10:47.531 Socket (2) | Closed. | 2022-08-05 14:10:47.531 HD Request # 3 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:47.605 HD Request # 3 | Sending historical data logon request message. | 2022-08-05 14:10:47.605 Teton CME Order Routing | Received logon response. | 2022-08-05 14:10:47.700 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-08-05 14:10:47.700 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:10:47.700 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-08-05 14:10:47.700 Teton CME Order Routing | Trading is supported. | 2022-08-05 14:10:47.700 Teton CME Order Routing | Order cancel and replace is supported. | 2022-08-05 14:10:47.700 Teton CME Order Routing | OCO Orders supported. | 2022-08-05 14:10:47.700 Teton CME Order Routing | Bracket Orders supported. | 2022-08-05 14:10:47.700 Teton CME Order Routing | Connected to server complete. | 2022-08-05 14:10:47.700 Triggering next historical data download in queue. | 2022-08-05 14:10:47.700 Triggering next historical data download in queue. | 2022-08-05 14:10:47.700 Triggering next historical data download in queue. | 2022-08-05 14:10:47.700 Triggering next historical data download in queue. | 2022-08-05 14:10:47.700 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-08-05 14:10:47.701 No download requests in the queue to start downloads for. | 2022-08-05 14:10:47.701 No download requests in the queue to start downloads for. | 2022-08-05 14:10:47.702 No download requests in the queue to start downloads for. | 2022-08-05 14:10:47.702 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 00:00:00.000000 | 2022-08-05 14:10:47.710 Using symbol data fast lookup vector | 2022-08-05 14:10:47.731 Teton CME Order Routing | Starting real-time market data updates for: ESU22-CME. ID: 1 | 2022-08-05 14:10:47.731 Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: ESU22-CME | 2022-08-05 14:10:47.731 Teton CME Order Routing | Requesting security definition data for: ESU22-CME. ID: 1 | 2022-08-05 14:10:47.731 No historical data client is currently set to download historical Intraday data for ESU22-CME. | 2022-08-05 14:10:47.731 Real-time Intraday chart data file updates started for ESU22-CME | 2022-08-05 14:10:47.731 Opened cached Intraday file: C:\SierraChart\Data\ESU22-CME.scid. Thread ID: 15072 | 2022-08-05 14:10:47.731 Intraday chart data file opened for ESU22-CME | 2022-08-05 14:10:47.731 Updated verified funded futures trading account ending date to: 2022-09-04 14:10:47 | 2022-08-05 14:10:47.766 Using Bid/Ask average for last trade price for XAUUSD | 2022-08-05 14:10:47.766 SC DTC Data with Market Depth | Starting real-time market data updates for: XAUUSD. ID: 2 Service code: fxcm | 2022-08-05 14:10:47.767 SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 10048 | 2022-08-05 14:10:47.767 DTC Client socket (2) | Creating socket. | 2022-08-05 14:10:47.767 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-08-05 14:10:47.767 DTC Client socket (2) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:10:47.767 SC DTC Data with Market Depth | Requesting security definition data for: XAUUSD. ID: 2 | 2022-08-05 14:10:47.768 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 14:10:47.768 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 14:10:47.768 Triggering next historical data download in queue. | 2022-08-05 14:10:47.768 Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data | 2022-08-05 14:10:47.784 SC Data - All Services | Starting real-time market data updates for: AAPL-NQTV (AAPL-NQTV). ID: 3 Service code: nasdaq_exchange.data | 2022-08-05 14:10:47.784 SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 10048 | 2022-08-05 14:10:47.784 DTC Client socket (4) | Creating socket. | 2022-08-05 14:10:47.785 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:10:47.785 DTC Client socket (4) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:10:47.785 SC Data - All Services | Requesting security definition data for: AAPL-NQTV (AAPL-NQTV). ID: 3 | 2022-08-05 14:10:47.786 XAUUSD[M] Daily #2 | Reloading chart. | 2022-08-05 14:10:47.796 Teton CME Order Routing | Received security definition for symbol ESU22-CME | 2022-08-05 14:10:47.798 Teton CME Order Routing | Starting real-time market data updates for: TSLA. ID: 4 Service code: equities.us | 2022-08-05 14:10:47.799 Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: TSLA | 2022-08-05 14:10:47.799 Teton CME Order Routing | Requesting security definition data for: TSLA. ID: 4 | 2022-08-05 14:10:47.799 Using Bid/Ask average for last trade price for US30 | 2022-08-05 14:10:47.803 SC DTC Data with Market Depth | Starting real-time market data updates for: US30. ID: 5 Service code: fxcm | 2022-08-05 14:10:47.803 SC DTC Data with Market Depth | Requesting security definition data for: US30. ID: 5 | 2022-08-05 14:10:47.803 Teton CME Order Routing | Starting real-time market data updates for: SPY. ID: 6 Service code: equities.us | 2022-08-05 14:10:47.809 Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: SPY | 2022-08-05 14:10:47.809 Teton CME Order Routing | Requesting security definition data for: SPY. ID: 6 | 2022-08-05 14:10:47.809 Using Bid/Ask average for last trade price for USOil | 2022-08-05 14:10:47.814 SC DTC Data with Market Depth | Starting real-time market data updates for: USOil. ID: 7 Service code: fxcm | 2022-08-05 14:10:47.814 SC DTC Data with Market Depth | Requesting security definition data for: USOil. ID: 7 | 2022-08-05 14:10:47.814 Using Bid/Ask average for last trade price for SPX500 | 2022-08-05 14:10:47.823 SC DTC Data with Market Depth | Starting real-time market data updates for: SPX500. ID: 8 Service code: fxcm | 2022-08-05 14:10:47.823 SC DTC Data with Market Depth | Requesting security definition data for: SPX500. ID: 8 | 2022-08-05 14:10:47.823 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43878 | 2022-08-05 14:10:47.827 SC DTC Data with Market Depth | Network connection to server complete. | 2022-08-05 14:10:47.828 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-08-05 14:10:47.828 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:10:47.828 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:10:47.850 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:10:47.850 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-08-05 14:10:47.850 Using Bid/Ask average for last trade price for EURUSD | 2022-08-05 14:10:47.855 SC DTC Data with Market Depth | Starting real-time market data updates for: EURUSD. ID: 9 Service code: fxcm | 2022-08-05 14:10:47.855 SC DTC Data with Market Depth | Requesting security definition data for: EURUSD. ID: 9 | 2022-08-05 14:10:47.855 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: AAPL-NQTV | 2022-08-05 14:10:47.901 Teton CME Order Routing | Received security definition for symbol AAPL-NQTV | 2022-08-05 14:10:47.901 Teton CME Order Routing | Received security definition for symbol TSLA | 2022-08-05 14:10:47.901 Teton CME Order Routing | Received security definition for symbol SPY | 2022-08-05 14:10:47.901 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:47.909 SC DTC Data with Market Depth | Sending logon request message. | 2022-08-05 14:10:47.909 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:47.924 SC Data - All Services | Sending logon request message. | 2022-08-05 14:10:47.924 HD Request # 3 | Requesting Intraday data. Start date-time: 2022-08-04 23:20:18. Record interval: 1. Symbol: US30 | 2022-08-05 14:10:48.184 HD Request # 3 | Decompressing data. | 2022-08-05 14:10:48.243 HD Request # 3 | Receiving Intraday data for US30 starting at 2022-08-04 23:20:18.445000 | 2022-08-05 14:10:48.521 SC DTC Data with Market Depth | Received logon response. | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Successfully connected. | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Trading is not supported. | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2022-08-05 14:10:48.599 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-08-05 14:10:48.599 SC Data - All Services | Received logon response. | 2022-08-05 14:10:48.612 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:10:48.612 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:10:48.612 SC Data - All Services | Successfully connected. | 2022-08-05 14:10:48.612 SC Data - All Services | Trading is not supported. | 2022-08-05 14:10:48.612 SC Data - All Services | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2022-08-05 14:10:48.612 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2022-08-05 14:10:48.752 SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-08-05 14:10:48.752 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2022-08-05 14:10:48.752 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2022-08-05 14:10:48.752 SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-08-05 14:10:48.752 SC Data - All Services | Received security definition for symbol AAPL-NQTV | 2022-08-05 14:10:48.773 HD Request # 3 | Timestamp of first Intraday data file record written: 2022-08-04 23:20:18.445000. | 2022-08-05 14:10:48.792 Socket (3) | CloseSocket call. | 2022-08-05 14:10:48.793 Historical data download thread signaled to stop. | 2022-08-05 14:10:48.793 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:48.793 HD Request # 3 | Received 34356 Intraday data records from 2022-08-04 23:20:18.445000 to 2022-08-05 14:10:46.042000 (14.8 hours) and wrote 34356 records for US30 | 2022-08-05 14:10:48.793 HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:10:46.042000 | 2022-08-05 14:10:48.798 Added 1 Time and Sales records to Intraday data file for US30 after download. | 2022-08-05 14:10:48.798 HD Request # 3 | Completion time: 1s. | 2022-08-05 14:10:48.798 HD Request # 3 | Intraday data download complete for US30. Unique request ID: 3 | 2022-08-05 14:10:48.798 Removing historical data download ID 3. | 2022-08-05 14:10:48.798 Real-time Intraday chart data file updates started for US30 | 2022-08-05 14:10:48.798 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 14:10:48.801 Intraday chart data file opened for US30 | 2022-08-05 14:10:48.801 HD Request # 3 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:10:48.801 Triggering next historical data download in queue. | 2022-08-05 14:10:48.801 Initiating new historical data download for US30 to get the latest data since the download was started while not connected to primary service. | 2022-08-05 14:10:48.801 Added historical Intraday data request for US30 to the queue. | 2022-08-05 14:10:48.801 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 14:10:48.801 Delaying start of download for US30. | 2022-08-05 14:10:48.801 Socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:10:48.849 Socket (3) | Closed. | 2022-08-05 14:10:48.849 HD Request # 4 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 14:10:53.917 HD Request # 4 | Download start date-time: 2022-08-05 14:10:48.000000. File last date-time: 2022-08-05 14:10:48.933000 | 2022-08-05 14:10:53.917 HD Request # 4 | Using server: ds12.sierracharts.com port 10149 | 2022-08-05 14:10:53.917 Socket (3) | Creating socket. | 2022-08-05 14:10:53.917 Socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:10:53.917 Socket (3) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:10:53.917 HD Request # 4 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:54.065 HD Request # 4 | Sending historical data logon request message. | 2022-08-05 14:10:54.065 MESU22_FUT_CME [CBV] #2 | Reloading chart. | 2022-08-05 14:10:54.192 MESU22_FUT_CME [CBV] #2 | Performing continuous chart historical Daily data download for symbol MESU22_FUT_CME starting at last date in file. | 2022-08-05 14:10:54.211 Starting DelayedDownloadMonitoringTimer | 2022-08-05 14:10:54.211 Starting HDTimeoutTimer | 2022-08-05 14:10:54.211 Added historical Daily data request for MESU22_FUT_CME to the queue. | 2022-08-05 14:10:54.211 Triggering next historical data download in queue. | 2022-08-05 14:10:54.211 MESU22_FUT_CME [CBV] #2 | Waiting for historical downloads to complete with the IDs: 13, | 2022-08-05 14:10:54.233 Mapping MESU22_FUT_CME to MESU22. Service code: cme | 2022-08-05 14:10:54.250 HD Request # 5 | Downloading Historical Daily chart data for MESU22_FUT_CME. Starting date: 2022-08-02. Service: sc_futures_direct.dtc.trading | 2022-08-05 14:10:54.252 HD Request # 4 | Requesting Intraday data. Start date-time: 2022-08-05 14:10:48. Record interval: 1. Symbol: US30 | 2022-08-05 14:10:54.658 HD Request # 4 | Decompressing data. | 2022-08-05 14:10:54.728 HD Request # 4 | Receiving Intraday data for US30 starting at 2022-08-05 14:10:48.032000 | 2022-08-05 14:10:54.729 Socket (3) | CloseSocket call. | 2022-08-05 14:10:54.729 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:54.729 Historical data download thread signaled to stop. | 2022-08-05 14:10:54.729 HD Request # 4 | Timestamp of first Intraday data file record written: 2022-08-05 14:10:49.003000. | 2022-08-05 14:10:54.729 HD Request # 4 | Received 6 Intraday data records from 2022-08-05 14:10:48.032000 to 2022-08-05 14:10:53.382000 (5.3 seconds) and wrote 5 records for US30 | 2022-08-05 14:10:54.729 HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:10:53.382000 | 2022-08-05 14:10:54.733 Added 1 Time and Sales records to Intraday data file for US30 after download. | 2022-08-05 14:10:54.733 HD Request # 4 | Completion time: 1s. | 2022-08-05 14:10:54.733 HD Request # 4 | Intraday data download complete for US30. Unique request ID: 12 | 2022-08-05 14:10:54.734 Removing historical data download ID 12. | 2022-08-05 14:10:54.734 Real-time Intraday chart data file updates started for US30 | 2022-08-05 14:10:54.734 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 14:10:54.737 Intraday chart data file opened for US30 | 2022-08-05 14:10:54.737 HD Request # 4 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:10:54.737 Triggering next historical data download in queue. | 2022-08-05 14:10:54.737 HD Request # 6 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2022-08-05 14:10:54.738 HD Request # 6 | Download start date-time: 2022-08-04 23:50:41.000000. File last date-time: 2022-08-04 23:50:41.000000 | 2022-08-05 14:10:54.738 HD Request # 6 | Using server: ds13-3.sierracharts.com port 10150 | 2022-08-05 14:10:54.738 Socket (6) | Creating socket. | 2022-08-05 14:10:54.738 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:10:54.738 Socket (6) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:10:54.738 Socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:10:54.799 Socket (3) | Closed. | 2022-08-05 14:10:54.799 HD Request # 6 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:54.868 HD Request # 6 | Sending historical data logon request message. | 2022-08-05 14:10:54.868 HD Request # 5 | Requesting historical Daily data for ETU22 starting at 2022-08-01. SC External HD service. | 2022-08-05 14:10:54.965 HD Request # 5 | Receiving historical Daily data for MESU22_FUT_CME starting at 2022-08-02. | 2022-08-05 14:10:55.245 HD Request # 5 | Writing historical Daily data to the file MESU22_FUT_CME.dly. | 2022-08-05 14:10:55.245 HD Request # 5 | Bytes received: 241 | 2022-08-05 14:10:55.247 HD Request # 5 | Received 4 Daily data records from 2022-08-02 00:00:00 to 2022-08-04 00:00:00 (3.0 days) and wrote 3 records for MESU22_FUT_CME | 2022-08-05 14:10:55.247 HD Request # 5 | Completion time: 1s. | 2022-08-05 14:10:55.248 HD Request # 5 | Daily data download complete for MESU22_FUT_CME. Unique request ID: 13 | 2022-08-05 14:10:55.248 Removing historical data download ID 13. | 2022-08-05 14:10:55.248 Triggering next historical data download in queue. | 2022-08-05 14:10:55.248 No download requests in the queue to start downloads for. | 2022-08-05 14:10:55.248 HD Request # 6 | Requesting Intraday data. Start date-time: 2022-08-04 23:50:41. Record interval: 1. Symbol: USOil | 2022-08-05 14:10:55.575 HD Request # 6 | Decompressing data. | 2022-08-05 14:10:55.638 MESU22_FUT_CME [CBV] #2 | Download is complete for all contract months in chart. Proceeding with data load. | 2022-08-05 14:10:55.700 MESU22_FUT_CME [CBV] #2 | Reloading chart. | 2022-08-05 14:10:55.701 HD Request # 6 | Receiving Intraday data for USOil starting at 2022-08-04 23:50:41.473000 | 2022-08-05 14:10:55.844 Socket (6) | CloseSocket call. | 2022-08-05 14:10:56.046 Historical data download thread signaled to stop. | 2022-08-05 14:10:56.046 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:56.046 HD Request # 6 | Timestamp of first Intraday data file record written: 2022-08-04 23:50:41.473000. | 2022-08-05 14:10:56.047 HD Request # 6 | Received 23639 Intraday data records from 2022-08-04 23:50:41.473000 to 2022-08-05 14:10:54.114000 (14.3 hours) and wrote 23639 records for USOil | 2022-08-05 14:10:56.047 HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:10:54.114000 | 2022-08-05 14:10:56.051 Added 2 Time and Sales records to Intraday data file for USOil after download. | 2022-08-05 14:10:56.051 HD Request # 6 | Completion time: 2s. | 2022-08-05 14:10:56.051 HD Request # 6 | Intraday data download complete for USOil. Unique request ID: 4 | 2022-08-05 14:10:56.051 Removing historical data download ID 4. | 2022-08-05 14:10:56.051 Real-time Intraday chart data file updates started for USOil | 2022-08-05 14:10:56.051 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 15072 | 2022-08-05 14:10:56.054 Intraday chart data file opened for USOil | 2022-08-05 14:10:56.054 HD Request # 6 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:10:56.054 Triggering next historical data download in queue. | 2022-08-05 14:10:56.054 HD Request # 7 | Downloading Historical Daily chart data for SPX500. Starting date: 2022-08-02. Service: fxcm | 2022-08-05 14:10:56.056 HD Request # 7 | Using server: ds4.sierracharts.com port 10149 | 2022-08-05 14:10:56.056 Socket (3) | Creating socket. | 2022-08-05 14:10:56.056 Socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:10:56.056 Socket (3) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:10:56.056 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:10:56.102 Socket (6) | Closed. | 2022-08-05 14:10:56.102 HD Request # 7 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:56.189 HD Request # 7 | Sending historical data logon request message. | 2022-08-05 14:10:56.189 MESU22_FUT_CME [CBV] #2 | Reloading chart. | 2022-08-05 14:10:56.201 SC Data - All Services | Starting real-time market data updates for: MESU22_FUT_CME (MESU22). ID: 10 Service code: cme | 2022-08-05 14:10:56.700 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2022-08-05 14:10:56.700 SC Data - All Services | Requesting security definition data for: MESU22_FUT_CME (MESU22). ID: 10 | 2022-08-05 14:10:56.701 Added historical Intraday data request for MESU22_FUT_CME to the queue. | 2022-08-05 14:10:56.701 Intraday data recording state for symbol MESU22_FUT_CME is set to download 'Pending'. | 2022-08-05 14:10:56.701 Triggering next historical data download in queue. | 2022-08-05 14:10:56.701 DTC Client socket (5) | Creating socket. | 2022-08-05 14:10:56.704 DTC Client socket (5) | New receive buffer size: 5242880 | 2022-08-05 14:10:56.704 DTC Client socket (5) | Connecting to IP: 208.185.224.129. | 2022-08-05 14:10:56.704 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESU22_FUT_CME | 2022-08-05 14:10:56.763 Teton CME Order Routing | Received security definition for symbol MESU22_FUT_CME | 2022-08-05 14:10:56.763 HD Request # 7 | Requesting historical Daily data starting at 2022-08-02. | 2022-08-05 14:10:56.769 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:10:56.770 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:10:56.770 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:10:56.770 HD Request # 7 | Decompressing data. | 2022-08-05 14:10:56.831 HD Request # 7 | Receiving historical Daily data for SPX500 starting at 2022-08-02. | 2022-08-05 14:10:56.850 HD Request # 7 | Writing historical Daily data to the file SPX500.dly. | 2022-08-05 14:10:56.850 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:56.853 SC Data - All Services | Sending logon request message. | 2022-08-05 14:10:56.853 Socket (3) | CloseSocket call. | 2022-08-05 14:10:56.905 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:56.905 Historical data download thread signaled to stop. | 2022-08-05 14:10:56.905 HD Request # 7 | Received 4 Daily data records from 2022-08-02 00:00:00 to 2022-08-05 00:00:00 (4.0 days) and wrote 4 records for SPX500 | 2022-08-05 14:10:56.905 HD Request # 7 | Completion time: 0s. | 2022-08-05 14:10:56.905 HD Request # 7 | Daily data download complete for SPX500. Unique request ID: 5 | 2022-08-05 14:10:56.905 Removing historical data download ID 5. | 2022-08-05 14:10:56.905 Triggering next historical data download in queue. | 2022-08-05 14:10:56.905 HD Request # 8 | Downloading Historical Daily chart data for EURUSD. Starting date: 2022-08-02. Service: fxcm | 2022-08-05 14:10:56.906 HD Request # 8 | Using server: ds12.sierracharts.com port 10150 | 2022-08-05 14:10:56.906 Socket (6) | Creating socket. | 2022-08-05 14:10:56.906 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:10:56.906 Socket (6) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:10:56.906 Socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:10:56.964 Socket (3) | Closed. | 2022-08-05 14:10:56.964 HD Request # 8 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:57.054 HD Request # 8 | Sending historical data logon request message. | 2022-08-05 14:10:57.054 HD Request # 8 | Requesting historical Daily data starting at 2022-08-02. | 2022-08-05 14:10:57.114 HD Request # 8 | Decompressing data. | 2022-08-05 14:10:57.199 HD Request # 8 | Receiving historical Daily data for EURUSD starting at 2022-08-02. | 2022-08-05 14:10:57.208 HD Request # 8 | Writing historical Daily data to the file EURUSD.dly. | 2022-08-05 14:10:57.209 Socket (6) | CloseSocket call. | 2022-08-05 14:10:57.262 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:57.262 Historical data download thread signaled to stop. | 2022-08-05 14:10:57.262 HD Request # 8 | Received 4 Daily data records from 2022-08-02 00:00:00 to 2022-08-05 00:00:00 (4.0 days) and wrote 4 records for EURUSD | 2022-08-05 14:10:57.262 HD Request # 8 | Completion time: 1s. | 2022-08-05 14:10:57.262 HD Request # 8 | Daily data download complete for EURUSD. Unique request ID: 6 | 2022-08-05 14:10:57.262 Removing historical data download ID 6. | 2022-08-05 14:10:57.262 Triggering next historical data download in queue. | 2022-08-05 14:10:57.263 HD Request # 9 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2022-08-05 14:10:57.263 HD Request # 9 | Download start date-time: 2022-08-04 23:50:45.000000. File last date-time: 2022-08-04 23:50:45.000000 | 2022-08-05 14:10:57.263 HD Request # 9 | Using server: ds13-3.sierracharts.com port 10149 | 2022-08-05 14:10:57.263 Socket (3) | Creating socket. | 2022-08-05 14:10:57.263 Socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:10:57.263 Socket (3) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:10:57.263 SPX500[M] Daily #6 | Reloading chart. | 2022-08-05 14:10:57.325 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:10:57.329 Socket (6) | Closed. | 2022-08-05 14:10:57.329 EURUSD[M] Daily #7 | Reloading chart. | 2022-08-05 14:10:57.355 HD Request # 9 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:57.408 HD Request # 9 | Sending historical data logon request message. | 2022-08-05 14:10:57.408 HD Request # 9 | Requesting Intraday data. Start date-time: 2022-08-04 23:50:45. Record interval: 1. Symbol: EURUSD | 2022-08-05 14:10:57.470 HD Request # 9 | Decompressing data. | 2022-08-05 14:10:57.531 SC Data - All Services | Received logon response. | 2022-08-05 14:10:57.605 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:10:57.605 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:10:57.605 SC Data - All Services | Successfully connected. | 2022-08-05 14:10:57.605 SC Data - All Services | Trading is not supported. | 2022-08-05 14:10:57.605 SC Data - All Services | Restarting real-time data updates for symbol: MESU22_FUT_CME -> MESU22 | 2022-08-05 14:10:57.605 SC Data - All Services | Received security definition for symbol MESU22_FUT_CME | 2022-08-05 14:10:57.761 HD Request # 9 | Receiving Intraday data for EURUSD starting at 2022-08-04 23:50:45.172000 | 2022-08-05 14:10:57.816 HD Request # 9 | Timestamp of first Intraday data file record written: 2022-08-04 23:50:45.172000. | 2022-08-05 14:10:58.028 Socket (3) | CloseSocket call. | 2022-08-05 14:10:58.029 Historical data download thread signaled to stop. | 2022-08-05 14:10:58.029 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:58.029 HD Request # 9 | Received 33764 Intraday data records from 2022-08-04 23:50:45.172000 to 2022-08-05 14:10:56.026000 (14.3 hours) and wrote 33764 records for EURUSD | 2022-08-05 14:10:58.030 HD Request # 9 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:10:56.026000 | 2022-08-05 14:10:58.033 Added 1 Time and Sales records to Intraday data file for EURUSD after download. | 2022-08-05 14:10:58.033 HD Request # 9 | Completion time: 1s. | 2022-08-05 14:10:58.034 HD Request # 9 | Intraday data download complete for EURUSD. Unique request ID: 7 | 2022-08-05 14:10:58.034 Removing historical data download ID 7. | 2022-08-05 14:10:58.034 Real-time Intraday chart data file updates started for EURUSD | 2022-08-05 14:10:58.034 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 15072 | 2022-08-05 14:10:58.037 Intraday chart data file opened for EURUSD | 2022-08-05 14:10:58.037 HD Request # 9 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:10:58.037 Triggering next historical data download in queue. | 2022-08-05 14:10:58.037 HD Request # 10 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data | 2022-08-05 14:10:58.037 HD Request # 10 | Download start date-time: 2022-08-04 23:50:37.000000. File last date-time: 2022-08-04 23:50:37.000000 | 2022-08-05 14:10:58.037 HD Request # 10 | Using server: ds25.sierracharts.com port 10150 | 2022-08-05 14:10:58.037 Socket (6) | Creating socket. | 2022-08-05 14:10:58.037 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:10:58.038 Socket (6) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:10:58.038 Socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:10:58.091 Socket (3) | Closed. | 2022-08-05 14:10:58.091 HD Request # 10 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:58.168 HD Request # 10 | Sending historical data logon request message. | 2022-08-05 14:10:58.168 HD Request # 10 | Requesting Intraday data. Start date-time: 2022-08-04 23:50:37. Record interval: 1. Symbol: AAPL-NQTV | 2022-08-05 14:10:58.662 HD Request # 10 | Decompressing data. | 2022-08-05 14:10:58.723 HD Request # 10 | Receiving Intraday data for AAPL-NQTV starting at 2022-08-04 23:50:37.042000 | 2022-08-05 14:10:58.934 Socket (6) | CloseSocket call. | 2022-08-05 14:10:58.936 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:10:58.936 Historical data download thread signaled to stop. | 2022-08-05 14:10:58.936 HD Request # 10 | Timestamp of first Intraday data file record written: 2022-08-04 23:50:37.042000. | 2022-08-05 14:10:58.936 HD Request # 10 | Received 3554 Intraday data records from 2022-08-04 23:50:37.042000 to 2022-08-05 14:10:57.516000 (14.3 hours) and wrote 3554 records for AAPL-NQTV | 2022-08-05 14:10:58.937 HD Request # 10 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:10:57.516000 | 2022-08-05 14:10:58.941 HD Request # 10 | Completion time: 0s. | 2022-08-05 14:10:58.941 HD Request # 10 | Intraday data download complete for AAPL-NQTV. Unique request ID: 8 | 2022-08-05 14:10:58.941 Removing historical data download ID 8. | 2022-08-05 14:10:58.941 Real-time Intraday chart data file updates started for AAPL-NQTV | 2022-08-05 14:10:58.941 Opened cached Intraday file: C:\SierraChart\Data\AAPL-NQTV.scid. Thread ID: 15072 | 2022-08-05 14:10:58.941 Intraday chart data file opened for AAPL-NQTV | 2022-08-05 14:10:58.941 HD Request # 10 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:10:58.941 Triggering next historical data download in queue. | 2022-08-05 14:10:58.941 HD Request # 11 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2022-08-05 14:10:58.941 HD Request # 11 | Download start date-time: 2022-08-04 13:42:51.000000. File last date-time: 2022-08-04 13:42:51.253000 | 2022-08-05 14:10:58.941 HD Request # 11 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2022-08-05 14:10:58.941 Socket (3) | Creating socket. | 2022-08-05 14:10:58.998 Socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:10:58.998 Socket (3) | Connecting to IP: 8.18.161.133. | 2022-08-05 14:10:58.998 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:10:59.005 Socket (6) | Closed. | 2022-08-05 14:10:59.005 HD Request # 11 | Setting DTC encoding to Binary VLS | 2022-08-05 14:10:59.108 HD Request # 11 | Sending historical data logon request message. | 2022-08-05 14:10:59.108 HD Request # 11 | Requesting Intraday data. Start date-time: 2022-08-04 13:42:51. Record interval: 1. Symbol: TSLA | 2022-08-05 14:10:59.622 HD Request # 11 | Decompressing data. | 2022-08-05 14:10:59.683 HD Request # 11 | Receiving Intraday data for TSLA starting at 2022-08-04 13:42:51.253000 | 2022-08-05 14:10:59.979 Socket (3) | CloseSocket call. | 2022-08-05 14:11:00.103 Historical data download thread signaled to stop. | 2022-08-05 14:11:00.103 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:11:00.103 HD Request # 11 | Timestamp of first Intraday data file record written: 2022-08-04 13:42:51.253000. | 2022-08-05 14:11:00.103 HD Request # 11 | Received 18631 Intraday data records from 2022-08-04 13:42:51.253000 to 2022-08-05 13:55:59.122000 (24.2 hours) and wrote 18631 records for TSLA | 2022-08-05 14:11:00.103 HD Request # 11 | Add time&sales data | Remembered last file record date-time: 2022-08-05 13:55:59.122000 | 2022-08-05 14:11:00.109 HD Request # 11 | Completion time: 2s. | 2022-08-05 14:11:00.109 HD Request # 11 | Intraday data download complete for TSLA. Unique request ID: 9 | 2022-08-05 14:11:00.109 Removing historical data download ID 9. | 2022-08-05 14:11:00.109 Real-time Intraday chart data file updates started for TSLA | 2022-08-05 14:11:00.109 Opened cached Intraday file: C:\SierraChart\Data\TSLA.scid. Thread ID: 15072 | 2022-08-05 14:11:00.109 Intraday chart data file opened for TSLA | 2022-08-05 14:11:00.109 HD Request # 11 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:11:00.109 Triggering next historical data download in queue. | 2022-08-05 14:11:00.109 HD Request # 12 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: equities.us | 2022-08-05 14:11:00.110 HD Request # 12 | Download start date-time: 2022-08-04 13:42:50.000000. File last date-time: 2022-08-04 13:42:50.191000 | 2022-08-05 14:11:00.110 HD Request # 12 | Using server: exchangehistdata1.sierracharts.com port 10150 | 2022-08-05 14:11:00.110 Socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:11:00.154 Socket (3) | Closed. | 2022-08-05 14:11:00.154 Socket (6) | Creating socket. | 2022-08-05 14:11:00.178 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:11:00.178 Socket (6) | Connecting to IP: 8.18.161.135. | 2022-08-05 14:11:00.178 HD Request # 12 | Setting DTC encoding to Binary VLS | 2022-08-05 14:11:00.313 HD Request # 12 | Sending historical data logon request message. | 2022-08-05 14:11:00.313 HD Request # 12 | Requesting Intraday data. Start date-time: 2022-08-04 13:42:50. Record interval: 1. Symbol: SPY | 2022-08-05 14:11:00.824 HD Request # 12 | Decompressing data. | 2022-08-05 14:11:00.878 HD Request # 12 | Receiving Intraday data for SPY starting at 2022-08-04 13:42:50.191000 | 2022-08-05 14:11:01.200 Socket (6) | CloseSocket call. | 2022-08-05 14:11:01.377 Historical data download thread signaled to stop. | 2022-08-05 14:11:01.377 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:11:01.377 HD Request # 12 | Timestamp of first Intraday data file record written: 2022-08-04 13:42:50.191000. | 2022-08-05 14:11:01.378 HD Request # 12 | Received 23920 Intraday data records from 2022-08-04 13:42:50.191000 to 2022-08-05 13:56:00.014000 (24.2 hours) and wrote 23920 records for SPY | 2022-08-05 14:11:01.378 HD Request # 12 | Add time&sales data | Remembered last file record date-time: 2022-08-05 13:56:00.014000 | 2022-08-05 14:11:01.382 HD Request # 12 | Completion time: 1s. | 2022-08-05 14:11:01.382 HD Request # 12 | Intraday data download complete for SPY. Unique request ID: 10 | 2022-08-05 14:11:01.382 Removing historical data download ID 10. | 2022-08-05 14:11:01.382 Real-time Intraday chart data file updates started for SPY | 2022-08-05 14:11:01.382 Opened cached Intraday file: C:\SierraChart\Data\SPY.scid. Thread ID: 15072 | 2022-08-05 14:11:01.382 Intraday chart data file opened for SPY | 2022-08-05 14:11:01.382 HD Request # 12 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:11:01.382 Triggering next historical data download in queue. | 2022-08-05 14:11:01.382 HD Request # 13 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 14:11:01.382 HD Request # 13 | Download start date-time: 2022-08-05 14:10:45.000000. File last date-time: 2022-08-05 14:10:45.037000 | 2022-08-05 14:11:01.383 HD Request # 13 | Using server: ds4.sierracharts.com port 10149 | 2022-08-05 14:11:01.383 Socket (3) | Creating socket. | 2022-08-05 14:11:01.383 Socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:11:01.383 Socket (3) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:11:01.383 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:11:01.429 Socket (6) | Closed. | 2022-08-05 14:11:01.429 HD Request # 13 | Setting DTC encoding to Binary VLS | 2022-08-05 14:11:01.512 HD Request # 13 | Sending historical data logon request message. | 2022-08-05 14:11:01.512 HD Request # 13 | Requesting Intraday data. Start date-time: 2022-08-05 14:10:45. Record interval: 1. Symbol: XAUUSD | 2022-08-05 14:11:01.576 HD Request # 13 | Decompressing data. | 2022-08-05 14:11:01.637 HD Request # 13 | Receiving Intraday data for XAUUSD starting at 2022-08-05 14:10:45.037000 | 2022-08-05 14:11:01.637 Socket (3) | CloseSocket call. | 2022-08-05 14:11:01.637 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:11:01.637 Historical data download thread signaled to stop. | 2022-08-05 14:11:01.637 HD Request # 13 | Timestamp of first Intraday data file record written: 2022-08-05 14:10:45.037000. | 2022-08-05 14:11:01.637 HD Request # 13 | Received 16 Intraday data records from 2022-08-05 14:10:45.037000 to 2022-08-05 14:11:00.017000 (15.0 seconds) and wrote 16 records for XAUUSD | 2022-08-05 14:11:01.638 HD Request # 13 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:11:00.017000 | 2022-08-05 14:11:01.642 Added 1 Time and Sales records to Intraday data file for XAUUSD after download. | 2022-08-05 14:11:01.642 HD Request # 13 | Completion time: 0s. | 2022-08-05 14:11:01.642 HD Request # 13 | Intraday data download complete for XAUUSD. Unique request ID: 11 | 2022-08-05 14:11:01.642 Removing historical data download ID 11. | 2022-08-05 14:11:01.642 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-05 14:11:01.642 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 15072 | 2022-08-05 14:11:01.645 Intraday chart data file opened for XAUUSD | 2022-08-05 14:11:01.645 HD Request # 13 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:11:01.645 Triggering next historical data download in queue. | 2022-08-05 14:11:01.645 Delaying start of download for MESU22_FUT_CME. | 2022-08-05 14:11:01.645 Socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:11:01.703 Socket (3) | Closed. | 2022-08-05 14:11:01.703 HD Request # 14 | Downloading Intraday chart data for MESU22_FUT_CME to the file MESU22_FUT_CME.scid. Service: cme | 2022-08-05 14:11:02.928 HD Request # 14 | Download start date-time: 2022-08-05 03:32:53.000000. File last date-time: 2022-08-05 03:32:53.000000 | 2022-08-05 14:11:02.928 HD Request # 14 | Using server: ds23.sierracharts.com port 10150 | 2022-08-05 14:11:02.928 Socket (3) | Creating socket. | 2022-08-05 14:11:02.975 Socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:11:02.976 Socket (3) | Connecting to IP: 216.1.90.130. | 2022-08-05 14:11:02.976 HD Request # 14 | Setting DTC encoding to Binary VLS | 2022-08-05 14:11:03.103 HD Request # 14 | Sending historical data logon request message. | 2022-08-05 14:11:03.103 HD Request # 14 | Requesting Intraday data. Start date-time: 2022-08-05 03:32:53. Record interval: 1. Symbol: MESU22 | 2022-08-05 14:11:03.696 HD Request # 14 | Decompressing data. | 2022-08-05 14:11:03.764 HD Request # 14 | Receiving Intraday data for MESU22_FUT_CME starting at 2022-08-05 03:32:53.882000 | 2022-08-05 14:11:03.988 Socket (3) | CloseSocket call. | 2022-08-05 14:11:04.141 Socket (3) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:11:04.141 Historical data download thread signaled to stop. | 2022-08-05 14:11:04.141 HD Request # 14 | Timestamp of first Intraday data file record written: 2022-08-05 03:32:53.882000. | 2022-08-05 14:11:04.142 HD Request # 14 | Received 15079 Intraday data records from 2022-08-05 03:32:53.882000 to 2022-08-05 14:11:00.038000 (10.6 hours) and wrote 15079 records for MESU22_FUT_CME | 2022-08-05 14:11:04.142 HD Request # 14 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:11:00.038000 | 2022-08-05 14:11:04.146 Added 4 Time and Sales records to Intraday data file for MESU22_FUT_CME after download. | 2022-08-05 14:11:04.146 HD Request # 14 | Completion time: 2s. | 2022-08-05 14:11:04.146 HD Request # 14 | Intraday data download complete for MESU22_FUT_CME. Unique request ID: 14 | 2022-08-05 14:11:04.146 Removing historical data download ID 14. | 2022-08-05 14:11:04.146 Real-time Intraday chart data file updates started for MESU22_FUT_CME | 2022-08-05 14:11:04.146 Opened cached Intraday file: C:\SierraChart\Data\MESU22_FUT_CME.scid. Thread ID: 15072 | 2022-08-05 14:11:04.149 Intraday chart data file opened for MESU22_FUT_CME | 2022-08-05 14:11:04.149 HD Request # 14 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:11:04.149 Triggering next historical data download in queue. | 2022-08-05 14:11:04.149 No download requests in the queue to start downloads for. | 2022-08-05 14:11:04.149 Socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:11:04.200 Socket (3) | Closed. | 2022-08-05 14:11:04.200 DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:16:39.026 * DTC Client socket (5) | Socket gracefully closed by remote side. | 2022-08-05 14:16:39.026 DTC Client socket (5) | CloseSocket call. | 2022-08-05 14:16:39.026 DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:16:39.026 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:16:39.026 DTC Client socket (5) | Closed. | 2022-08-05 14:16:39.026 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:16:39.027 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:16:39.027 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:16:39.027 SC Data - All Services | Connecting to the server ds26.sierracharts.com. Port 10048 | 2022-08-05 14:16:41.033 DTC Client socket (3) | Creating socket. | 2022-08-05 14:16:41.071 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:16:41.071 DTC Client socket (3) | Connecting to IP: 38.89.235.129. | 2022-08-05 14:16:41.071 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:16:41.120 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:16:41.120 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:16:41.120 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:41.206 SC Data - All Services | Sending logon request message. | 2022-08-05 14:16:41.206 SC Data - All Services | Received logon response. | 2022-08-05 14:16:41.957 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:16:41.957 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:16:41.957 SC Data - All Services | Successfully connected. | 2022-08-05 14:16:41.957 SC Data - All Services | Trading is not supported. | 2022-08-05 14:16:41.957 Added historical Intraday data request for MESU22_FUT_CME to the queue. | 2022-08-05 14:16:41.957 Intraday data recording state for symbol MESU22_FUT_CME is set to download 'Pending'. | 2022-08-05 14:16:41.957 Triggering next historical data download in queue. | 2022-08-05 14:16:41.957 SC Data - All Services | Restarting real-time data updates for symbol: MESU22_FUT_CME -> MESU22 | 2022-08-05 14:16:41.957 HD Request # 15 | Downloading Intraday chart data for MESU22_FUT_CME to the file MESU22_FUT_CME.scid. Service: cme | 2022-08-05 14:16:41.957 HD Request # 15 | Download start date-time: 2022-08-05 14:16:23.000000. File last date-time: 2022-08-05 14:16:23.000000 | 2022-08-05 14:16:41.958 HD Request # 15 | Using server: ds21.sierracharts.com port 10149 | 2022-08-05 14:16:41.958 Socket (5) | Creating socket. | 2022-08-05 14:16:41.993 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 14:16:41.994 Socket (5) | Connecting to IP: 216.1.90.129. | 2022-08-05 14:16:41.994 SC Data - All Services | Received security definition for symbol MESU22_FUT_CME | 2022-08-05 14:16:42.115 HD Request # 15 | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:42.118 HD Request # 15 | Sending historical data logon request message. | 2022-08-05 14:16:42.118 HD Request # 15 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:23. Record interval: 1. Symbol: MESU22 | 2022-08-05 14:16:42.686 HD Request # 15 | Decompressing data. | 2022-08-05 14:16:42.743 HD Request # 15 | Receiving Intraday data for MESU22_FUT_CME starting at 2022-08-05 14:16:23.050000 | 2022-08-05 14:16:42.743 Socket (5) | CloseSocket call. | 2022-08-05 14:16:42.743 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:16:42.743 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 14:16:42.798 Socket (5) | Closed. | 2022-08-05 14:16:42.798 Historical data download thread signaled to stop. | 2022-08-05 14:16:42.803 HD Request # 15 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:23.050000. | 2022-08-05 14:16:42.803 HD Request # 15 | Received 19 Intraday data records from 2022-08-05 14:16:23.050000 to 2022-08-05 14:16:41.344000 (18.3 seconds) and wrote 19 records for MESU22_FUT_CME | 2022-08-05 14:16:42.803 HD Request # 15 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:16:41.344000 | 2022-08-05 14:16:42.807 Added 1 Time and Sales records to Intraday data file for MESU22_FUT_CME after download. | 2022-08-05 14:16:42.807 HD Request # 15 | Completion time: 1s. | 2022-08-05 14:16:42.807 HD Request # 15 | Intraday data download complete for MESU22_FUT_CME. Unique request ID: 15 | 2022-08-05 14:16:42.807 Removing historical data download ID 15. | 2022-08-05 14:16:42.807 Real-time Intraday chart data file updates started for MESU22_FUT_CME | 2022-08-05 14:16:42.807 Opened cached Intraday file: C:\SierraChart\Data\MESU22_FUT_CME.scid. Thread ID: 15072 | 2022-08-05 14:16:42.810 Intraday chart data file opened for MESU22_FUT_CME | 2022-08-05 14:16:42.810 HD Request # 15 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:16:42.810 Triggering next historical data download in queue. | 2022-08-05 14:16:42.810 No download requests in the queue to start downloads for. | 2022-08-05 14:16:42.810 DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:16:51.608 * DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-08-05 14:16:51.608 DTC Client socket (4) | CloseSocket call. | 2022-08-05 14:16:51.608 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:16:51.608 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:16:51.608 DTC Client socket (4) | Closed. | 2022-08-05 14:16:51.609 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:16:51.609 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:16:51.609 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:16:51.609 DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:16:52.607 * DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-08-05 14:16:52.607 DTC Client socket (2) | CloseSocket call. | 2022-08-05 14:16:52.607 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:16:52.607 DTC Client socket (2) | Closed. | 2022-08-05 14:16:52.607 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-08-05 14:16:52.607 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:16:52.607 SC DTC Data with Market Depth | Disconnected from the server. | 2022-08-05 14:16:52.607 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:16:52.607 SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 10048 | 2022-08-05 14:16:53.609 DTC Client socket (2) | Creating socket. | 2022-08-05 14:16:53.609 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-08-05 14:16:53.609 DTC Client socket (2) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:16:53.609 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:16:53.677 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:16:53.677 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-08-05 14:16:53.677 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:16:53.756 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-08-05 14:16:53.756 DTC Client socket (1) | CloseSocket call. | 2022-08-05 14:16:53.805 DTC Client socket (1) | Max send buffers used during socket life: 3 | 2022-08-05 14:16:53.805 DTC Client socket (1) | Max send buffer size during socket life: 329 | 2022-08-05 14:16:53.805 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:16:53.805 Connection to the external service has been lost. | 2022-08-05 14:16:53.805 DTC Client socket (1) | Closed. | 2022-08-05 14:16:53.805 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:53.818 SC Data - All Services | Sending logon request message. | 2022-08-05 14:16:53.818 Teton CME Order Routing | Waiting for socket receive thread to end | 2022-08-05 14:16:53.818 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:16:53.818 Teton CME Order Routing | Disconnected. | 2022-08-05 14:16:53.818 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-08-05 14:16:53.818 SC Data - All Services | Received logon response. | 2022-08-05 14:16:54.509 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:16:54.509 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:16:54.509 SC Data - All Services | Successfully connected. | 2022-08-05 14:16:54.509 SC Data - All Services | Trading is not supported. | 2022-08-05 14:16:54.509 Added historical Intraday data request for AAPL-NQTV to the queue. | 2022-08-05 14:16:54.509 Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'. | 2022-08-05 14:16:54.509 Triggering next historical data download in queue. | 2022-08-05 14:16:54.509 SC Data - All Services | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2022-08-05 14:16:54.509 HD Request # 16 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data | 2022-08-05 14:16:54.509 HD Request # 16 | Download start date-time: 2022-08-05 14:16:23.000000. File last date-time: 2022-08-05 14:16:23.000000 | 2022-08-05 14:16:54.509 HD Request # 16 | Using server: ds25.sierracharts.com port 10150 | 2022-08-05 14:16:54.509 Socket (1) | Creating socket. | 2022-08-05 14:16:54.510 Socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:16:54.510 Socket (1) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:16:54.510 SC DTC Data with Market Depth | Connecting to the server ds13-3.sierracharts.com. Port 443 | 2022-08-05 14:16:54.610 DTC Client socket (4) | Creating socket. | 2022-08-05 14:16:54.611 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:16:54.611 DTC Client socket (4) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:16:54.611 HD Request # 16 | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:54.652 HD Request # 16 | Sending historical data logon request message. | 2022-08-05 14:16:54.652 SC Data - All Services | Received security definition for symbol AAPL-NQTV | 2022-08-05 14:16:54.667 SC DTC Data with Market Depth | Network connection to server complete. | 2022-08-05 14:16:54.680 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-08-05 14:16:54.680 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:16:54.680 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:54.802 SC DTC Data with Market Depth | Sending logon request message. | 2022-08-05 14:16:54.802 HD Request # 16 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:23. Record interval: 1. Symbol: AAPL-NQTV | 2022-08-05 14:16:55.186 HD Request # 16 | Decompressing data. | 2022-08-05 14:16:55.258 HD Request # 16 | Receiving Intraday data for AAPL-NQTV starting at 2022-08-05 14:16:23.058000 | 2022-08-05 14:16:55.258 Socket (1) | CloseSocket call. | 2022-08-05 14:16:55.258 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:16:55.258 Historical data download thread signaled to stop. | 2022-08-05 14:16:55.299 HD Request # 16 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:23.058000. | 2022-08-05 14:16:55.299 HD Request # 16 | Received 27 Intraday data records from 2022-08-05 14:16:23.058000 to 2022-08-05 14:16:55.089000 (32.0 seconds) and wrote 27 records for AAPL-NQTV | 2022-08-05 14:16:55.300 HD Request # 16 | Completion time: 1s. | 2022-08-05 14:16:55.300 HD Request # 16 | Intraday data download complete for AAPL-NQTV. Unique request ID: 16 | 2022-08-05 14:16:55.300 Removing historical data download ID 16. | 2022-08-05 14:16:55.300 HD Request # 16 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:16:55.300 Triggering next historical data download in queue. | 2022-08-05 14:16:55.300 Historical data for AAPL-NQTV is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-08-05 14:16:55.300 No download requests in the queue to start downloads for. | 2022-08-05 14:16:55.300 Socket (1) | Socket gracefully closed by remote side. | 2022-08-05 14:16:55.324 Socket (1) | Closed. | 2022-08-05 14:16:55.324 SC DTC Data with Market Depth | Received logon response. | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Successfully connected. | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Trading is not supported. | 2022-08-05 14:16:55.593 Added historical Intraday data request for EURUSD to the queue. | 2022-08-05 14:16:55.593 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2022-08-05 14:16:55.593 Triggering next historical data download in queue. | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-08-05 14:16:55.593 Added historical Intraday data request for US30 to the queue. | 2022-08-05 14:16:55.593 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2022-08-05 14:16:55.593 Added historical Intraday data request for USOil to the queue. | 2022-08-05 14:16:55.593 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2022-08-05 14:16:55.593 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 14:16:55.593 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 14:16:55.593 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-08-05 14:16:55.593 HD Request # 17 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2022-08-05 14:16:55.593 HD Request # 17 | Download start date-time: 2022-08-05 14:16:22.000000. File last date-time: 2022-08-05 14:16:22.000000 | 2022-08-05 14:16:55.593 HD Request # 17 | Using server: ds12.sierracharts.com port 10149 | 2022-08-05 14:16:55.593 Socket (1) | Creating socket. | 2022-08-05 14:16:55.594 Socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:16:55.594 Socket (1) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:16:55.594 HD Request # 17 | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:55.733 HD Request # 17 | Sending historical data logon request message. | 2022-08-05 14:16:55.733 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2022-08-05 14:16:55.805 SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-08-05 14:16:55.805 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2022-08-05 14:16:55.805 