Date/Time: Fri, 27 Jan 2023 14:00:42 +0000
FXCM/Sierra question
View Count: 928
[2014-04-29 16:29:14] |
User88901 - Posts: 33 |
Hi, what does the +1 pip mean? Does that mean I will get filled at the raw spreads but I will pay 1 pip for commission for a buy or 2 pips for a buy and sell? FXCM US. What is included: Raw active trader spreads +1 pip. Trade all available FXCM Forex pairs. |
[2014-04-29 16:50:55] |
The fill price will be based upon the raw active trader spreads +1 pip. And exactly what the value is of one pip is for a particular symbol, we are not completely sure.
[2014-06-13 13:50:59] |
DamienBoyle - Posts: 7 |
Does this mean there is no $3.50 per side commission, as is listed for a FXCM Active Trader account? Rather this is the reason for the +1pip on the spread?
[2014-06-13 16:26:23] |
We think this is correct but we are not completely sure. We have to check on this before you.
[2014-06-13 17:45:31] |
we have confirmed with FXCM there is no commission. Rather the adjusted spread.
