Date/Time: Fri, 19 Apr 2024 19:49:22 +0000
EOD ICE Data
View Count: 345
[2022-05-17 15:44:06] |
User956379 - Posts: 22 |
hello, I need the data of the ICE. Delayed EOD data is enough for me. Unfortunately it is no longer possible to update them since 05.04. - what can I do?
[2022-05-17 16:20:16] |
John - SC Support - Posts: 30973 |
We no longer have the ICE data. You can check with IQ Feed and see if they have it available and then you could use a separate installation of Sierra Chart for that data. Refer to the information at the following link for information on IQ Feed: DTN IQ Feed Data Service And refer to the following for how to install another Sierra Chart: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