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2022-08-05 14:16:55.805 SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-08-05 14:16:55.805 Teton CME Order Routing | Firm: Dorman | 2022-08-05 14:16:55.807 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-08-05 14:16:55.807 DTC Client socket (5) | Creating socket. Using TLS 1.2. | 2022-08-05 14:16:55.808 DTC Client socket (5) | New receive buffer size: 5242880 | 2022-08-05 14:16:55.808 DTC Client socket (5) | Connecting to IP: 208.185.224.129. | 2022-08-05 14:16:55.808 Teton CME Order Routing | Network connection to server complete. | 2022-08-05 14:16:55.867 Teton CME Order Routing | Starting socket receive thread. | 2022-08-05 14:16:55.867 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-08-05 14:16:55.867 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:56.075 Teton CME Order Routing | Sending logon request message. | 2022-08-05 14:16:56.075 HD Request # 17 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:22. Record interval: 1. Symbol: EURUSD | 2022-08-05 14:16:56.314 HD Request # 17 | Decompressing data. | 2022-08-05 14:16:56.382 HD Request # 17 | Receiving Intraday data for EURUSD starting at 2022-08-05 14:16:22.008000 | 2022-08-05 14:16:56.382 Socket (1) | CloseSocket call. | 2022-08-05 14:16:56.382 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:16:56.382 Historical data download thread signaled to stop. | 2022-08-05 14:16:56.382 HD Request # 17 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:22.008000. | 2022-08-05 14:16:56.382 HD Request # 17 | Received 31 Intraday data records from 2022-08-05 14:16:22.008000 to 2022-08-05 14:16:54.028000 (32.0 seconds) and wrote 31 records for EURUSD | 2022-08-05 14:16:56.383 HD Request # 17 | Completion time: 1s. | 2022-08-05 14:16:56.383 HD Request # 17 | Intraday data download complete for EURUSD. Unique request ID: 17 | 2022-08-05 14:16:56.383 Removing historical data download ID 17. | 2022-08-05 14:16:56.383 HD Request # 17 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:16:56.383 Triggering next historical data download in queue. | 2022-08-05 14:16:56.383 Historical data for EURUSD is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-08-05 14:16:56.383 HD Request # 18 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 14:16:56.383 HD Request # 18 | Download start date-time: 2022-08-05 14:16:23.000000. File last date-time: 2022-08-05 14:16:23.000000 | 2022-08-05 14:16:56.383 HD Request # 18 | Using server: ds13-3.sierracharts.com port 10150 | 2022-08-05 14:16:56.383 Socket (6) | Creating socket. | 2022-08-05 14:16:56.383 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:16:56.383 Socket (6) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:16:56.383 Socket (1) | Socket gracefully closed by remote side. | 2022-08-05 14:16:56.455 Socket (1) | Closed. | 2022-08-05 14:16:56.455 HD Request # 18 | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:56.521 HD Request # 18 | Sending historical data logon request message. | 2022-08-05 14:16:56.521 Teton CME Order Routing | Received logon response. | 2022-08-05 14:16:56.608 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-08-05 14:16:56.608 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:16:56.608 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-08-05 14:16:56.608 Teton CME Order Routing | Trading is supported. | 2022-08-05 14:16:56.608 Teton CME Order Routing | Order cancel and replace is supported. | 2022-08-05 14:16:56.608 Teton CME Order Routing | OCO Orders supported. | 2022-08-05 14:16:56.608 Teton CME Order Routing | Bracket Orders supported. | 2022-08-05 14:16:56.608 Teton CME Order Routing | Connected to server complete. | 2022-08-05 14:16:56.608 Triggering next historical data download in queue. | 2022-08-05 14:16:56.609 Triggering next historical data download in queue. | 2022-08-05 14:16:56.609 Triggering next historical data download in queue. | 2022-08-05 14:16:56.609 Triggering next historical data download in queue. | 2022-08-05 14:16:56.609 Updated verified funded futures trading account ending date to: 2022-09-04 14:16:56 | 2022-08-05 14:16:56.609 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-08-05 14:16:56.621 No download requests in the queue to start downloads for. | 2022-08-05 14:16:56.621 No download requests in the queue to start downloads for. | 2022-08-05 14:16:56.621 No download requests in the queue to start downloads for. | 2022-08-05 14:16:56.621 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 00:00:00.000000 | 2022-08-05 14:16:56.633 Updated verified funded futures trading account ending date to: 2022-09-04 14:16:56 | 2022-08-05 14:16:56.683 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43878 | 2022-08-05 14:16:56.692 HD Request # 18 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:23. Record interval: 1. Symbol: US30 | 2022-08-05 14:16:57.227 HD Request # 18 | Decompressing data. | 2022-08-05 14:16:57.303 HD Request # 18 | Receiving Intraday data for US30 starting at 2022-06-07 14:04:01.627000 | 2022-08-05 14:16:57.442 Socket (6) | CloseSocket call. | 2022-08-05 14:16:57.443 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:16:57.443 Historical data download thread signaled to stop. | 2022-08-05 14:16:57.443 HD Request # 18 | Received 1510 Intraday data records from 2022-06-07 14:04:01.627000 to 2022-06-07 15:03:42.116000 (59.7 minutes) and wrote 0 records for US30 | 2022-08-05 14:16:57.443 HD Request # 18 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:16:23.000000 | 2022-08-05 14:16:57.444 HD Request # 18 | Completion time: 1s. | 2022-08-05 14:16:57.444 HD Request # 18 | Intraday data download complete for US30. Unique request ID: 18 | 2022-08-05 14:16:57.444 Removing historical data download ID 18. | 2022-08-05 14:16:57.444 Real-time Intraday chart data file updates started for US30 | 2022-08-05 14:16:57.444 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 14:16:57.444 Intraday chart data file opened for US30 | 2022-08-05 14:16:57.444 HD Request # 18 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:16:57.444 Triggering next historical data download in queue. | 2022-08-05 14:16:57.444 Initiating new historical data download for US30 to get the latest data since the download was started while not connected to primary service. | 2022-08-05 14:16:57.444 Added historical Intraday data request for US30 to the queue. | 2022-08-05 14:16:57.444 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 14:16:57.444 HD Request # 19 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 14:16:57.444 HD Request # 19 | Download start date-time: 2022-08-05 14:16:23.000000. File last date-time: 2022-08-05 14:16:23.000000 | 2022-08-05 14:16:57.444 HD Request # 19 | Using server: ds4.sierracharts.com port 10149 | 2022-08-05 14:16:57.444 Socket (1) | Creating socket. | 2022-08-05 14:16:57.444 Socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:16:57.444 Socket (1) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:16:57.444 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:16:57.507 Socket (6) | Closed. | 2022-08-05 14:16:57.507 HD Request # 19 | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:57.575 HD Request # 19 | Sending historical data logon request message. | 2022-08-05 14:16:57.575 HD Request # 19 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:23. Record interval: 1. Symbol: US30 | 2022-08-05 14:16:58.154 HD Request # 19 | Decompressing data. | 2022-08-05 14:16:58.211 HD Request # 19 | Receiving Intraday data for US30 starting at 2022-08-05 14:16:23.012000 | 2022-08-05 14:16:58.211 Socket (1) | CloseSocket call. | 2022-08-05 14:16:58.212 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:16:58.212 Historical data download thread signaled to stop. | 2022-08-05 14:16:58.212 HD Request # 19 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:23.012000. | 2022-08-05 14:16:58.212 HD Request # 19 | Received 35 Intraday data records from 2022-08-05 14:16:23.012000 to 2022-08-05 14:16:57.014000 (34.0 seconds) and wrote 35 records for US30 | 2022-08-05 14:16:58.212 HD Request # 19 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:16:57.014000 | 2022-08-05 14:16:58.216 HD Request # 19 | Completion time: 1s. | 2022-08-05 14:16:58.216 HD Request # 19 | Intraday data download complete for US30. Unique request ID: 21 | 2022-08-05 14:16:58.216 Removing historical data download ID 21. | 2022-08-05 14:16:58.216 Real-time Intraday chart data file updates started for US30 | 2022-08-05 14:16:58.216 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 14:16:58.216 Intraday chart data file opened for US30 | 2022-08-05 14:16:58.216 HD Request # 19 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:16:58.216 Triggering next historical data download in queue. | 2022-08-05 14:16:58.216 HD Request # 20 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2022-08-05 14:16:58.216 HD Request # 20 | Download start date-time: 2022-08-05 14:16:22.000000. File last date-time: 2022-08-05 14:16:22.000000 | 2022-08-05 14:16:58.216 HD Request # 20 | Using server: ds12.sierracharts.com port 10150 | 2022-08-05 14:16:58.216 Socket (6) | Creating socket. | 2022-08-05 14:16:58.216 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:16:58.216 Socket (6) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:16:58.216 Socket (1) | Socket gracefully closed by remote side. | 2022-08-05 14:16:58.271 Socket (1) | Closed. | 2022-08-05 14:16:58.271 HD Request # 20 | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:58.357 HD Request # 20 | Sending historical data logon request message. | 2022-08-05 14:16:58.357 HD Request # 20 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:22. Record interval: 1. Symbol: USOil | 2022-08-05 14:16:58.940 HD Request # 20 | Decompressing data. | 2022-08-05 14:16:59.004 HD Request # 20 | Receiving Intraday data for USOil starting at 2022-08-05 14:16:22.600000 | 2022-08-05 14:16:59.005 Socket (6) | CloseSocket call. | 2022-08-05 14:16:59.005 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:16:59.005 Historical data download thread signaled to stop. | 2022-08-05 14:16:59.005 HD Request # 20 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:22.600000. | 2022-08-05 14:16:59.005 HD Request # 20 | Received 33 Intraday data records from 2022-08-05 14:16:22.600000 to 2022-08-05 14:16:57.014000 (34.4 seconds) and wrote 33 records for USOil | 2022-08-05 14:16:59.005 HD Request # 20 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:16:57.014000 | 2022-08-05 14:16:59.009 HD Request # 20 | Completion time: 1s. | 2022-08-05 14:16:59.009 HD Request # 20 | Intraday data download complete for USOil. Unique request ID: 19 | 2022-08-05 14:16:59.009 Removing historical data download ID 19. | 2022-08-05 14:16:59.009 Real-time Intraday chart data file updates started for USOil | 2022-08-05 14:16:59.009 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 15072 | 2022-08-05 14:16:59.009 Intraday chart data file opened for USOil | 2022-08-05 14:16:59.009 HD Request # 20 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:16:59.009 Triggering next historical data download in queue. | 2022-08-05 14:16:59.009 HD Request # 21 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 14:16:59.009 HD Request # 21 | Download start date-time: 2022-08-05 14:16:22.000000. File last date-time: 2022-08-05 14:16:22.000000 | 2022-08-05 14:16:59.010 HD Request # 21 | Using server: ds13-3.sierracharts.com port 10149 | 2022-08-05 14:16:59.010 Socket (1) | Creating socket. | 2022-08-05 14:16:59.010 Socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:16:59.010 Socket (1) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:16:59.010 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:16:59.066 Socket (6) | Closed. | 2022-08-05 14:16:59.066 HD Request # 21 | Setting DTC encoding to Binary VLS | 2022-08-05 14:16:59.138 HD Request # 21 | Sending historical data logon request message. | 2022-08-05 14:16:59.138 HD Request # 21 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:22. Record interval: 1. Symbol: XAUUSD | 2022-08-05 14:16:59.827 HD Request # 21 | Decompressing data. | 2022-08-05 14:16:59.890 HD Request # 21 | Receiving Intraday data for XAUUSD starting at 2022-08-05 14:16:22.719000 | 2022-08-05 14:16:59.890 Socket (1) | CloseSocket call. | 2022-08-05 14:16:59.890 Socket (1) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:16:59.890 Historical data download thread signaled to stop. | 2022-08-05 14:16:59.891 HD Request # 21 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:22.719000. | 2022-08-05 14:16:59.891 HD Request # 21 | Received 37 Intraday data records from 2022-08-05 14:16:22.719000 to 2022-08-05 14:16:58.100000 (35.4 seconds) and wrote 37 records for XAUUSD | 2022-08-05 14:16:59.891 HD Request # 21 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:16:58.100000 | 2022-08-05 14:16:59.894 Added 1 Time and Sales records to Intraday data file for XAUUSD after download. | 2022-08-05 14:16:59.894 HD Request # 21 | Completion time: 0s. | 2022-08-05 14:16:59.895 HD Request # 21 | Intraday data download complete for XAUUSD. Unique request ID: 20 | 2022-08-05 14:16:59.895 Removing historical data download ID 20. | 2022-08-05 14:16:59.895 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-05 14:16:59.895 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 15072 | 2022-08-05 14:16:59.897 Intraday chart data file opened for XAUUSD | 2022-08-05 14:16:59.898 HD Request # 21 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:16:59.898 Triggering next historical data download in queue. | 2022-08-05 14:16:59.898 No download requests in the queue to start downloads for. | 2022-08-05 14:16:59.898 Socket (1) | Socket gracefully closed by remote side. | 2022-08-05 14:16:59.962 Socket (1) | Closed. | 2022-08-05 14:16:59.962 DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:17:56.027 * DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-08-05 14:17:56.027 DTC Client socket (4) | CloseSocket call. | 2022-08-05 14:17:56.027 DTC Client socket (4) | Max send buffers used during socket life: 4 | 2022-08-05 14:17:56.027 DTC Client socket (4) | Max send buffer size during socket life: 354 | 2022-08-05 14:17:56.027 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:17:56.027 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-08-05 14:17:56.028 DTC Client socket (4) | Closed. | 2022-08-05 14:17:56.028 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:17:56.028 SC DTC Data with Market Depth | Disconnected from the server. | 2022-08-05 14:17:56.028 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:17:56.028 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 443 | 2022-08-05 14:17:58.031 DTC Client socket (1) | Creating socket. | 2022-08-05 14:17:58.031 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:17:58.031 DTC Client socket (1) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:17:58.031 SC DTC Data with Market Depth | Network connection to server complete. | 2022-08-05 14:17:58.094 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-08-05 14:17:58.094 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:17:58.094 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-08-05 14:17:58.163 SC DTC Data with Market Depth | Sending logon request message. | 2022-08-05 14:17:58.163 SC DTC Data with Market Depth | Received logon response. | 2022-08-05 14:17:58.848 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-08-05 14:17:58.848 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:17:58.848 SC DTC Data with Market Depth | Successfully connected. | 2022-08-05 14:17:58.848 SC DTC Data with Market Depth | Trading is not supported. | 2022-08-05 14:17:58.848 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-08-05 14:17:58.848 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-08-05 14:17:58.848 Added historical Intraday data request for US30 to the queue. | 2022-08-05 14:17:58.849 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 14:17:58.849 Triggering next historical data download in queue. | 2022-08-05 14:17:58.849 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2022-08-05 14:17:58.849 Added historical Intraday data request for USOil to the queue. | 2022-08-05 14:17:58.849 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2022-08-05 14:17:58.849 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2022-08-05 14:17:58.849 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 14:17:58.849 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 14:17:58.849 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-08-05 14:17:58.849 HD Request # 22 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 14:17:58.849 HD Request # 22 | Download start date-time: 2022-08-05 14:16:57.000000. File last date-time: 2022-08-05 14:16:57.014000 | 2022-08-05 14:17:58.849 HD Request # 22 | Using server: ds4.sierracharts.com port 10150 | 2022-08-05 14:17:58.849 Socket (4) | Creating socket. | 2022-08-05 14:17:58.849 Socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:17:58.849 Socket (4) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:17:58.849 HD Request # 22 | Setting DTC encoding to Binary VLS | 2022-08-05 14:17:58.992 HD Request # 22 | Sending historical data logon request message. | 2022-08-05 14:17:58.992 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2022-08-05 14:17:59.004 SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-08-05 14:17:59.004 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2022-08-05 14:17:59.004 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2022-08-05 14:17:59.004 SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-08-05 14:17:59.004 HD Request # 22 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:57. Record interval: 1. Symbol: US30 | 2022-08-05 14:17:59.565 HD Request # 22 | Decompressing data. | 2022-08-05 14:17:59.631 HD Request # 22 | Receiving Intraday data for US30 starting at 2022-08-05 14:16:57.014000 | 2022-08-05 14:17:59.633 Socket (4) | CloseSocket call. | 2022-08-05 14:17:59.633 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:17:59.634 Historical data download thread signaled to stop. | 2022-08-05 14:17:59.634 HD Request # 22 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:57.014000. | 2022-08-05 14:17:59.634 HD Request # 22 | Received 62 Intraday data records from 2022-08-05 14:16:57.014000 to 2022-08-05 14:17:58.021000 (61.0 seconds) and wrote 62 records for US30 | 2022-08-05 14:17:59.634 HD Request # 22 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:17:58.021000 | 2022-08-05 14:17:59.638 Added 1 Time and Sales records to Intraday data file for US30 after download. | 2022-08-05 14:17:59.638 HD Request # 22 | Completion time: 1s. | 2022-08-05 14:17:59.638 HD Request # 22 | Intraday data download complete for US30. Unique request ID: 22 | 2022-08-05 14:17:59.638 Removing historical data download ID 22. | 2022-08-05 14:17:59.638 Real-time Intraday chart data file updates started for US30 | 2022-08-05 14:17:59.638 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 14:17:59.641 Intraday chart data file opened for US30 | 2022-08-05 14:17:59.641 HD Request # 22 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:17:59.641 Triggering next historical data download in queue. | 2022-08-05 14:17:59.641 HD Request # 23 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2022-08-05 14:17:59.641 HD Request # 23 | Download start date-time: 2022-08-05 14:17:51.000000. File last date-time: 2022-08-05 14:17:51.000000 | 2022-08-05 14:17:59.641 HD Request # 23 | Using server: ds12.sierracharts.com port 10149 | 2022-08-05 14:17:59.641 Socket (6) | Creating socket. | 2022-08-05 14:17:59.641 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:17:59.641 Socket (6) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:17:59.641 Socket (4) | Socket gracefully closed by remote side. | 2022-08-05 14:17:59.711 Socket (4) | Closed. | 2022-08-05 14:17:59.711 HD Request # 23 | Setting DTC encoding to Binary VLS | 2022-08-05 14:17:59.825 HD Request # 23 | Sending historical data logon request message. | 2022-08-05 14:17:59.825 HD Request # 23 | Requesting Intraday data. Start date-time: 2022-08-05 14:17:51. Record interval: 1. Symbol: USOil | 2022-08-05 14:18:00.410 HD Request # 23 | Decompressing data. | 2022-08-05 14:18:00.478 HD Request # 23 | Receiving Intraday data for USOil starting at 2022-08-05 14:17:51.542000 | 2022-08-05 14:18:00.478 Socket (6) | CloseSocket call. | 2022-08-05 14:18:00.478 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:18:00.478 Historical data download thread signaled to stop. | 2022-08-05 14:18:00.479 HD Request # 23 | Timestamp of first Intraday data file record written: 2022-08-05 14:17:51.542000. | 2022-08-05 14:18:00.479 HD Request # 23 | Received 8 Intraday data records from 2022-08-05 14:17:51.542000 to 2022-08-05 14:17:58.477000 (6.9 seconds) and wrote 8 records for USOil | 2022-08-05 14:18:00.479 HD Request # 23 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:17:58.477000 | 2022-08-05 14:18:00.483 Added 2 Time and Sales records to Intraday data file for USOil after download. | 2022-08-05 14:18:00.483 HD Request # 23 | Completion time: 1s. | 2022-08-05 14:18:00.483 HD Request # 23 | Intraday data download complete for USOil. Unique request ID: 23 | 2022-08-05 14:18:00.483 Removing historical data download ID 23. | 2022-08-05 14:18:00.483 Real-time Intraday chart data file updates started for USOil | 2022-08-05 14:18:00.483 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 15072 | 2022-08-05 14:18:00.485 Intraday chart data file opened for USOil | 2022-08-05 14:18:00.485 HD Request # 23 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:18:00.485 Triggering next historical data download in queue. | 2022-08-05 14:18:00.485 HD Request # 24 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 14:18:00.485 HD Request # 24 | Download start date-time: 2022-08-05 14:17:51.000000. File last date-time: 2022-08-05 14:17:51.000000 | 2022-08-05 14:18:00.486 HD Request # 24 | Using server: ds13-3.sierracharts.com port 10150 | 2022-08-05 14:18:00.486 Socket (4) | Creating socket. | 2022-08-05 14:18:00.486 Socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:18:00.486 Socket (4) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:18:00.486 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:18:00.540 Socket (6) | Closed. | 2022-08-05 14:18:00.540 HD Request # 24 | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:00.614 HD Request # 24 | Sending historical data logon request message. | 2022-08-05 14:18:00.614 HD Request # 24 | Requesting Intraday data. Start date-time: 2022-08-05 14:17:51. Record interval: 1. Symbol: XAUUSD | 2022-08-05 14:18:01.344 HD Request # 24 | Decompressing data. | 2022-08-05 14:18:01.414 HD Request # 24 | Receiving Intraday data for XAUUSD starting at 2022-08-05 14:17:51.788000 | 2022-08-05 14:18:01.415 Socket (4) | CloseSocket call. | 2022-08-05 14:18:01.415 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:18:01.415 Historical data download thread signaled to stop. | 2022-08-05 14:18:01.415 HD Request # 24 | Timestamp of first Intraday data file record written: 2022-08-05 14:17:51.788000. | 2022-08-05 14:18:01.415 HD Request # 24 | Received 9 Intraday data records from 2022-08-05 14:17:51.788000 to 2022-08-05 14:18:00.103000 (8.3 seconds) and wrote 9 records for XAUUSD | 2022-08-05 14:18:01.415 HD Request # 24 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:18:00.103000 | 2022-08-05 14:18:01.419 Added 1 Time and Sales records to Intraday data file for XAUUSD after download. | 2022-08-05 14:18:01.419 HD Request # 24 | Completion time: 1s. | 2022-08-05 14:18:01.419 HD Request # 24 | Intraday data download complete for XAUUSD. Unique request ID: 24 | 2022-08-05 14:18:01.419 Removing historical data download ID 24. | 2022-08-05 14:18:01.419 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-05 14:18:01.419 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 15072 | 2022-08-05 14:18:01.422 Intraday chart data file opened for XAUUSD | 2022-08-05 14:18:01.422 HD Request # 24 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:18:01.422 Triggering next historical data download in queue. | 2022-08-05 14:18:01.422 No download requests in the queue to start downloads for. | 2022-08-05 14:18:01.422 Socket (4) | Socket gracefully closed by remote side. | 2022-08-05 14:18:01.479 Socket (4) | Closed. | 2022-08-05 14:18:01.479 DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:18:14.384 * DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-08-05 14:18:14.384 DTC Client socket (2) | CloseSocket call. | 2022-08-05 14:18:14.384 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:18:14.384 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:18:14.384 DTC Client socket (2) | Closed. | 2022-08-05 14:18:14.384 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:18:14.385 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:18:14.385 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:18:14.385 SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 10048 | 2022-08-05 14:18:16.393 DTC Client socket (2) | Creating socket. | 2022-08-05 14:18:16.393 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-08-05 14:18:16.393 DTC Client socket (2) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:18:16.393 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:18:16.453 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:18:16.453 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-08-05 14:18:16.453 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:16.550 SC Data - All Services | Sending logon request message. | 2022-08-05 14:18:16.550 DTC Client socket (5) | Socket gracefully closed by remote side. | 2022-08-05 14:18:16.563 DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:18:16.563 * DTC Client socket (5) | CloseSocket call. | 2022-08-05 14:18:16.563 DTC Client socket (5) | Max send buffers used during socket life: 3 | 2022-08-05 14:18:16.563 DTC Client socket (5) | Max send buffer size during socket life: 236 | 2022-08-05 14:18:16.563 Connection to the external service has been lost. | 2022-08-05 14:18:16.563 DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:18:16.563 DTC Client socket (5) | Closed. | 2022-08-05 14:18:16.563 Teton CME Order Routing | Waiting for socket receive thread to end | 2022-08-05 14:18:16.575 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:18:16.576 Teton CME Order Routing | Disconnected. | 2022-08-05 14:18:16.576 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-08-05 14:18:16.576 SC Data - All Services | Received logon response. | 2022-08-05 14:18:17.238 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:18:17.238 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:18:17.238 SC Data - All Services | Successfully connected. | 2022-08-05 14:18:17.238 SC Data - All Services | Trading is not supported. | 2022-08-05 14:18:17.238 SC Data - All Services | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2022-08-05 14:18:17.238 SC Data - All Services | Received security definition for symbol AAPL-NQTV | 2022-08-05 14:18:17.395 Teton CME Order Routing | Firm: Dorman | 2022-08-05 14:18:18.575 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-08-05 14:18:18.575 DTC Client socket (4) | Creating socket. Using TLS 1.2. | 2022-08-05 14:18:18.575 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:18:18.575 DTC Client socket (4) | Connecting to IP: 208.185.224.129. | 2022-08-05 14:18:18.575 Teton CME Order Routing | Network connection to server complete. | 2022-08-05 14:18:18.640 Teton CME Order Routing | Starting socket receive thread. | 2022-08-05 14:18:18.640 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-08-05 14:18:18.641 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:18.824 Teton CME Order Routing | Sending logon request message. | 2022-08-05 14:18:18.824 Teton CME Order Routing | Received logon response. | 2022-08-05 14:18:19.359 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-08-05 14:18:19.359 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:18:19.359 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-08-05 14:18:19.359 Teton CME Order Routing | Trading is supported. | 2022-08-05 14:18:19.359 Teton CME Order Routing | Order cancel and replace is supported. | 2022-08-05 14:18:19.359 Teton CME Order Routing | OCO Orders supported. | 2022-08-05 14:18:19.359 Teton CME Order Routing | Bracket Orders supported. | 2022-08-05 14:18:19.359 Teton CME Order Routing | Connected to server complete. | 2022-08-05 14:18:19.359 Triggering next historical data download in queue. | 2022-08-05 14:18:19.359 Triggering next historical data download in queue. | 2022-08-05 14:18:19.359 Triggering next historical data download in queue. | 2022-08-05 14:18:19.359 Triggering next historical data download in queue. | 2022-08-05 14:18:19.359 Updated verified funded futures trading account ending date to: 2022-09-04 14:18:19 | 2022-08-05 14:18:19.359 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-08-05 14:18:19.371 No download requests in the queue to start downloads for. | 2022-08-05 14:18:19.371 No download requests in the queue to start downloads for. | 2022-08-05 14:18:19.371 No download requests in the queue to start downloads for. | 2022-08-05 14:18:19.371 No download requests in the queue to start downloads for. | 2022-08-05 14:18:19.371 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 00:00:00.000000 | 2022-08-05 14:18:19.383 Updated verified funded futures trading account ending date to: 2022-09-04 14:18:19 | 2022-08-05 14:18:19.434 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43878 | 2022-08-05 14:18:19.453 DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:18:24.860 DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:18:24.860 * DTC Client socket (3) | CloseSocket call. | 2022-08-05 14:18:24.861 DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:18:24.861 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:18:24.861 DTC Client socket (3) | Closed. | 2022-08-05 14:18:24.861 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:18:24.861 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:18:24.861 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:18:24.861 SC Data - All Services | Connecting to the server ds23.sierracharts.com. Port 10048 | 2022-08-05 14:18:26.867 DTC Client socket (3) | Creating socket. | 2022-08-05 14:18:26.867 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:18:26.867 DTC Client socket (3) | Connecting to IP: 216.1.90.130. | 2022-08-05 14:18:26.867 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:18:26.924 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:18:26.924 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:18:26.924 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:27.020 SC Data - All Services | Sending logon request message. | 2022-08-05 14:18:27.020 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:18:39.496 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-08-05 14:18:39.496 DTC Client socket (1) | CloseSocket call. | 2022-08-05 14:18:39.496 DTC Client socket (1) | Max send buffers used during socket life: 3 | 2022-08-05 14:18:39.496 DTC Client socket (1) | Max send buffer size during socket life: 354 | 2022-08-05 14:18:39.496 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:18:39.496 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-08-05 14:18:39.496 DTC Client socket (1) | Closed. | 2022-08-05 14:18:39.496 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:18:39.497 SC DTC Data with Market Depth | Disconnected from the server. | 2022-08-05 14:18:39.497 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:18:39.497 SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2022-08-05 14:18:41.502 DTC Client socket (1) | Creating socket. | 2022-08-05 14:18:41.502 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:18:41.502 DTC Client socket (1) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:18:41.502 SC DTC Data with Market Depth | Network connection to server complete. | 2022-08-05 14:18:41.567 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-08-05 14:18:41.567 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:18:41.567 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:41.664 SC DTC Data with Market Depth | Sending logon request message. | 2022-08-05 14:18:41.664 SC DTC Data with Market Depth | Received logon response. | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Successfully connected. | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Trading is not supported. | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-08-05 14:18:42.351 Added historical Intraday data request for US30 to the queue. | 2022-08-05 14:18:42.351 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 14:18:42.351 Triggering next historical data download in queue. | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2022-08-05 14:18:42.351 Added historical Intraday data request for USOil to the queue. | 2022-08-05 14:18:42.351 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2022-08-05 14:18:42.351 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 14:18:42.351 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 14:18:42.351 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-08-05 14:18:42.351 HD Request # 25 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 14:18:42.351 HD Request # 25 | Download start date-time: 2022-08-05 14:18:27.000000. File last date-time: 2022-08-05 14:18:27.000000 | 2022-08-05 14:18:42.352 HD Request # 25 | Using server: ds4.sierracharts.com port 10149 | 2022-08-05 14:18:42.352 Socket (5) | Creating socket. | 2022-08-05 14:18:42.352 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 14:18:42.352 Socket (5) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:18:42.352 HD Request # 25 | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:42.480 HD Request # 25 | Sending historical data logon request message. | 2022-08-05 14:18:42.480 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2022-08-05 14:18:42.508 SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-08-05 14:18:42.508 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2022-08-05 14:18:42.508 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2022-08-05 14:18:42.508 SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-08-05 14:18:42.508 HD Request # 25 | Requesting Intraday data. Start date-time: 2022-08-05 14:18:27. Record interval: 1. Symbol: US30 | 2022-08-05 14:18:43.064 HD Request # 25 | Decompressing data. | 2022-08-05 14:18:43.125 HD Request # 25 | Receiving Intraday data for US30 starting at 2022-08-05 14:18:27.089000 | 2022-08-05 14:18:43.125 Socket (5) | CloseSocket call. | 2022-08-05 14:18:43.125 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:18:43.126 Historical data download thread signaled to stop. | 2022-08-05 14:18:43.126 HD Request # 25 | Timestamp of first Intraday data file record written: 2022-08-05 14:18:27.089000. | 2022-08-05 14:18:43.126 HD Request # 25 | Received 16 Intraday data records from 2022-08-05 14:18:27.089000 to 2022-08-05 14:18:42.009000 (14.9 seconds) and wrote 16 records for US30 | 2022-08-05 14:18:43.126 HD Request # 25 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:18:42.009000 | 2022-08-05 14:18:43.130 Added 1 Time and Sales records to Intraday data file for US30 after download. | 2022-08-05 14:18:43.130 HD Request # 25 | Completion time: 1s. | 2022-08-05 14:18:43.130 HD Request # 25 | Intraday data download complete for US30. Unique request ID: 25 | 2022-08-05 14:18:43.130 Removing historical data download ID 25. | 2022-08-05 14:18:43.130 Real-time Intraday chart data file updates started for US30 | 2022-08-05 14:18:43.130 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 14:18:43.134 Intraday chart data file opened for US30 | 2022-08-05 14:18:43.134 HD Request # 25 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:18:43.134 Triggering next historical data download in queue. | 2022-08-05 14:18:43.134 HD Request # 26 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2022-08-05 14:18:43.134 HD Request # 26 | Download start date-time: 2022-08-05 14:18:26.000000. File last date-time: 2022-08-05 14:18:26.000000 | 2022-08-05 14:18:43.134 HD Request # 26 | Using server: ds12.sierracharts.com port 10150 | 2022-08-05 14:18:43.134 Socket (6) | Creating socket. | 2022-08-05 14:18:43.134 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:18:43.134 Socket (6) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:18:43.134 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 14:18:43.192 Socket (5) | Closed. | 2022-08-05 14:18:43.192 HD Request # 26 | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:43.286 HD Request # 26 | Sending historical data logon request message. | 2022-08-05 14:18:43.286 HD Request # 26 | Requesting Intraday data. Start date-time: 2022-08-05 14:18:26. Record interval: 1. Symbol: USOil | 2022-08-05 14:18:43.867 HD Request # 26 | Decompressing data. | 2022-08-05 14:18:43.933 HD Request # 26 | Receiving Intraday data for USOil starting at 2022-08-05 14:18:26.556000 | 2022-08-05 14:18:43.933 Socket (6) | CloseSocket call. | 2022-08-05 14:18:43.933 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:18:43.933 Historical data download thread signaled to stop. | 2022-08-05 14:18:43.933 HD Request # 26 | Timestamp of first Intraday data file record written: 2022-08-05 14:18:26.556000. | 2022-08-05 14:18:43.934 HD Request # 26 | Received 17 Intraday data records from 2022-08-05 14:18:26.556000 to 2022-08-05 14:18:43.042000 (16.5 seconds) and wrote 17 records for USOil | 2022-08-05 14:18:43.934 HD Request # 26 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:18:43.042000 | 2022-08-05 14:18:43.938 HD Request # 26 | Completion time: 0s. | 2022-08-05 14:18:43.938 HD Request # 26 | Intraday data download complete for USOil. Unique request ID: 26 | 2022-08-05 14:18:43.938 Removing historical data download ID 26. | 2022-08-05 14:18:43.938 Real-time Intraday chart data file updates started for USOil | 2022-08-05 14:18:43.938 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 15072 | 2022-08-05 14:18:43.938 Intraday chart data file opened for USOil | 2022-08-05 14:18:43.938 HD Request # 26 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:18:43.938 Triggering next historical data download in queue. | 2022-08-05 14:18:43.938 HD Request # 27 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 14:18:43.938 HD Request # 27 | Download start date-time: 2022-08-05 14:18:27.000000. File last date-time: 2022-08-05 14:18:27.000000 | 2022-08-05 14:18:43.938 HD Request # 27 | Using server: ds13-3.sierracharts.com port 10149 | 2022-08-05 14:18:43.938 Socket (5) | Creating socket. | 2022-08-05 14:18:43.938 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 14:18:43.938 Socket (5) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:18:43.938 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:18:43.999 Socket (6) | Closed. | 2022-08-05 14:18:43.999 HD Request # 27 | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:44.077 HD Request # 27 | Sending historical data logon request message. | 2022-08-05 14:18:44.077 HD Request # 27 | Requesting Intraday data. Start date-time: 2022-08-05 14:18:27. Record interval: 1. Symbol: XAUUSD | 2022-08-05 14:18:44.821 HD Request # 27 | Decompressing data. | 2022-08-05 14:18:44.884 HD Request # 27 | Receiving Intraday data for XAUUSD starting at 2022-08-05 14:18:27.682000 | 2022-08-05 14:18:44.884 Socket (5) | CloseSocket call. | 2022-08-05 14:18:44.885 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:18:44.885 Historical data download thread signaled to stop. | 2022-08-05 14:18:44.885 HD Request # 27 | Timestamp of first Intraday data file record written: 2022-08-05 14:18:27.682000. | 2022-08-05 14:18:44.885 HD Request # 27 | Received 17 Intraday data records from 2022-08-05 14:18:27.682000 to 2022-08-05 14:18:44.289000 (16.6 seconds) and wrote 17 records for XAUUSD | 2022-08-05 14:18:44.885 HD Request # 27 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:18:44.289000 | 2022-08-05 14:18:44.889 HD Request # 27 | Completion time: 1s. | 2022-08-05 14:18:44.889 HD Request # 27 | Intraday data download complete for XAUUSD. Unique request ID: 27 | 2022-08-05 14:18:44.889 Removing historical data download ID 27. | 2022-08-05 14:18:44.889 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-05 14:18:44.889 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 15072 | 2022-08-05 14:18:44.889 Intraday chart data file opened for XAUUSD | 2022-08-05 14:18:44.889 HD Request # 27 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:18:44.889 Triggering next historical data download in queue. | 2022-08-05 14:18:44.889 No download requests in the queue to start downloads for. | 2022-08-05 14:18:44.889 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 14:18:44.954 Socket (5) | Closed. | 2022-08-05 14:18:44.954 DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:18:56.838 * DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-08-05 14:18:56.838 DTC Client socket (2) | CloseSocket call. | 2022-08-05 14:18:56.838 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:18:56.838 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:18:56.838 DTC Client socket (2) | Closed. | 2022-08-05 14:18:56.838 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:18:56.839 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:18:56.839 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:18:56.839 SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 443 | 2022-08-05 14:18:58.846 DTC Client socket (2) | Creating socket. | 2022-08-05 14:18:58.847 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-08-05 14:18:58.847 DTC Client socket (2) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:18:58.847 DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:18:58.896 * DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-08-05 14:18:58.896 DTC Client socket (4) | CloseSocket call. | 2022-08-05 14:18:58.896 DTC Client socket (4) | Max send buffers used during socket life: 3 | 2022-08-05 14:18:58.896 DTC Client socket (4) | Max send buffer size during socket life: 329 | 2022-08-05 14:18:58.896 Connection to the external service has been lost. | 2022-08-05 14:18:58.896 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:18:58.896 DTC Client socket (4) | Closed. | 2022-08-05 14:18:58.896 Teton CME Order Routing | Waiting for socket receive thread to end | 2022-08-05 14:18:58.910 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:18:58.910 Teton CME Order Routing | Disconnected. | 2022-08-05 14:18:58.911 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-08-05 14:18:58.911 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:18:58.911 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:18:58.911 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-08-05 14:18:58.911 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:18:58.992 SC Data - All Services | Sending logon request message. | 2022-08-05 14:18:58.992 SC Data - All Services | Received logon response. | 2022-08-05 14:18:59.711 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:18:59.711 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:18:59.711 SC Data - All Services | Successfully connected. | 2022-08-05 14:18:59.711 SC Data - All Services | Trading is not supported. | 2022-08-05 14:18:59.711 SC Data - All Services | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2022-08-05 14:18:59.711 SC Data - All Services | Received security definition for symbol AAPL-NQTV | 2022-08-05 14:18:59.868 Teton CME Order Routing | Firm: Dorman | 2022-08-05 14:19:00.905 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-08-05 14:19:00.905 DTC Client socket (4) | Creating socket. Using TLS 1.2. | 2022-08-05 14:19:00.905 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:19:00.905 DTC Client socket (4) | Connecting to IP: 208.185.224.129. | 2022-08-05 14:19:00.905 Teton CME Order Routing | Network connection to server complete. | 2022-08-05 14:19:00.968 Teton CME Order Routing | Starting socket receive thread. | 2022-08-05 14:19:00.968 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-08-05 14:19:00.969 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:01.156 Teton CME Order Routing | Sending logon request message. | 2022-08-05 14:19:01.156 Teton CME Order Routing | Received logon response. | 2022-08-05 14:19:01.218 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-08-05 14:19:01.218 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:19:01.218 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-08-05 14:19:01.218 Teton CME Order Routing | Trading is supported. | 2022-08-05 14:19:01.218 Teton CME Order Routing | Order cancel and replace is supported. | 2022-08-05 14:19:01.218 Teton CME Order Routing | OCO Orders supported. | 2022-08-05 14:19:01.218 Teton CME Order Routing | Bracket Orders supported. | 2022-08-05 14:19:01.218 Teton CME Order Routing | Connected to server complete. | 2022-08-05 14:19:01.218 Triggering next historical data download in queue. | 2022-08-05 14:19:01.219 Triggering next historical data download in queue. | 2022-08-05 14:19:01.219 Triggering next historical data download in queue. | 2022-08-05 14:19:01.219 Triggering next historical data download in queue. | 2022-08-05 14:19:01.219 Updated verified funded futures trading account ending date to: 2022-09-04 14:19:01 | 2022-08-05 14:19:01.219 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-08-05 14:19:01.231 No download requests in the queue to start downloads for. | 2022-08-05 14:19:01.231 No download requests in the queue to start downloads for. | 2022-08-05 14:19:01.231 No download requests in the queue to start downloads for. | 2022-08-05 14:19:01.231 No download requests in the queue to start downloads for. | 2022-08-05 14:19:01.231 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 00:00:00.000000 | 2022-08-05 14:19:01.242 Updated verified funded futures trading account ending date to: 2022-09-04 14:19:01 | 2022-08-05 14:19:01.291 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43878 | 2022-08-05 14:19:01.310 File >> Disconnect selected. | 2022-08-05 14:19:41.820 Teton CME Order Routing | Waiting for socket receive thread to end | 2022-08-05 14:19:41.833 DTC Client socket (4) | CloseSocket call. | 2022-08-05 14:19:41.833 DTC Client socket (4) | Max send buffers used during socket life: 3 | 2022-08-05 14:19:41.833 DTC Client socket (4) | Max send buffer size during socket life: 329 | 2022-08-05 14:19:41.833 DTC Client socket (4) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:41.833 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:19:41.833 DTC Client socket (3) | CloseSocket call. | 2022-08-05 14:19:41.834 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:19:41.834 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:19:41.834 DTC Client socket (3) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:41.834 DTC Client socket (2) | CloseSocket call. | 2022-08-05 14:19:41.834 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:19:41.834 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-08-05 14:19:41.834 DTC Client socket (2) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:41.834 DTC Client socket (1) | CloseSocket call. | 2022-08-05 14:19:41.834 DTC Client socket (1) | Max send buffers used during socket life: 3 | 2022-08-05 14:19:41.834 DTC Client socket (1) | Max send buffer size during socket life: 354 | 2022-08-05 14:19:41.834 SC DTC Data with Market Depth | Disconnected from the server. | 2022-08-05 14:19:41.834 Teton CME Order Routing | Disconnected. | 2022-08-05 14:19:41.834 DTC Client socket (1) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:41.834 DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-08-05 14:19:41.890 DTC Client socket (4) | Closed. | 2022-08-05 14:19:41.890 Teton CME Order Routing | Firm: Dorman | 2022-08-05 14:19:44.987 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-08-05 14:19:44.987 DTC Client socket (4) | Creating socket. Using TLS 1.2. | 2022-08-05 14:19:44.987 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:19:44.987 DTC Client socket (4) | Connecting to IP: 208.185.224.129. | 2022-08-05 14:19:44.987 Teton CME Order Routing | Network connection to server complete. | 2022-08-05 14:19:45.050 Teton CME Order Routing | Starting socket receive thread. | 2022-08-05 14:19:45.050 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-08-05 14:19:45.050 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:45.254 Teton CME Order Routing | Sending logon request message. | 2022-08-05 14:19:45.254 Teton CME Order Routing | Received logon response. | 2022-08-05 14:19:45.794 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-08-05 14:19:45.794 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:19:45.794 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-08-05 14:19:45.794 Teton CME Order Routing | Trading is supported. | 2022-08-05 14:19:45.794 Teton CME Order Routing | Order cancel and replace is supported. | 2022-08-05 14:19:45.794 Teton CME Order Routing | OCO Orders supported. | 2022-08-05 14:19:45.794 Teton CME Order Routing | Bracket Orders supported. | 2022-08-05 14:19:45.794 Teton CME Order Routing | Connected to server complete. | 2022-08-05 14:19:45.794 Triggering next historical data download in queue. | 2022-08-05 14:19:45.794 Triggering next historical data download in queue. | 2022-08-05 14:19:45.794 Triggering next historical data download in queue. | 2022-08-05 14:19:45.794 Triggering next historical data download in queue. | 2022-08-05 14:19:45.794 Updated verified funded futures trading account ending date to: 2022-09-04 14:19:45 | 2022-08-05 14:19:45.794 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-08-05 14:19:45.806 No download requests in the queue to start downloads for. | 2022-08-05 14:19:45.807 No download requests in the queue to start downloads for. | 2022-08-05 14:19:45.807 No download requests in the queue to start downloads for. | 2022-08-05 14:19:45.807 No download requests in the queue to start downloads for. | 2022-08-05 14:19:45.807 Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data | 2022-08-05 14:19:45.808 Using symbol data fast lookup vector | 2022-08-05 14:19:45.808 SC Data - All Services | Starting real-time market data updates for: AAPL-NQTV (AAPL-NQTV). ID: 1 Service code: nasdaq_exchange.data | 2022-08-05 14:19:45.808 SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 10048 | 2022-08-05 14:19:45.808 SC Data - All Services | Requesting security definition data for: AAPL-NQTV (AAPL-NQTV). ID: 1 | 2022-08-05 14:19:45.808 Added historical Intraday data request for AAPL-NQTV to the queue. | 2022-08-05 14:19:45.808 Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'. | 2022-08-05 14:19:45.808 Triggering next historical data download in queue. | 2022-08-05 14:19:45.808 Delaying start of download for AAPL-NQTV. | 2022-08-05 14:19:45.808 Using Bid/Ask average for last trade price for XAUUSD | 2022-08-05 14:19:45.808 SC DTC Data with Market Depth | Starting real-time market data updates for: XAUUSD. ID: 2 Service code: fxcm | 2022-08-05 14:19:45.808 SC DTC Data with Market Depth | Connecting to the server ds13-3.sierracharts.com. Port 10048 | 2022-08-05 14:19:45.808 DTC Client socket (5) | Creating socket. | 2022-08-05 14:19:45.808 SC DTC Data with Market Depth | Requesting security definition data for: XAUUSD. ID: 2 | 2022-08-05 14:19:45.808 DTC Client socket (5) | New receive buffer size: 5242880 | 