Date/Time: Wed, 24 Apr 2024 01:24:12 +0000
[User Discussion] - indicator updating in real time
View Count: 302
[2022-05-25 10:10:36] |
User259724 - Posts: 43 |
Hello: Is there any way for an indicator to be set to NOT update in real time. For instance, a moving average moves up and down in real time as the bar forms. Is there a setting to have the moving average not update until the current bar closes? That is, the current bar does not have the moving average moving as the current bar forms. Thanks for any help received. |
[2022-05-25 13:01:21] |
Sawtooth - Posts: 3976 |
See this thread: Show study drawing on only current bar Date Time Of Last Edit: 2022-05-25 13:02:41
[2022-05-25 20:43:29] |
This is not supported but one thing you can do is Displace the study forward by one bar and keep the chart scrolled to the end and effectively just not see the last column of values for a study. Refer to: Chart Studies: Subgraphs Tab >> Displacement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
