Date/Time: Fri, 19 Apr 2024 13:16:08 +0000
Numbers Bars - Show Total Price Levels
View Count: 297
[2022-06-23 20:36:12] |
User964846 - Posts: 38 |
Hello SC, I'm trying to see how many price levels exist within each Number Bar. Some Bars might have 10 levels (ticks) from their highest point to the lowest. Is there an option in NB, that would allow me to display this total number? Thanks for your time and effort. |
[2022-06-23 21:17:47] |
John - SC Support - Posts: 30953 |
The easiest way to do this would be to use the Spreadsheet Formula since it gives access to the TICKSIZE variable. Therefore, your formula would be: =(H - L) / TICKSIZE To then put this above/below the Numbers Bars, use the Study Subgraph Above/Below Bar as Text. Refer to the following information: Spreadsheet Formula Study Subgraph Above/Below Bar as Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