2022-08-05 14:19:45.808 DTC Client socket (5) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:19:45.808 Teton CME Order Routing | Starting real-time market data updates for: TSLA. ID: 3 Service code: equities.us | 2022-08-05 14:19:45.808 Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: TSLA | 2022-08-05 14:19:45.808 Teton CME Order Routing | Requesting security definition data for: TSLA. ID: 3 | 2022-08-05 14:19:45.808 Added historical Intraday data request for TSLA to the queue. | 2022-08-05 14:19:45.808 Intraday data recording state for symbol TSLA is set to download 'Pending'. | 2022-08-05 14:19:45.808 Triggering next historical data download in queue. | 2022-08-05 14:19:45.808 DTC Client socket (6) | Creating socket. | 2022-08-05 14:19:45.808 DTC Client socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:19:45.808 DTC Client socket (6) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:19:45.808 Using Bid/Ask average for last trade price for US30 | 2022-08-05 14:19:45.809 SC DTC Data with Market Depth | Starting real-time market data updates for: US30. ID: 4 Service code: fxcm | 2022-08-05 14:19:45.809 SC DTC Data with Market Depth | Requesting security definition data for: US30. ID: 4 | 2022-08-05 14:19:45.809 Added historical Intraday data request for US30 to the queue. | 2022-08-05 14:19:45.809 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 14:19:45.809 Triggering next historical data download in queue. | 2022-08-05 14:19:45.809 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 00:00:00.000000 | 2022-08-05 14:19:45.818 Using Bid/Ask average for last trade price for SPX500 | 2022-08-05 14:19:45.839 SC DTC Data with Market Depth | Starting real-time market data updates for: SPX500. ID: 5 Service code: fxcm | 2022-08-05 14:19:45.839 SC DTC Data with Market Depth | Requesting security definition data for: SPX500. ID: 5 | 2022-08-05 14:19:45.839 Teton CME Order Routing | Starting real-time market data updates for: SPY. ID: 6 Service code: equities.us | 2022-08-05 14:19:45.839 Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: SPY | 2022-08-05 14:19:45.839 Teton CME Order Routing | Requesting security definition data for: SPY. ID: 6 | 2022-08-05 14:19:45.839 Added historical Intraday data request for SPY to the queue. | 2022-08-05 14:19:45.839 Intraday data recording state for symbol SPY is set to download 'Pending'. | 2022-08-05 14:19:45.839 Triggering next historical data download in queue. | 2022-08-05 14:19:45.839 Teton CME Order Routing | Starting real-time market data updates for: ESU22-CME. ID: 7 | 2022-08-05 14:19:45.839 Teton CME Order Routing | Subscribing to streaming market data in the service client is not supported. Symbol: ESU22-CME | 2022-08-05 14:19:45.839 Teton CME Order Routing | Requesting security definition data for: ESU22-CME. ID: 7 | 2022-08-05 14:19:45.839 No historical data client is currently set to download historical Intraday data for ESU22-CME. | 2022-08-05 14:19:45.839 Real-time Intraday chart data file updates started for ESU22-CME | 2022-08-05 14:19:45.839 Opened cached Intraday file: C:\SierraChart\Data\ESU22-CME.scid. Thread ID: 15072 | 2022-08-05 14:19:45.840 Intraday chart data file opened for ESU22-CME | 2022-08-05 14:19:45.840 Using Bid/Ask average for last trade price for USOil | 2022-08-05 14:19:45.840 SC DTC Data with Market Depth | Starting real-time market data updates for: USOil. ID: 8 Service code: fxcm | 2022-08-05 14:19:45.840 SC DTC Data with Market Depth | Requesting security definition data for: USOil. ID: 8 | 2022-08-05 14:19:45.840 Added historical Intraday data request for USOil to the queue. | 2022-08-05 14:19:45.840 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2022-08-05 14:19:45.840 Triggering next historical data download in queue. | 2022-08-05 14:19:45.840 Updated verified funded futures trading account ending date to: 2022-09-04 14:19:45 | 2022-08-05 14:19:45.868 Using Bid/Ask average for last trade price for EURUSD | 2022-08-05 14:19:45.871 SC DTC Data with Market Depth | Starting real-time market data updates for: EURUSD. ID: 9 Service code: fxcm | 2022-08-05 14:19:45.871 SC DTC Data with Market Depth | Requesting security definition data for: EURUSD. ID: 9 | 2022-08-05 14:19:45.871 SC DTC Data with Market Depth | Network connection to server complete. | 2022-08-05 14:19:45.872 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-08-05 14:19:45.872 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:19:45.872 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:19:45.873 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:19:45.873 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-08-05 14:19:45.873 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: AAPL-NQTV | 2022-08-05 14:19:45.876 Teton CME Order Routing | Received security definition for symbol AAPL-NQTV | 2022-08-05 14:19:45.876 Teton CME Order Routing | Received security definition for symbol TSLA | 2022-08-05 14:19:45.877 Added historical Intraday data request for EURUSD to the queue. | 2022-08-05 14:19:45.903 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2022-08-05 14:19:45.903 Triggering next historical data download in queue. | 2022-08-05 14:19:45.903 Teton CME Order Routing | Received security definition for symbol SPY | 2022-08-05 14:19:45.938 Teton CME Order Routing | Received security definition for symbol ESU22-CME | 2022-08-05 14:19:45.938 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43878 | 2022-08-05 14:19:45.942 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:45.950 SC Data - All Services | Sending logon request message. | 2022-08-05 14:19:45.950 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:45.971 SC DTC Data with Market Depth | Sending logon request message. | 2022-08-05 14:19:45.971 Mapping MESU22_FUT_CME to MESU22. Service code: cme | 2022-08-05 14:19:46.217 SC Data - All Services | Starting real-time market data updates for: MESU22_FUT_CME (MESU22). ID: 10 Service code: cme | 2022-08-05 14:19:46.217 SC Data - All Services | Connecting to the server ds27.sierracharts.com. Port 443 | 2022-08-05 14:19:46.217 SC Data - All Services | Requesting security definition data for: MESU22_FUT_CME (MESU22). ID: 10 | 2022-08-05 14:19:46.217 Added historical Intraday data request for MESU22_FUT_CME to the queue. | 2022-08-05 14:19:46.217 Intraday data recording state for symbol MESU22_FUT_CME is set to download 'Pending'. | 2022-08-05 14:19:46.217 Triggering next historical data download in queue. | 2022-08-05 14:19:46.217 DTC Client socket (7) | Creating socket. | 2022-08-05 14:19:46.266 DTC Client socket (7) | New receive buffer size: 5242880 | 2022-08-05 14:19:46.266 DTC Client socket (7) | Connecting to IP: 208.185.224.128. | 2022-08-05 14:19:46.266 Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: MESU22_FUT_CME | 2022-08-05 14:19:46.303 Teton CME Order Routing | Received security definition for symbol MESU22_FUT_CME | 2022-08-05 14:19:46.303 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 14:19:46.305 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 14:19:46.305 Triggering next historical data download in queue. | 2022-08-05 14:19:46.305 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:19:46.322 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:19:46.322 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:19:46.322 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:46.403 SC Data - All Services | Sending logon request message. | 2022-08-05 14:19:46.403 SC Data - All Services | Received logon response. | 2022-08-05 14:19:46.637 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:19:46.637 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:19:46.637 SC Data - All Services | Successfully connected. | 2022-08-05 14:19:46.637 SC Data - All Services | Trading is not supported. | 2022-08-05 14:19:46.637 SC Data - All Services | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2022-08-05 14:19:46.637 SC DTC Data with Market Depth | Received logon response. | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Successfully connected. | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Trading is not supported. | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2022-08-05 14:19:46.751 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-08-05 14:19:46.751 SC Data - All Services | Received security definition for symbol AAPL-NQTV | 2022-08-05 14:19:46.793 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2022-08-05 14:19:46.908 SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-08-05 14:19:46.908 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2022-08-05 14:19:46.908 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2022-08-05 14:19:46.908 SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-08-05 14:19:46.908 SC Data - All Services | Received logon response. | 2022-08-05 14:19:47.122 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:19:47.122 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:19:47.122 SC Data - All Services | Successfully connected. | 2022-08-05 14:19:47.122 SC Data - All Services | Trading is not supported. | 2022-08-05 14:19:47.122 SC Data - All Services | Restarting real-time data updates for symbol: MESU22_FUT_CME -> MESU22 | 2022-08-05 14:19:47.122 SC Data - All Services | Received security definition for symbol MESU22_FUT_CME | 2022-08-05 14:19:47.282 HD Request # 28 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data | 2022-08-05 14:19:51.934 HD Request # 28 | Download start date-time: 2022-08-05 14:16:55.000000. File last date-time: 2022-08-05 14:16:55.089000 | 2022-08-05 14:19:51.935 HD Request # 28 | Using server: ds25.sierracharts.com port 10150 | 2022-08-05 14:19:51.935 Socket (8) | Creating socket. | 2022-08-05 14:19:51.935 Socket (8) | New receive buffer size: 5242880 | 2022-08-05 14:19:51.935 Socket (8) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:19:51.935 HD Request # 28 | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:52.068 HD Request # 28 | Sending historical data logon request message. | 2022-08-05 14:19:52.068 HD Request # 28 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:55. Record interval: 1. Symbol: AAPL-NQTV | 2022-08-05 14:19:52.599 HD Request # 28 | Decompressing data. | 2022-08-05 14:19:52.665 HD Request # 28 | Receiving Intraday data for AAPL-NQTV starting at 2022-08-05 14:16:55.089000 | 2022-08-05 14:19:52.666 Socket (8) | CloseSocket call. | 2022-08-05 14:19:52.666 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:52.666 Historical data download thread signaled to stop. | 2022-08-05 14:19:52.666 HD Request # 28 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:55.089000. | 2022-08-05 14:19:52.666 HD Request # 28 | Received 145 Intraday data records from 2022-08-05 14:16:55.089000 to 2022-08-05 14:19:48.139000 (2.9 minutes) and wrote 145 records for AAPL-NQTV | 2022-08-05 14:19:52.666 HD Request # 28 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:19:48.139000 | 2022-08-05 14:19:52.670 Added 3 Time and Sales records to Intraday data file for AAPL-NQTV after download. | 2022-08-05 14:19:52.670 HD Request # 28 | Completion time: 1s. | 2022-08-05 14:19:52.670 HD Request # 28 | Intraday data download complete for AAPL-NQTV. Unique request ID: 28 | 2022-08-05 14:19:52.670 Removing historical data download ID 28. | 2022-08-05 14:19:52.670 Real-time Intraday chart data file updates started for AAPL-NQTV | 2022-08-05 14:19:52.670 Opened cached Intraday file: C:\SierraChart\Data\AAPL-NQTV.scid. Thread ID: 15072 | 2022-08-05 14:19:52.674 Intraday chart data file opened for AAPL-NQTV | 2022-08-05 14:19:52.674 HD Request # 28 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:19:52.674 Triggering next historical data download in queue. | 2022-08-05 14:19:52.674 HD Request # 29 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2022-08-05 14:19:52.674 HD Request # 29 | Download start date-time: 2022-08-05 13:55:59.000000. File last date-time: 2022-08-05 13:55:59.122000 | 2022-08-05 14:19:52.674 HD Request # 29 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2022-08-05 14:19:52.674 Socket (9) | Creating socket. | 2022-08-05 14:19:52.674 Socket (9) | New receive buffer size: 5242880 | 2022-08-05 14:19:52.674 Socket (9) | Connecting to IP: 8.18.161.133. | 2022-08-05 14:19:52.674 Socket (8) | Socket gracefully closed by remote side. | 2022-08-05 14:19:52.734 Socket (8) | Closed. | 2022-08-05 14:19:52.734 HD Request # 29 | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:52.798 HD Request # 29 | Sending historical data logon request message. | 2022-08-05 14:19:52.798 HD Request # 29 | Requesting Intraday data. Start date-time: 2022-08-05 13:55:59. Record interval: 1. Symbol: TSLA | 2022-08-05 14:19:53.306 HD Request # 29 | Decompressing data. | 2022-08-05 14:19:53.377 HD Request # 29 | Receiving Intraday data for TSLA starting at 2022-08-05 13:55:59.122000 | 2022-08-05 14:19:53.440 Socket (9) | CloseSocket call. | 2022-08-05 14:19:53.441 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:53.441 Historical data download thread signaled to stop. | 2022-08-05 14:19:53.441 HD Request # 29 | Timestamp of first Intraday data file record written: 2022-08-05 13:55:59.122000. | 2022-08-05 14:19:53.441 HD Request # 29 | Received 503 Intraday data records from 2022-08-05 13:55:59.122000 to 2022-08-05 14:04:51.222000 (8.9 minutes) and wrote 503 records for TSLA | 2022-08-05 14:19:53.441 HD Request # 29 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:04:51.222000 | 2022-08-05 14:19:53.446 HD Request # 29 | Completion time: 1s. | 2022-08-05 14:19:53.446 HD Request # 29 | Intraday data download complete for TSLA. Unique request ID: 29 | 2022-08-05 14:19:53.446 Removing historical data download ID 29. | 2022-08-05 14:19:53.446 Real-time Intraday chart data file updates started for TSLA | 2022-08-05 14:19:53.446 Opened cached Intraday file: C:\SierraChart\Data\TSLA.scid. Thread ID: 15072 | 2022-08-05 14:19:53.446 Intraday chart data file opened for TSLA | 2022-08-05 14:19:53.446 HD Request # 29 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:19:53.446 Triggering next historical data download in queue. | 2022-08-05 14:19:53.446 HD Request # 30 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 14:19:53.446 HD Request # 30 | Download start date-time: 2022-08-05 14:19:41.000000. File last date-time: 2022-08-05 14:19:41.000000 | 2022-08-05 14:19:53.446 HD Request # 30 | Using server: ds4.sierracharts.com port 10150 | 2022-08-05 14:19:53.446 Socket (8) | Creating socket. | 2022-08-05 14:19:53.447 Socket (8) | New receive buffer size: 5242880 | 2022-08-05 14:19:53.447 Socket (8) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:19:53.447 Socket (9) | Socket gracefully closed by remote side. | 2022-08-05 14:19:53.501 Socket (9) | Closed. | 2022-08-05 14:19:53.501 HD Request # 30 | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:53.581 HD Request # 30 | Sending historical data logon request message. | 2022-08-05 14:19:53.581 HD Request # 30 | Requesting Intraday data. Start date-time: 2022-08-05 14:19:41. Record interval: 1. Symbol: US30 | 2022-08-05 14:19:54.157 HD Request # 30 | Decompressing data. | 2022-08-05 14:19:54.218 HD Request # 30 | Receiving Intraday data for US30 starting at 2022-08-05 14:19:41.067000 | 2022-08-05 14:19:54.218 Socket (8) | CloseSocket call. | 2022-08-05 14:19:54.218 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:54.218 Socket (8) | Socket gracefully closed by remote side. | 2022-08-05 14:19:54.283 Socket (8) | Closed. | 2022-08-05 14:19:54.283 Historical data download thread signaled to stop. | 2022-08-05 14:19:54.302 HD Request # 30 | Timestamp of first Intraday data file record written: 2022-08-05 14:19:41.067000. | 2022-08-05 14:19:54.302 HD Request # 30 | Received 12 Intraday data records from 2022-08-05 14:19:41.067000 to 2022-08-05 14:19:52.162000 (11.1 seconds) and wrote 12 records for US30 | 2022-08-05 14:19:54.302 HD Request # 30 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:19:52.162000 | 2022-08-05 14:19:54.306 HD Request # 30 | Completion time: 1s. | 2022-08-05 14:19:54.306 HD Request # 30 | Intraday data download complete for US30. Unique request ID: 30 | 2022-08-05 14:19:54.306 Removing historical data download ID 30. | 2022-08-05 14:19:54.306 Real-time Intraday chart data file updates started for US30 | 2022-08-05 14:19:54.306 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 14:19:54.307 Intraday chart data file opened for US30 | 2022-08-05 14:19:54.307 HD Request # 30 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:19:54.307 Triggering next historical data download in queue. | 2022-08-05 14:19:54.307 HD Request # 31 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: equities.us | 2022-08-05 14:19:54.307 HD Request # 31 | Download start date-time: 2022-08-05 13:56:00.000000. File last date-time: 2022-08-05 13:56:00.014000 | 2022-08-05 14:19:54.307 HD Request # 31 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2022-08-05 14:19:54.307 Socket (8) | Creating socket. | 2022-08-05 14:19:54.307 Socket (8) | New receive buffer size: 5242880 | 2022-08-05 14:19:54.307 Socket (8) | Connecting to IP: 8.18.161.135. | 2022-08-05 14:19:54.307 HD Request # 31 | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:54.420 HD Request # 31 | Sending historical data logon request message. | 2022-08-05 14:19:54.420 HD Request # 31 | Requesting Intraday data. Start date-time: 2022-08-05 13:56:00. Record interval: 1. Symbol: SPY | 2022-08-05 14:19:54.926 HD Request # 31 | Decompressing data. | 2022-08-05 14:19:54.995 HD Request # 31 | Receiving Intraday data for SPY starting at 2022-08-05 13:56:00.014000 | 2022-08-05 14:19:55.054 Socket (8) | CloseSocket call. | 2022-08-05 14:19:55.055 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:55.055 Historical data download thread signaled to stop. | 2022-08-05 14:19:55.055 HD Request # 31 | Timestamp of first Intraday data file record written: 2022-08-05 13:56:00.014000. | 2022-08-05 14:19:55.055 HD Request # 31 | Received 526 Intraday data records from 2022-08-05 13:56:00.014000 to 2022-08-05 14:04:54.210000 (8.9 minutes) and wrote 526 records for SPY | 2022-08-05 14:19:55.055 HD Request # 31 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:04:54.210000 | 2022-08-05 14:19:55.060 HD Request # 31 | Completion time: 1s. | 2022-08-05 14:19:55.060 HD Request # 31 | Intraday data download complete for SPY. Unique request ID: 31 | 2022-08-05 14:19:55.060 Removing historical data download ID 31. | 2022-08-05 14:19:55.060 Real-time Intraday chart data file updates started for SPY | 2022-08-05 14:19:55.060 Opened cached Intraday file: C:\SierraChart\Data\SPY.scid. Thread ID: 15072 | 2022-08-05 14:19:55.060 Intraday chart data file opened for SPY | 2022-08-05 14:19:55.060 HD Request # 31 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:19:55.060 Triggering next historical data download in queue. | 2022-08-05 14:19:55.060 HD Request # 32 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2022-08-05 14:19:55.060 HD Request # 32 | Download start date-time: 2022-08-05 14:19:41.000000. File last date-time: 2022-08-05 14:19:41.000000 | 2022-08-05 14:19:55.060 HD Request # 32 | Using server: ds12.sierracharts.com port 10150 | 2022-08-05 14:19:55.060 Socket (9) | Creating socket. | 2022-08-05 14:19:55.060 Socket (9) | New receive buffer size: 5242880 | 2022-08-05 14:19:55.060 Socket (9) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:19:55.060 Socket (8) | Socket gracefully closed by remote side. | 2022-08-05 14:19:55.115 Socket (8) | Closed. | 2022-08-05 14:19:55.115 HD Request # 32 | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:55.211 HD Request # 32 | Sending historical data logon request message. | 2022-08-05 14:19:55.211 HD Request # 32 | Requesting Intraday data. Start date-time: 2022-08-05 14:19:41. Record interval: 1. Symbol: USOil | 2022-08-05 14:19:55.806 HD Request # 32 | Decompressing data. | 2022-08-05 14:19:55.874 HD Request # 32 | Receiving Intraday data for USOil starting at 2022-08-05 14:19:41.911000 | 2022-08-05 14:19:55.876 Socket (9) | CloseSocket call. | 2022-08-05 14:19:55.877 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:55.877 Historical data download thread signaled to stop. | 2022-08-05 14:19:55.877 HD Request # 32 | Timestamp of first Intraday data file record written: 2022-08-05 14:19:41.911000. | 2022-08-05 14:19:55.877 HD Request # 32 | Received 13 Intraday data records from 2022-08-05 14:19:41.911000 to 2022-08-05 14:19:55.228000 (13.3 seconds) and wrote 13 records for USOil | 2022-08-05 14:19:55.877 HD Request # 32 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:19:55.228000 | 2022-08-05 14:19:55.881 HD Request # 32 | Completion time: 0s. | 2022-08-05 14:19:55.881 HD Request # 32 | Intraday data download complete for USOil. Unique request ID: 32 | 2022-08-05 14:19:55.881 Removing historical data download ID 32. | 2022-08-05 14:19:55.881 Real-time Intraday chart data file updates started for USOil | 2022-08-05 14:19:55.881 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 15072 | 2022-08-05 14:19:55.881 Intraday chart data file opened for USOil | 2022-08-05 14:19:55.881 HD Request # 32 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:19:55.881 Triggering next historical data download in queue. | 2022-08-05 14:19:55.881 HD Request # 33 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2022-08-05 14:19:55.881 HD Request # 33 | Download start date-time: 2022-08-05 14:16:54.000000. File last date-time: 2022-08-05 14:16:54.028000 | 2022-08-05 14:19:55.881 HD Request # 33 | Using server: ds13-3.sierracharts.com port 10149 | 2022-08-05 14:19:55.881 Socket (8) | Creating socket. | 2022-08-05 14:19:55.881 Socket (8) | New receive buffer size: 5242880 | 2022-08-05 14:19:55.881 Socket (8) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:19:55.881 Socket (9) | Socket gracefully closed by remote side. | 2022-08-05 14:19:55.951 Socket (9) | Closed. | 2022-08-05 14:19:55.951 HD Request # 33 | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:56.035 HD Request # 33 | Sending historical data logon request message. | 2022-08-05 14:19:56.035 HD Request # 33 | Requesting Intraday data. Start date-time: 2022-08-05 14:16:54. Record interval: 1. Symbol: EURUSD | 2022-08-05 14:19:56.735 HD Request # 33 | Decompressing data. | 2022-08-05 14:19:56.802 HD Request # 33 | Receiving Intraday data for EURUSD starting at 2022-08-05 14:16:54.000000 | 2022-08-05 14:19:56.804 Socket (8) | CloseSocket call. | 2022-08-05 14:19:56.804 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:56.804 Historical data download thread signaled to stop. | 2022-08-05 14:19:56.804 HD Request # 33 | Timestamp of first Intraday data file record written: 2022-08-05 14:16:55.026000. | 2022-08-05 14:19:56.804 HD Request # 33 | Received 176 Intraday data records from 2022-08-05 14:16:54.000000 to 2022-08-05 14:19:55.022000 (3.0 minutes) and wrote 175 records for EURUSD | 2022-08-05 14:19:56.804 HD Request # 33 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:19:55.022000 | 2022-08-05 14:19:56.809 Added 1 Time and Sales records to Intraday data file for EURUSD after download. | 2022-08-05 14:19:56.809 HD Request # 33 | Completion time: 1s. | 2022-08-05 14:19:56.809 HD Request # 33 | Intraday data download complete for EURUSD. Unique request ID: 33 | 2022-08-05 14:19:56.809 Removing historical data download ID 33. | 2022-08-05 14:19:56.809 Real-time Intraday chart data file updates started for EURUSD | 2022-08-05 14:19:56.809 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 15072 | 2022-08-05 14:19:56.812 Intraday chart data file opened for EURUSD | 2022-08-05 14:19:56.812 HD Request # 33 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:19:56.812 Triggering next historical data download in queue. | 2022-08-05 14:19:56.812 HD Request # 34 | Downloading Intraday chart data for MESU22_FUT_CME to the file MESU22_FUT_CME.scid. Service: cme | 2022-08-05 14:19:56.813 HD Request # 34 | Download start date-time: 2022-08-05 14:17:52.000000. File last date-time: 2022-08-05 14:17:52.000000 | 2022-08-05 14:19:56.813 HD Request # 34 | Using server: ds23.sierracharts.com port 10150 | 2022-08-05 14:19:56.813 Socket (9) | Creating socket. | 2022-08-05 14:19:56.813 Socket (9) | New receive buffer size: 5242880 | 2022-08-05 14:19:56.813 Socket (9) | Connecting to IP: 216.1.90.130. | 2022-08-05 14:19:56.813 Socket (8) | Socket gracefully closed by remote side. | 2022-08-05 14:19:56.868 Socket (8) | Closed. | 2022-08-05 14:19:56.868 HD Request # 34 | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:56.940 HD Request # 34 | Sending historical data logon request message. | 2022-08-05 14:19:56.940 HD Request # 34 | Requesting Intraday data. Start date-time: 2022-08-05 14:17:52. Record interval: 1. Symbol: MESU22 | 2022-08-05 14:19:57.495 HD Request # 34 | Decompressing data. | 2022-08-05 14:19:57.551 HD Request # 34 | Receiving Intraday data for MESU22_FUT_CME starting at 2022-08-05 14:17:52.226000 | 2022-08-05 14:19:57.556 Socket (9) | CloseSocket call. | 2022-08-05 14:19:57.556 Socket (9) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:57.556 Historical data download thread signaled to stop. | 2022-08-05 14:19:57.556 HD Request # 34 | Timestamp of first Intraday data file record written: 2022-08-05 14:17:52.226000. | 2022-08-05 14:19:57.556 HD Request # 34 | Received 126 Intraday data records from 2022-08-05 14:17:52.226000 to 2022-08-05 14:19:57.023000 (2.1 minutes) and wrote 126 records for MESU22_FUT_CME | 2022-08-05 14:19:57.556 HD Request # 34 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:19:57.023000 | 2022-08-05 14:19:57.561 HD Request # 34 | Completion time: 1s. | 2022-08-05 14:19:57.561 HD Request # 34 | Intraday data download