Date/Time: Fri, 29 Mar 2024 14:34:15 +0000
"Auto" suggestion for "Volume At Price Threshold Alert V2" study
View Count: 307
[2022-05-21 08:11:56] |
BenjFlame - Posts: 302 |
Hi, there should be an additional setting so the volume threshold would be determined automatically instead of an annoying fixed amount. Example - Comparison: Bid volume - Mode: Auto - Threshold: 5% This would mark any bid level on visible bars in the highest 5% of all bid levels volume of visible bars. I tried a software that has this and it would be a very useful view in addition to the existing ones. Date Time Of Last Edit: 2022-05-21 08:54:45
[2022-05-21 09:47:39] |
You can modify this existing study to meet your requirements. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2022-05-21 18:58:57] |
Yes, I know, but I thought it would be good to have this part of the standard distribution.
