Date/Time: Thu, 25 Apr 2024 17:56:57 +0000
OHLC body thickness
View Count: 283
[2022-05-18 17:43:44] |
User566250 - Posts: 24 |
Hello, Is there a way to make the body of OHLC bars thicker? Currently, I am not seeing any settings for allowing to change the thickness of the OHLC vertical part (not the %width setting). Please see comparisons. Thank you |
Screenshot 2022-05-12 233450.jpg / V - Attached On 2022-05-18 17:42:09 UTC - Size: 34 KB - 88 views Screenshot 2022-05-12 233410.jpg / V - Attached On 2022-05-18 17:42:16 UTC - Size: 40.48 KB - 88 views |
[2022-05-18 18:15:37] |
John - SC Support - Posts: 31117 |
The width of the OHLC body is controlled through the Graphics Settings for Bar High-Low Down and Bar High-Low Up. Refer to the information starting at the following link: Graphics Settings: Bar High-Low Down For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