complete for MESU22_FUT_CME. Unique request ID: 34 | 2022-08-05 14:19:57.561 Removing historical data download ID 34. | 2022-08-05 14:19:57.561 Real-time Intraday chart data file updates started for MESU22_FUT_CME | 2022-08-05 14:19:57.561 Opened cached Intraday file: C:\SierraChart\Data\MESU22_FUT_CME.scid. Thread ID: 15072 | 2022-08-05 14:19:57.561 Intraday chart data file opened for MESU22_FUT_CME | 2022-08-05 14:19:57.561 HD Request # 34 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:19:57.561 Triggering next historical data download in queue. | 2022-08-05 14:19:57.561 HD Request # 35 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 14:19:57.561 HD Request # 35 | Download start date-time: 2022-08-05 14:19:41.000000. File last date-time: 2022-08-05 14:19:41.000000 | 2022-08-05 14:19:57.561 HD Request # 35 | Using server: ds4.sierracharts.com port 10149 | 2022-08-05 14:19:57.561 Socket (8) | Creating socket. | 2022-08-05 14:19:57.561 Socket (8) | New receive buffer size: 5242880 | 2022-08-05 14:19:57.561 Socket (8) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:19:57.561 Socket (9) | Socket gracefully closed by remote side. | 2022-08-05 14:19:57.612 Socket (9) | Closed. | 2022-08-05 14:19:57.612 HD Request # 35 | Setting DTC encoding to Binary VLS | 2022-08-05 14:19:57.696 HD Request # 35 | Sending historical data logon request message. | 2022-08-05 14:19:57.696 HD Request # 35 | Requesting Intraday data. Start date-time: 2022-08-05 14:19:41. Record interval: 1. Symbol: XAUUSD | 2022-08-05 14:19:58.272 HD Request # 35 | Decompressing data. | 2022-08-05 14:19:58.340 HD Request # 35 | Receiving Intraday data for XAUUSD starting at 2022-08-05 14:19:41.385000 | 2022-08-05 14:19:58.340 Socket (8) | CloseSocket call. | 2022-08-05 14:19:58.341 Socket (8) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:19:58.341 Historical data download thread signaled to stop. | 2022-08-05 14:19:58.341 HD Request # 35 | Timestamp of first Intraday data file record written: 2022-08-05 14:19:41.385000. | 2022-08-05 14:19:58.341 HD Request # 35 | Received 16 Intraday data records from 2022-08-05 14:19:41.385000 to 2022-08-05 14:19:56.426000 (15.0 seconds) and wrote 16 records for XAUUSD | 2022-08-05 14:19:58.341 HD Request # 35 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:19:56.426000 | 2022-08-05 14:19:58.345 Added 2 Time and Sales records to Intraday data file for XAUUSD after download. | 2022-08-05 14:19:58.345 HD Request # 35 | Completion time: 1s. | 2022-08-05 14:19:58.345 HD Request # 35 | Intraday data download complete for XAUUSD. Unique request ID: 35 | 2022-08-05 14:19:58.345 Removing historical data download ID 35. | 2022-08-05 14:19:58.345 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-05 14:19:58.345 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 15072 | 2022-08-05 14:19:58.349 Intraday chart data file opened for XAUUSD | 2022-08-05 14:19:58.349 HD Request # 35 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:19:58.349 Triggering next historical data download in queue. | 2022-08-05 14:19:58.349 No download requests in the queue to start downloads for. | 2022-08-05 14:19:58.349 Socket (8) | Socket gracefully closed by remote side. | 2022-08-05 14:19:58.403 Socket (8) | Closed. | 2022-08-05 14:19:58.403 DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:20:00.776 * DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-08-05 14:20:00.776 DTC Client socket (3) | Closed. | 2022-08-05 14:20:00.776 DTC Client socket (1) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-08-05 14:22:06.352 DTC Client socket (1) | Closed. | 2022-08-05 14:22:06.352 DTC Client socket (2) | Timed out waiting for shutdown. Performing an immediate socket close. | 2022-08-05 14:22:06.352 DTC Client socket (2) | Closed. | 2022-08-05 14:22:06.352 DTC Client socket (1) | Deleting network socket now after delay. | 2022-08-05 14:22:36.352 DTC Client socket (2) | Deleting network socket now after delay. | 2022-08-05 14:22:36.352 DTC Client socket (7) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:23:41.769 * DTC Client socket (7) | Socket gracefully closed by remote side. | 2022-08-05 14:23:41.769 DTC Client socket (7) | CloseSocket call. | 2022-08-05 14:23:41.769 DTC Client socket (7) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:23:41.769 DTC Client socket (7) | Closed. | 2022-08-05 14:23:41.769 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:23:41.769 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:23:41.770 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:23:41.770 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:23:41.770 SC Data - All Services | Connecting to the server ds21.sierracharts.com. Port 443 | 2022-08-05 14:23:43.768 DTC Client socket (1) | Creating socket. | 2022-08-05 14:23:43.769 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-08-05 14:23:43.769 DTC Client socket (1) | Connecting to IP: 216.1.90.129. | 2022-08-05 14:23:43.769 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:23:43.823 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:23:43.823 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:23:43.823 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:23:43.889 SC Data - All Services | Sending logon request message. | 2022-08-05 14:23:43.889 SC Data - All Services | Received logon response. | 2022-08-05 14:23:44.612 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:23:44.612 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:23:44.612 SC Data - All Services | Successfully connected. | 2022-08-05 14:23:44.612 SC Data - All Services | Trading is not supported. | 2022-08-05 14:23:44.612 Added historical Intraday data request for MESU22_FUT_CME to the queue. | 2022-08-05 14:23:44.612 Intraday data recording state for symbol MESU22_FUT_CME is set to download 'Pending'. | 2022-08-05 14:23:44.612 Triggering next historical data download in queue. | 2022-08-05 14:23:44.612 SC Data - All Services | Restarting real-time data updates for symbol: MESU22_FUT_CME -> MESU22 | 2022-08-05 14:23:44.612 HD Request # 36 | Downloading Intraday chart data for MESU22_FUT_CME to the file MESU22_FUT_CME.scid. Service: cme | 2022-08-05 14:23:44.612 HD Request # 36 | Download start date-time: 2022-08-05 14:23:41.000000. File last date-time: 2022-08-05 14:23:41.000000 | 2022-08-05 14:23:44.616 HD Request # 36 | Using server: ds21.sierracharts.com port 10150 | 2022-08-05 14:23:44.617 Socket (2) | Creating socket. | 2022-08-05 14:23:44.617 Socket (2) | New receive buffer size: 5242880 | 2022-08-05 14:23:44.617 Socket (2) | Connecting to IP: 216.1.90.129. | 2022-08-05 14:23:44.617 HD Request # 36 | Setting DTC encoding to Binary VLS | 2022-08-05 14:23:44.732 HD Request # 36 | Sending historical data logon request message. | 2022-08-05 14:23:44.732 SC Data - All Services | Received security definition for symbol MESU22_FUT_CME | 2022-08-05 14:23:44.770 HD Request # 36 | Requesting Intraday data. Start date-time: 2022-08-05 14:23:41. Record interval: 1. Symbol: MESU22 | 2022-08-05 14:23:45.302 HD Request # 36 | Decompressing data. | 2022-08-05 14:23:45.356 HD Request # 36 | Receiving Intraday data for MESU22_FUT_CME starting at 2022-08-05 14:23:41.297000 | 2022-08-05 14:23:45.356 Socket (2) | CloseSocket call. | 2022-08-05 14:23:45.356 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:23:45.357 Historical data download thread signaled to stop. | 2022-08-05 14:23:45.357 HD Request # 36 | Timestamp of first Intraday data file record written: 2022-08-05 14:23:41.297000. | 2022-08-05 14:23:45.357 HD Request # 36 | Received 3 Intraday data records from 2022-08-05 14:23:41.297000 to 2022-08-05 14:23:43.049000 (1.8 seconds) and wrote 3 records for MESU22_FUT_CME | 2022-08-05 14:23:45.357 HD Request # 36 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:23:43.049000 | 2022-08-05 14:23:45.361 Added 1 Time and Sales records to Intraday data file for MESU22_FUT_CME after download. | 2022-08-05 14:23:45.361 HD Request # 36 | Completion time: 1s. | 2022-08-05 14:23:45.361 HD Request # 36 | Intraday data download complete for MESU22_FUT_CME. Unique request ID: 36 | 2022-08-05 14:23:45.361 Removing historical data download ID 36. | 2022-08-05 14:23:45.361 Real-time Intraday chart data file updates started for MESU22_FUT_CME | 2022-08-05 14:23:45.361 Opened cached Intraday file: C:\SierraChart\Data\MESU22_FUT_CME.scid. Thread ID: 15072 | 2022-08-05 14:23:45.364 Intraday chart data file opened for MESU22_FUT_CME | 2022-08-05 14:23:45.364 HD Request # 36 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:23:45.364 Triggering next historical data download in queue. | 2022-08-05 14:23:45.364 No download requests in the queue to start downloads for. | 2022-08-05 14:23:45.364 Socket (2) | Socket gracefully closed by remote side. | 2022-08-05 14:23:45.416 Socket (2) | Closed. | 2022-08-05 14:23:45.416 DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-08-05 14:24:05.780 DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:24:05.780 * DTC Client socket (4) | CloseSocket call. | 2022-08-05 14:24:05.780 DTC Client socket (4) | Max send buffers used during socket life: 3 | 2022-08-05 14:24:05.780 DTC Client socket (4) | Max send buffer size during socket life: 281 | 2022-08-05 14:24:05.780 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:24:05.780 Connection to the external service has been lost. | 2022-08-05 14:24:05.780 DTC Client socket (4) | Closed. | 2022-08-05 14:24:05.780 Teton CME Order Routing | Waiting for socket receive thread to end | 2022-08-05 14:24:05.795 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:24:05.795 Teton CME Order Routing | Disconnected. | 2022-08-05 14:24:05.795 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-08-05 14:24:05.795 Teton CME Order Routing | Firm: Dorman | 2022-08-05 14:24:07.803 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-08-05 14:24:07.803 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-08-05 14:24:07.853 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-08-05 14:24:07.854 DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2022-08-05 14:24:07.854 Teton CME Order Routing | Network connection to server complete. | 2022-08-05 14:24:07.915 Teton CME Order Routing | Starting socket receive thread. | 2022-08-05 14:24:07.915 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-08-05 14:24:07.915 DTC Client socket (5) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:24:08.081 * DTC Client socket (5) | Socket gracefully closed by remote side. | 2022-08-05 14:24:08.081 DTC Client socket (5) | CloseSocket call. | 2022-08-05 14:24:08.081 DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:24:08.081 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 14:24:08.081 DTC Client socket (5) | Closed. | 2022-08-05 14:24:08.081 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:24:08.082 SC Data - All Services | Disconnected from the server. | 2022-08-05 14:24:08.082 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:24:08.082 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-08-05 14:24:08.113 Teton CME Order Routing | Sending logon request message. | 2022-08-05 14:24:08.113 Teton CME Order Routing | Received logon response. | 2022-08-05 14:24:08.665 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-08-05 14:24:08.665 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:24:08.665 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-08-05 14:24:08.665 Teton CME Order Routing | Trading is supported. | 2022-08-05 14:24:08.665 Teton CME Order Routing | Order cancel and replace is supported. | 2022-08-05 14:24:08.665 Teton CME Order Routing | OCO Orders supported. | 2022-08-05 14:24:08.665 Teton CME Order Routing | Bracket Orders supported. | 2022-08-05 14:24:08.665 Teton CME Order Routing | Connected to server complete. | 2022-08-05 14:24:08.665 Triggering next historical data download in queue. | 2022-08-05 14:24:08.666 Triggering next historical data download in queue. | 2022-08-05 14:24:08.666 Triggering next historical data download in queue. | 2022-08-05 14:24:08.666 Triggering next historical data download in queue. | 2022-08-05 14:24:08.666 Updated verified funded futures trading account ending date to: 2022-09-04 14:24:08 | 2022-08-05 14:24:08.666 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-08-05 14:24:08.672 No download requests in the queue to start downloads for. | 2022-08-05 14:24:08.672 No download requests in the queue to start downloads for. | 2022-08-05 14:24:08.672 No download requests in the queue to start downloads for. | 2022-08-05 14:24:08.672 No download requests in the queue to start downloads for. | 2022-08-05 14:24:08.672 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 00:00:00.000000 | 2022-08-05 14:24:08.686 Updated verified funded futures trading account ending date to: 2022-09-04 14:24:08 | 2022-08-05 14:24:08.769 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43878 | 2022-08-05 14:24:08.769 SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 10048 | 2022-08-05 14:24:10.072 DTC Client socket (3) | Creating socket. | 2022-08-05 14:24:10.073 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-08-05 14:24:10.073 DTC Client socket (3) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:24:10.073 SC Data - All Services | Network connection to server complete. | 2022-08-05 14:24:10.151 SC Data - All Services | Starting socket receive thread. | 2022-08-05 14:24:10.151 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-08-05 14:24:10.151 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 14:24:10.271 SC Data - All Services | Sending logon request message. | 2022-08-05 14:24:10.271 DTC Client socket (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 14:24:10.444 * DTC Client socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:24:10.444 DTC Client socket (6) | CloseSocket call. | 2022-08-05 14:24:10.444 DTC Client socket (6) | Max send buffers used during socket life: 4 | 2022-08-05 14:24:10.444 DTC Client socket (6) | Max send buffer size during socket life: 354 | 2022-08-05 14:24:10.444 DTC Client socket (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 14:24:10.444 DTC Client socket (6) | Closed. | 2022-08-05 14:24:10.444 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-08-05 14:24:10.444 DTC Client socket (0) | CloseSocket call. | 2022-08-05 14:24:10.445 SC DTC Data with Market Depth | Disconnected from the server. | 2022-08-05 14:24:10.445 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 14:24:10.445 SC Data - All Services | Received logon response. | 2022-08-05 14:24:10.946 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 14:24:10.946 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:24:10.946 SC Data - All Services | Successfully connected. | 2022-08-05 14:24:10.946 SC Data - All Services | Trading is not supported. | 2022-08-05 14:24:10.946 Added historical Intraday data request for AAPL-NQTV to the queue. | 2022-08-05 14:24:10.946 Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'. | 2022-08-05 14:24:10.946 Triggering next historical data download in queue. | 2022-08-05 14:24:10.946 SC Data - All Services | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2022-08-05 14:24:10.946 HD Request # 37 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data | 2022-08-05 14:24:10.946 HD Request # 37 | Download start date-time: 2022-08-05 14:23:41.000000. File last date-time: 2022-08-05 14:23:41.000000 | 2022-08-05 14:24:10.950 HD Request # 37 | Using server: ds25.sierracharts.com port 10149 | 2022-08-05 14:24:10.950 Socket (4) | Creating socket. | 2022-08-05 14:24:10.950 Socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:24:10.950 Socket (4) | Connecting to IP: 38.65.8.115. | 2022-08-05 14:24:10.950 HD Request # 37 | Setting DTC encoding to Binary VLS | 2022-08-05 14:24:11.082 HD Request # 37 | Sending historical data logon request message. | 2022-08-05 14:24:11.082 SC Data - All Services | Received security definition for symbol AAPL-NQTV | 2022-08-05 14:24:11.101 HD Request # 37 | Requesting Intraday data. Start date-time: 2022-08-05 14:23:41. Record interval: 1. Symbol: AAPL-NQTV | 2022-08-05 14:24:11.582 HD Request # 37 | Decompressing data. | 2022-08-05 14:24:11.646 HD Request # 37 | Receiving Intraday data for AAPL-NQTV starting at 2022-08-05 14:23:41.110000 | 2022-08-05 14:24:11.646 Socket (4) | CloseSocket call. | 2022-08-05 14:24:11.646 Historical data download thread signaled to stop. | 2022-08-05 14:24:11.646 Socket (4) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:24:11.646 HD Request # 37 | Timestamp of first Intraday data file record written: 2022-08-05 14:23:41.110000. | 2022-08-05 14:24:11.646 HD Request # 37 | Received 23 Intraday data records from 2022-08-05 14:23:41.110000 to 2022-08-05 14:24:08.026000 (26.9 seconds) and wrote 23 records for AAPL-NQTV | 2022-08-05 14:24:11.647 HD Request # 37 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:24:08.026000 | 2022-08-05 14:24:11.650 HD Request # 37 | Completion time: 1s. | 2022-08-05 14:24:11.650 HD Request # 37 | Intraday data download complete for AAPL-NQTV. Unique request ID: 37 | 2022-08-05 14:24:11.650 Removing historical data download ID 37. | 2022-08-05 14:24:11.650 Real-time Intraday chart data file updates started for AAPL-NQTV | 2022-08-05 14:24:11.650 Opened cached Intraday file: C:\SierraChart\Data\AAPL-NQTV.scid. Thread ID: 15072 | 2022-08-05 14:24:11.651 Intraday chart data file opened for AAPL-NQTV | 2022-08-05 14:24:11.651 HD Request # 37 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:24:11.651 Triggering next historical data download in queue. | 2022-08-05 14:24:11.651 No download requests in the queue to start downloads for. | 2022-08-05 14:24:11.651 Socket (4) | Socket gracefully closed by remote side. | 2022-08-05 14:24:11.709 Socket (4) | Closed. | 2022-08-05 14:24:11.709 SC DTC Data with Market Depth | Connecting to the server ds4.sierracharts.com. Port 10048 | 2022-08-05 14:24:12.432 DTC Client socket (4) | Creating socket. | 2022-08-05 14:24:12.432 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-08-05 14:24:12.432 DTC Client socket (4) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:24:12.432 SC DTC Data with Market Depth | Network connection to server complete. | 2022-08-05 14:24:12.494 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-08-05 14:24:12.494 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 14:24:12.494 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-08-05 14:24:12.561 SC DTC Data with Market Depth | Sending logon request message. | 2022-08-05 14:24:12.561 SC DTC Data with Market Depth | Received logon response. | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Successfully connected. | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Trading is not supported. | 2022-08-05 14:24:13.264 Added historical Intraday data request for EURUSD to the queue. | 2022-08-05 14:24:13.264 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2022-08-05 14:24:13.264 Triggering next historical data download in queue. | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-08-05 14:24:13.264 Added historical Intraday data request for US30 to the queue. | 2022-08-05 14:24:13.264 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2022-08-05 14:24:13.264 Added historical Intraday data request for USOil to the queue. | 2022-08-05 14:24:13.264 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2022-08-05 14:24:13.264 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 14:24:13.264 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 14:24:13.264 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-08-05 14:24:13.264 HD Request # 38 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2022-08-05 14:24:13.264 HD Request # 38 | Download start date-time: 2022-08-05 14:23:41.000000. File last date-time: 2022-08-05 14:23:41.000000 | 2022-08-05 14:24:13.269 HD Request # 38 | Using server: ds12.sierracharts.com port 10150 | 2022-08-05 14:24:13.269 Socket (5) | Creating socket. | 2022-08-05 14:24:13.269 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 14:24:13.269 Socket (5) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:24:13.269 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2022-08-05 14:24:13.405 SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-08-05 14:24:13.405 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2022-08-05 14:24:13.405 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2022-08-05 14:24:13.405 HD Request # 38 | Setting DTC encoding to Binary VLS | 2022-08-05 14:24:13.411 HD Request # 38 | Sending historical data logon request message. | 2022-08-05 14:24:13.411 SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-08-05 14:24:13.501 HD Request # 38 | Requesting Intraday data. Start date-time: 2022-08-05 14:23:41. Record interval: 1. Symbol: EURUSD | 2022-08-05 14:24:14.002 HD Request # 38 | Decompressing data. | 2022-08-05 14:24:14.065 HD Request # 38 | Receiving Intraday data for EURUSD starting at 2022-08-05 14:23:41.430000 | 2022-08-05 14:24:14.067 Socket (5) | CloseSocket call. | 2022-08-05 14:24:14.067 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:24:14.067 Historical data download thread signaled to stop. | 2022-08-05 14:24:14.067 HD Request # 38 | Timestamp of first Intraday data file record written: 2022-08-05 14:23:41.430000. | 2022-08-05 14:24:14.067 HD Request # 38 | Received 32 Intraday data records from 2022-08-05 14:23:41.430000 to 2022-08-05 14:24:13.030000 (31.6 seconds) and wrote 32 records for EURUSD | 2022-08-05 14:24:14.067 HD Request # 38 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:24:13.030000 | 2022-08-05 14:24:14.071 Added 1 Time and Sales records to Intraday data file for EURUSD after download. | 2022-08-05 14:24:14.071 HD Request # 38 | Completion time: 1s. | 2022-08-05 14:24:14.071 HD Request # 38 | Intraday data download complete for EURUSD. Unique request ID: 38 | 2022-08-05 14:24:14.071 Removing historical data download ID 38. | 2022-08-05 14:24:14.071 Real-time Intraday chart data file updates started for EURUSD | 2022-08-05 14:24:14.071 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 15072 | 2022-08-05 14:24:14.075 Intraday chart data file opened for EURUSD | 2022-08-05 14:24:14.075 HD Request # 38 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:24:14.075 Triggering next historical data download in queue. | 2022-08-05 14:24:14.075 HD Request # 39 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 14:24:14.075 HD Request # 39 | Download start date-time: 2022-08-05 14:19:52.000000. File last date-time: 2022-08-05 14:19:52.162000 | 2022-08-05 14:24:14.075 HD Request # 39 | Using server: ds13-3.sierracharts.com port 10149 | 2022-08-05 14:24:14.075 Socket (6) | Creating socket. | 2022-08-05 14:24:14.076 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:24:14.076 Socket (6) | Connecting to IP: 162.251.232.235. | 2022-08-05 14:24:14.076 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 14:24:14.148 Socket (5) | Closed. | 2022-08-05 14:24:14.148 HD Request # 39 | Setting DTC encoding to Binary VLS | 2022-08-05 14:24:14.215 HD Request # 39 | Sending historical data logon request message. | 2022-08-05 14:24:14.215 HD Request # 39 | Requesting Intraday data. Start date-time: 2022-08-05 14:19:52. Record interval: 1. Symbol: US30 | 2022-08-05 14:24:14.908 HD Request # 39 | Decompressing data. | 2022-08-05 14:24:14.970 HD Request # 39 | Receiving Intraday data for US30 starting at 2022-06-07 14:04:01.627000 | 2022-08-05 14:24:15.113 Socket (6) | CloseSocket call. | 2022-08-05 14:24:15.113 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:24:15.113 Historical data download thread signaled to stop. | 2022-08-05 14:24:15.113 HD Request # 39 | Received 1510 Intraday data records from 2022-06-07 14:04:01.627000 to 2022-06-07 15:03:42.116000 (59.7 minutes) and wrote 0 records for US30 | 2022-08-05 14:24:15.114 HD Request # 39 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:19:52.162000 | 2022-08-05 14:24:15.114 Added 3 Time and Sales records to Intraday data file for US30 after download. | 2022-08-05 14:24:15.114 HD Request # 39 | Timestamp of first Intraday data file record written: 2022-08-05 14:24:13.609000. | 2022-08-05 14:24:15.114 HD Request # 39 | Completion time: 1s. | 2022-08-05 14:24:15.114 HD Request # 39 | Intraday data download complete for US30. Unique request ID: 39 | 2022-08-05 14:24:15.114 Removing historical data download ID 39. | 2022-08-05 14:24:15.114 Real-time Intraday chart data file updates started for US30 | 2022-08-05 14:24:15.114 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 14:24:15.118 Intraday chart data file opened for US30 | 2022-08-05 14:24:15.118 HD Request # 39 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:24:15.118 Triggering next historical data download in queue. | 2022-08-05 14:24:15.118 HD Request # 40 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2022-08-05 14:24:15.118 HD Request # 40 | Download start date-time: 2022-08-05 14:23:41.000000. File last date-time: 2022-08-05 14:23:41.000000 | 2022-08-05 14:24:15.119 HD Request # 40 | Using server: ds4.sierracharts.com port 10150 | 2022-08-05 14:24:15.119 Socket (5) | Creating socket. | 2022-08-05 14:24:15.119 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 14:24:15.119 Socket (5) | Connecting to IP: 192.81.56.146. | 2022-08-05 14:24:15.119 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:24:15.182 Socket (6) | Closed. | 2022-08-05 14:24:15.182 HD Request # 40 | Setting DTC encoding to Binary VLS | 2022-08-05 14:24:15.242 HD Request # 40 | Sending historical data logon request message. | 2022-08-05 14:24:15.242 HD Request # 40 | Requesting Intraday data. Start date-time: 2022-08-05 14:23:41. Record interval: 1. Symbol: USOil | 