Date/Time: Fri, 29 Mar 2024 10:55:50 +0000
Orders not being filled
View Count: 435
[2022-05-19 01:58:22] |
Gasoil - Posts: 18 |
Hi i set 2 Limit orders and they have not being filled i set the limit inside the box on the trade window they stood as pending orders but when price reach the limit order the order was not filled . I check my trade service log and nothing is mentioned about the pending orders |
Screenshot_1.png / V - Attached On 2022-05-19 01:57:22 UTC - Size: 150.61 KB - 94 views |
[2022-05-19 06:05:53] |
Those two buy orders with a quantity of 0, near the current price, are not going to fill because they are not open orders. They are pending child orders, Attached Orders.
[2022-05-20 02:36:09] |
So can you tell me what i'm doing wrong i followed your tutorial and also i watch videos. I though i have covered every aspect of the oco order. My order was a limit order TIF at the end of the day with one limit target and one stop that uses price offset. I also activate the attached orders on the main panel. in the target panel the order has the oco group the PO and qty 1 so i then placed the order
Attachment Deleted. Screenshot_4.png / V - Attached On 2022-05-20 02:34:39 UTC - Size: 12.18 KB - 93 views |
[2022-05-20 03:41:03] |
So what is the problem you are having with that particular order? We need to know the specific issue with that particular order. Also, instead of using a Price Offset, set the Offset Type to Ticks and use 20 ticks for both the target and the stop. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
