Date/Time: Thu, 25 Apr 2024 08:51:01 +0000
Technical Studies Reference Spreadsheet
View Count: 277
[2022-05-20 07:47:26] |
User787778 - Posts: 139 |
I have copied the spread sheet for the Moving Average Arnaud Legoux in the Sierra data folder. I can open the spread sheet, but there are no formulas in columns A - Z, all that is there is in column AA = Bar Numbering and in column AC the value of the study Arnaud Legoux. I have looked at the Support document that was started on 2019-04-27 but this was no help. |
[2022-05-20 09:24:26] |
The spreadsheet file will contain more than one sheet. Check the other sheets for the formulas. It may be on the second sheet.: Working with Spreadsheets: Activating and Viewing (Selecting) Sheets within a Spreadsheet Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-05-20 10:09:42