2022-08-05 14:24:15.830 HD Request # 40 | Decompressing data. | 2022-08-05 14:24:15.898 HD Request # 40 | Receiving Intraday data for USOil starting at 2022-08-05 14:23:41.109000 | 2022-08-05 14:24:15.898 Socket (5) | CloseSocket call. | 2022-08-05 14:24:15.899 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:24:15.899 Historical data download thread signaled to stop. | 2022-08-05 14:24:15.899 HD Request # 40 | Timestamp of first Intraday data file record written: 2022-08-05 14:23:41.109000. | 2022-08-05 14:24:15.899 HD Request # 40 | Received 31 Intraday data records from 2022-08-05 14:23:41.109000 to 2022-08-05 14:24:14.449000 (33.3 seconds) and wrote 31 records for USOil | 2022-08-05 14:24:15.899 HD Request # 40 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:24:14.449000 | 2022-08-05 14:24:15.903 Added 1 Time and Sales records to Intraday data file for USOil after download. | 2022-08-05 14:24:15.903 HD Request # 40 | Completion time: 0s. | 2022-08-05 14:24:15.903 HD Request # 40 | Intraday data download complete for USOil. Unique request ID: 40 | 2022-08-05 14:24:15.903 Removing historical data download ID 40. | 2022-08-05 14:24:15.903 Real-time Intraday chart data file updates started for USOil | 2022-08-05 14:24:15.903 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 15072 | 2022-08-05 14:24:15.907 Intraday chart data file opened for USOil | 2022-08-05 14:24:15.907 HD Request # 40 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:24:15.907 Triggering next historical data download in queue. | 2022-08-05 14:24:15.907 HD Request # 41 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 14:24:15.907 HD Request # 41 | Download start date-time: 2022-08-05 14:23:41.000000. File last date-time: 2022-08-05 14:23:41.000000 | 2022-08-05 14:24:15.907 HD Request # 41 | Using server: ds12.sierracharts.com port 10149 | 2022-08-05 14:24:15.907 Socket (6) | Creating socket. | 2022-08-05 14:24:15.907 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 14:24:15.907 Socket (6) | Connecting to IP: 204.15.197.14. | 2022-08-05 14:24:15.907 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 14:24:15.967 Socket (5) | Closed. | 2022-08-05 14:24:15.967 HD Request # 41 | Setting DTC encoding to Binary VLS | 2022-08-05 14:24:16.059 HD Request # 41 | Sending historical data logon request message. | 2022-08-05 14:24:16.059 HD Request # 41 | Requesting Intraday data. Start date-time: 2022-08-05 14:23:41. Record interval: 1. Symbol: XAUUSD | 2022-08-05 14:24:16.640 HD Request # 41 | Decompressing data. | 2022-08-05 14:24:16.700 HD Request # 41 | Receiving Intraday data for XAUUSD starting at 2022-08-05 14:23:41.003000 | 2022-08-05 14:24:16.700 Socket (6) | CloseSocket call. | 2022-08-05 14:24:16.701 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 14:24:16.701 Historical data download thread signaled to stop. | 2022-08-05 14:24:16.701 HD Request # 41 | Timestamp of first Intraday data file record written: 2022-08-05 14:23:41.003000. | 2022-08-05 14:24:16.701 HD Request # 41 | Received 34 Intraday data records from 2022-08-05 14:23:41.003000 to 2022-08-05 14:24:14.327000 (33.3 seconds) and wrote 34 records for XAUUSD | 2022-08-05 14:24:16.701 HD Request # 41 | Add time&sales data | Remembered last file record date-time: 2022-08-05 14:24:14.327000 | 2022-08-05 14:24:16.705 Added 1 Time and Sales records to Intraday data file for XAUUSD after download. | 2022-08-05 14:24:16.705 HD Request # 41 | Completion time: 1s. | 2022-08-05 14:24:16.705 HD Request # 41 | Intraday data download complete for XAUUSD. Unique request ID: 41 | 2022-08-05 14:24:16.705 Removing historical data download ID 41. | 2022-08-05 14:24:16.705 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-05 14:24:16.705 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 15072 | 2022-08-05 14:24:16.709 Intraday chart data file opened for XAUUSD | 2022-08-05 14:24:16.709 HD Request # 41 | Enabling Intraday chart updating for symbol. | 2022-08-05 14:24:16.709 Triggering next historical data download in queue. | 2022-08-05 14:24:16.709 No download requests in the queue to start downloads for. | 2022-08-05 14:24:16.709 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 14:24:16.766 Socket (6) | Closed. | 2022-08-05 14:24:16.766 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.087 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.087 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.421 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.421 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.429 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.429 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.437 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.437 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.445 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.445 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.453 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.453 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.461 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.461 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.469 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.469 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.477 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.477 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.485 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.485 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.493 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.493 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.501 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.501 Chart #2 | TPO Profile Chart ID: 0 DateTime: Out of bounds array error at Index 1884 | 2022-08-05 19:20:24.509 Array message repeat count limit reached. | 2022-08-05 19:20:24.509 Teton CME Order Routing | Market data feed reported to be lost. | 2022-08-05 22:10:07.238 DTC Client socket (1) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 22:16:54.502 * DTC Client socket (1) | Socket gracefully closed by remote side. | 2022-08-05 22:16:54.502 DTC Client socket (1) | CloseSocket call. | 2022-08-05 22:16:54.502 DTC Client socket (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 22:16:54.502 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 22:16:54.502 DTC Client socket (1) | Closed. | 2022-08-05 22:16:54.502 DTC Client socket (0) | CloseSocket call. | 2022-08-05 22:16:54.503 SC Data - All Services | Disconnected from the server. | 2022-08-05 22:16:54.503 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 22:16:54.503 SC Data - All Services | Connecting to the server ds22.sierracharts.com. Port 443 | 2022-08-05 22:16:56.494 DTC Client socket (1) | Creating socket. | 2022-08-05 22:16:56.545 DTC Client socket (1) | New receive buffer size: 5242880 | 2022-08-05 22:16:56.545 DTC Client socket (1) | Connecting to IP: 208.185.224.129. | 2022-08-05 22:16:56.545 SC Data - All Services | Network connection to server complete. | 2022-08-05 22:16:56.609 SC Data - All Services | Starting socket receive thread. | 2022-08-05 22:16:56.609 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 22:16:56.609 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 22:16:56.685 SC Data - All Services | Sending logon request message. | 2022-08-05 22:16:56.685 SC Data - All Services | Received logon response. | 2022-08-05 22:16:57.466 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 22:16:57.466 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 22:16:57.466 SC Data - All Services | Successfully connected. | 2022-08-05 22:16:57.466 SC Data - All Services | Trading is not supported. | 2022-08-05 22:16:57.466 Added historical Intraday data request for MESU22_FUT_CME to the queue. | 2022-08-05 22:16:57.466 Intraday data recording state for symbol MESU22_FUT_CME is set to download 'Pending'. | 2022-08-05 22:16:57.466 Triggering next historical data download in queue. | 2022-08-05 22:16:57.466 SC Data - All Services | Restarting real-time data updates for symbol: MESU22_FUT_CME -> MESU22 | 2022-08-05 22:16:57.466 HD Request # 42 | Downloading Intraday chart data for MESU22_FUT_CME to the file MESU22_FUT_CME.scid. Service: cme | 2022-08-05 22:16:57.466 HD Request # 42 | Download start date-time: 2022-08-05 20:59:59.000000. File last date-time: 2022-08-05 20:59:59.000000 | 2022-08-05 22:16:57.467 HD Request # 42 | Using server: ds23.sierracharts.com port 10150 | 2022-08-05 22:16:57.467 Socket (5) | Creating socket. | 2022-08-05 22:16:57.468 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 22:16:57.468 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-08-05 22:16:57.468 HD Request # 42 | Setting DTC encoding to Binary VLS | 2022-08-05 22:16:57.587 HD Request # 42 | Sending historical data logon request message. | 2022-08-05 22:16:57.587 SC Data - All Services | Received security definition for symbol MESU22_FUT_CME | 2022-08-05 22:16:57.622 HD Request # 42 | Requesting Intraday data. Start date-time: 2022-08-05 20:59:59. Record interval: 1. Symbol: MESU22 | 2022-08-05 22:16:58.164 HD Request # 42 | Decompressing data. | 2022-08-05 22:16:58.222 HD Request # 42 | Receiving Intraday data for MESU22_FUT_CME starting at 2022-08-05 20:59:59.073000 | 2022-08-05 22:16:58.223 Socket (5) | CloseSocket call. | 2022-08-05 22:16:58.223 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:16:58.223 Historical data download thread signaled to stop. | 2022-08-05 22:16:58.223 HD Request # 42 | Timestamp of first Intraday data file record written: 2022-08-05 20:59:59.073000. | 2022-08-05 22:16:58.223 HD Request # 42 | Received 1 Intraday data record from 2022-08-05 20:59:59.073000 to 2022-08-05 20:59:59.073000 (0.0 seconds) and wrote 1 record for MESU22_FUT_CME | 2022-08-05 22:16:58.223 HD Request # 42 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:59:59.073000 | 2022-08-05 22:16:58.228 HD Request # 42 | Completion time: 1s. | 2022-08-05 22:16:58.228 HD Request # 42 | Intraday data download complete for MESU22_FUT_CME. Unique request ID: 42 | 2022-08-05 22:16:58.228 Removing historical data download ID 42. | 2022-08-05 22:16:58.228 Real-time Intraday chart data file updates started for MESU22_FUT_CME | 2022-08-05 22:16:58.228 Opened cached Intraday file: C:\SierraChart\Data\MESU22_FUT_CME.scid. Thread ID: 15072 | 2022-08-05 22:16:58.228 Intraday chart data file opened for MESU22_FUT_CME | 2022-08-05 22:16:58.228 HD Request # 42 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:16:58.228 Triggering next historical data download in queue. | 2022-08-05 22:16:58.228 No download requests in the queue to start downloads for. | 2022-08-05 22:16:58.228 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 22:16:58.287 Socket (5) | Closed. | 2022-08-05 22:16:58.287 DTC Client socket (3) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 22:17:17.479 * DTC Client socket (3) | Socket gracefully closed by remote side. | 2022-08-05 22:17:17.479 DTC Client socket (3) | CloseSocket call. | 2022-08-05 22:17:17.479 DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 22:17:17.479 SC Data - All Services | Waiting for socket receive thread to end | 2022-08-05 22:17:17.479 DTC Client socket (3) | Closed. | 2022-08-05 22:17:17.479 DTC Client socket (0) | CloseSocket call. | 2022-08-05 22:17:17.479 SC Data - All Services | Disconnected from the server. | 2022-08-05 22:17:17.479 SC Data - All Services | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 22:17:17.480 SC Data - All Services | Connecting to the server ds25.sierracharts.com. Port 10048 | 2022-08-05 22:17:19.487 DTC Client socket (3) | Creating socket. | 2022-08-05 22:17:19.487 DTC Client socket (3) | New receive buffer size: 5242880 | 2022-08-05 22:17:19.487 DTC Client socket (3) | Connecting to IP: 38.65.8.115. | 2022-08-05 22:17:19.487 SC Data - All Services | Network connection to server complete. | 2022-08-05 22:17:19.551 SC Data - All Services | Starting socket receive thread. | 2022-08-05 22:17:19.551 SC Data - All Services | Sending encoding request to server: Binary VLS. Compression: high | 2022-08-05 22:17:19.551 SC Data - All Services | Setting DTC encoding to Binary VLS | 2022-08-05 22:17:19.619 SC Data - All Services | Sending logon request message. | 2022-08-05 22:17:19.619 DTC Client socket (2) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 22:17:19.811 * DTC Client socket (2) | Socket gracefully closed by remote side. | 2022-08-05 22:17:19.811 DTC Client socket (2) | CloseSocket call. | 2022-08-05 22:17:19.812 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 22:17:19.812 DTC Client socket (2) | Closed. | 2022-08-05 22:17:19.812 Connection to the external service has been lost. | 2022-08-05 22:17:19.812 Teton CME Order Routing | Waiting for socket receive thread to end | 2022-08-05 22:17:19.827 DTC Client socket (0) | CloseSocket call. | 2022-08-05 22:17:19.827 Teton CME Order Routing | Disconnected. | 2022-08-05 22:17:19.827 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2022-08-05 22:17:19.827 SC Data - All Services | Received logon response. | 2022-08-05 22:17:20.307 SC Data - All Services | Server Name: SC Realtime Server. | 2022-08-05 22:17:20.307 SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 22:17:20.307 SC Data - All Services | Successfully connected. | 2022-08-05 22:17:20.307 SC Data - All Services | Trading is not supported. | 2022-08-05 22:17:20.307 Added historical Intraday data request for AAPL-NQTV to the queue. | 2022-08-05 22:17:20.307 Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'. | 2022-08-05 22:17:20.307 Triggering next historical data download in queue. | 2022-08-05 22:17:20.307 SC Data - All Services | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV | 2022-08-05 22:17:20.307 HD Request # 43 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data | 2022-08-05 22:17:20.307 HD Request # 43 | Download start date-time: 2022-08-05 22:16:35.000000. File last date-time: 2022-08-05 22:16:35.000000 | 2022-08-05 22:17:20.311 HD Request # 43 | Using server: ds25.sierracharts.com port 10149 | 2022-08-05 22:17:20.311 Socket (2) | Creating socket. | 2022-08-05 22:17:20.311 Socket (2) | New receive buffer size: 5242880 | 2022-08-05 22:17:20.311 Socket (2) | Connecting to IP: 38.65.8.115. | 2022-08-05 22:17:20.311 HD Request # 43 | Setting DTC encoding to Binary VLS | 2022-08-05 22:17:20.436 HD Request # 43 | Sending historical data logon request message. | 2022-08-05 22:17:20.436 SC Data - All Services | Received security definition for symbol AAPL-NQTV | 2022-08-05 22:17:20.462 HD Request # 43 | Requesting Intraday data. Start date-time: 2022-08-05 22:16:35. Record interval: 1. Symbol: AAPL-NQTV | 2022-08-05 22:17:20.927 HD Request # 43 | Decompressing data. | 2022-08-05 22:17:20.987 HD Request # 43 | Receiving Intraday data for AAPL-NQTV starting at 2022-08-05 22:16:35.456000 | 2022-08-05 22:17:20.987 Socket (2) | CloseSocket call. | 2022-08-05 22:17:20.987 Socket (2) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:17:20.987 Historical data download thread signaled to stop. | 2022-08-05 22:17:20.987 HD Request # 43 | Timestamp of first Intraday data file record written: 2022-08-05 22:16:35.456000. | 2022-08-05 22:17:20.988 HD Request # 43 | Received 1 Intraday data record from 2022-08-05 22:16:35.456000 to 2022-08-05 22:16:35.456000 (0.0 seconds) and wrote 1 record for AAPL-NQTV | 2022-08-05 22:17:20.988 HD Request # 43 | Completion time: 0s. | 2022-08-05 22:17:20.988 HD Request # 43 | Intraday data download complete for AAPL-NQTV. Unique request ID: 43 | 2022-08-05 22:17:20.988 Removing historical data download ID 43. | 2022-08-05 22:17:20.988 HD Request # 43 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:17:20.988 Triggering next historical data download in queue. | 2022-08-05 22:17:20.988 Historical data for AAPL-NQTV is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2022-08-05 22:17:20.988 No download requests in the queue to start downloads for. | 2022-08-05 22:17:20.988 Socket (2) | Socket gracefully closed by remote side. | 2022-08-05 22:17:21.043 Socket (2) | Closed. | 2022-08-05 22:17:21.043 Teton CME Order Routing | Firm: Dorman | 2022-08-05 22:17:21.826 Teton CME Order Routing | Connecting to the server futurestrading10.sierracharts.com. Port 11091 | 2022-08-05 22:17:21.826 DTC Client socket (2) | Creating socket. Using TLS 1.2. | 2022-08-05 22:17:21.889 DTC Client socket (2) | New receive buffer size: 5242880 | 2022-08-05 22:17:21.889 DTC Client socket (2) | Connecting to IP: 208.185.224.129. | 2022-08-05 22:17:21.889 Teton CME Order Routing | Network connection to server complete. | 2022-08-05 22:17:21.944 Teton CME Order Routing | Starting socket receive thread. | 2022-08-05 22:17:21.944 Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none | 2022-08-05 22:17:21.945 Teton CME Order Routing | Setting DTC encoding to Binary VLS | 2022-08-05 22:17:22.123 Teton CME Order Routing | Sending logon request message. | 2022-08-05 22:17:22.123 Teton CME Order Routing | Received logon response. | 2022-08-05 22:17:22.648 Teton CME Order Routing | Server Name: SC DTC Server. Build=42789. | 2022-08-05 22:17:22.648 Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 22:17:22.648 Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink.trading|SymbolSettings=cme_ilink_live.trading. | 2022-08-05 22:17:22.648 Teton CME Order Routing | Trading is supported. | 2022-08-05 22:17:22.648 Teton CME Order Routing | Order cancel and replace is supported. | 2022-08-05 22:17:22.648 Teton CME Order Routing | OCO Orders supported. | 2022-08-05 22:17:22.648 Teton CME Order Routing | Bracket Orders supported. | 2022-08-05 22:17:22.648 Teton CME Order Routing | Connected to server complete. | 2022-08-05 22:17:22.648 Triggering next historical data download in queue. | 2022-08-05 22:17:22.648 Triggering next historical data download in queue. | 2022-08-05 22:17:22.648 Triggering next historical data download in queue. | 2022-08-05 22:17:22.648 Triggering next historical data download in queue. | 2022-08-05 22:17:22.648 Updated verified funded futures trading account ending date to: 2022-09-04 22:17:22 | 2022-08-05 22:17:22.648 Teton CME Order Routing | Performing query for most recent Order Activity Date-Time. | 2022-08-05 22:17:22.654 No download requests in the queue to start downloads for. | 2022-08-05 22:17:22.654 No download requests in the queue to start downloads for. | 2022-08-05 22:17:22.654 No download requests in the queue to start downloads for. | 2022-08-05 22:17:22.654 No download requests in the queue to start downloads for. | 2022-08-05 22:17:22.654 Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 00:00:00.000000 | 2022-08-05 22:17:22.666 Updated verified funded futures trading account ending date to: 2022-09-04 22:17:22 | 2022-08-05 22:17:22.716 Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=43878 | 2022-08-05 22:17:22.732 DTC Client socket (4) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2022-08-05 22:17:26.745 * DTC Client socket (4) | Socket gracefully closed by remote side. | 2022-08-05 22:17:26.745 DTC Client socket (4) | CloseSocket call. | 2022-08-05 22:17:26.746 DTC Client socket (4) | Max send buffers used during socket life: 3 | 2022-08-05 22:17:26.746 DTC Client socket (4) | Max send buffer size during socket life: 354 | 2022-08-05 22:17:26.746 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2022-08-05 22:17:26.746 DTC Client socket (4) | Closed. | 2022-08-05 22:17:26.746 SC DTC Data with Market Depth | Waiting for socket receive thread to end | 2022-08-05 22:17:26.746 DTC Client socket (0) | CloseSocket call. | 2022-08-05 22:17:26.746 SC DTC Data with Market Depth | Disconnected from the server. | 2022-08-05 22:17:26.746 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2022-08-05 22:17:26.746 SC DTC Data with Market Depth | Connecting to the server ds12.sierracharts.com. Port 443 | 2022-08-05 22:17:28.769 DTC Client socket (4) | Creating socket. | 2022-08-05 22:17:28.805 DTC Client socket (4) | New receive buffer size: 5242880 | 2022-08-05 22:17:28.805 DTC Client socket (4) | Connecting to IP: 204.15.197.14. | 2022-08-05 22:17:28.805 SC DTC Data with Market Depth | Network connection to server complete. | 2022-08-05 22:17:28.872 SC DTC Data with Market Depth | Starting socket receive thread. | 2022-08-05 22:17:28.872 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS. Compression: standard | 2022-08-05 22:17:28.872 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2022-08-05 22:17:28.939 SC DTC Data with Market Depth | Sending logon request message. | 2022-08-05 22:17:28.939 SC DTC Data with Market Depth | Received logon response. | 2022-08-05 22:17:29.628 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2022-08-05 22:17:29.628 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2022-08-05 22:17:29.628 SC DTC Data with Market Depth | Successfully connected. | 2022-08-05 22:17:29.628 SC DTC Data with Market Depth | Trading is not supported. | 2022-08-05 22:17:29.628 Added historical Intraday data request for EURUSD to the queue. | 2022-08-05 22:17:29.628 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2022-08-05 22:17:29.628 Triggering next historical data download in queue. | 2022-08-05 22:17:29.628 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EURUSD | 2022-08-05 22:17:29.628 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: SPX500 | 2022-08-05 22:17:29.628 Added historical Intraday data request for US30 to the queue. | 2022-08-05 22:17:29.628 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 22:17:29.628 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: US30 | 2022-08-05 22:17:29.628 Added historical Intraday data request for USOil to the queue. | 2022-08-05 22:17:29.629 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2022-08-05 22:17:29.629 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USOil | 2022-08-05 22:17:29.629 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 22:17:29.629 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 22:17:29.629 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XAUUSD | 2022-08-05 22:17:29.629 HD Request # 44 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2022-08-05 22:17:29.629 HD Request # 44 | Download start date-time: 2022-08-05 20:58:55.000000. File last date-time: 2022-08-05 20:58:55.000000 | 2022-08-05 22:17:29.634 HD Request # 44 | Using server: ds13-3.sierracharts.com port 10150 | 2022-08-05 22:17:29.634 Socket (5) | Creating socket. | 2022-08-05 22:17:29.672 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 22:17:29.672 Socket (5) | Connecting to IP: 162.251.232.235. | 2022-08-05 22:17:29.672 SC DTC Data with Market Depth | Received security definition for symbol EURUSD | 2022-08-05 22:17:29.788 SC DTC Data with Market Depth | Received security definition for symbol SPX500 | 2022-08-05 22:17:29.788 SC DTC Data with Market Depth | Received security definition for symbol US30 | 2022-08-05 22:17:29.788 SC DTC Data with Market Depth | Received security definition for symbol USOil | 2022-08-05 22:17:29.788 SC DTC Data with Market Depth | Received security definition for symbol XAUUSD | 2022-08-05 22:17:29.788 HD Request # 44 | Setting DTC encoding to Binary VLS | 2022-08-05 22:17:29.802 HD Request # 44 | Sending historical data logon request message. | 2022-08-05 22:17:29.802 HD Request # 44 | Requesting Intraday data. Start date-time: 2022-08-05 20:58:55. Record interval: 1. Symbol: EURUSD | 2022-08-05 22:17:30.502 HD Request # 44 | Decompressing data. | 2022-08-05 22:17:30.566 HD Request # 44 | Receiving Intraday data for EURUSD starting at 2022-08-05 20:58:55.856000 | 2022-08-05 22:17:30.566 Socket (5) | CloseSocket call. | 2022-08-05 22:17:30.567 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:17:30.567 Historical data download thread signaled to stop. | 2022-08-05 22:17:30.567 HD Request # 44 | Timestamp of first Intraday data file record written: 2022-08-05 20:58:55.856000. | 2022-08-05 22:17:30.567 HD Request # 44 | Received 19 Intraday data records from 2022-08-05 20:58:55.856000 to 2022-08-05 20:59:57.353000 (61.5 seconds) and wrote 19 records for EURUSD | 2022-08-05 22:17:30.567 HD Request # 44 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:59:57.353000 | 2022-08-05 22:17:30.571 HD Request # 44 | Completion time: 1s. | 2022-08-05 22:17:30.571 HD Request # 44 | Intraday data download complete for EURUSD. Unique request ID: 44 | 2022-08-05 22:17:30.571 Removing historical data download ID 44. | 2022-08-05 22:17:30.571 Real-time Intraday chart data file updates started for EURUSD | 2022-08-05 22:17:30.571 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 15072 | 2022-08-05 22:17:30.571 Intraday chart data file opened for EURUSD | 2022-08-05 22:17:30.571 HD Request # 44 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:17:30.571 Triggering next historical data download in queue. | 2022-08-05 22:17:30.571 HD Request # 45 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 22:17:30.571 HD Request # 45 | Download start date-time: 2022-08-05 20:44:59.000000. File last date-time: 2022-08-05 20:44:59.000000 | 2022-08-05 22:17:30.572 HD Request # 45 | Using server: ds4.sierracharts.com port 10149 | 2022-08-05 22:17:30.572 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 22:17:30.629 Socket (5) | Closed. | 2022-08-05 22:17:30.629 Socket (6) | Creating socket. | 2022-08-05 22:17:30.647 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 22:17:30.647 Socket (6) | Connecting to IP: 192.81.56.146. | 2022-08-05 22:17:30.647 HD Request # 45 | Setting DTC encoding to Binary VLS | 2022-08-05 22:17:30.772 HD Request # 45 | Sending historical data logon request message. | 2022-08-05 22:17:30.772 HD Request # 45 | Requesting Intraday data. Start date-time: 2022-08-05 20:44:59. Record