Date/Time: Thu, 25 Apr 2024 12:54:07 +0000
chart not working
View Count: 289
[2022-06-23 18:57:02] |
User411320 - Posts: 252 |
hello, I uploaded a chart book but I cant see chart, I see it's using ESH, anyway I can change that ? attached is pic |
Screenshot 2022-06-22 184926.png / V - Attached On 2022-06-23 18:56:39 UTC - Size: 11.03 KB - 80 views |
[2022-06-23 19:01:17] |
John - SC Support - Posts: 31098 |
Your symbols are not correct. Select Edit >> Translate Symbols to Current Service and see if that resolves it for you. Also, refer to the following: Changing the Symbol of a Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-06-23 19:04:31] |
that worked thank you