interval: 1. Symbol: US30 | 2022-08-05 22:17:31.355 HD Request # 45 | Decompressing data. | 2022-08-05 22:17:31.439 HD Request # 45 | Receiving Intraday data for US30 starting at 2022-08-05 20:44:59.419000 | 2022-08-05 22:17:31.439 Socket (6) | CloseSocket call. | 2022-08-05 22:17:31.440 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:17:31.440 Historical data download thread signaled to stop. | 2022-08-05 22:17:31.440 HD Request # 45 | Timestamp of first Intraday data file record written: 2022-08-05 20:44:59.419000. | 2022-08-05 22:17:31.440 HD Request # 45 | Received 1 Intraday data record from 2022-08-05 20:44:59.419000 to 2022-08-05 20:44:59.419000 (0.0 seconds) and wrote 1 record for US30 | 2022-08-05 22:17:31.440 HD Request # 45 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:44:59.419000 | 2022-08-05 22:17:31.444 HD Request # 45 | Completion time: 1s. | 2022-08-05 22:17:31.444 HD Request # 45 | Intraday data download complete for US30. Unique request ID: 45 | 2022-08-05 22:17:31.444 Removing historical data download ID 45. | 2022-08-05 22:17:31.444 Real-time Intraday chart data file updates started for US30 | 2022-08-05 22:17:31.444 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 22:17:31.444 Intraday chart data file opened for US30 | 2022-08-05 22:17:31.444 HD Request # 45 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:17:31.444 Triggering next historical data download in queue. | 2022-08-05 22:17:31.444 HD Request # 46 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2022-08-05 22:17:31.444 HD Request # 46 | Download start date-time: 2022-08-05 20:44:59.000000. File last date-time: 2022-08-05 20:44:59.000000 | 2022-08-05 22:17:31.444 HD Request # 46 | Using server: ds12.sierracharts.com port 10150 | 2022-08-05 22:17:31.444 Socket (5) | Creating socket. | 2022-08-05 22:17:31.444 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 22:17:31.444 Socket (5) | Connecting to IP: 204.15.197.14. | 2022-08-05 22:17:31.444 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 22:17:31.504 Socket (6) | Closed. | 2022-08-05 22:17:31.504 HD Request # 46 | Setting DTC encoding to Binary VLS | 2022-08-05 22:17:31.598 HD Request # 46 | Sending historical data logon request message. | 2022-08-05 22:17:31.598 HD Request # 46 | Requesting Intraday data. Start date-time: 2022-08-05 20:44:59. Record interval: 1. Symbol: USOil | 2022-08-05 22:17:32.186 HD Request # 46 | Decompressing data. | 2022-08-05 22:17:32.248 HD Request # 46 | Receiving Intraday data for USOil starting at 2022-08-05 20:44:59.089000 | 2022-08-05 22:17:32.248 Socket (5) | CloseSocket call. | 2022-08-05 22:17:32.248 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:17:32.248 Historical data download thread signaled to stop. | 2022-08-05 22:17:32.248 HD Request # 46 | Timestamp of first Intraday data file record written: 2022-08-05 20:44:59.089000. | 2022-08-05 22:17:32.248 HD Request # 46 | Received 1 Intraday data record from 2022-08-05 20:44:59.089000 to 2022-08-05 20:44:59.089000 (0.0 seconds) and wrote 1 record for USOil | 2022-08-05 22:17:32.248 HD Request # 46 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:44:59.089000 | 2022-08-05 22:17:32.253 HD Request # 46 | Completion time: 1s. | 2022-08-05 22:17:32.253 HD Request # 46 | Intraday data download complete for USOil. Unique request ID: 46 | 2022-08-05 22:17:32.253 Removing historical data download ID 46. | 2022-08-05 22:17:32.253 Real-time Intraday chart data file updates started for USOil | 2022-08-05 22:17:32.253 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 15072 | 2022-08-05 22:17:32.253 Intraday chart data file opened for USOil | 2022-08-05 22:17:32.253 HD Request # 46 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:17:32.253 Triggering next historical data download in queue. | 2022-08-05 22:17:32.253 HD Request # 47 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 22:17:32.253 HD Request # 47 | Download start date-time: 2022-08-05 20:58:49.000000. File last date-time: 2022-08-05 20:58:49.000000 | 2022-08-05 22:17:32.253 HD Request # 47 | Using server: ds13-3.sierracharts.com port 10149 | 2022-08-05 22:17:32.253 Socket (6) | Creating socket. | 2022-08-05 22:17:32.253 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 22:17:32.253 Socket (6) | Connecting to IP: 162.251.232.235. | 2022-08-05 22:17:32.253 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 22:17:32.318 Socket (5) | Closed. | 2022-08-05 22:17:32.318 HD Request # 47 | Setting DTC encoding to Binary VLS | 2022-08-05 22:17:32.392 HD Request # 47 | Sending historical data logon request message. | 2022-08-05 22:17:32.392 HD Request # 47 | Requesting Intraday data. Start date-time: 2022-08-05 20:58:49. Record interval: 1. Symbol: XAUUSD | 2022-08-05 22:17:33.132 HD Request # 47 | Decompressing data. | 2022-08-05 22:17:33.196 HD Request # 47 | Receiving Intraday data for XAUUSD starting at 2022-08-05 20:58:49.436000 | 2022-08-05 22:17:33.197 Socket (6) | CloseSocket call. | 2022-08-05 22:17:33.197 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:17:33.197 Historical data download thread signaled to stop. | 2022-08-05 22:17:33.197 HD Request # 47 | Timestamp of first Intraday data file record written: 2022-08-05 20:58:49.436000. | 2022-08-05 22:17:33.197 HD Request # 47 | Received 21 Intraday data records from 2022-08-05 20:58:49.436000 to 2022-08-05 20:59:58.038000 (68.6 seconds) and wrote 21 records for XAUUSD | 2022-08-05 22:17:33.197 HD Request # 47 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:59:58.038000 | 2022-08-05 22:17:33.201 HD Request # 47 | Completion time: 1s. | 2022-08-05 22:17:33.201 HD Request # 47 | Intraday data download complete for XAUUSD. Unique request ID: 47 | 2022-08-05 22:17:33.201 Removing historical data download ID 47. | 2022-08-05 22:17:33.201 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-05 22:17:33.201 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 15072 | 2022-08-05 22:17:33.202 Intraday chart data file opened for XAUUSD | 2022-08-05 22:17:33.202 HD Request # 47 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:17:33.202 Triggering next historical data download in queue. | 2022-08-05 22:17:33.202 No download requests in the queue to start downloads for. | 2022-08-05 22:17:33.202 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 22:17:33.256 Socket (6) | Closed. | 2022-08-05 22:17:33.256 Teton CME Order Routing | Market data feed reported to be restored. | 2022-08-05 22:33:55.452 Added historical Intraday data request for XAUUSD to the queue. | 2022-08-05 22:33:55.452 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2022-08-05 22:33:55.452 Triggering next historical data download in queue. | 2022-08-05 22:33:55.452 Added historical Intraday data request for TSLA to the queue. | 2022-08-05 22:33:55.452 Intraday data recording state for symbol TSLA is set to download 'Pending'. | 2022-08-05 22:33:55.452 Added historical Intraday data request for US30 to the queue. | 2022-08-05 22:33:55.452 Intraday data recording state for symbol US30 is set to download 'Pending'. | 2022-08-05 22:33:55.452 Added historical Intraday data request for SPY to the queue. | 2022-08-05 22:33:55.452 Intraday data recording state for symbol SPY is set to download 'Pending'. | 2022-08-05 22:33:55.452 No historical data client is currently set to download historical Intraday data for ESU22-CME. | 2022-08-05 22:33:55.452 Real-time Intraday chart data file updates started for ESU22-CME | 2022-08-05 22:33:55.452 Opened cached Intraday file: C:\SierraChart\Data\ESU22-CME.scid. Thread ID: 15072 | 2022-08-05 22:33:55.452 Intraday chart data file opened for ESU22-CME | 2022-08-05 22:33:55.452 Added historical Intraday data request for USOil to the queue. | 2022-08-05 22:33:55.453 Intraday data recording state for symbol USOil is set to download 'Pending'. | 2022-08-05 22:33:55.453 Added historical Intraday data request for EURUSD to the queue. | 2022-08-05 22:33:55.453 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2022-08-05 22:33:55.453 Added historical Intraday data request for MESU22_FUT_CME to the queue. | 2022-08-05 22:33:55.453 Intraday data recording state for symbol MESU22_FUT_CME is set to download 'Pending'. | 2022-08-05 22:33:55.453 HD Request # 48 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm | 2022-08-05 22:33:55.453 HD Request # 48 | Download start date-time: 2022-08-05 20:59:58.000000. File last date-time: 2022-08-05 20:59:58.038000 | 2022-08-05 22:33:55.453 HD Request # 48 | Using server: ds4.sierracharts.com port 10150 | 2022-08-05 22:33:55.453 Socket (5) | Creating socket. | 2022-08-05 22:33:55.453 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 22:33:55.453 Socket (5) | Connecting to IP: 192.81.56.146. | 2022-08-05 22:33:55.453 HD Request # 48 | Setting DTC encoding to Binary VLS | 2022-08-05 22:33:55.579 HD Request # 48 | Sending historical data logon request message. | 2022-08-05 22:33:55.579 HD Request # 48 | Requesting Intraday data. Start date-time: 2022-08-05 20:59:58. Record interval: 1. Symbol: XAUUSD | 2022-08-05 22:33:56.157 HD Request # 48 | Decompressing data. | 2022-08-05 22:33:56.222 HD Request # 48 | Receiving Intraday data for XAUUSD starting at 2022-08-05 19:58:49.279000 | 2022-08-05 22:33:56.286 Socket (5) | CloseSocket call. | 2022-08-05 22:33:56.286 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:33:56.286 Historical data download thread signaled to stop. | 2022-08-05 22:33:56.287 HD Request # 48 | Received 958 Intraday data records from 2022-08-05 19:58:49.279000 to 2022-08-05 20:58:49.273000 (60.0 minutes) and wrote 0 records for XAUUSD | 2022-08-05 22:33:56.287 HD Request # 48 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:59:58.038000 | 2022-08-05 22:33:56.287 HD Request # 48 | Completion time: 1s. | 2022-08-05 22:33:56.287 HD Request # 48 | Intraday data download complete for XAUUSD. Unique request ID: 48 | 2022-08-05 22:33:56.287 Removing historical data download ID 48. | 2022-08-05 22:33:56.287 Real-time Intraday chart data file updates started for XAUUSD | 2022-08-05 22:33:56.287 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 15072 | 2022-08-05 22:33:56.287 Intraday chart data file opened for XAUUSD | 2022-08-05 22:33:56.287 HD Request # 48 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:33:56.287 Triggering next historical data download in queue. | 2022-08-05 22:33:56.287 HD Request # 49 | Downloading Intraday chart data for TSLA to the file TSLA.scid. Service: equities.us | 2022-08-05 22:33:56.287 HD Request # 49 | Download start date-time: 2022-08-05 14:04:51.000000. File last date-time: 2022-08-05 14:04:51.222000 | 2022-08-05 22:33:56.287 HD Request # 49 | Using server: exchangehistdata2.sierracharts.com port 10149 | 2022-08-05 22:33:56.287 Socket (6) | Creating socket. | 2022-08-05 22:33:56.288 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 22:33:56.288 Socket (6) | Connecting to IP: 8.18.161.133. | 2022-08-05 22:33:56.288 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 22:33:56.351 Socket (5) | Closed. | 2022-08-05 22:33:56.351 HD Request # 49 | Setting DTC encoding to Binary VLS | 2022-08-05 22:33:56.404 HD Request # 49 | Sending historical data logon request message. | 2022-08-05 22:33:56.404 HD Request # 49 | Requesting Intraday data. Start date-time: 2022-08-05 14:04:51. Record interval: 1. Symbol: TSLA | 2022-08-05 22:33:56.924 HD Request # 49 | Decompressing data. | 2022-08-05 22:33:56.999 HD Request # 49 | Receiving Intraday data for TSLA starting at 2022-08-05 14:04:51.222000 | 2022-08-05 22:33:57.355 Socket (6) | CloseSocket call. | 2022-08-05 22:33:57.478 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:33:57.478 Historical data download thread signaled to stop. | 2022-08-05 22:33:57.478 HD Request # 49 | Timestamp of first Intraday data file record written: 2022-08-05 14:04:51.222000. | 2022-08-05 22:33:57.478 HD Request # 49 | Received 18475 Intraday data records from 2022-08-05 14:04:51.222000 to 2022-08-05 22:17:04.349000 (8.2 hours) and wrote 18475 records for TSLA | 2022-08-05 22:33:57.478 HD Request # 49 | Add time&sales data | Remembered last file record date-time: 2022-08-05 22:17:04.349000 | 2022-08-05 22:33:57.484 HD Request # 49 | Completion time: 1s. | 2022-08-05 22:33:57.484 HD Request # 49 | Intraday data download complete for TSLA. Unique request ID: 49 | 2022-08-05 22:33:57.484 Removing historical data download ID 49. | 2022-08-05 22:33:57.484 Real-time Intraday chart data file updates started for TSLA | 2022-08-05 22:33:57.484 Opened cached Intraday file: C:\SierraChart\Data\TSLA.scid. Thread ID: 15072 | 2022-08-05 22:33:57.484 Intraday chart data file opened for TSLA | 2022-08-05 22:33:57.484 HD Request # 49 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:33:57.484 Triggering next historical data download in queue. | 2022-08-05 22:33:57.484 HD Request # 50 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm | 2022-08-05 22:33:57.484 HD Request # 50 | Download start date-time: 2022-08-05 20:44:59.000000. File last date-time: 2022-08-05 20:44:59.419000 | 2022-08-05 22:33:57.484 HD Request # 50 | Using server: ds12.sierracharts.com port 10150 | 2022-08-05 22:33:57.484 Socket (5) | Creating socket. | 2022-08-05 22:33:57.485 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 22:33:57.485 Socket (5) | Connecting to IP: 204.15.197.14. | 2022-08-05 22:33:57.485 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 22:33:57.530 Socket (6) | Closed. | 2022-08-05 22:33:57.531 HD Request # 50 | Setting DTC encoding to Binary VLS | 2022-08-05 22:33:57.650 HD Request # 50 | Sending historical data logon request message. | 2022-08-05 22:33:57.650 HD Request # 50 | Requesting Intraday data. Start date-time: 2022-08-05 20:44:59. Record interval: 1. Symbol: US30 | 2022-08-05 22:33:58.234 HD Request # 50 | Decompressing data. | 2022-08-05 22:33:58.294 HD Request # 50 | Receiving Intraday data for US30 starting at 2022-08-05 20:44:59.419000 | 2022-08-05 22:33:58.294 Socket (5) | CloseSocket call. | 2022-08-05 22:33:58.294 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:33:58.294 Historical data download thread signaled to stop. | 2022-08-05 22:33:58.294 HD Request # 50 | Timestamp of first Intraday data file record written: 2022-08-05 20:44:59.419000. | 2022-08-05 22:33:58.295 HD Request # 50 | Received 1 Intraday data record from 2022-08-05 20:44:59.419000 to 2022-08-05 20:44:59.419000 (0.0 seconds) and wrote 1 record for US30 | 2022-08-05 22:33:58.295 HD Request # 50 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:44:59.419000 | 2022-08-05 22:33:58.298 HD Request # 50 | Completion time: 1s. | 2022-08-05 22:33:58.298 HD Request # 50 | Intraday data download complete for US30. Unique request ID: 50 | 2022-08-05 22:33:58.298 Removing historical data download ID 50. | 2022-08-05 22:33:58.298 Real-time Intraday chart data file updates started for US30 | 2022-08-05 22:33:58.298 Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 15072 | 2022-08-05 22:33:58.299 Intraday chart data file opened for US30 | 2022-08-05 22:33:58.299 HD Request # 50 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:33:58.299 Triggering next historical data download in queue. | 2022-08-05 22:33:58.299 HD Request # 51 | Downloading Intraday chart data for SPY to the file SPY.scid. Service: equities.us | 2022-08-05 22:33:58.299 HD Request # 51 | Download start date-time: 2022-08-05 14:04:54.000000. File last date-time: 2022-08-05 14:04:54.210000 | 2022-08-05 22:33:58.299 HD Request # 51 | Using server: exchangehistdata1.sierracharts.com port 10149 | 2022-08-05 22:33:58.299 Socket (6) | Creating socket. | 2022-08-05 22:33:58.299 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 22:33:58.299 Socket (6) | Connecting to IP: 8.18.161.135. | 2022-08-05 22:33:58.299 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 22:33:58.362 Socket (5) | Closed. | 2022-08-05 22:33:58.362 HD Request # 51 | Setting DTC encoding to Binary VLS | 2022-08-05 22:33:58.418 HD Request # 51 | Sending historical data logon request message. | 2022-08-05 22:33:58.418 HD Request # 51 | Requesting Intraday data. Start date-time: 2022-08-05 14:04:54. Record interval: 1. Symbol: SPY | 2022-08-05 22:33:58.927 HD Request # 51 | Decompressing data. | 2022-08-05 22:33:58.994 HD Request # 51 | Receiving Intraday data for SPY starting at 2022-08-05 14:04:54.210000 | 2022-08-05 22:33:59.382 Socket (6) | CloseSocket call. | 2022-08-05 22:33:59.615 Historical data download thread signaled to stop. | 2022-08-05 22:33:59.615 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:33:59.615 HD Request # 51 | Timestamp of first Intraday data file record written: 2022-08-05 14:04:54.210000. | 2022-08-05 22:33:59.616 HD Request # 51 | Received 19757 Intraday data records from 2022-08-05 14:04:54.210000 to 2022-08-05 22:16:52.063000 (8.2 hours) and wrote 19757 records for SPY | 2022-08-05 22:33:59.616 HD Request # 51 | Add time&sales data | Remembered last file record date-time: 2022-08-05 22:16:52.063000 | 2022-08-05 22:33:59.620 HD Request # 51 | Completion time: 1s. | 2022-08-05 22:33:59.620 HD Request # 51 | Intraday data download complete for SPY. Unique request ID: 51 | 2022-08-05 22:33:59.620 Removing historical data download ID 51. | 2022-08-05 22:33:59.620 Real-time Intraday chart data file updates started for SPY | 2022-08-05 22:33:59.620 Opened cached Intraday file: C:\SierraChart\Data\SPY.scid. Thread ID: 15072 | 2022-08-05 22:33:59.620 Intraday chart data file opened for SPY | 2022-08-05 22:33:59.620 HD Request # 51 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:33:59.620 Triggering next historical data download in queue. | 2022-08-05 22:33:59.620 HD Request # 52 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm | 2022-08-05 22:33:59.620 HD Request # 52 | Download start date-time: 2022-08-05 20:44:59.000000. File last date-time: 2022-08-05 20:44:59.089000 | 2022-08-05 22:33:59.620 HD Request # 52 | Using server: ds13-3.sierracharts.com port 10150 | 2022-08-05 22:33:59.620 Socket (5) | Creating socket. | 2022-08-05 22:33:59.621 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 22:33:59.621 Socket (5) | Connecting to IP: 162.251.232.235. | 2022-08-05 22:33:59.621 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 22:33:59.671 Socket (6) | Closed. | 2022-08-05 22:33:59.671 HD Request # 52 | Setting DTC encoding to Binary VLS | 2022-08-05 22:33:59.768 HD Request # 52 | Sending historical data logon request message. | 2022-08-05 22:33:59.768 HD Request # 52 | Requesting Intraday data. Start date-time: 2022-08-05 20:44:59. Record interval: 1. Symbol: USOil | 2022-08-05 22:34:00.480 HD Request # 52 | Decompressing data. | 2022-08-05 22:34:00.547 HD Request # 52 | Receiving Intraday data for USOil starting at 2022-08-05 20:44:59.132000 | 2022-08-05 22:34:00.547 Socket (5) | CloseSocket call. | 2022-08-05 22:34:00.548 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:34:00.548 Historical data download thread signaled to stop. | 2022-08-05 22:34:00.548 HD Request # 52 | Timestamp of first Intraday data file record written: 2022-08-05 20:44:59.132000. | 2022-08-05 22:34:00.548 HD Request # 52 | Received 182 Intraday data records from 2022-08-05 20:44:59.132000 to 2022-08-05 20:59:59.043000 (15.0 minutes) and wrote 182 records for USOil | 2022-08-05 22:34:00.548 HD Request # 52 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:59:59.043000 | 2022-08-05 22:34:00.552 HD Request # 52 | Completion time: 1s. | 2022-08-05 22:34:00.552 HD Request # 52 | Intraday data download complete for USOil. Unique request ID: 52 | 2022-08-05 22:34:00.552 Removing historical data download ID 52. | 2022-08-05 22:34:00.552 Real-time Intraday chart data file updates started for USOil | 2022-08-05 22:34:00.552 Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 15072 | 2022-08-05 22:34:00.553 Intraday chart data file opened for USOil | 2022-08-05 22:34:00.553 HD Request # 52 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:34:00.553 Triggering next historical data download in queue. | 2022-08-05 22:34:00.553 HD Request # 53 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm | 2022-08-05 22:34:00.553 HD Request # 53 | Download start date-time: 2022-08-05 20:59:57.000000. File last date-time: 2022-08-05 20:59:57.353000 | 2022-08-05 22:34:00.553 HD Request # 53 | Using server: ds4.sierracharts.com port 10149 | 2022-08-05 22:34:00.553 Socket (6) | Creating socket. | 2022-08-05 22:34:00.553 Socket (6) | New receive buffer size: 5242880 | 2022-08-05 22:34:00.553 Socket (6) | Connecting to IP: 192.81.56.146. | 2022-08-05 22:34:00.553 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 22:34:00.618 Socket (5) | Closed. | 2022-08-05 22:34:00.618 HD Request # 53 | Setting DTC encoding to Binary VLS | 2022-08-05 22:34:00.684 HD Request # 53 | Sending historical data logon request message. | 2022-08-05 22:34:00.684 HD Request # 53 | Requesting Intraday data. Start date-time: 2022-08-05 20:59:57. Record interval: 1. Symbol: EURUSD | 2022-08-05 22:34:01.262 HD Request # 53 | Decompressing data. | 2022-08-05 22:34:01.323 HD Request # 53 | Receiving Intraday data for EURUSD starting at 2022-08-05 19:58:58.293000 | 2022-08-05 22:34:01.388 Socket (6) | CloseSocket call. | 2022-08-05 22:34:01.389 Socket (6) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:34:01.389 Historical data download thread signaled to stop. | 2022-08-05 22:34:01.389 HD Request # 53 | Received 1295 Intraday data records from 2022-08-05 19:58:58.293000 to 2022-08-05 20:58:55.746000 (60.0 minutes) and wrote 0 records for EURUSD | 2022-08-05 22:34:01.389 HD Request # 53 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:59:57.353000 | 2022-08-05 22:34:01.390 HD Request # 53 | Completion time: 1s. | 2022-08-05 22:34:01.390 HD Request # 53 | Intraday data download complete for EURUSD. Unique request ID: 53 | 2022-08-05 22:34:01.390 Removing historical data download ID 53. | 2022-08-05 22:34:01.390 Real-time Intraday chart data file updates started for EURUSD | 2022-08-05 22:34:01.390 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 15072 | 2022-08-05 22:34:01.390 Intraday chart data file opened for EURUSD | 2022-08-05 22:34:01.390 HD Request # 53 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:34:01.390 Triggering next historical data download in queue. | 2022-08-05 22:34:01.390 HD Request # 54 | Downloading Intraday chart data for MESU22_FUT_CME to the file MESU22_FUT_CME.scid. Service: cme | 2022-08-05 22:34:01.390 HD Request # 54 | Download start date-time: 2022-08-05 20:59:59.000000. File last date-time: 2022-08-05 20:59:59.073000 | 2022-08-05 22:34:01.390 HD Request # 54 | Using server: ds23.sierracharts.com port 10150 | 2022-08-05 22:34:01.390 Socket (5) | Creating socket. | 2022-08-05 22:34:01.390 Socket (5) | New receive buffer size: 5242880 | 2022-08-05 22:34:01.390 Socket (5) | Connecting to IP: 216.1.90.130. | 2022-08-05 22:34:01.390 Socket (6) | Socket gracefully closed by remote side. | 2022-08-05 22:34:01.452 Socket (6) | Closed. | 2022-08-05 22:34:01.452 HD Request # 54 | Setting DTC encoding to Binary VLS | 2022-08-05 22:34:01.649 HD Request # 54 | Sending historical data logon request message. | 2022-08-05 22:34:01.649 HD Request # 54 | Requesting Intraday data. Start date-time: 2022-08-05 20:59:59. Record interval: 1. Symbol: MESU22 | 2022-08-05 22:34:10.883 HD Request # 54 | Decompressing data. | 2022-08-05 22:34:10.940 HD Request # 54 | Receiving Intraday data for MESU22_FUT_CME starting at 2022-08-05 20:59:59.073000 | 2022-08-05 22:34:10.940 Socket (5) | CloseSocket call. | 2022-08-05 22:34:10.940 Socket (5) | Shutdown started. Waiting for graceful close. | 2022-08-05 22:34:10.940 Historical data download thread signaled to stop. | 2022-08-05 22:34:10.940 HD Request # 54 | Timestamp of first Intraday data file record written: 2022-08-05 20:59:59.073000. | 2022-08-05 22:34:10.941 HD Request # 54 | Received 1 Intraday data record from 2022-08-05 20:59:59.073000 to 2022-08-05 20:59:59.073000 (0.0 seconds) and wrote 1 record for MESU22_FUT_CME | 2022-08-05 22:34:10.941 HD Request # 54 | Add time&sales data | Remembered last file record date-time: 2022-08-05 20:59:59.073000 | 2022-08-05 22:34:10.945 HD Request # 54 | Completion time: 9s. | 2022-08-05 22:34:10.945 HD Request # 54 | Intraday data download complete for MESU22_FUT_CME. Unique request ID: 54 | 2022-08-05 22:34:10.945 Removing historical data download ID 54. | 2022-08-05 22:34:10.945 Real-time Intraday chart data file updates started for MESU22_FUT_CME | 2022-08-05 22:34:10.945 Opened cached Intraday file: C:\SierraChart\Data\MESU22_FUT_CME.scid. Thread ID: 15072 | 2022-08-05 22:34:10.945 Intraday chart data file opened for MESU22_FUT_CME | 2022-08-05 22:34:10.945 HD Request # 54 | Enabling Intraday chart updating for symbol. | 2022-08-05 22:34:10.945 Triggering next historical data download in queue. | 2022-08-05 22:34:10.945 No download requests in the queue to start downloads for. | 2022-08-05 22:34:10.945 Socket (5) | Socket gracefully closed by remote side. | 2022-08-05 22:34:10.996 Socket (5) | Closed. | 2022-08-05 22:34:10.996 |
[2022-08-08 14:19:56] |
John - SC Support - Posts: 31113 |
We see a few of the following messages in your log: DTC Client socket (6) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine.
Refer to the information at the following link regarding this message: https://www.sierrachart.com/index.php?page=doc/helpdetails1.php#NetworkCommunicationOrServerProblem ---- You also still have your symbols incorrect. You need to change your charts for ESU22-CME to be the symbol ESU22_FUT_CME. And you need to change the symbols for TSLA and SPY to TSLA-NQTV and SPY-NQTV in order to get the data from the NASDAQ TotalView exchange. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
